Usage of device-tree for blobs
Hello Simon,
some boards like qemu-riscv64_defconfig do not use any device-tree at build time. A device-tree is only supplied at runtime by the prior boot stage (CONFIG_OF_PRIOR_STAGE=y).
In doc/develop/devicetree/intro.rst you suggest to put binary blobs into the device-tree.
Could you, please, update the documentation to explain how adding blobs to the device-tree works in the different scenarios depending on the values of:
CONFIG_OF_EMBED CONFIG_OF_SEPARATE CONFIG_OF_BOARD CONFIG_OF_HOSTFILE CONFIG_OF_PRIOR_STAGE
It would be especially important to understand how one can develop a board independent feature which works for all of these settings.
Please, describe CONFIG_OF_PRIOR_STAGE in doc/develop/devicetree/control.rst.
Best regards
Heinrich
Hi Heinrich,
On Wed, 25 Aug 2021 at 02:05, Heinrich Schuchardt xypron.glpk@gmx.de wrote:
Hello Simon,
OK I will take a crack at this tomorrow.
But I think there is a disconnect here, since the only options that matter within U-Boot are OF_SEPARATE and OF_HOSTFILE, which both use a u-boot.dtb file. There is nothing tricky here.
The OF_BOARD business is for when the board does special things. Presumably signing will do special things too. We cannot really know what those things are because the board as 'opted out' of the standard options.
So I'm not allowed to delete that option? :-) It seems to me to be extremely sparse on documentation. We need an explanation of what it means and what effect it has on the build system, U-Boot and some discussion of how qemu works. It seems to have been added as part of an unrelated broadcom commit. The tags were incorrect so I doubt anyone noticed it. Since then it has apparently proved useful elsewhere, but no one has added more docs.
So perhaps you can help me with my doc by explaining how OF_PRIOR_STAGE works in qmeu, why the DT in U-Boot cannot be used, and which project actually hosts the DT that qemu provides? Armed with that information, I might be able to make sense of it all.
On 8/26/21 5:15 AM, Simon Glass wrote:
Hi Heinrich,
Hello Simon,
The following boards use OF_PRIO_STAGE:
* QEMU * bcm7260_defconfig * bcm7445_defconfig * ae350_rv32_defconfig * ae350_rv32_spl_defconfig * ae350_rv64_defconfig * ae350_rv64_spl_defconfig
No.
The DT provided by QEMU is not hosted anywhere. It is generated on the fly by QEMU in dependence of the command line arguments that are used for calling QEMU. The project is hosted at
On RISC-V the address of the device-tree of the prior bootstage is provided in register t0.
On ARM platforms QEMU places the device-tree at 0x40000000.
QEMU is not the only platform where the prior boot stage supplies the device-tree which is to be used for booting the operating system. Any platform using TF-A or OpenSBI can be setup in this way.
Generally it would be preferable that the prior boot stage provides the device-tree. But unfortunately Linux is not always backwards compatible.
Don't expect the device-tree of the prior stage to contain any U-Boot specific quirks.
Best regards
Heinrich
Hi Heinrich,
Hi Heinrich,
Hello Simon,
- QEMU
- bcm7260_defconfig
- bcm7445_defconfig
- ae350_rv32_defconfig
- ae350_rv32_spl_defconfig
- ae350_rv64_defconfig
- ae350_rv64_spl_defconfig
Most of these seem OK as they have an in-tree DT. But the arm and riscv qemus and the bcm builds do not:
bcm7260_defconfig bcm7445_defconfig configs/qemu_arm64_defconfig configs/qemu_arm_defconfig configs/qemu-ppce500_defconfig configs/qemu-riscv32_defconfig configs/qemu-riscv32_smode_defconfig configs/qemu-riscv64_defconfig configs/qemu-riscv64_smode_defconfig
I think we are going to have to ban this. We are not really testing the build at all, and it presumably depends on the version of qemu that is used. It's OK to provide the DT to U-Boot as one flow, but not to completely drop it from the tree.
Where is the qemu source code that creates these DTs?
No.
https://github.com/qemu/qemu.
404 on that. Do you have a link to the code that actually generates the DT?
This is my concern. I think every board in U-Boot needs at least a basic DT, even if only a skeleton, so we have places to put things. Any packaging at all needs a binman node, for example. U-Boot also has its own options for certain things.
Also, where does the environment come from on these boards? Having the env in one tree and the DT in another must make things very interesting.
From: Simon Glass sjg@chromium.org Date: Thu, 26 Aug 2021 13:54:49 -0600
Hi Heinrich,
Hi Heinrich,
Hello Simon,
- QEMU
- bcm7260_defconfig
- bcm7445_defconfig
So you want to have a DT in the U-Boot tree that is completely unused?
