[PATCH] i2c: octeon_i2c: Misc fixes for ARM Octeon TX2 support
This patch fixes a few issues noticed, when testing this new driver on ARM Octeon TX2 again. Here the details:
- Remove "common.h" header inclusion - Use correct THP define on Octeon TX2 - Octeon TX2 uses the same compatible as Octeon TX. We can't distinguish both platforms this way. Remove the unused "cavium,thunder2-99xx-twsi" compatible and add a check to the Octeon TX2 specific "cavium,thunderx-i2c" so that the correct driver data is selected. - Removed "struct pci_device_id" definition and U_BOOT_PCI_DEVICE() as its not needed for the PCI based probing on Octeon TX2
Signed-off-by: Stefan Roese sr@denx.de Cc: Heiko Schocher hs@denx.de Cc: Daniel Schwierzeck daniel.schwierzeck@gmail.com Cc: Suneel Garapati sgarapati@marvell.com Cc: Aaron Williams awilliams@marvell.com Cc: Chandrakala Chavva cchavva@marvell.com --- drivers/i2c/octeon_i2c.c | 59 ++++++++++++++++++---------------------- 1 file changed, 26 insertions(+), 33 deletions(-)
diff --git a/drivers/i2c/octeon_i2c.c b/drivers/i2c/octeon_i2c.c index c11d6ff93d..23dcb1563e 100644 --- a/drivers/i2c/octeon_i2c.c +++ b/drivers/i2c/octeon_i2c.c @@ -3,11 +3,10 @@ * Copyright (C) 2018 Marvell International Ltd. */
-#include <common.h> #include <clk.h> #include <dm.h> #include <i2c.h> -#include <pci_ids.h> +#include <time.h> #include <asm/io.h> #include <linux/bitfield.h> #include <linux/compat.h> @@ -749,6 +748,27 @@ static int octeon_i2c_set_bus_speed(struct udevice *bus, unsigned int speed) return 0; }
+static const struct octeon_i2c_data i2c_octeon_data = { + .probe = PROBE_DT, + .reg_offs = 0x0000, + .thp = 3, + .clk_method = CLK_METHOD_OCTEON, +}; + +static const struct octeon_i2c_data i2c_octeontx_data = { + .probe = PROBE_PCI, + .reg_offs = 0x1000, + .thp = 24, + .clk_method = CLK_METHOD_OCTEON, +}; + +static const struct octeon_i2c_data i2c_octeontx2_data = { + .probe = PROBE_PCI, + .reg_offs = 0x1000, + .thp = 3, + .clk_method = CLK_METHOD_OCTEONTX2, +}; + /** * Driver probe function * @@ -761,6 +781,10 @@ static int octeon_i2c_probe(struct udevice *dev) u32 i2c_slave_addr; int ret;
+ /* Octeon TX2 needs a different data struct */ + if (device_is_compatible(dev, "cavium,thunderx-i2c")) + dev->driver_data = (long)&i2c_octeontx2_data; + twsi->data = (const struct octeon_i2c_data *)dev_get_driver_data(dev);
if (twsi->data->probe == PROBE_PCI) { @@ -798,34 +822,11 @@ static const struct dm_i2c_ops octeon_i2c_ops = { .set_bus_speed = octeon_i2c_set_bus_speed, };
-static const struct octeon_i2c_data i2c_octeon_data = { - .probe = PROBE_DT, - .reg_offs = 0x0000, - .thp = 3, - .clk_method = CLK_METHOD_OCTEON, -}; - -static const struct octeon_i2c_data i2c_octeontx_data = { - .probe = PROBE_PCI, - .reg_offs = 0x8000, - .thp = 3, - .clk_method = CLK_METHOD_OCTEON, -}; - -static const struct octeon_i2c_data i2c_octeontx2_data = { - .probe = PROBE_PCI, - .reg_offs = 0x8000, - .thp = 24, - .clk_method = CLK_METHOD_OCTEONTX2, -}; - static const struct udevice_id octeon_i2c_ids[] = { { .compatible = "cavium,octeon-7890-twsi", .data = (ulong)&i2c_octeon_data }, { .compatible = "cavium,thunder-8890-twsi", .data = (ulong)&i2c_octeontx_data }, - { .compatible = "cavium,thunder2-99xx-twsi", - .data = (ulong)&i2c_octeontx2_data }, { } };
@@ -837,11 +838,3 @@ U_BOOT_DRIVER(octeon_pci_twsi) = { .priv_auto_alloc_size = sizeof(struct octeon_twsi), .ops = &octeon_i2c_ops, }; - -static struct pci_device_id octeon_twsi_supported[] = { - { PCI_VDEVICE(CAVIUM, PCI_DEVICE_ID_CAVIUM_TWSI), - .driver_data = (ulong)&i2c_octeontx2_data }, - { }, -}; - -U_BOOT_PCI_DEVICE(octeon_pci_twsi, octeon_twsi_supported);
Reviewed-by: Daniel Schwierzeck daniel.schwierzeck@gmail.com
Hello Stefan,
Am 23.07.2020 um 14:09 schrieb Stefan Roese:
Reviewed-by: Heiko Schocher hs@denx.de
bye, Heiko
Hello Stefan,
Applied to u-boot-i2c.git
Thanks!
bye, Heiko
Daniel Schwierzeck
Heiko Schocher
Stefan Roese
