[U-Boot-Users] [PATCH 10/18] include/configs: Use new CONFIG_CMD_* in various [NO]* named board config files.
Signed-off-by: Jon Loeliger jdl@freescale.com --- include/configs/NC650.h | 31 +++++++++++++++++-------------- include/configs/NETPHONE.h | 26 ++++++++++++++------------ include/configs/NETTA.h | 38 ++++++++++++++++++++------------------ include/configs/NETTA2.h | 26 ++++++++++++++------------ include/configs/NETVIA.h | 23 ++++++++++++----------- include/configs/NSCU.h | 25 ++++++++++++++----------- include/configs/NX823.h | 17 +++++++++++------ include/configs/OCRTC.h | 27 +++++++++++++++------------ include/configs/ORSG.h | 27 +++++++++++++++------------ include/configs/OXC.h | 12 ++++++++---- 10 files changed, 140 insertions(+), 112 deletions(-)
diff --git a/include/configs/NC650.h b/include/configs/NC650.h index a12c8da..221fce9 100644 --- a/include/configs/NC650.h +++ b/include/configs/NC650.h @@ -134,25 +134,28 @@ #define CONFIG_RTC_PCF8563 #define CFG_I2C_RTC_ADDR 0x51
-#define CONFIG_COMMANDS ( CONFIG_CMD_DFL | \ - CFG_CMD_ASKENV | \ - CFG_CMD_DATE | \ - CFG_CMD_DHCP | \ - CFG_CMD_I2C | \ - CFG_CMD_NAND | \ - CFG_CMD_JFFS2 | \ - CFG_CMD_NFS | \ - CFG_CMD_SNTP ) - -/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h> + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_ASKENV +#define CONFIG_CMD_DATE +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_I2C +#define CONFIG_CMD_NAND +#define CONFIG_CMD_JFFS2 +#define CONFIG_CMD_NFS +#define CONFIG_CMD_SNTP +
/* * Miscellaneous configurable options */ #define CFG_LONGHELP /* undef to save memory */ #define CFG_PROMPT "=> " /* Monitor Command Prompt */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ @@ -230,7 +233,7 @@ * Cache Configuration */ #define CFG_CACHELINE_SIZE 16 /* For all MPC8xx CPUs */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CACHELINE_SHIFT 4 /* log base 2 of the above value */ #endif
diff --git a/include/configs/NETPHONE.h b/include/configs/NETPHONE.h index 444f721..cfca811 100644 --- a/include/configs/NETPHONE.h +++ b/include/configs/NETPHONE.h @@ -105,20 +105,22 @@
#define CONFIG_ENV_OVERWRITE 1 /* allow modification of vendor params */
-#define CONFIG_COMMANDS ( CONFIG_CMD_DFL | \ - CFG_CMD_NAND | \ - CFG_CMD_DHCP | \ - CFG_CMD_PING | \ - CFG_CMD_MII | \ - CFG_CMD_CDP \ - ) + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_NAND +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_PING +#define CONFIG_CMD_MII +#define CONFIG_CMD_CDP +
#define CONFIG_BOARD_EARLY_INIT_F 1 #define CONFIG_MISC_INIT_R
-/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h> - /* * Miscellaneous configurable options */ @@ -128,7 +130,7 @@ #define CFG_HUSH_PARSER 1 #define CFG_PROMPT_HUSH_PS2 "> "
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ @@ -220,7 +222,7 @@ * Cache Configuration */ #define CFG_CACHELINE_SIZE 16 /* For all MPC8xx CPUs */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CACHELINE_SHIFT 4 /* log base 2 of the above value */ #endif
diff --git a/include/configs/NETTA.h b/include/configs/NETTA.h index 25b6345..e2e8803 100644 --- a/include/configs/NETTA.h +++ b/include/configs/NETTA.h @@ -111,26 +111,28 @@ CFG_POST_CODEC | \ CFG_POST_DSP )
