[U-Boot] [Patch 11/16] make size_t equal to unsigned int
err.. maybe a bug of gcc? In my memory, size_t is equaled to unsigned int.
diff --git a/arch/mips/include/asm/posix_types.h b/arch/mips/include/asm/posix_types.h index 879aae2..86a866a 100644 --- a/arch/mips/include/asm/posix_types.h +++ b/arch/mips/include/asm/posix_types.h @@ -24,7 +24,11 @@ typedef int __kernel_pid_t; typedef int __kernel_ipc_pid_t; typedef int __kernel_uid_t; typedef int __kernel_gid_t; +#ifndef CONFIG_MIPS64 typedef unsigned int __kernel_size_t; +#else +typedef unsigned long __kernel_size_t; +#endif typedef int __kernel_ssize_t; typedef int __kernel_ptrdiff_t; typedef long __kernel_time_t;
2012/8/14 Zhi-zhou Zhang etou.zh@gmail.com:
to be consistent you should do something like this:
#ifndef CONFIG_MIPS64 typedef unsigned int __kernel_size_t; typedef int __kernel_ssize_t; typedef int __kernel_ptrdiff_t; #else typedef unsigned long __kernel_size_t; typedef long __kernel_ssize_t; typedef long __kernel_ptrdiff_t; #endif
This is similar to what Linux is doing in asm-generic/posix_types.h
-- Regards, Zhizhou Zhang
Daniel Schwierzeck
Zhi-zhou Zhang