For ARM the code is in:
https://github.com/qemu/qemu/blob/master/hw/arm/virt.c
No.
Most of the options are for SPL though, and these platforms don't have that as there is other firmware that does the low-level bringup. And these platforms typically don't need packaging. I believe QEMU just needs the ELF binary, and that's also the case for how we boot the Apple M1 using m1n1.
I suppose we could have a DT for these platforms that doesn't describe the hardware and just does the config stuff. But then you'll be juggling two DTs and have to make sure that the real one is passed on to the kernel booted by U-Boot. But I think your idea of having everything configured in a single DT is flawed.
What environment do you mean? The U-Boot variables are defined in the config files, not in the DT.
Hi Mark,
Hi Heinrich,
Hi Heinrich,
Hello Simon,
- QEMU
- bcm7260_defconfig
- bcm7445_defconfig
Why would I want it to be unused?
It is used by the U-Boot build, at least.
Does this all work because the qemu support has been in there for ages and never changes? Otherwise I wonder about version compatibility.
Gosh that's 3k LOC that I didn't even imagine existed! Thank you for the pointer.
I don't see any mention in there about U-Boot. Are you sure that it is passed to U-Boot, or is it just passed to Linux? If U-Boot uses it, someone should make a note of that in the file.
No.
You mean that you load u-boot (the ELF file) with no DT?
No, I'd like a basic DT that describes the hardware and has a node for each of the enabled drivres.
Perhaps the real issue here is that OF_PRIOR_STAGE is a build-time option. Perhaps it should be a run-time option, selected by the prior stage. If not provided, U-Bot uses its own DT?
What is the flaw? Do you want to use overlays? I don't think it is unreasonable for U-Boot to have a DT in its own project. It has a defconfig, an environment and all the drivers.
The U-Boot environment. Eg. here:
https://www.denx.de/wiki/DULG/UBootEnvVariables
From: Simon Glass sjg@chromium.org Date: Thu, 26 Aug 2021 21:57:19 -0600 Cc: Heinrich Schuchardt xypron.glpk@gmx.de, Ilias Apalodimas ilias.apalodimas@linaro.org, U-Boot Mailing List u-boot@lists.denx.de Content-Type: text/plain; charset="UTF-8"
Hi Mark,
Hi Heinrich,
Hi Heinrich,
Hello Simon,
- QEMU
- bcm7260_defconfig
- bcm7445_defconfig
To do what?
Well, DT bindings are supposed to be stable. See the discussion we had earlier this week about the layerscape bindings... So yes, I think the folks involved on both the QEMU and Linux side are committed to backwards compatibility here.
I don't know why you want to single out U-Boot and Linux. The DT bindings are OS agnostic. They work equally well for OpenBSD and FreeBSD. So why wouldn't they work for U-Boot?
No.
What actually happens is that m1n1, u-boot and the DT get concatenated into a single file. m1n1 recognizes the DT, modifies it as needed and passes it along to the Linux kernel or U-Boot. I suppose we could use binman to do this concatenation if we really wanted to and have the "base" device trees in the U-Boot repository. But I expect that for Asahi Linux we really want to have these in the m1n1 repository. That way we can add device trees for new Mac models quickly without being tied to the U-Boot release cycle.
I suppose we can have one for documentation purposes.
In the case of the Apple M1 this makes no sense. U-Boot has to use the device tree that gets passed by m1n1. Without the modifications made by m1n1 some stuff simply won't work and the user experience will suck.
Right. I don't see how that is tied to the device tree.
Hi Mark,
Hi Mark,
Hi Heinrich,
Hi Heinrich,
On Wed, 25 Aug 2021 at 02:05, Heinrich Schuchardt xypron.glpk@gmx.de wrote: > > Hello Simon, > > some boards like qemu-riscv64_defconfig do not use any device-tree at > build time. A device-tree is only supplied at runtime by the prior boot > stage (CONFIG_OF_PRIOR_STAGE=y). > > In doc/develop/devicetree/intro.rst you suggest to put binary blobs into > the device-tree. > > Could you, please, update the documentation to explain how adding blobs > to the device-tree works in the different scenarios depending on the > values of: > > CONFIG_OF_EMBED > CONFIG_OF_SEPARATE > CONFIG_OF_BOARD > CONFIG_OF_HOSTFILE > CONFIG_OF_PRIOR_STAGE > > It would be especially important to understand how one can develop a > board independent feature which works for all of these settings.
- QEMU
- bcm7260_defconfig
- bcm7445_defconfig
To do what?
Discoverability, documentation, for CI to check it. I cover that in the doc I sent.
OK good. Then so long as U-Boot does the same, QEMU should be fine.
You are completely missing my point, sorry.
