[PATCH v3 0/3] Re-Send Timer support for ARM Tegra
3.5 weeks have passed and I got no reviews. Since deadline of timer dm driver implementation is approaching I am re-sending partches.
- ARM: tegra: remap clock_osc_freq for all Tegra family Enum clock_osc_freq was designed to use only with T20. This patch remaps it to use additional frequencies, added in T30+ SoC while maintaining backwards compatibility with T20.
- drivers: timer: add timer driver for ARMv7 based Tegra devices Add timer support for T20/T30/T114 and T124 based devices. Driver is based on DM, has device tree support and can be used on SPL and early boot stage.
- ARM: tegra: include timer as default option Enable TIMER as default option for add Tegra devices and enable TEGRA_TIMER for TEGRA_ARMV7_COMMON. Additionally enable SPL_TIMER if build as SPL part and drop deprecated configs from common header.
P. S. I have no arm64 Tegra and according to comment in tegra-common.h Use the Tegra US timer on ARMv7, but the architected timer on ARMv8.
Svyatoslav Ryhel (3): ARM: tegra: remap clock_osc_freq for all Tegra family drivers: timer: add timer driver for ARMv7 based Tegra devices ARM: tegra: include timer as default option
arch/arm/Kconfig | 1 + arch/arm/include/asm/arch-tegra/clock.h | 9 +- arch/arm/mach-tegra/Kconfig | 2 + arch/arm/mach-tegra/clock.c | 17 +++- arch/arm/mach-tegra/cpu.c | 70 ++++++++++--- arch/arm/mach-tegra/tegra114/clock.c | 13 +-- arch/arm/mach-tegra/tegra124/clock.c | 13 +-- arch/arm/mach-tegra/tegra20/clock.c | 4 +- arch/arm/mach-tegra/tegra210/clock.c | 22 +---- arch/arm/mach-tegra/tegra30/clock.c | 10 +- drivers/timer/Kconfig | 8 ++ drivers/timer/Makefile | 1 + drivers/timer/tegra-timer.c | 124 ++++++++++++++++++++++++ drivers/usb/host/ehci-tegra.c | 46 +++++++-- include/configs/tegra-common.h | 6 -- 15 files changed, 267 insertions(+), 79 deletions(-) create mode 100644 drivers/timer/tegra-timer.c
Tested-by: Andreas Westman Dorcsak hedmoo@yahoo.com # ASUS TF600T T30 Tested-by: Jonas Schwöbel jonasschwoebel@yahoo.de # Surface RT T30 Tested-by: Robert Eckelmann longnoserob@gmail.com # ASUS TF101 T20 Tested-by: Svyatoslav Ryhel clamor95@gmail.com # LG P895 T30 Signed-off-by: Svyatoslav Ryhel clamor95@gmail.com --- arch/arm/include/asm/arch-tegra/clock.h | 9 ++-- arch/arm/mach-tegra/clock.c | 17 ++++-- arch/arm/mach-tegra/cpu.c | 70 ++++++++++++++++++++----- arch/arm/mach-tegra/tegra114/clock.c | 13 ++--- arch/arm/mach-tegra/tegra124/clock.c | 13 ++--- arch/arm/mach-tegra/tegra20/clock.c | 4 +- arch/arm/mach-tegra/tegra210/clock.c | 22 ++------ arch/arm/mach-tegra/tegra30/clock.c | 10 +--- drivers/usb/host/ehci-tegra.c | 46 ++++++++++++---- 9 files changed, 131 insertions(+), 73 deletions(-)
diff --git a/arch/arm/include/asm/arch-tegra/clock.h b/arch/arm/include/asm/arch-tegra/clock.h index 6586015fd2..1dd5d0742c 100644 --- a/arch/arm/include/asm/arch-tegra/clock.h +++ b/arch/arm/include/asm/arch-tegra/clock.h @@ -13,12 +13,13 @@ struct udevice; /* Set of oscillator frequencies supported in the internal API. */ enum clock_osc_freq { /* All in MHz, so 13_0 is 13.0MHz */ - CLOCK_OSC_FREQ_13_0, - CLOCK_OSC_FREQ_19_2, - CLOCK_OSC_FREQ_12_0, - CLOCK_OSC_FREQ_26_0, + CLOCK_OSC_FREQ_13_0 = 0, + CLOCK_OSC_FREQ_16_8, + CLOCK_OSC_FREQ_19_2 = 4, CLOCK_OSC_FREQ_38_4, + CLOCK_OSC_FREQ_12_0 = 8, CLOCK_OSC_FREQ_48_0, + CLOCK_OSC_FREQ_26_0 = 12,
CLOCK_OSC_FREQ_COUNT, }; diff --git a/arch/arm/mach-tegra/clock.c b/arch/arm/mach-tegra/clock.c index 77c8ad978e..11bffc1701 100644 --- a/arch/arm/mach-tegra/clock.c +++ b/arch/arm/mach-tegra/clock.c @@ -28,16 +28,23 @@ static unsigned pll_rate[CLOCK_ID_COUNT];
