[U-Boot] [PATCH 0/4] USB: Add support for designware UDC
Support for designware USB device controller (UDC) exists in the u-boot for SPEAr platform. This patchset makes the driver more generic so that it can be used across multiple platforms.
Shiraz Hashim (1): USB:gadget:designware Fix memory nonalignment issue
Vipin KUMAR (3): USB:gadget:designware USB device controller (UDC) implementation USB:gadget:designware Device controller bugfixes USB:gadget:designware Support high speed
drivers/serial/usbtty.h | 4 +- drivers/usb/gadget/Makefile | 2 +- drivers/usb/gadget/{spr_udc.c => designware_udc.c} | 138 ++++++++++++-------- include/configs/spear-common.h | 4 +- include/usb/{spr_udc.h => designware_udc.h} | 9 +- 5 files changed, 98 insertions(+), 59 deletions(-) rename drivers/usb/gadget/{spr_udc.c => designware_udc.c} (89%) rename include/usb/{spr_udc.h => designware_udc.h} (97%)
The earlier usb device controller driver was specific to spear platforms. This patch implements the usb device controller driver as a generic controller which can be reused by other platforms using this peripheral.
Signed-off-by: Vipin Kumar vipin.kumar@st.com Signed-off-by: Amit Virdi amit.virdi@st.com --- drivers/serial/usbtty.h | 4 +- drivers/usb/gadget/Makefile | 2 +- drivers/usb/gadget/{spr_udc.c => designware_udc.c} | 57 ++++++++++---------- include/configs/spear-common.h | 4 +- include/usb/{spr_udc.h => designware_udc.h} | 6 +- 5 files changed, 37 insertions(+), 36 deletions(-) rename drivers/usb/gadget/{spr_udc.c => designware_udc.c} (94%) rename include/usb/{spr_udc.h => designware_udc.h} (98%)
diff --git a/drivers/serial/usbtty.h b/drivers/serial/usbtty.h index e449cd7..60347d7 100644 --- a/drivers/serial/usbtty.h +++ b/drivers/serial/usbtty.h @@ -33,8 +33,8 @@ #include <usb/musb_udc.h> #elif defined(CONFIG_CPU_PXA27X) #include <usb/pxa27x_udc.h> -#elif defined(CONFIG_SPEAR3XX) || defined(CONFIG_SPEAR600) -#include <usb/spr_udc.h> +#elif defined(CONFIG_DW_UDC) +#include <usb/designware_udc.h> #endif
#include <version.h> diff --git a/drivers/usb/gadget/Makefile b/drivers/usb/gadget/Makefile index 64b091f..87d1918 100644 --- a/drivers/usb/gadget/Makefile +++ b/drivers/usb/gadget/Makefile @@ -39,11 +39,11 @@ else ifdef CONFIG_USB_DEVICE COBJS-y += core.o COBJS-y += ep0.o +COBJS-$(CONFIG_DW_UDC) += designware_udc.o COBJS-$(CONFIG_OMAP1510) += omap1510_udc.o COBJS-$(CONFIG_OMAP1610) += omap1510_udc.o COBJS-$(CONFIG_MPC885_FAMILY) += mpc8xx_udc.o COBJS-$(CONFIG_CPU_PXA27X) += pxa27x_udc.o -COBJS-$(CONFIG_SPEARUDC) += spr_udc.o endif endif
diff --git a/drivers/usb/gadget/spr_udc.c b/drivers/usb/gadget/designware_udc.c similarity index 94% rename from drivers/usb/gadget/spr_udc.c rename to drivers/usb/gadget/designware_udc.c index f2b06d6..aee44aa 100644 --- a/drivers/usb/gadget/spr_udc.c +++ b/drivers/usb/gadget/designware_udc.c @@ -29,14 +29,13 @@
