[U-Boot-Users] Patch: Support for Motorola PQ2FADS-ZU board
16 Jul
2003
16 Jul
'03
3:58 p.m.
The attached patch adds support for new Motorola PQ2FADS-ZU evaluation board which replaced MPC8260ADS and MPC8266ADS. Since it shares some 90% of code with MPC8260ADS, it's supported as an MPC8260ADS subtype and not completely new board to avoid unnecessary cloning.
Yuli Barcohen | Phone +972-9-765-1788 | Software Project Leader
yuli@arabellasw.com | Fax +972-9-765-7494 | Arabella Software, Israel
Index: README
RCS file: /home/CVS/u-boot/u-boot/README,v
retrieving revision 1.1.1.4
diff -p -u -r1.1.1.4 README
--- README 16 Jul 2003 11:23:40 -0000 1.1.1.4
+++ README 16 Jul 2003 13:12:52 -0000
@@ -197,7 +197,7 @@ Directory Hierarchy:
- board/lwmon Files specific to LWMON boards
- board/mbx8xx Files specific to MBX boards
- board/mpc8260ads
- Files specific to MMPC8260ADS boards
+ Files specific to MPC8260ADS and PQ2FADS-ZU boards
- board/mpl/ Files specific to boards manufactured by MPL
- board/mpl/common Common files for MPL boards
- board/mpl/pip405 Files specific to PIP405 boards
@@ -383,6 +383,14 @@ The following options need to be configu
the lcd display every second with
a "rotator" |-/|-/
+- Board flavour: (if CONFIG_MPC8260ADS is defined)
+ CONFIG_ADSTYPE
+ Possible values are:
+ CFG_8260ADS - original MPC8260ADS
+ CFG_8266ADS - MPC8266ADS (untested)
+ CFG_PQ2FADS - PQ2FADS-ZU
- MPC824X Family Member (if CONFIG_MPC824X is defined)
Define exactly one of
CONFIG_MPC8240, CONFIG_MPC8245
@@ -1687,9 +1695,9 @@ Low Level (hardware related) configurati
- CFG_DEFAULT_IMMR:
Default address of the IMMR after system reset.
- Needed on some 8260 systems (MPC8260ADS and RPXsuper)
- to be able to adjust the position of the IMMR
- register after a reset.
+ Needed on some 8260 systems (MPC8260ADS, PQ2FADS-ZU,
+ and RPXsuper) to be able to adjust the position of
+ the IMMR register after a reset.
- Floppy Disk Support:
CFG_FDC_DRIVE_NUMBER
@@ -1862,7 +1870,7 @@ configurations; the following names are
GENIETV_config TQM823L_config PIP405_config
GEN860T_config EBONY_config FPS860L_config
ELPT860_config cmi_mpc5xx_config NETVIA_config
- at91rm9200dk_config omap1510inn_config
+ at91rm9200dk_config omap1510inn_config MPC8260ADS_config
Note: for some board special configuration names may exist; check if
additional information is available from the board vendor; for
Index: board/mpc8260ads/mpc8260ads.c
RCS file: /home/CVS/u-boot/u-boot/board/mpc8260ads/mpc8260ads.c,v
retrieving revision 1.7
diff -p -u -r1.1.1.4 -r1.7
--- board/mpc8260ads/mpc8260ads.c 16 Jul 2003 11:23:42 -0000 1.1.1.4
+++ board/mpc8260ads/mpc8260ads.c 16 Jul 2003 12:24:41 -0000 1.7
@@ -198,11 +198,19 @@ void reset_phy (void)
vu_long *bcsr = (vu_long *)CFG_BCSR;
/* reset the FEC port */
- bcsr[1] &= ~FETH_RST;
+ bcsr[1] &= ~FETH1_RST;
udelay(2);
- bcsr[1] |= FETH_RST;
+ bcsr[1] |= FETH1_RST;
udelay(1000);
#ifdef CONFIG_MII
+#if CONFIG_ADSTYPE == CFG_PQ2FADS
+ * Do not bypass Rx/Tx (de)scrambler (fix configuration error)
+ * Enable autonegotiation.