/* - * The oscillator frequency is fixed to one of four set values. Based on this + * The oscillator frequency is fixed to one of seven set values. Based on this * the other clocks are set up appropriately. */ static unsigned osc_freq[CLOCK_OSC_FREQ_COUNT] = { 13000000, + 16800000, + 0, + 0, 19200000, - 12000000, - 26000000, 38400000, + 0, + 0, + 12000000, 48000000, + 0, + 0, + 26000000, };
/* return 1 if a peripheral ID is in range */ @@ -766,6 +773,7 @@ void tegra30_set_up_pllp(void) */ switch (clock_get_osc_freq()) { case CLOCK_OSC_FREQ_12_0: /* OSC is 12Mhz */ + case CLOCK_OSC_FREQ_48_0: /* OSC is 48Mhz */ clock_set_rate(CLOCK_ID_PERIPH, 408, 12, 0, 8); clock_set_rate(CLOCK_ID_CGENERAL, 456, 12, 1, 8); break; @@ -776,10 +784,13 @@ void tegra30_set_up_pllp(void) break;
case CLOCK_OSC_FREQ_13_0: /* OSC is 13Mhz */ + case CLOCK_OSC_FREQ_16_8: /* OSC is 16.8Mhz */ clock_set_rate(CLOCK_ID_PERIPH, 408, 13, 0, 8); clock_set_rate(CLOCK_ID_CGENERAL, 600, 13, 0, 8); break; + case CLOCK_OSC_FREQ_19_2: + case CLOCK_OSC_FREQ_38_4: default: /* * These are not supported. It is too early to print a diff --git a/arch/arm/mach-tegra/cpu.c b/arch/arm/mach-tegra/cpu.c index 65b15b79fe..59ca8aeaba 100644 --- a/arch/arm/mach-tegra/cpu.c +++ b/arch/arm/mach-tegra/cpu.c @@ -55,11 +55,18 @@ struct clk_pll_table tegra_pll_x_table[TEGRA_SOC_CNT][CLOCK_OSC_FREQ_COUNT] = { */ { { .n = 1000, .m = 13, .p = 0, .cpcon = 12 }, /* OSC: 13.0 MHz */ + { .n = 0, .m = 0, .p = 0, .cpcon = 0 }, /* N/A */ + { .n = 0, .m = 0, .p = 0, .cpcon = 0 }, /* N/A */ + { .n = 0, .m = 0, .p = 0, .cpcon = 0 }, /* N/A */ { .n = 625, .m = 12, .p = 0, .cpcon = 8 }, /* OSC: 19.2 MHz */ + { .n = 0, .m = 0, .p = 0, .cpcon = 0 }, /* N/A */ + { .n = 0, .m = 0, .p = 0, .cpcon = 0 }, /* N/A */ + { .n = 0, .m = 0, .p = 0, .cpcon = 0 }, /* N/A */ { .n = 1000, .m = 12, .p = 0, .cpcon = 12 }, /* OSC: 12.0 MHz */ + { .n = 0, .m = 0, .p = 0, .cpcon = 0 }, /* N/A */ + { .n = 0, .m = 0, .p = 0, .cpcon = 0 }, /* N/A */ + { .n = 0, .m = 0, .p = 0, .cpcon = 0 }, /* N/A */ { .n = 1000, .m = 26, .p = 0, .cpcon = 12 }, /* OSC: 26.0 MHz */ - { .n = 0, .m = 0, .p = 0, .cpcon = 0 }, /* OSC: 38.4 MHz (N/A) */ - { .n = 0, .m = 0, .p = 0, .cpcon = 0 }, /* OSC: 48.0 MHz (N/A) */ }, /* * T25: 1.2 GHz @@ -73,11 +80,18 @@ struct clk_pll_table tegra_pll_x_table[TEGRA_SOC_CNT][CLOCK_OSC_FREQ_COUNT] = { */ { { .n = 923, .m = 10, .p = 0, .cpcon = 12 }, /* OSC: 13.0 MHz */ + { .n = 0, .m = 0, .p = 0, .cpcon = 0 }, /* N/A */ + { .n = 0, .m = 0, .p = 0, .cpcon = 0 }, /* N/A */ + { .n = 0, .m = 0, .p = 0, .cpcon = 0 }, /* N/A */ { .n = 750, .m = 12, .p = 0, .cpcon = 8 }, /* OSC: 19.2 MHz */ + { .n = 0, .m = 0, .p = 0, .cpcon = 0 }, /* N/A */ + { .n = 0, .m = 0, .p = 0, .cpcon = 0 }, /* N/A */ + { .n = 0, .m = 0, .p = 0, .cpcon = 0 }, /* N/A */ { .n = 600, .m = 6, .p = 0, .cpcon = 12 }, /* OSC: 12.0 MHz */ + { .n = 0, .m = 0, .p = 0, .cpcon = 0 }, /* N/A */ + { .n = 0, .m = 0, .p = 0, .cpcon = 0 }, /* N/A */ + { .n = 0, .m = 0, .p = 0, .cpcon = 0 }, /* N/A */ { .n = 600, .m = 13, .p = 0, .cpcon = 12 }, /* OSC: 26.0 MHz */ - { .n = 0, .m = 0, .p = 0, .cpcon = 0 }, /* OSC: 38.4 MHz (N/A) */ - { .n = 0, .m = 0, .p = 0, .cpcon = 0 }, /* OSC: 48.0 MHz (N/A) */ }, /* * T30: 600 MHz @@ -91,11 +105,18 @@ struct clk_pll_table tegra_pll_x_table[TEGRA_SOC_CNT][CLOCK_OSC_FREQ_COUNT] = { */ { { .n = 600, .m = 13, .p = 0, .cpcon = 8 }, /* OSC: 13.0 MHz */ + { .n = 600, .m = 13, .p = 0, .cpcon = 8 }, /* OSC: 16.8 MHz */ + { .n = 0, .m = 0, .p = 0, .cpcon = 0 }, /* N/A */ + { .n = 0, .m = 0, .p = 0, .cpcon = 0 }, /* N/A */ { .n = 500, .m = 16, .p = 0, .cpcon = 8 }, /* OSC: 19.2 MHz */ + { .n = 500, .m = 16, .p = 0, .cpcon = 8 }, /* OSC: 38.4 MHz */ + { .n = 0, .m = 0, .p = 0, .cpcon = 0 }, /* N/A */ + { .n = 0, .m = 0, .p = 0, .cpcon = 0 }, /* N/A */ { .n = 600, .m = 12, .p = 0, .cpcon = 8 }, /* OSC: 12.0 MHz */ + { .n = 600, .m = 12, .p = 0, .cpcon = 8 }, /* OSC: 48.0 MHz */ + { .n = 0, .m = 0, .p = 0, .cpcon = 0 }, /* N/A */ + { .n = 0, .m = 0, .p = 0, .cpcon = 0 }, /* N/A */ { .n = 600, .m = 26, .p = 0, .cpcon = 8 }, /* OSC: 26.0 MHz */ - { .n = 0, .m = 0, .p = 0, .cpcon = 0 }, /* OSC: 38.4 MHz (N/A) */ - { .n = 0, .m = 0, .p = 0, .cpcon = 0 }, /* OSC: 48.0 MHz (N/A) */ }, /* * T114: 700 MHz @@ -108,11 +129,18 @@ struct clk_pll_table tegra_pll_x_table[TEGRA_SOC_CNT][CLOCK_OSC_FREQ_COUNT] = { */ { { .n = 108, .m = 1, .p = 1 }, /* OSC: 13.0 MHz */ + { .n = 108, .m = 1, .p = 1 }, /* OSC: 16.8 MHz */ + { .n = 0, .m = 0, .p = 0 }, /* (N/A) */ + { .n = 0, .m = 0, .p = 0 }, /* (N/A) */ { .n = 73, .m = 1, .p = 1 }, /* OSC: 19.2 MHz */ + { .n = 73, .m = 1, .p = 1 }, /* OSC: 38.4 MHz */ + { .n = 0, .m = 0, .p = 0 }, /* (N/A) */ + { .n = 0, .m = 0, .p = 0 }, /* (N/A) */ { .n = 116, .m = 1, .p = 1 }, /* OSC: 12.0 MHz */ + { .n = 116, .m = 1, .p = 1 }, /* OSC: 48.0 MHz */ + { .n = 0, .m = 0, .p = 0 }, /* (N/A) */ + { .n = 0, .m = 0, .p = 0 }, /* (N/A) */ { .n = 108, .m = 2, .p = 1 }, /* OSC: 26.0 MHz */ - { .n = 0, .m = 0, .p = 0 }, /* OSC: 38.4 MHz (N/A) */ - { .n = 0, .m = 0, .p = 0 }, /* OSC: 48.0 MHz (N/A) */ },
/* @@ -126,11 +154,18 @@ struct clk_pll_table tegra_pll_x_table[TEGRA_SOC_CNT][CLOCK_OSC_FREQ_COUNT] = { */ { { .n = 108, .m = 1, .p = 1 }, /* OSC: 13.0 MHz */ + { .n = 108, .m = 1, .p = 1 }, /* OSC: 16.8 MHz */ + { .n = 0, .m = 0, .p = 0 }, /* (N/A) */ + { .n = 0, .m = 0, .p = 0 }, /* (N/A) */ { .n = 73, .m = 1, .p = 1 }, /* OSC: 19.2 MHz */ + { .n = 73, .m = 1, .p = 1 }, /* OSC: 38.4 MHz */ + { .n = 0, .m = 0, .p = 0 }, /* (N/A) */ + { .n = 0, .m = 0, .p = 0 }, /* (N/A) */ { .n = 116, .m = 1, .p = 1 }, /* OSC: 12.0 MHz */ + { .n = 116, .m = 1, .p = 1 }, /* OSC: 48.0 MHz */ + { .n = 0, .m = 0, .p = 0 }, /* (N/A) */ + { .n = 0, .m = 0, .p = 0 }, /* (N/A) */ { .n = 108, .m = 2, .p = 1 }, /* OSC: 26.0 MHz */ - { .n = 0, .m = 0, .p = 0 }, /* OSC: 38.4 MHz (N/A) */ - { .n = 0, .m = 0, .p = 0 }, /* OSC: 48.0 MHz (N/A) */ },
/* @@ -143,12 +178,19 @@ struct clk_pll_table tegra_pll_x_table[TEGRA_SOC_CNT][CLOCK_OSC_FREQ_COUNT] = { * PLLX_BASE m 7: 0 8 */ { - { .n = 108, .m = 1, .p = 1 }, /* OSC: 13.0 MHz = 702 MHz*/ - { .n = 73, .m = 1, .p = 1 }, /* OSC: 19.2 MHz = 700.8 MHz*/ - { .n = 116, .m = 1, .p = 1 }, /* OSC: 12.0 MHz = 696 MHz*/ - { .n = 108, .m = 2, .p = 1 }, /* OSC: 26.0 MHz = 702 MHz*/ + { .n = 108, .m = 1, .p = 1 }, /* OSC: 13.0 MHz = 702 MHz */ + { .n = 108, .m = 1, .p = 1 }, /* OSC: 16.0 MHz = 702 MHz */ + { .n = 0, .m = 0, .p = 0 }, /* (N/A) */ + { .n = 0, .m = 0, .p = 0 }, /* (N/A) */ + { .n = 73, .m = 1, .p = 1 }, /* OSC: 19.2 MHz = 700.8 MHz */ { .n = 36, .m = 1, .p = 1 }, /* OSC: 38.4 MHz = 691.2 MHz */ + { .n = 0, .m = 0, .p = 0 }, /* (N/A) */ + { .n = 0, .m = 0, .p = 0 }, /* (N/A) */ + { .n = 116, .m = 1, .p = 1 }, /* OSC: 12.0 MHz = 696 MHz */ { .n = 58, .m = 2, .p = 1 }, /* OSC: 48.0 MHz = 696 MHz */ + { .n = 0, .m = 0, .p = 0 }, /* (N/A) */ + { .n = 0, .m = 0, .p = 0 }, /* (N/A) */ + { .n = 108, .m = 2, .p = 1 }, /* OSC: 26.0 MHz = 702 MHz */ }, };