#include <usbdevice.h> #include "ep0.h" -#include <usb/spr_udc.h> +#include <usb/designware_udc.h> #include <asm/arch/hardware.h> -#include <asm/arch/spr_misc.h>
#define UDC_INIT_MDELAY 80 /* Device settle delay */
/* Some kind of debugging output... */ -#ifndef DEBUG_SPRUSBTTY +#ifndef DEBUG_DWUSBTTY #define UDCDBG(str) #define UDCDBGA(fmt, args...) #else @@ -251,7 +250,7 @@ static void usbputpcktofifo(int epNum, u8 *bufp, u32 len) }
/* - * spear_write_noniso_tx_fifo - Write the next packet to TxFIFO. + * dw_write_noniso_tx_fifo - Write the next packet to TxFIFO. * @endpoint: Endpoint pointer. * * If the endpoint has an active tx_urb, then the next packet of data from the @@ -263,7 +262,7 @@ static void usbputpcktofifo(int epNum, u8 *bufp, u32 len) * transmitted in this packet. * */ -static void spear_write_noniso_tx_fifo(struct usb_endpoint_instance +static void dw_write_noniso_tx_fifo(struct usb_endpoint_instance *endpoint) { struct urb *urb = endpoint->tx_urb; @@ -307,7 +306,7 @@ static void spear_write_noniso_tx_fifo(struct usb_endpoint_instance * Handle SETUP USB interrupt. * This function implements TRM Figure 14-14. */ -static void spear_udc_setup(struct usb_endpoint_instance *endpoint) +static void dw_udc_setup(struct usb_endpoint_instance *endpoint) { u8 *datap = (u8 *)&ep0_urb->device_request; int ep_addr = endpoint->endpoint_address; @@ -344,11 +343,11 @@ static void spear_udc_setup(struct usb_endpoint_instance *endpoint) endpoint->tx_urb = ep0_urb; endpoint->sent = 0; /* - * Write packet data to the FIFO. spear_write_noniso_tx_fifo + * Write packet data to the FIFO. dw_write_noniso_tx_fifo * will update endpoint->last with the number of bytes written * to the FIFO. */ - spear_write_noniso_tx_fifo(endpoint); + dw_write_noniso_tx_fifo(endpoint);
writel(0x0, &inep_regs_p[ep_addr].write_done); } @@ -361,7 +360,7 @@ static void spear_udc_setup(struct usb_endpoint_instance *endpoint) /* * Handle endpoint 0 RX interrupt */ -static void spear_udc_ep0_rx(struct usb_endpoint_instance *endpoint) +static void dw_udc_ep0_rx(struct usb_endpoint_instance *endpoint) { u8 dummy[64];
@@ -395,7 +394,7 @@ static void spear_udc_ep0_rx(struct usb_endpoint_instance *endpoint) /* * Handle endpoint 0 TX interrupt */ -static void spear_udc_ep0_tx(struct usb_endpoint_instance *endpoint) +static void dw_udc_ep0_tx(struct usb_endpoint_instance *endpoint) { struct usb_device_request *request = &ep0_urb->device_request; int ep_addr; @@ -444,7 +443,7 @@ static void spear_udc_ep0_tx(struct usb_endpoint_instance *endpoint) * need a zero-length terminating packet. */ UDCDBG("ACK control read data stage packet"); - spear_write_noniso_tx_fifo(endpoint); + dw_write_noniso_tx_fifo(endpoint);
ep_addr = endpoint->endpoint_address; writel(0x0, &inep_regs_p[ep_addr].write_done); @@ -452,7 +451,7 @@ static void spear_udc_ep0_tx(struct usb_endpoint_instance *endpoint) } }