+ miiphy_write(0, 16, 0x610);
+ miiphy_write(0, PHY_BMCR, PHY_BMCR_AUTON | PHY_BMCR_RST_NEG);
+#else
* Ethernet PHY is configured (by means of configuration pins)
* to work at 10Mb/s only. We reconfigure it using MII
@@ -212,6 +220,7 @@ void reset_phy (void)
miiphy_write(0, PHY_ANAR, 0x01E1); /* Advertise all capabilities */
miiphy_write(0, PHY_DCR, 0x0000); /* Do not bypass Rx/Tx (de)scrambler */
+#endif /* CONFIG_ADSTYPE == CFG_PQ2FADS */
#endif /* CONFIG_MII */
@@ -219,7 +228,7 @@ int board_pre_init (void)
- bcsr[1] = ~FETHIEN & ~RS232EN_1;
+ bcsr[1] = ~FETHIEN1 & ~RS232EN_1;
@@ -231,12 +240,10 @@ long int initdram (int board_type)
volatile immap_t *immap = (immap_t *) CFG_IMMR;
volatile memctl8260_t *memctl = &immap->im_memctl;
volatile uchar *ramaddr, c = 0xff;
- /* Initialisation is for 16MB DIMM the board is shipped with */
- long int msize = 16;
- uint or = 0xFF000CA0;
- uint psdmr = CFG_PSDMR;
- uint psrt = CFG_PSRT;
+ long int msize;
+ uint or;
+ uint psdmr;
+ uint psrt;
int i;
@@ -246,22 +253,29 @@ long int initdram (int board_type)
immap->im_siu_conf.sc_tescr1 = 0x00004000;
memctl->memc_mptpr = CFG_MPTPR;
- /* init local sdram, bank 4 */
- memctl->memc_lsrt = 0x00000010;
+#ifdef CFG_LSDRAM_BASE
+ /* Init local bus SDRAM */
+ memctl->memc_lsrt = CFG_LSRT;
+#if CONFIG_ADSTYPE == CFG_PQ2FADS /* CS3 */
+ memctl->memc_or3 = 0xFF803280;
+ memctl->memc_br3 = CFG_LSDRAM_BASE | 0x00001861;
+#else /* CS4 */
memctl->memc_or4 = 0xFFC01480;
- memctl->memc_br4 = 0x04001861;
- memctl->memc_lsdmr = 0x2886A522;
+ memctl->memc_br4 = CFG_LSDRAM_BASE | 0x00001861;
+ memctl->memc_lsdmr = CFG_LSDMR | 0x28000000;
ramaddr = (uchar *) CFG_LSDRAM_BASE;
*ramaddr = c;
- memctl->memc_lsdmr = 0x0886A522;
+ memctl->memc_lsdmr = CFG_LSDMR | 0x08000000;
for (i = 0; i < 8; i++) {
*ramaddr = c;
- memctl->memc_lsdmr = 0x1886A522;
+ memctl->memc_lsdmr = CFG_LSDMR | 0x18000000;
*ramaddr = c;
- memctl->memc_lsdmr = 0x4086A522;
+ memctl->memc_lsdmr = CFG_LSDMR | 0x40000000;
+#endif /* CFG_LSDRAM_BASE */
- /* init sdram dimm */
+ /* Init 60x bus SDRAM */
#ifdef CONFIG_SPD_EEPROM
spd_eeprom_t spd;
@@ -398,6 +412,16 @@ long int initdram (int board_type)
printf ("OR=%X, PSDMR=%08X, PSRT=%0X\n", or, psdmr, psrt);
#endif /* SPD_DEBUG */
+#else /* !CONFIG_SPD_EEPROM */
+ msize = 32;
+ or = 0xFE002EC0;
+#else
+ msize = 16;
+ or = 0xFF000CA0;
+ psdmr = CFG_PSDMR;
+ psrt = CFG_PSRT;
#endif /* CONFIG_SPD_EEPROM */
memctl->memc_psrt = psrt;
memctl->memc_or2 = or;
@@ -415,12 +439,20 @@ long int initdram (int board_type)
*ramaddr = c;
#endif
- /* return total ram size of DIMM */
+ /* return total 60x bus SDRAM size */
return (msize * 1024 * 1024);
int checkboard (void)
+#if CONFIG_ADSTYPE == CFG_8260ADS
puts ("Board: Motorola MPC8260ADS\n");
+#elif CONFIG_ADSTYPE == CFG_8266ADS
+ puts ("Board: Motorola MPC8266ADS\n");
+#elif CONFIG_ADSTYPE == CFG_PQ2FADS
+ puts ("Board: Motorola PQ2FADS-ZU\n");
+#else
+ puts ("Board: unknown\n");
Index: include/configs/MPC8260ADS.h
RCS file: /home/CVS/u-boot/u-boot/include/configs/MPC8260ADS.h,v
retrieving revision 1.9
diff -p -u -r1.1.1.4 -r1.9
--- include/configs/MPC8260ADS.h 16 Jul 2003 11:23:52 -0000 1.1.1.4
+++ include/configs/MPC8260ADS.h 14 Jul 2003 17:15:25 -0000 1.9
@@ -9,7 +9,8 @@
* (C) Copyright 2003 Arabella Software Ltd.
