[PATCH V2] cpu: imx8_cpu: Avoid revision to corrupt device tree
U-Boot device tree is padded just after U-Boot proper. After the whole stuff loaded to DRAM space, the device tree area is conflict with BSS region before U-Boot relocation.
So any write to BSS area before reloc_fdt will corrupt the device tree. Without the fix, there is issue that “binman_init failed:-2” on i.MX8MP-EVK board.
Signed-off-by: Peng Fan peng.fan@nxp.com ---
V2: move the rev to malloc area in cpu_imx_plat tested on i.MX8MP EVK
drivers/cpu/imx8_cpu.c | 35 ++++++++++++++++++++--------------- 1 file changed, 20 insertions(+), 15 deletions(-)
diff --git a/drivers/cpu/imx8_cpu.c b/drivers/cpu/imx8_cpu.c index 6c0a8c0cbe4..b11f8dc0c91 100644 --- a/drivers/cpu/imx8_cpu.c +++ b/drivers/cpu/imx8_cpu.c @@ -20,10 +20,11 @@
DECLARE_GLOBAL_DATA_PTR;
+#define IMX_REV_LEN 4 struct cpu_imx_plat { const char *name; - const char *rev; const char *type; + char rev[IMX_REV_LEN]; u32 cpu_rsrc; u32 cpurev; u32 freq_mhz; @@ -69,28 +70,32 @@ static const char *get_imx_type_str(u32 imxtype) } }
-static const char *get_imx_rev_str(u32 rev) +static void get_imx_rev_str(struct cpu_imx_plat *plat, u32 rev) { - static char revision[4]; - if (IS_ENABLED(CONFIG_IMX8)) { + char rev; + switch (rev) { case CHIP_REV_A: - return "A"; + rev = 'A'; + break; case CHIP_REV_B: - return "B"; + rev = 'B'; + break; case CHIP_REV_C: - return "C"; + rev = 'C'; + break; default: - return "?"; + rev = '?'; + break; } + plat->rev[0] = rev; + plat->rev[1] = '\0'; } else { - revision[0] = '1' + (((rev & 0xf0) - CHIP_REV_1_0) >> 4); - revision[1] = '.'; - revision[2] = '0' + (rev & 0xf); - revision[3] = '\0'; - - return revision; + plat->rev[0] = '1' + (((rev & 0xf0) - CHIP_REV_1_0) >> 4); + plat->rev[1] = '.'; + plat->rev[2] = '0' + (rev & 0xf); + plat->rev[3] = '\0'; } }
@@ -318,7 +323,7 @@ static int imx_cpu_probe(struct udevice *dev) set_core_data(dev); cpurev = get_cpu_rev(); plat->cpurev = cpurev; - plat->rev = get_imx_rev_str(cpurev & 0xFFF); + get_imx_rev_str(plat, cpurev & 0xFFF); plat->type = get_imx_type_str((cpurev & 0x1FF000) >> 12); plat->freq_mhz = imx_get_cpu_rate(dev) / 1000000; plat->mpidr = dev_read_addr(dev);
Placing the 'revision' variable into the 'data' section would achieve the same goal without any further code change: static char revision[4] __section(".data");
- char rev[IMX_REV_LEN]; u32 cpu_rsrc; u32 cpurev; u32 freq_mhz;
char rev;
- switch (rev) { case CHIP_REV_A:
return "A";
rev = 'A';
case CHIP_REV_B:break;
return "B";
rev = 'B';
case CHIP_REV_C:break;
return "C";
rev = 'C';
default:break;
return "?";
rev = '?';
}break;
plat->rev[0] = rev;
} else {plat->rev[1] = '\0';
revision[1] = '.';
revision[3] = '\0';
return revision;
plat->rev[1] = '.';
}plat->rev[3] = '\0';
- get_imx_rev_str(plat, cpurev & 0xFFF); plat->type = get_imx_type_str((cpurev & 0x1FF000) >> 12); plat->freq_mhz = imx_get_cpu_rate(dev) / 1000000; plat->mpidr = dev_read_addr(dev);
Lothar Waßmann
Subject: Re: [PATCH V2] cpu: imx8_cpu: Avoid revision to corrupt device tree
So any write to BSS area before reloc_fdt will corrupt the device tree. Without the fix, there is issue that "binman_init failed:-2" on i.MX8MP-EVK board.