-static struct usb_endpoint_instance *spear_find_ep(int ep) +static struct usb_endpoint_instance *dw_find_ep(int ep) { int i;
@@ -469,11 +468,11 @@ static struct usb_endpoint_instance *spear_find_ep(int ep) * The ep argument is a physical endpoint number for a non-ISO IN endpoint * in the range 1 to 15. */ -static void spear_udc_epn_rx(int ep) +static void dw_udc_epn_rx(int ep) { int nbytes = 0; struct urb *urb; - struct usb_endpoint_instance *endpoint = spear_find_ep(ep); + struct usb_endpoint_instance *endpoint = dw_find_ep(ep);
if (endpoint) { urb = endpoint->rcv_urb; @@ -494,9 +493,9 @@ static void spear_udc_epn_rx(int ep) * The ep argument is a physical endpoint number for a non-ISO IN endpoint * in the range 16 to 30. */ -static void spear_udc_epn_tx(int ep) +static void dw_udc_epn_tx(int ep) { - struct usb_endpoint_instance *endpoint = spear_find_ep(ep); + struct usb_endpoint_instance *endpoint = dw_find_ep(ep);
/* * We need to transmit a terminating zero-length packet now if @@ -516,7 +515,7 @@ static void spear_udc_epn_tx(int ep) */ if (endpoint->tx_urb && endpoint->tx_urb->actual_length) { /* write data to FIFO */ - spear_write_noniso_tx_fifo(endpoint); + dw_write_noniso_tx_fifo(endpoint); writel(0x0, &inep_regs_p[ep].write_done);
} else if (endpoint->tx_urb @@ -765,7 +764,7 @@ void udc_startup_events(struct usb_device_instance *device) * DEVICE_HUB_CONFIGURED and DEVICE_RESET events here. * DEVICE_HUB_CONFIGURED causes a transition to the state STATE_POWERED, * and DEVICE_RESET causes a transition to the state STATE_DEFAULT. - * The SPEAr USB client controller has the capability to detect when the + * The DW USB client controller has the capability to detect when the * USB cable is connected to a powered USB bus, so we will defer the * DEVICE_HUB_CONFIGURED and DEVICE_RESET events until later. */ @@ -776,7 +775,7 @@ void udc_startup_events(struct usb_device_instance *device) /* * Plug detection interrupt handling */ -void spear_udc_plug_irq(void) +void dw_udc_plug_irq(void) { if (readl(&plug_regs_p->plug_state) & PLUG_STATUS_ATTACHED) { /* @@ -805,7 +804,7 @@ void spear_udc_plug_irq(void) /* * Device interrupt handling */ -void spear_udc_dev_irq(void) +void dw_udc_dev_irq(void) { if (readl(&udc_regs_p->dev_int) & DEV_INT_USBRESET) { writel(~0x0, &udc_regs_p->endp_int_mask); @@ -870,7 +869,7 @@ void spear_udc_dev_irq(void) /* * Endpoint interrupt handling */ -void spear_udc_endpoint_irq(void) +void dw_udc_endpoint_irq(void) { while (readl(&udc_regs_p->endp_int) & ENDP0_INT_CTRLOUT) {
@@ -878,13 +877,13 @@ void spear_udc_endpoint_irq(void)
if ((readl(&outep_regs_p[0].endp_status) & ENDP_STATUS_OUTMSK) == ENDP_STATUS_OUT_SETUP) { - spear_udc_setup(udc_device->bus->endpoint_array + 0); + dw_udc_setup(udc_device->bus->endpoint_array + 0); writel(ENDP_STATUS_OUT_SETUP, &outep_regs_p[0].endp_status);
