[U-Boot] [PATCH 2/4] spi: cadence_qspi: Fix fdt read of spi-max-frequency
Fix the fdt read for spi-max-frequency as it's contained in the child node. Current state of code is always returning default value.
Signed-off-by: Chin Liang See clsee@altera.com Cc: Dinh Nguyen dinguyen@opensource.altera.com Cc: Dinh Nguyen dinh.linux@gmail.com Cc: Marek Vasut marex@denx.de Cc: Stefan Roese sr@denx.de Cc: Vikas Manocha vikas.manocha@st.com Cc: Jagannadh Teki jteki@openedev.com Cc: Pavel Machek pavel@denx.de --- Changes for v2 - Add unsigned casting for plat->max_hz --- drivers/spi/cadence_qspi.c | 8 ++++---- 1 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/spi/cadence_qspi.c b/drivers/spi/cadence_qspi.c index 23c88d5..8c0f7dd 100644 --- a/drivers/spi/cadence_qspi.c +++ b/drivers/spi/cadence_qspi.c @@ -296,10 +296,6 @@ static int cadence_spi_ofdata_to_platdata(struct udevice *bus) plat->regbase = (void *)data[0]; plat->ahbbase = (void *)data[2];
- /* Use 500KHz as a suitable default */ - plat->max_hz = fdtdec_get_int(blob, node, "spi-max-frequency", - 500000); - /* All other paramters are embedded in the child node */ subnode = fdt_first_subnode(blob, node); if (subnode < 0) { @@ -307,6 +303,10 @@ static int cadence_spi_ofdata_to_platdata(struct udevice *bus) return -ENODEV; }
+ /* Use 500KHz as a suitable default */ + plat->max_hz = (unsigned int)fdtdec_get_int(blob, subnode, + "spi-max-frequency", 500000); + /* Read other parameters from DT */ plat->page_size = fdtdec_get_int(blob, subnode, "page-size", 256); plat->block_size = fdtdec_get_int(blob, subnode, "block-size", 16);
Changes for v2
500000);
fdtdec_get_int will return default_val (say 500000 here) or property value from dts which is usually "unsigned", unless wrongly set as -ve value ie reason there is no typecasting used in rest of the code.
But, if still worried, better to add unsigned fdtdec_get_* instead of type casting.
-- 1.7.7.4
thanks!
Changes for v2
500000);
Thanks to Marek, I will use fdt_getprop_u32_default_node to achieve this :)
Thanks Chin Liang
-- 1.7.7.4
thanks!
Changes for v2
500000);
- plat->max_hz = (unsigned int)fdtdec_get_int(blob, subnode,
fdt_getprop_u32() might be the right thing to do here :)
Best regards, Marek Vasut
Changes for v2
500000);
Cool, yup, I am using fdt_getprop_u32_default_node. But need additional patch to enable this and more FDT related function in SPL
Thanks Chin Liang
Changes for v2
500000);
All right, be careful not to blow the SPL size too much btw.
Changes for v2
500000);
And as you'll be updating it... it should be "500 kHz", AFAICT.
- /* Read other parameters from DT */ plat->page_size = fdtdec_get_int(blob, subnode, "page-size", 256); plat->block_size = fdtdec_get_int(blob, subnode, "block-size",
16);
Pavel
Changes for v2
500000);
That sounds easy fix :)
Thanks Chin Liang
16);
Pavel
Chin Liang See
Jagan Teki
Pavel Machek