diff --git a/arch/arm/mach-tegra/tegra114/clock.c b/arch/arm/mach-tegra/tegra114/clock.c index 703a2314e7..143f86863f 100644 --- a/arch/arm/mach-tegra/tegra114/clock.c +++ b/arch/arm/mach-tegra/tegra114/clock.c @@ -459,8 +459,7 @@ struct clk_pll_info tegra_pll_info_table[CLOCK_ID_PLL_COUNT] = {
/* * Get the oscillator frequency, from the corresponding hardware configuration - * field. Note that T30/T114 support 3 new higher freqs, but we map back - * to the old T20 freqs. Support for the higher oscillators is TBD. + * field. Note that T30+ supports 3 new higher freqs. */ enum clock_osc_freq clock_get_osc_freq(void) { @@ -469,12 +468,7 @@ enum clock_osc_freq clock_get_osc_freq(void) u32 reg;
reg = readl(&clkrst->crc_osc_ctrl); - reg = (reg & OSC_FREQ_MASK) >> OSC_FREQ_SHIFT; - - if (reg & 1) /* one of the newer freqs */ - printf("Warning: OSC_FREQ is unsupported! (%d)\n", reg); - - return reg >> 2; /* Map to most common (T20) freqs */ + return (reg & OSC_FREQ_MASK) >> OSC_FREQ_SHIFT; }
/* Returns a pointer to the clock source register for a peripheral */ @@ -674,6 +668,7 @@ void clock_early_init(void) */ switch (clock_get_osc_freq()) { case CLOCK_OSC_FREQ_12_0: /* OSC is 12Mhz */ + case CLOCK_OSC_FREQ_48_0: /* OSC is 48Mhz */ clock_set_rate(CLOCK_ID_CGENERAL, 600, 12, 0, 8); clock_set_rate(CLOCK_ID_DISPLAY, 925, 12, 0, 12); break; @@ -684,10 +679,12 @@ void clock_early_init(void) break;
case CLOCK_OSC_FREQ_13_0: /* OSC is 13Mhz */ + case CLOCK_OSC_FREQ_16_8: /* OSC is 16.8Mhz */ clock_set_rate(CLOCK_ID_CGENERAL, 600, 13, 0, 8); clock_set_rate(CLOCK_ID_DISPLAY, 925, 13, 0, 12); break; case CLOCK_OSC_FREQ_19_2: + case CLOCK_OSC_FREQ_38_4: default: /* * These are not supported. It is too early to print a diff --git a/arch/arm/mach-tegra/tegra124/clock.c b/arch/arm/mach-tegra/tegra124/clock.c index bbfe184652..da38b26c27 100644 --- a/arch/arm/mach-tegra/tegra124/clock.c +++ b/arch/arm/mach-tegra/tegra124/clock.c @@ -601,8 +601,7 @@ struct clk_pll_info tegra_pll_info_table[CLOCK_ID_PLL_COUNT] = {
/* * Get the oscillator frequency, from the corresponding hardware configuration - * field. Note that Tegra30+ support 3 new higher freqs, but we map back - * to the old T20 freqs. Support for the higher oscillators is TBD. + * field. Note that T30+ supports 3 new higher freqs. */ enum clock_osc_freq clock_get_osc_freq(void) { @@ -611,12 +610,7 @@ enum clock_osc_freq clock_get_osc_freq(void) u32 reg;
/* Returns a pointer to the clock source register for a peripheral */ @@ -854,6 +848,7 @@ void clock_early_init(void) */ switch (clock_get_osc_freq()) { case CLOCK_OSC_FREQ_12_0: /* OSC is 12Mhz */ + case CLOCK_OSC_FREQ_48_0: /* OSC is 48Mhz */ clock_set_rate(CLOCK_ID_CGENERAL, 600, 12, 0, 8); clock_set_rate(CLOCK_ID_DISPLAY, 925, 12, 0, 12); break; @@ -864,10 +859,12 @@ void clock_early_init(void) break;
case CLOCK_OSC_FREQ_13_0: /* OSC is 13Mhz */ + case CLOCK_OSC_FREQ_16_8: /* OSC is 16.8Mhz */ clock_set_rate(CLOCK_ID_CGENERAL, 600, 13, 0, 8); clock_set_rate(CLOCK_ID_DISPLAY, 925, 13, 0, 12); break; case CLOCK_OSC_FREQ_19_2: + case CLOCK_OSC_FREQ_38_4: default: /* * These are not supported. It is too early to print a diff --git a/arch/arm/mach-tegra/tegra20/clock.c b/arch/arm/mach-tegra/tegra20/clock.c index 3b50a81194..8c127430aa 100644 --- a/arch/arm/mach-tegra/tegra20/clock.c +++ b/arch/arm/mach-tegra/tegra20/clock.c @@ -399,7 +399,9 @@ enum clock_osc_freq clock_get_osc_freq(void) u32 reg;