-#define CONFIG_COMMANDS ( CONFIG_CMD_DFL | \ - CFG_CMD_CDP | \ - CFG_CMD_DHCP | \ - CFG_CMD_DIAG | \ - CFG_CMD_FAT | \ - CFG_CMD_IDE | \ - CFG_CMD_JFFS2 | \ - CFG_CMD_MII | \ - CFG_CMD_NAND | \ - CFG_CMD_NFS | \ - CFG_CMD_PCMCIA | \ - CFG_CMD_PING | \ - 0) + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_CDP +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_DIAG +#define CONFIG_CMD_FAT +#define CONFIG_CMD_IDE +#define CONFIG_CMD_JFFS2 +#define CONFIG_CMD_MII +#define CONFIG_CMD_NAND +#define CONFIG_CMD_NFS +#define CONFIG_CMD_PCMCIA +#define CONFIG_CMD_PING +
-/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h> - /* * Miscellaneous configurable options */ @@ -140,7 +142,7 @@ #define CFG_HUSH_PARSER 1 #define CFG_PROMPT_HUSH_PS2 "> "
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ @@ -223,7 +225,7 @@ * Cache Configuration */ #define CFG_CACHELINE_SIZE 16 /* For all MPC8xx CPUs */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CACHELINE_SHIFT 4 /* log base 2 of the above value */ #endif
diff --git a/include/configs/NETTA2.h b/include/configs/NETTA2.h index e20e724..ac8e481 100644 --- a/include/configs/NETTA2.h +++ b/include/configs/NETTA2.h @@ -105,20 +105,22 @@
diff --git a/include/configs/NETVIA.h b/include/configs/NETVIA.h index e30be09..fa91306 100644 --- a/include/configs/NETVIA.h +++ b/include/configs/NETVIA.h @@ -88,28 +88,29 @@
#define CONFIG_RTC_MPC8xx /* use internal RTC of MPC8xx */
-#define CONFIG_COMMANDS_BASE ( CONFIG_CMD_DFL | \ - CFG_CMD_DHCP | \ - CFG_CMD_PING ) + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_PING
#if defined(CONFIG_NETVIA_VERSION) && CONFIG_NETVIA_VERSION >= 2 -#define CONFIG_COMMANDS (CONFIG_COMMANDS_BASE | CFG_CMD_NAND) -#else -#define CONFIG_COMMANDS CONFIG_COMMANDS_BASE +#define CONFIG_CMD_NAND #endif
+ #define CONFIG_BOARD_EARLY_INIT_F 1 #define CONFIG_MISC_INIT_R
-/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h> - /* * Miscellaneous configurable options */ #define CFG_LONGHELP /* undef to save memory */ #define CFG_PROMPT "=> " /* Monitor Command Prompt */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ @@ -192,7 +193,7 @@ * Cache Configuration */ #define CFG_CACHELINE_SIZE 16 /* For all MPC8xx CPUs */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CACHELINE_SHIFT 4 /* log base 2 of the above value */ #endif
diff --git a/include/configs/NSCU.h b/include/configs/NSCU.h index d994420..0edfebf 100644 --- a/include/configs/NSCU.h +++ b/include/configs/NSCU.h @@ -93,16 +93,19 @@
#define CONFIG_ISP1362_USB /* ISP1362 USB OTG controller */
-#define CONFIG_COMMANDS ( CONFIG_CMD_DFL | \ - CFG_CMD_ASKENV | \ - CFG_CMD_DATE | \ - CFG_CMD_DHCP | \ - CFG_CMD_IDE | \ - CFG_CMD_NFS | \ - CFG_CMD_SNTP )
-/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h> +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_ASKENV +#define CONFIG_CMD_DATE +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_IDE +#define CONFIG_CMD_NFS +#define CONFIG_CMD_SNTP +
/* * Miscellaneous configurable options @@ -117,7 +120,7 @@ #define CFG_PROMPT_HUSH_PS2 "> " #endif
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ @@ -201,7 +204,7 @@ * Cache Configuration */ #define CFG_CACHELINE_SIZE 16 /* For all MPC8xx CPUs */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CACHELINE_SHIFT 4 /* log base 2 of the above value */ #endif
diff --git a/include/configs/NX823.h b/include/configs/NX823.h index 1cb8b8f..527bd9d 100644 --- a/include/configs/NX823.h +++ b/include/configs/NX823.h @@ -56,21 +56,26 @@ #undef CFG_LOADS_BAUD_CHANGE /* don't allow baudrate change */ #undef CONFIG_WATCHDOG /* watchdog disabled, for now */ #define CONFIG_BOOTP_MASK (CONFIG_BOOTP_DEFAULT | CONFIG_BOOTP_BOOTFILESIZE) -#define CONFIG_COMMANDS (CONFIG_CMD_DFL | CFG_CMD_AUTOSCRIPT) #define CONFIG_AUTOSCRIPT