* Yuli Barcohen yuli@arabellasw.com
- * Added support for SDRAM DIMMs SPD EEPROM, MII.
+ * Added support for SDRAM DIMMs SPD EEPROM, MII, JFFS2.
+ * Ported to PQ2FADS-ZU board.
* See file CREDITS for list of people who contributed to this
* project.
@@ -41,6 +42,15 @@
#define CONFIG_MPC8260 1 /* This is an MPC8260 CPU */
#define CONFIG_MPC8260ADS 1 /* ...on motorola ads board */
+/* ADS flavours */
+#define CFG_8260ADS 1 /* MPC8260ADS */
+#define CFG_8266ADS 2 /* MPC8266ADS */
+#define CFG_PQ2FADS 3 /* PQ2FADS-ZU */
+#ifndef CONFIG_ADSTYPE
+#define CONFIG_ADSTYPE CFG_8260ADS
+#endif /* CONFIG_ADSTYPE */
#define CONFIG_BOARD_PRE_INIT 1 /* Call board_pre_init */
/* allow serial and ethaddr to be overwritten */
@@ -116,7 +126,9 @@
#endif /* CONFIG_ETHER_ON_FCC */
-/* other options */
+#undef CONFIG_SPD_EEPROM /* On PQ2FADS-ZU, SDRAM is soldered */
+#else
#define CONFIG_HARD_I2C 1 /* To enable I2C support */
#define CFG_I2C_SPEED 400000 /* I2C speed and slave address */
#define CFG_I2C_SLAVE 0x7F
@@ -124,18 +136,23 @@
#if defined(CONFIG_SPD_EEPROM) && !defined(CONFIG_SPD_ADDR)
#define CONFIG_SPD_ADDR 0x50
#endif
#ifndef CONFIG_SDRAM_PBI
#define CONFIG_SDRAM_PBI 1 /* By default, use page-based interleaving */
#endif
#ifndef CONFIG_8260_CLKIN
+#define CONFIG_8260_CLKIN 100000000 /* in Hz */
+#else
#define CONFIG_8260_CLKIN 66666666 /* in Hz */
#endif
#define CONFIG_BAUDRATE 115200
-#define CONFIG_COMMANDS (CFG_CMD_ALL & ~( \
- CFG_CMD_BEDBUG | \
+#define CFG_EXCLUDE CFG_CMD_BEDBUG | \
CFG_CMD_BMP | \
CFG_CMD_BSP | \
CFG_CMD_DATE | \
@@ -143,11 +160,11 @@
CFG_CMD_DTT | \
CFG_CMD_EEPROM | \
CFG_CMD_ELF | \
+ CFG_CMD_FAT | \
CFG_CMD_FDC | \
CFG_CMD_FDOS | \
CFG_CMD_HWFLOW | \
CFG_CMD_IDE | \
- CFG_CMD_JFFS2 | \
CFG_CMD_KGDB | \
CFG_CMD_MMC | \
CFG_CMD_NAND | \
@@ -155,8 +172,18 @@
CFG_CMD_PCMCIA | \
CFG_CMD_SCSI | \
CFG_CMD_SPI | \
- CFG_CMD_VFD | \
- CFG_CMD_USB ) )
+ CFG_CMD_USB | \
+ CFG_CMD_VFD
+#define CONFIG_COMMANDS (CFG_CMD_ALL & ~( \
+ CFG_CMD_SDRAM | \
+ CFG_CMD_I2C | \
+ CFG_EXCLUDE ) )
+#else
+ CFG_EXCLUDE ) )
/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */
#include <cmd_confdefs.h>
@@ -200,7 +227,6 @@
#define CFG_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200, 230400 }