reg = readl(&clkrst->crc_osc_ctrl); - return (reg & OSC_FREQ_MASK) >> OSC_FREQ_SHIFT; + reg = (reg & OSC_FREQ_MASK) >> OSC_FREQ_SHIFT; + + return reg << 2; }
/* Returns a pointer to the clock source register for a peripheral */ diff --git a/arch/arm/mach-tegra/tegra210/clock.c b/arch/arm/mach-tegra/tegra210/clock.c index 10c2478df7..330753f2ad 100644 --- a/arch/arm/mach-tegra/tegra210/clock.c +++ b/arch/arm/mach-tegra/tegra210/clock.c @@ -672,8 +672,7 @@ struct clk_pll_info tegra_pll_info_table[CLOCK_ID_PLL_COUNT] = {
/* * Get the oscillator frequency, from the corresponding hardware configuration - * field. Note that Tegra30+ support 3 new higher freqs, but we map back - * to the old T20 freqs. Support for the higher oscillators is TBD. + * field. Note that T30+ supports 3 new higher freqs. */ enum clock_osc_freq clock_get_osc_freq(void) { @@ -682,22 +681,7 @@ enum clock_osc_freq clock_get_osc_freq(void) u32 reg;
reg = readl(&clkrst->crc_osc_ctrl); - reg = (reg & OSC_FREQ_MASK) >> OSC_FREQ_SHIFT; - /* - * 0 = 13MHz, 1 = 16.8MHz, 4 = 19.2MHz, 5 = 38.4MHz, - * 8 = 12MHz, 9 = 48MHz, 12 = 26MHz - */ - if (reg == 5) { - debug("OSC_FREQ is 38.4MHz (%d) ...\n", reg); - /* Map it to the 5th CLOCK_OSC_ enum, i.e. 4 */ - return 4; - } - - /* - * Map to most common (T20) freqs (except 38.4, handled above): - * 13/16.8 = 0, 19.2 = 1, 12/48 = 2, 26 = 3 - */ - return reg >> 2; + return (reg & OSC_FREQ_MASK) >> OSC_FREQ_SHIFT; }
/* Returns a pointer to the clock source register for a peripheral */ @@ -986,6 +970,7 @@ void clock_early_init(void) */ switch (clock_get_osc_freq()) { case CLOCK_OSC_FREQ_12_0: /* OSC is 12Mhz */ + case CLOCK_OSC_FREQ_48_0: /* OSC is 48Mhz */ clock_set_rate(CLOCK_ID_CGENERAL, 600, 12, 0, 8); clock_set_rate(CLOCK_ID_DISPLAY, 925, 12, 0, 12); break; @@ -996,6 +981,7 @@ void clock_early_init(void) break;
case CLOCK_OSC_FREQ_13_0: /* OSC is 13Mhz */ + case CLOCK_OSC_FREQ_16_8: /* OSC is 16.8Mhz */ clock_set_rate(CLOCK_ID_CGENERAL, 600, 13, 0, 8); clock_set_rate(CLOCK_ID_DISPLAY, 925, 13, 0, 12); break; diff --git a/arch/arm/mach-tegra/tegra30/clock.c b/arch/arm/mach-tegra/tegra30/clock.c index 54855d6be7..04ad5c504d 100644 --- a/arch/arm/mach-tegra/tegra30/clock.c +++ b/arch/arm/mach-tegra/tegra30/clock.c @@ -439,8 +439,7 @@ struct clk_pll_info tegra_pll_info_table[CLOCK_ID_PLL_COUNT] = {
/* * Get the oscillator frequency, from the corresponding hardware configuration - * field. Note that T30 supports 3 new higher freqs, but we map back - * to the old T20 freqs. Support for the higher oscillators is TBD. + * field. Note that T30+ supports 3 new higher freqs. */ enum clock_osc_freq clock_get_osc_freq(void) { @@ -449,12 +448,7 @@ enum clock_osc_freq clock_get_osc_freq(void) u32 reg;
/* Returns a pointer to the clock source register for a peripheral */ diff --git a/drivers/usb/host/ehci-tegra.c b/drivers/usb/host/ehci-tegra.c index b02ee89c3e..6fe8594d48 100644 --- a/drivers/usb/host/ehci-tegra.c +++ b/drivers/usb/host/ehci-tegra.c @@ -127,42 +127,70 @@ struct fdt_usb { static const unsigned T20_usb_pll[CLOCK_OSC_FREQ_COUNT][PARAM_COUNT] = { /* DivN, DivM, DivP, CPCON, LFCON, Delays Debounce, Bias */ { 0x3C0, 0x0D, 0x00, 0xC, 0, 0x02, 0x33, 0x05, 0x7F, 0x7EF4, 5 }, + { 0x3C0, 0x0D, 0x00, 0xC, 0, 0x02, 0x33, 0x05, 0x7F, 0x7EF4, 5 }, + { 0x000, 0x00, 0x00, 0x0, 0, 0x00, 0x00, 0x00, 0x00, 0x0000, 0 }, + { 0x000, 0x00, 0x00, 0x0, 0, 0x00, 0x00, 0x00, 0x00, 0x0000, 0 }, + { 0x0C8, 0x04, 0x00, 0x3, 0, 0x03, 0x4B, 0x06, 0xBB, 0xBB80, 7 }, { 0x0C8, 0x04, 0x00, 0x3, 0, 0x03, 0x4B, 