+ +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_AUTOSCRIPT + + /* call various generic functions */ #define CONFIG_MISC_INIT_R
-/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h> - /* * Miscellaneous configurable options */ #define CFG_LONGHELP /* undef to save memory */ #define CFG_PROMPT "=> " /* Monitor Command Prompt */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ @@ -152,7 +157,7 @@ * Cache Configuration */ #define CFG_CACHELINE_SIZE 16 /* For all MPC8xx CPUs */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CACHELINE_SHIFT 4 /* log base 2 of the above value */ #endif
diff --git a/include/configs/OCRTC.h b/include/configs/OCRTC.h index aa9d1ba..00f747e 100644 --- a/include/configs/OCRTC.h +++ b/include/configs/OCRTC.h @@ -54,20 +54,23 @@ #define CONFIG_PHY_ADDR 0 /* PHY address */ #define CONFIG_LXT971_NO_SLEEP 1 /* disable sleep mode in LXT971 */
-#define CONFIG_COMMANDS ( CONFIG_CMD_DFL | \ - CFG_CMD_PCI | \ - CFG_CMD_IRQ | \ - CFG_CMD_ASKENV | \ - CFG_CMD_ELF | \ - CFG_CMD_BSP | \ - CFG_CMD_EEPROM ) + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_PCI +#define CONFIG_CMD_IRQ +#define CONFIG_CMD_ASKENV +#define CONFIG_CMD_ELF +#define CONFIG_CMD_BSP +#define CONFIG_CMD_EEPROM +
#define CONFIG_MAC_PARTITION #define CONFIG_DOS_PARTITION
-/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h> - #undef CONFIG_WATCHDOG /* watchdog disabled */
#define CONFIG_SDRAM_BANK0 1 /* init onboard SDRAM bank 0 */ @@ -77,7 +80,7 @@ */ #define CFG_LONGHELP /* undef to save memory */ #define CFG_PROMPT "=> " /* Monitor Command Prompt */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ @@ -215,7 +218,7 @@ */ #define CFG_DCACHE_SIZE 8192 /* For AMCC 405 CPUs */ #define CFG_CACHELINE_SIZE 32 /* ... */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CACHELINE_SHIFT 5 /* log base 2 of the above value */ #endif
diff --git a/include/configs/ORSG.h b/include/configs/ORSG.h index 2e7c505..bab4c3d 100644 --- a/include/configs/ORSG.h +++ b/include/configs/ORSG.h @@ -54,20 +54,23 @@ #define CONFIG_PHY_ADDR 0 /* PHY address */ #define CONFIG_LXT971_NO_SLEEP 1 /* disable sleep mode in LXT971 */
#define CONFIG_SDRAM_BANK0 1 /* init onboard SDRAM bank 0 */ @@ -77,7 +80,7 @@ */ #define CFG_LONGHELP /* undef to save memory */ #define CFG_PROMPT "=> " /* Monitor Command Prompt */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ @@ -213,7 +216,7 @@ */ #define CFG_DCACHE_SIZE 8192 /* For AMCC 405 CPUs */ #define CFG_CACHELINE_SIZE 32 /* ... */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CACHELINE_SHIFT 5 /* log base 2 of the above value */ #endif
diff --git a/include/configs/OXC.h b/include/configs/OXC.h index 787407c..e70d485 100644 --- a/include/configs/OXC.h +++ b/include/configs/OXC.h @@ -51,10 +51,14 @@ #define CONFIG_BAUDRATE 9600 #define CFG_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 }
-#define CONFIG_COMMANDS (CONFIG_CMD_DFL | CFG_CMD_ELF)
-/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ -#include <cmd_confdefs.h> +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_ELF +
/* * Miscellaneous configurable options @@ -299,7 +303,7 @@ * Cache Configuration */ #define CFG_CACHELINE_SIZE 32 /* For MPC8240 CPU */ -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) # define CFG_CACHELINE_SHIFT 5 /* log base 2 of the above value */ #endif
Jon Loeliger