} else if ((readl(&outep_regs_p[0].endp_status) & ENDP_STATUS_OUTMSK) == ENDP_STATUS_OUT_DATA) { - spear_udc_ep0_rx(udc_device->bus->endpoint_array + 0); + dw_udc_ep0_rx(udc_device->bus->endpoint_array + 0); writel(ENDP_STATUS_OUT_DATA, &outep_regs_p[0].endp_status);
@@ -897,7 +896,7 @@ void spear_udc_endpoint_irq(void) }
if (readl(&udc_regs_p->endp_int) & ENDP0_INT_CTRLIN) { - spear_udc_ep0_tx(udc_device->bus->endpoint_array + 0); + dw_udc_ep0_tx(udc_device->bus->endpoint_array + 0);
writel(ENDP_STATUS_IN, &inep_regs_p[0].endp_status); writel(ENDP0_INT_CTRLIN, &udc_regs_p->endp_int); @@ -919,7 +918,7 @@ void spear_udc_endpoint_irq(void) if ((readl(&outep_regs_p[epnum].endp_status) & ENDP_STATUS_OUTMSK) == ENDP_STATUS_OUT_DATA) {
- spear_udc_epn_rx(epnum); + dw_udc_epn_rx(epnum); writel(ENDP_STATUS_OUT_DATA, &outep_regs_p[epnum].endp_status); } else if ((readl(&outep_regs_p[epnum].endp_status) & @@ -941,7 +940,7 @@ void spear_udc_endpoint_irq(void) if (readl(&inep_regs_p[epnum].endp_status) & ENDP_STATUS_IN) { writel(ENDP_STATUS_IN, &outep_regs_p[epnum].endp_status); - spear_udc_epn_tx(epnum); + dw_udc_epn_tx(epnum);
writel(ENDP_STATUS_IN, &outep_regs_p[epnum].endp_status); @@ -963,13 +962,13 @@ void udc_irq(void) * host requests. */ while (readl(&plug_regs_p->plug_pending)) - spear_udc_plug_irq(); + dw_udc_plug_irq();
while (readl(&udc_regs_p->dev_int)) - spear_udc_dev_irq(); + dw_udc_dev_irq();
if (readl(&udc_regs_p->endp_int)) - spear_udc_endpoint_irq(); + dw_udc_endpoint_irq(); }
/* Flow control */ diff --git a/include/configs/spear-common.h b/include/configs/spear-common.h index 258574f..3dd6b57 100644 --- a/include/configs/spear-common.h +++ b/include/configs/spear-common.h @@ -28,14 +28,16 @@ */
/* USBD driver configuration */ -#define CONFIG_SPEARUDC +#define CONFIG_DW_UDC #define CONFIG_USB_DEVICE #define CONFIG_USB_TTY
#define CONFIG_USBD_PRODUCT_NAME "SPEAr SoC" #define CONFIG_USBD_MANUFACTURER "ST Microelectronics"
+#if defined(CONFIG_USB_TTY) #define CONFIG_EXTRA_ENV_USBTTY "usbtty=cdc_acm\0" +#endif
/* I2C driver configuration */ #define CONFIG_HARD_I2C diff --git a/include/usb/spr_udc.h b/include/usb/designware_udc.h similarity index 98% rename from include/usb/spr_udc.h rename to include/usb/designware_udc.h index 2c332d5..ae98e8c 100644 --- a/include/usb/spr_udc.h +++ b/include/usb/designware_udc.h @@ -21,8 +21,8 @@ * MA 02111-1307 USA */
-#ifndef __SPR_UDC_H -#define __SPR_UDC_H +#ifndef __DW_UDC_H +#define __DW_UDC_H
/* * Defines for USBD @@ -227,4 +227,4 @@ void udc_startup_events(struct usb_device_instance *device); void udc_setup_ep(struct usb_device_instance *device, unsigned int ep, struct usb_endpoint_instance *endpoint);
-#endif /* __SPR_UDC_H */ +#endif /* __DW_UDC_H */
Dear Amit Virdi,
This patch is just a rename, right?
Acked-by: Marek Vasut marex@denx.de
Best regards, Marek Vasut
Hello Marek,
On 3/5/2012 11:42 PM, Marek Vasut wrote:
Dear Amit Virdi,
Signed-off-by: Vipin Kumarvipin.kumar@st.com Signed-off-by: Amit Virdiamit.virdi@st.com
Yes.
