[PATCH 1/2] arm: imx: imx8mm_beacon: Remove unnecessary configs
Because the Beacon imx8mm board uses device tree for MMC/SD and Ethernet, there is no need to have some of the config options. It's handled by the device tree.
Signed-off-by: Adam Ford aford173@gmail.com
diff --git a/include/configs/imx8mm_beacon.h b/include/configs/imx8mm_beacon.h index e4805951fa..7c17f14964 100644 --- a/include/configs/imx8mm_beacon.h +++ b/include/configs/imx8mm_beacon.h @@ -99,14 +99,4 @@ #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ sizeof(CONFIG_SYS_PROMPT) + 16) - -/* USDHC */ -#define CONFIG_SYS_FSL_USDHC_NUM 2 -#define CONFIG_SYS_FSL_ESDHC_ADDR 0 - -/* FEC*/ -#define CONFIG_FEC_MXC_PHYADDR 0 -#define FEC_QUIRK_ENET_MAC -#define IMX_FEC_BASE 0x30BE0000 - #endif
Because the Beacon imx8mn board uses device tree for MMC/SD and Ethernet, there is no need to have some of the config options. It's handled by the device tree.
diff --git a/include/configs/imx8mn_beacon.h b/include/configs/imx8mn_beacon.h index 7fed9a38c1..41ce3c1c8c 100644 --- a/include/configs/imx8mn_beacon.h +++ b/include/configs/imx8mn_beacon.h @@ -115,16 +115,4 @@ #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ sizeof(CONFIG_SYS_PROMPT) + 16) - -/* USDHC */ -#define CONFIG_SYS_FSL_USDHC_NUM 2 -#define CONFIG_SYS_FSL_ESDHC_ADDR 0 - -/* ENET Config */ -#if defined(CONFIG_FEC_MXC) -#define CONFIG_FEC_MXC_PHYADDR 0 -#define FEC_QUIRK_ENET_MAC -#define IMX_FEC_BASE 0x30BE0000 -#endif /* CONFIG_FEC_MXC */ - #endif
Reviewed-by: Fabio Estevam festevam@denx.de
Because the Beacon imx8mn board uses device tree for MMC/SD and Ethernet, there is no need to have some of the config options. It's handled by the device tree. Signed-off-by: Adam Ford aford173@gmail.com Reviewed-by: Fabio Estevam festevam@denx.de diff --git a/include/configs/imx8mn_beacon.h b/include/configs/imx8mn_beacon.h index 7fed9a38c1..41ce3c1c8c 100644 --- a/include/configs/imx8mn_beacon.h +++ b/include/configs/imx8mn_beacon.h @@ -115,16 +115,4 @@ #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ sizeof(CONFIG_SYS_PROMPT) + 16)
#endif
Best regards, Stefano Babic
Hi Adam,
Nice cleanup:
Because the Beacon imx8mm board uses device tree for MMC/SD and Ethernet, there is no need to have some of the config options. It's handled by the device tree. Signed-off-by: Adam Ford aford173@gmail.com Reviewed-by: Fabio Estevam festevam@denx.de diff --git a/include/configs/imx8mm_beacon.h b/include/configs/imx8mm_beacon.h index e4805951fa..7c17f14964 100644 --- a/include/configs/imx8mm_beacon.h +++ b/include/configs/imx8mm_beacon.h @@ -99,14 +99,4 @@ #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ sizeof(CONFIG_SYS_PROMPT) + 16)
#endif
Adam Ford
Fabio Estevam
sbabic@denx.de
