[U-Boot] [PATCH v2] Condense some lines in common/Makefile for readability.
Collect object files corresponding to the same CONFIG variable on the same line for better readability.
Signed-off-by: Robert P. J. Day rpjday@crashcourse.ca
clearly no *functional* difference but it follows the standard set out in the rest of the file. compile tested for a beagle, for what it's worth.
and the slight change to this version is that a duplicate and redundant check for ENV_IS_IN_EEPROM further down the file was also removed.
diff --git a/common/Makefile b/common/Makefile index 3781738..b3d66aa 100644 --- a/common/Makefile +++ b/common/Makefile @@ -50,15 +50,12 @@ COBJS-y += cmd_nvedit.o # environment COBJS-y += env_common.o COBJS-$(CONFIG_ENV_IS_IN_DATAFLASH) += env_dataflash.o -COBJS-$(CONFIG_ENV_IS_IN_EEPROM) += env_eeprom.o +COBJS-$(CONFIG_ENV_IS_IN_EEPROM) += env_embedded.o env_eeprom.o COBJS-$(CONFIG_ENV_IS_EMBEDDED) += env_embedded.o -COBJS-$(CONFIG_ENV_IS_IN_EEPROM) += env_embedded.o -COBJS-$(CONFIG_ENV_IS_IN_FLASH) += env_embedded.o -COBJS-$(CONFIG_ENV_IS_IN_NVRAM) += env_embedded.o -COBJS-$(CONFIG_ENV_IS_IN_FLASH) += env_flash.o +COBJS-$(CONFIG_ENV_IS_IN_FLASH) += env_embedded.o env_flash.o +COBJS-$(CONFIG_ENV_IS_IN_NVRAM) += env_embedded.o env_nvram.o COBJS-$(CONFIG_ENV_IS_IN_MG_DISK) += env_mgdisk.o COBJS-$(CONFIG_ENV_IS_IN_NAND) += env_nand.o -COBJS-$(CONFIG_ENV_IS_IN_NVRAM) += env_nvram.o COBJS-$(CONFIG_ENV_IS_IN_ONENAND) += env_onenand.o COBJS-$(CONFIG_ENV_IS_IN_SPI_FLASH) += env_sf.o COBJS-$(CONFIG_ENV_IS_NOWHERE) += env_nowhere.o @@ -84,7 +81,6 @@ COBJS-$(CONFIG_CMD_DIAG) += cmd_diag.o endif COBJS-$(CONFIG_CMD_DISPLAY) += cmd_display.o COBJS-$(CONFIG_CMD_DTT) += cmd_dtt.o -COBJS-$(CONFIG_ENV_IS_IN_EEPROM) += cmd_eeprom.o COBJS-$(CONFIG_CMD_EEPROM) += cmd_eeprom.o COBJS-$(CONFIG_CMD_ELF) += cmd_elf.o COBJS-$(CONFIG_CMD_EXT2) += cmd_ext2.o
======================================================================== Robert P. J. Day Waterloo, Ontario, CANADA
Linux Consulting, Training and Kernel Pedantry.
Web page: http://crashcourse.ca Twitter: http://twitter.com/rpjday ========================================================================
the env_embedded.o lines are kept sep on purpose and i'd prefer to keep it this way seeing as how i have patches to simply delete these. -mike
Mike Frysinger
Robert P. J. Day
