[U-Boot] [PATCH v2] gpio: xilinx: Add support for using label property
Add support for reading label property from DT and set up bank name based on that. If label property is not present full device node name is used.
Changes in v2: - Use strdup
drivers/gpio/xilinx_gpio.c | 10 +++++++++- drivers/gpio/zynq_gpio.c | 10 +++++++++- 2 files changed, 18 insertions(+), 2 deletions(-)
diff --git a/drivers/gpio/xilinx_gpio.c b/drivers/gpio/xilinx_gpio.c index fc460c343efe..2389abee3777 100644 --- a/drivers/gpio/xilinx_gpio.c +++ b/drivers/gpio/xilinx_gpio.c @@ -241,8 +241,16 @@ static int xilinx_gpio_probe(struct udevice *dev) struct xilinx_gpio_platdata *platdata = dev_get_platdata(dev); struct xilinx_gpio_privdata *priv = dev_get_priv(dev); struct gpio_dev_priv *uc_priv = dev_get_uclass_priv(dev); + const void *label_ptr;
- uc_priv->bank_name = dev->name; + label_ptr = dev_read_prop(dev, "label", NULL); + if (label_ptr) { + uc_priv->bank_name = strdup(label_ptr); + if (!uc_priv->bank_name) + return -ENOMEM; + } else { + uc_priv->bank_name = dev->name; + }
uc_priv->gpio_count = platdata->bank_max[0] + platdata->bank_max[1];
diff --git a/drivers/gpio/zynq_gpio.c b/drivers/gpio/zynq_gpio.c index 6fbaafb3fa3c..55a5cba0688e 100644 --- a/drivers/gpio/zynq_gpio.c +++ b/drivers/gpio/zynq_gpio.c @@ -336,8 +336,16 @@ static int zynq_gpio_probe(struct udevice *dev) { struct zynq_gpio_platdata *platdata = dev_get_platdata(dev); struct gpio_dev_priv *uc_priv = dev_get_uclass_priv(dev); + const void *label_ptr;
if (platdata->p_data) uc_priv->gpio_count = platdata->p_data->ngpio;
Am 06.08.2018 um 08:42 schrieb Michal Simek:
Changes in v2:
Use strdup
- const void *label_ptr;
if (label_ptr) {
return -ENOMEM;
} else {
if (label_ptr) {
return -ENOMEM;
} else {
Reviewed-by: Stefan Herbrechtsmeier stefan@herbrechtsmeier.net
Michal Simek