This was not welcomed, https://lore.kernel.org/all/20241017034507.GJ4959@bill-the-cat/
Regards, Peng.
EVK
imxtype)
char rev;
return "A";
rev = 'A';
return "B";
rev = 'B';
return "C";
rev = 'C';
default:break;
return "?";
rev = '?';
}break;
plat->rev[0] = rev;
revision[1] = '.';
revision[3] = '\0';
return revision;
4);
plat->rev[1] = '.';
Lothar Waßmann
Ka-Ro electronics GmbH | Pascalstraße 22 | D - 52076 Aachen Phone: +49 2408 1402-0 | Fax: +49 2408 1402-10 Geschäftsführer: Matthias Kaussen Handelsregistereintrag: Amtsgericht Aachen, HRB 4996
https://eur01.safelinks.protection.outlook.com/?url=http%3A%2F%2F www.karo- electronics.de%2F&data=05%7C02%7Cpeng.fan%40nxp.com%7Ce7321 3a6bf874b3f204f08dcee8cd46a%7C686ea1d3bc2b4c6fa92cd99c5c30 1635%7C0%7C0%7C638647535847647409%7CUnknown%7CTWFpbG Zsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJ XVCI6Mn0%3D%7C0%7C%7C%7C&sdata=jsnPkChbN7l4UlMJonwJhkn NBNwIPJD7c3t1j%2Bu%2FDiA%3D&reserved=0 | info@karo- electronics.de ___________________________________________________________
Thanks, good to know.
Lothar Waßmann
Please adapt the commit log to include this information.
This patch breaks CI. Make sure to run all your patches through CI:
https://source.denx.de/u-boot/custodians/u-boot-imx/-/jobs/920875
aarch64: + imx8qm_rom7720_a1_4G 321+WARNING 'mx8qm-ahab-container.img' not found, resulting binary is not-functional 322+drivers/cpu/imx8_cpu.c: In function 'get_imx_rev_str': 323+drivers/cpu/imx8_cpu.c:78:17: error: 'rev' is used uninitialized [-Werror=uninitialized] 324+ 78 | switch (rev) { 325+ | ^~~~~~ 326+drivers/cpu/imx8_cpu.c:76:22: note: 'rev' was declared here 327+ 76 | char rev; 328+ | ^~~ 329+cc1: all warnings being treated as errors
I am getting too much extra work to process the patches from NXP folks and I am not happy with it.
Azure can be slow, yes, but I would expect NXP to be able to setup their own internal GitLab instance and runners, or paid Azure setup, or even just use your own GitHub account and then own Azure account and not be using the shared free pool of runners.
EVK
https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2F source.denx.de%2Fu-boot%2Fcustodians%2Fu-boot-imx%2F- %2Fjobs%2F920875&data=05%7C02%7Cpeng.fan%40nxp.com%7C385 8971a1966454c3c5c08dceeaa4b47%7C686ea1d3bc2b4c6fa92cd99c5 c301635%7C0%7C0%7C638647662428479157%7CUnknown%7CTWF pbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWw iLCJXVCI6Mn0%3D%7C0%7C%7C%7C&sdata=AcYrq2JFg1BPegpK18%2 B7KsaD4ZoxIAqGX8ZYlGmUB2o%3D&reserved=0
Sorry for this. I was too confident with the patch (: I will take care.
-Peng.
participants (5)
Fabio Estevam
Lothar Waßmann
Peng Fan
Peng Fan (OSS)