0x06, 0xBB, 0xBB80, 7 }, + { 0x000, 0x00, 0x00, 0x0, 0, 0x00, 0x00, 0x00, 0x00, 0x0000, 0 }, + { 0x000, 0x00, 0x00, 0x0, 0, 0x00, 0x00, 0x00, 0x00, 0x0000, 0 }, + { 0x3C0, 0x0C, 0x00, 0xC, 0, 0x02, 0x2F, 0x04, 0x76, 0x7530, 5 }, { 0x3C0, 0x0C, 0x00, 0xC, 0, 0x02, 0x2F, 0x04, 0x76, 0x7530, 5 }, - { 0x3C0, 0x1A, 0x00, 0xC, 0, 0x04, 0x66, 0x09, 0xFE, 0xFDE8, 9 }, { 0x000, 0x00, 0x00, 0x0, 0, 0x00, 0x00, 0x00, 0x00, 0x0000, 0 }, - { 0x000, 0x00, 0x00, 0x0, 0, 0x00, 0x00, 0x00, 0x00, 0x0000, 0 } + { 0x000, 0x00, 0x00, 0x0, 0, 0x00, 0x00, 0x00, 0x00, 0x0000, 0 }, + { 0x3C0, 0x1A, 0x00, 0xC, 0, 0x04, 0x66, 0x09, 0xFE, 0xFDE8, 9 } };
static const unsigned T30_usb_pll[CLOCK_OSC_FREQ_COUNT][PARAM_COUNT] = { /* DivN, DivM, DivP, CPCON, LFCON, Delays Debounce, Bias */ { 0x3C0, 0x0D, 0x00, 0xC, 1, 0x02, 0x33, 0x09, 0x7F, 0x7EF4, 5 }, + { 0x3C0, 0x0D, 0x00, 0xC, 1, 0x02, 0x33, 0x09, 0x7F, 0x7EF4, 5 }, + { 0x000, 0x00, 0x00, 0x0, 0, 0x00, 0x00, 0x00, 0x00, 0x0000, 0 }, + { 0x000, 0x00, 0x00, 0x0, 0, 0x00, 0x00, 0x00, 0x00, 0x0000, 0 }, { 0x0C8, 0x04, 0x00, 0x3, 0, 0x03, 0x4B, 0x0C, 0xBB, 0xBB80, 7 }, + { 0x0C8, 0x04, 0x00, 0x3, 0, 0x03, 0x4B, 0x0C, 0xBB, 0xBB80, 7 }, + { 0x000, 0x00, 0x00, 0x0, 0, 0x00, 0x00, 0x00, 0x00, 0x0000, 0 }, + { 0x000, 0x00, 0x00, 0x0, 0, 0x00, 0x00, 0x00, 0x00, 0x0000, 0 }, { 0x3C0, 0x0C, 0x00, 0xC, 1, 0x02, 0x2F, 0x08, 0x76, 0x7530, 5 }, - { 0x3C0, 0x1A, 0x00, 0xC, 1, 0x04, 0x66, 0x09, 0xFE, 0xFDE8, 9 }, + { 0x3C0, 0x0C, 0x00, 0xC, 1, 0x02, 0x2F, 0x08, 0x76, 0x7530, 5 }, + { 0x000, 0x00, 0x00, 0x0, 0, 0x00, 0x00, 0x00, 0x00, 0x0000, 0 }, { 0x000, 0x00, 0x00, 0x0, 0, 0x00, 0x00, 0x00, 0x00, 0x0000, 0 }, - { 0x000, 0x00, 0x00, 0x0, 0, 0x00, 0x00, 0x00, 0x00, 0x0000, 0 } + { 0x3C0, 0x1A, 0x00, 0xC, 1, 0x04, 0x66, 0x09, 0xFE, 0xFDE8, 9 } };
static const unsigned T114_usb_pll[CLOCK_OSC_FREQ_COUNT][PARAM_COUNT] = { /* DivN, DivM, DivP, CPCON, LFCON, Delays Debounce, Bias */ { 0x3C0, 0x0D, 0x00, 0xC, 2, 0x02, 0x33, 0x09, 0x7F, 0x7EF4, 6 }, + { 0x3C0, 0x0D, 0x00, 0xC, 2, 0x02, 0x33, 0x09, 0x7F, 0x7EF4, 6 }, + { 0x000, 0x00, 0x00, 0x0, 0, 0x00, 0x00, 0x00, 0x00, 0x0000, 0 }, + { 0x000, 0x00, 0x00, 0x0, 0, 0x00, 0x00, 0x00, 0x00, 0x0000, 0 }, + { 0x0C8, 0x04, 0x00, 0x3, 2, 0x03, 0x4B, 0x0C, 0xBB, 0xBB80, 8 }, { 0x0C8, 0x04, 0x00, 0x3, 2, 0x03, 0x4B, 0x0C, 0xBB, 0xBB80, 8 }, + { 0x000, 0x00, 0x00, 0x0, 0, 0x00, 0x00, 0x00, 0x00, 0x0000, 0 }, + { 0x000, 0x00, 0x00, 0x0, 0, 0x00, 0x00, 0x00, 0x00, 0x0000, 0 }, + { 0x3C0, 0x0C, 0x00, 0xC, 2, 0x02, 0x2F, 0x08, 0x76, 0x7530, 5 }, { 0x3C0, 0x0C, 0x00, 0xC, 2, 0x02, 0x2F, 0x08, 0x76, 0x7530, 5 }, - { 0x3C0, 0x1A, 0x00, 0xC, 2, 0x04, 0x66, 0x09, 0xFE, 0xFDE8, 11 }, { 0x000, 0x00, 0x00, 0x0, 0, 0x00, 0x00, 0x00, 0x00, 0x0000, 0 }, - { 0x000, 0x00, 0x00, 0x0, 0, 0x00, 0x00, 0x00, 0x00, 0x0000, 0 } + { 0x000, 0x00, 0x00, 0x0, 0, 0x00, 0x00, 0x00, 0x00, 0x0000, 0 }, + { 0x3C0, 0x1A, 0x00, 0xC, 2, 0x04, 0x66, 0x09, 0xFE, 0xFDE8, 11 } };
/* NOTE: 13/26MHz settings are N/A for T210, so dupe 12MHz settings for now */ static const unsigned T210_usb_pll[CLOCK_OSC_FREQ_COUNT][PARAM_COUNT] = { /* DivN, DivM, DivP, KCP, KVCO, Delays Debounce, Bias */ { 0x028, 0x01, 0x01, 0x0, 0, 0x02, 0x2F, 0x08, 0x76, 32500, 5 }, + { 0x028, 0x01, 0x01, 0x0, 0, 0x02, 0x2F, 0x08, 0x76, 32500, 5 }, + { 0x000, 0x00, 0x00, 0x0, 0, 0x00, 0x00, 0x00, 0x00, 0, 0 }, + { 0x000, 0x00, 0x00, 0x0, 0, 0x00, 0x00, 0x00, 0x00, 0, 0 }, { 0x019, 0x01, 0x01, 0x0, 0, 0x03, 0x4B, 0x0C, 0xBB, 48000, 8 }, - { 0x028, 0x01, 0x01, 0x0, 0, 0x02, 0x2F, 0x08, 0x76, 30000, 