My problem with all of this is that I had no idea that it was going on....and I'm fairly active in U-Boot on and off. I am even the FDT maintainer in U-Boot. If I am not aware of it, how is anyone else supposed to find out? For example I don't see mention of this in doc/board/emulation/qemu-arm.rst
After close inspection I see a passing reference to it in the RISC-V doc: doc/board/emulation/qemu-riscv.rst
"...and the memory node in the embedded DTB created by QEMU reflects..."
(and I note in that case that the ELF file is passed to QEMU which doesn't seem right to me)
So however we got into this state (and I cover that somewhat in my series). I would like to see things documented much more clearly.
> > Please, describe CONFIG_OF_PRIOR_STAGE in > doc/develop/devicetree/control.rst.
No.
Yes, please don't use ELF as it bypasses part of the U-Boot build system.
I am not worried about passing a DT to U-Boot, but there should be something representative in the tree.
Yes please and thank you.
Again I think you are missing my point.
OF_PRIOR_STAGE should not mean there is no DT in U-Boot and it is unable to produce a complete image. I am fine with passing a DT through to U-Boot, But, as above, please put something in the U-Boot tree and build it.
My point is that the scheme here is able to update the devicetree built into U-Boot but not the environment built into U-Boot (actually I believe you can modify the env in DT these days). But both affect how U-Boot operates. I suppose my larger point is that IMO none of this appears to have been thought out very clearly, nor documented anywhere in U-Boot. That's actually the theme of the last several weeks for me and I really want to straighten this all out.
On 8/26/21 3:54 PM, Simon Glass wrote:
Hi Heinrich,
Hi Heinrich,
Hello Simon,
- QEMU
- bcm7260_defconfig
- bcm7445_defconfig
No.
https://github.com/qemu/qemu/blob/master/hw/riscv/virt.c#L179
From: Simon Glass sjg@chromium.org Date: Wed, 25 Aug 2021 21:15:00 -0600
Hi Heinrich,
Hello Simon,
Well, QEMU allows configuration of (emulated/paravirtualised) devices from the command line. So it is pretty much impossible for U-Boot to provide a DT that matches that configuration without adding a lot of code the dynamically build it from some sort of configuration specification provided by QEMU to U-Boot. But at that point QEMU might as well provide the DT itself, don't you agree?
Anyway, replying to this thread since for the Apple M1 support that I'm working on we're in a somewhat similar situation. The Asahi Linux project has implemented m1n1 as a bootloader and plans to use U-Boot as a "payload" to implement booting a standard Linux distribution (and other OSes). In this scenario m1n1 actually provides the DT since it parses Apple's version of the DT (which isn't in the standard DT format) and adds/updates certain properties that depend on the actual hardware it is running on.
For this code I use CONFIG_OF_BOARD and implement board_fdt_blob_setup() to simple return a pointer to the DT that m1n1 set up. But that seems to be exactly what CONFIG_OF_PRIOR_STAGE does...
Hi Mark,
Hi Heinrich,
Hello Simon,
Don't these devices have a DT in U-Boot? Is qemu enabling them (status = "okay") or actually inventing them?!
Yes I see. Still I'd like a basic DT in U-Boot, even if just for discoverability.
Right, and neither is really documented to the level that people can understand the purpose. They just come across as hacks to me.
I'd like to see an API for passing a info (including DT) to U-Boot. I think riscv has it? I suggest we use a register that points to a bloblist.
From: Simon Glass sjg@chromium.org Date: Thu, 26 Aug 2021 14:00:12 -0600
Hi Mark,
Hi Heinrich,
Hello Simon,
I actually invents them. See the mail I just sent for a reference to the code.
Discoverability of what?
Well, I think U-Boot by its very nature is a giant hack ;).
Well, having a generic API will be hard. It will depend on the low-level firmware. On RISC-V the SBI specification defines such an API. For the Apple M1 I just use the existing code that makes U-Boot look like a Linux kernel and use the same API that is used to pass the DTB to the kernel. The Raspberry Pi code does something similar. In the end it just boils down to passing a pointer to the DT in a specific register.
Hi Mark,
Hi Mark,
Hi Heinrich,
Hello Simon,
OK I see.
Devices that are available / used on the board.
I'm not even sure where to go with that one...
Yes that's what I'm talking about. if RISC-V does it, great. Perhaps ARM can also?
Hi Heinrich,
Hello Simon,
Back to this original request, I've taken a crack at this and sent out a patch.
Regards, SImon
Hi Heinrich,
Hello Simon,
+Tom Rini
I have now sent documentation on this, as requested.
Please can you stop waiting, and apply the revert series that I requested 6 weeks ago now? If this mess goes out in a release I will be extremely unhappy.
Mark Kettenis
Sean Anderson