#define CFG_FLASH_BASE 0xff800000
-#define FLASH_BASE 0xff800000
#define CFG_MAX_FLASH_BANKS 1 /* max num of memory banks */
#define CFG_MAX_FLASH_SECT 32 /* max num of sects on one chip */
#define CFG_FLASH_SIZE 8
@@ -219,14 +245,16 @@
#define CFG_DEFAULT_IMMR 0x0F010000
#define CFG_IMMR 0xF0000000
-#define CFG_BCSR 0x04500000
+#define CFG_BCSR 0xF4500000
#define CFG_SDRAM_BASE 0x00000000
-#define CFG_LSDRAM_BASE 0x04000000
+#define CFG_LSDRAM_BASE 0xD0000000
#define RS232EN_1 0x02000002
#define RS232EN_2 0x01000001
-#define FETHIEN 0x08000008
-#define FETH_RST 0x04000004
+#define FETHIEN1 0x08000008
+#define FETH1_RST 0x04000004
+#define FETHIEN2 0x01000000
+#define FETH2_RST 0x08000000
#define CFG_INIT_RAM_ADDR CFG_IMMR
#define CFG_INIT_RAM_END 0x4000 /* End of used area in DPRAM */
@@ -288,19 +316,30 @@
#define CFG_SYPCR 0xFFFFFFC3
#define CFG_BCR 0x100C0000
#define CFG_SIUMCR 0x0A200000
-#define CFG_SCCR 0x00000000
-#define CFG_BR0_PRELIM 0xFF801801
-#define CFG_OR0_PRELIM 0xFF800836
-#define CFG_BR1_PRELIM 0x04501801
+#define CFG_SCCR SCCR_DFBRG01
+#define CFG_BR0_PRELIM CFG_FLASH_BASE | 0x00001801
+#define CFG_OR0_PRELIM 0xFF800876
+#define CFG_BR1_PRELIM CFG_BCSR | 0x00001801
#define CFG_OR1_PRELIM 0xFFFF8010
-#define CFG_RMR 0
+#define CFG_RMR RMR_CSRE
#define CFG_TMCNTSC (TMCNTSC_SEC|TMCNTSC_ALR|TMCNTSC_TCF|TMCNTSC_TCE)
#define CFG_PISCR (PISCR_PS|PISCR_PTF|PISCR_PTE)
#define CFG_RCCR 0
+#define CFG_PSDMR 0x824B36A3
+#define CFG_PSRT 0x13
+#define CFG_LSDMR 0x828737A3
+#define CFG_LSRT 0x13
+#define CFG_MPTPR 0x2800
+#else
#define CFG_PSDMR 0x016EB452
-#define CFG_MPTPR 0x00001900
-#define CFG_PSRT 0x00000021
+#define CFG_PSRT 0x21
+#define CFG_LSDMR 0x0086A522
+#define CFG_LSRT 0x21
+#define CFG_MPTPR 0x1900
#define CFG_RESET_ADDRESS 0x04400000
N: Yuli Barcohen
E: yuli@arabellasw.com
D: Support for Motorola PQ2FADS-ZU board
17 Jul
17 Jul
11:35 p.m.
Thanks, added.
Will push to CVS soon.
Software Engineering: Embedded and Realtime Systems, Embedded Linux
Phone: (+49)-8142-4596-87 Fax: (+49)-8142-4596-88 Email: wd@denx.de
Man did not weave the web of life; he is merely a strand in it.
Whatever he does to the web, he does to himself. - Seattle [1854]
7969
1 comments
2 participants
Yuli Barcohen