5 }, - { 0x028, 0x01, 0x01, 0x0, 0, 0x02, 0x2F, 0x08, 0x76, 65000, 5 }, { 0x019, 0x02, 0x01, 0x0, 0, 0x05, 0x96, 0x18, 0x177, 96000, 15 }, - { 0x028, 0x04, 0x01, 0x0, 0, 0x04, 0x66, 0x09, 0xFE, 120000, 20 } + { 0x000, 0x00, 0x00, 0x0, 0, 0x00, 0x00, 0x00, 0x00, 0, 0 }, + { 0x000, 0x00, 0x00, 0x0, 0, 0x00, 0x00, 0x00, 0x00, 0, 0 }, + { 0x028, 0x01, 0x01, 0x0, 0, 0x02, 0x2F, 0x08, 0x76, 30000, 5 }, + { 0x028, 0x04, 0x01, 0x0, 0, 0x04, 0x66, 0x09, 0xFE, 120000, 20 }, + { 0x000, 0x00, 0x00, 0x0, 0, 0x00, 0x00, 0x00, 0x00, 0, 0 }, + { 0x000, 0x00, 0x00, 0x0, 0, 0x00, 0x00, 0x00, 0x00, 0, 0 }, + { 0x028, 0x01, 0x01, 0x0, 0, 0x02, 0x2F, 0x08, 0x76, 65000, 5 } };
/* UTMIP Idle Wait Delay */
Tested-by: Andreas Westman Dorcsak hedmoo@yahoo.com # ASUS TF600T T30 Tested-by: Jonas Schwöbel jonasschwoebel@yahoo.de # Surface RT T30 Tested-by: Robert Eckelmann longnoserob@gmail.com # ASUS TF101 T20 Tested-by: Svyatoslav Ryhel clamor95@gmail.com # LG P895 T30 Co-developed-by: Jonas Schwöbel jonasschwoebel@yahoo.de Signed-off-by: Jonas Schwöbel jonasschwoebel@yahoo.de Signed-off-by: Svyatoslav Ryhel clamor95@gmail.com --- drivers/timer/Kconfig | 8 +++ drivers/timer/Makefile | 1 + drivers/timer/tegra-timer.c | 124 ++++++++++++++++++++++++++++++++++++ 3 files changed, 133 insertions(+) create mode 100644 drivers/timer/tegra-timer.c
diff --git a/drivers/timer/Kconfig b/drivers/timer/Kconfig index 6d6665005c..f32bd16227 100644 --- a/drivers/timer/Kconfig +++ b/drivers/timer/Kconfig @@ -252,6 +252,14 @@ config STM32_TIMER Select this to enable support for the timer found on STM32 devices.
+config TEGRA_TIMER + bool "Tegra timer support" + depends on TIMER + select TIMER_EARLY + help + Select this to enable support for the timer found on + Tegra devices. + config X86_TSC_TIMER bool "x86 Time-Stamp Counter (TSC) timer support" depends on TIMER && X86 diff --git a/drivers/timer/Makefile b/drivers/timer/Makefile index 6470fd5426..3c92113fc6 100644 --- a/drivers/timer/Makefile +++ b/drivers/timer/Makefile @@ -27,6 +27,7 @@ obj-$(CONFIG_SP804_TIMER) += sp804_timer.o obj-$(CONFIG_$(SPL_)SIFIVE_CLINT) += sifive_clint_timer.o obj-$(CONFIG_ARM_GLOBAL_TIMER) += arm_global_timer.o obj-$(CONFIG_STM32_TIMER) += stm32_timer.o +obj-$(CONFIG_TEGRA_TIMER) += tegra-timer.o obj-$(CONFIG_X86_TSC_TIMER) += tsc_timer.o obj-$(CONFIG_MTK_TIMER) += mtk_timer.o obj-$(CONFIG_MCHP_PIT64B_TIMER) += mchp-pit64b-timer.o diff --git a/drivers/timer/tegra-timer.c b/drivers/timer/tegra-timer.c new file mode 100644 index 0000000000..cda460921f --- /dev/null +++ b/drivers/timer/tegra-timer.c @@ -0,0 +1,124 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2022 Svyatoslav Ryhel clamor95@gmail.com + */ + +#include <common.h> +#include <dm.h> +#include <errno.h> +#include <timer.h> + +#include <asm/io.h> +#include <asm/arch/clock.h> +#include <asm/arch/tegra.h> + +#define TEGRA_OSC_CLK_ENB_L_SET (NV_PA_CLK_RST_BASE + 0x320) +#define TEGRA_OSC_SET_CLK_ENB_TMR BIT(5) + +#define TEGRA_TIMER_USEC_CNTR (NV_PA_TMRUS_BASE + 0) +#define TEGRA_TIMER_USEC_CFG (NV_PA_TMRUS_BASE + 4) + +#define TEGRA_TIMER_RATE 1000000 /* 1 MHz */ + +u64 notrace timer_early_get_count(void) +{ + /* At this stage raw timer is used */ + return readl(TEGRA_TIMER_USEC_CNTR); +} + +unsigned long notrace timer_early_get_rate(void) +{ + return TEGRA_TIMER_RATE; +} + +#if CONFIG_IS_ENABLED(BOOTSTAGE) +ulong timer_get_boot_us(void) +{ + u64 ticks = 0; + int ret; + + ret = dm_timer_init(); + if (!ret) + timer_get_count(gd->timer, &ticks); + else + ticks = timer_early_get_count(); + + return ticks; +} +#endif + +static notrace u64 tegra_timer_get_count(struct udevice *dev) +{ + u32 val = timer_early_get_count(); + return timer_conv_64(val); +} + +static int tegra_timer_probe(struct udevice *dev) +{ + struct timer_dev_priv *uc_priv = dev_get_uclass_priv(dev); + u32 usec_config, value; + + /* Timer rate has to be set unconditionally */ + uc_priv->clock_rate = TEGRA_TIMER_RATE; + + /* + * Configure microsecond timers to have 1MHz clock + * Config register is 0xqqww, where qq is "dividend", ww is "divisor" + * Uses n+1 scheme + */ + switch (clock_get_osc_freq()) { + case CLOCK_OSC_FREQ_13_0: + usec_config = 0x000c; /* (12+1)/(0+1) */ + break; + case CLOCK_OSC_FREQ_19_2: + usec_config = 0x045f; /* (95+1)/(4+1) */ + break; + case CLOCK_OSC_FREQ_12_0: + usec_config = 0x000b; /* (11+1)/(0+1) */ + break; + case CLOCK_OSC_FREQ_26_0: + usec_config = 0x0019; /* (25+1)/(0+1) */ + break; + case CLOCK_OSC_FREQ_16_8: + usec_config = 0x0453; /* (83+1)/(4+1) */ + break; + case CLOCK_OSC_FREQ_38_4: + usec_config = 0x04bf; /* (191+1)/(4+1) */ + break; + case CLOCK_OSC_FREQ_48_0: + usec_config = 0x002f; /* (47+1)/(0+1) */ + break; + default: + return -EINVAL; + } + + /* Enable clock to timer hardware */ + value = readl_relaxed(TEGRA_OSC_CLK_ENB_L_SET); + writel_relaxed(value | TEGRA_OSC_SET_CLK_ENB_TMR, + TEGRA_OSC_CLK_ENB_L_SET); + + writel_relaxed(usec_config, TEGRA_TIMER_USEC_CFG); + + return 0; +} + +static const struct timer_ops tegra_timer_ops = { + .get_count = tegra_timer_get_count, +}; + +static const struct udevice_id tegra_timer_ids[] = { + { .compatible = "nvidia,tegra20-timer" }, + { .compatible = "nvidia,tegra30-timer" }, + { .compatible = "nvidia,tegra114-timer" }, + { .compatible = "nvidia,tegra124-timer" }, + { } +}; + +U_BOOT_DRIVER(tegra_timer) = { + .name = "tegra_timer", + .id = UCLASS_TIMER, + .of_match = tegra_timer_ids, + .probe = tegra_timer_probe, + .ops = &tegra_timer_ops, + .flags = DM_FLAG_PRE_RELOC, +};
Signed-off-by: Svyatoslav Ryhel clamor95@gmail.com --- arch/arm/Kconfig | 1 + arch/arm/mach-tegra/Kconfig | 2 ++ include/configs/tegra-common.h | 6 ------ 3 files changed, 3 insertions(+), 6 deletions(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 3f68d0988b..4fce820350 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -1334,6 +1334,7 @@ config ARCH_TEGRA select GPIO_EXTRA_HEADER imply DISTRO_DEFAULTS imply FAT_WRITE + imply SPL_TIMER if SPL
config ARCH_VEXPRESS64 bool "Support ARMv8 Arm Ltd. VExpress based boards and models" diff --git a/arch/arm/mach-tegra/Kconfig b/arch/arm/mach-tegra/Kconfig index 1bef2fb233..173be3c439 100644 --- a/arch/arm/mach-tegra/Kconfig +++ b/arch/arm/mach-tegra/Kconfig @@ -62,6 +62,7 @@ config TEGRA_COMMON select MISC select OF_CONTROL select SPI + select TIMER imply CMD_DM imply CRC32_VERIFY
@@ -87,6 +88,7 @@ config TEGRA_ARMV7_COMMON select TEGRA_NO_BPMP select TEGRA_PINCTRL select TEGRA_PMC + select TEGRA_TIMER
config TEGRA_ARMV8_COMMON bool "Tegra 64-bit common options" diff --git a/include/configs/tegra-common.h b/include/configs/tegra-common.h index 2915db7f8b..390a2387ea 100644 --- a/include/configs/tegra-common.h +++ b/include/configs/tegra-common.h @@ -15,12 +15,6 @@
#include <asm/arch/tegra.h> /* get chip and board defs */
-/* Use the Tegra US timer on ARMv7, but the architected timer on ARMv8. */ -#ifndef CONFIG_ARM64 -#define CONFIG_SYS_TIMER_RATE 1000000 -#define CONFIG_SYS_TIMER_COUNTER NV_PA_TMRUS_BASE -#endif - /* Environment */
Svyatoslav Ryhel