Acked-by: Marek Vasutmarex@denx.de
Thanks n Regards Amit Virdi
This patch fixes a few bugs in USB device controller driver. The fixes are as follows 1. Adding error condition checks eg. NULL return 2. Endpoint other than endpoint 0 (control endpoint) are initialized only if usb state machine reaches STATE_ADDRESSED or above 3. Zero length packet handling corrected 4. Dead code removed 5. Bulk out endpoint returns after servicing 1 interrupt and returns back to service if more interrupts are pending
Signed-off-by: Vipin Kumar vipin.kumar@st.com Signed-off-by: Amit Virdi amit.virdi@st.com --- drivers/usb/gadget/designware_udc.c | 59 ++++++++++++++++++++++------------ 1 files changed, 38 insertions(+), 21 deletions(-)
diff --git a/drivers/usb/gadget/designware_udc.c b/drivers/usb/gadget/designware_udc.c index aee44aa..3c20f3d 100644 --- a/drivers/usb/gadget/designware_udc.c +++ b/drivers/usb/gadget/designware_udc.c @@ -497,16 +497,24 @@ static void dw_udc_epn_tx(int ep) { struct usb_endpoint_instance *endpoint = dw_find_ep(ep);
+ if (!endpoint) + return; + /* * We need to transmit a terminating zero-length packet now if * we have sent all of the data in this URB and the transfer * size was an exact multiple of the packet size. */ - if (endpoint && endpoint->tx_urb && endpoint->tx_urb->actual_length) { - if (endpoint->last == endpoint->tx_packetSize) { - /* handle zero length packet here */ - writel(0x0, &inep_regs_p[ep].write_done); - } + if (endpoint->tx_urb && + (endpoint->last == endpoint->tx_packetSize) && + (endpoint->tx_urb->actual_length - endpoint->sent - + endpoint->last == 0)) { + /* handle zero length packet here */ + writel(0x0, &inep_regs_p[ep].write_done); + + } + + if (endpoint->tx_urb && endpoint->tx_urb->actual_length) { /* retire the data that was just sent */ usbd_tx_complete(endpoint); /* @@ -548,8 +556,6 @@ int udc_init(void)
readl(&plug_regs_p->plug_pending);
- udc_disconnect(); - for (i = 0; i < UDC_INIT_MDELAY; i++) udelay(1000);
@@ -561,10 +567,9 @@ int udc_init(void) writel(~0x0, &udc_regs_p->endp_int_mask);
writel(DEV_CONF_FS_SPEED | DEV_CONF_REMWAKEUP | DEV_CONF_SELFPOW | - /* Dev_Conf_SYNCFRAME | */ DEV_CONF_PHYINT_16, &udc_regs_p->dev_conf);
- writel(0x0, &udc_regs_p->dev_cntl); + writel(DEV_CNTL_SOFTDISCONNECT, &udc_regs_p->dev_cntl);
/* Clear all interrupts pending */ writel(DEV_INT_MSK, &udc_regs_p->dev_int); @@ -588,6 +593,9 @@ void udc_setup_ep(struct usb_device_instance *device, char *tt; u32 endp_intmask;
+ if ((ep != 0) && (udc_device->device_state < STATE_ADDRESSED)) + return; + tt = getenv("usbtty"); if (!tt) tt = "generic"; @@ -647,9 +655,6 @@ void udc_setup_ep(struct usb_device_instance *device, writel(packet_size | ((buffer_size / sizeof(int)) << 16), &out_p->endp_maxpacksize);
- writel((packet_size << 19) | ENDP_EPTYPE_CNTL, - &udc_regs_p->udc_endp_reg[ep_num]); - } else if ((ep_addr & USB_ENDPOINT_DIR_MASK) == USB_DIR_IN) { /* Setup the IN endpoint */ writel(0x0, &in_p->endp_status); @@ -708,7 +713,17 @@ void udc_setup_ep(struct usb_device_instance *device, /* Turn on the USB connection by enabling the pullup resistor */ void udc_connect(void) { - u32 plug_st; + u32 plug_st, dev_cntl; + + dev_cntl = readl(&udc_regs_p->dev_cntl); + dev_cntl |= DEV_CNTL_SOFTDISCONNECT; + writel(dev_cntl, &udc_regs_p->dev_cntl); + + udelay(1000); + + dev_cntl = readl(&udc_regs_p->dev_cntl); + dev_cntl &= ~DEV_CNTL_SOFTDISCONNECT; + writel(dev_cntl, &udc_regs_p->dev_cntl);
plug_st = readl(&plug_regs_p->plug_state); plug_st &= ~(PLUG_STATUS_PHY_RESET | PLUG_STATUS_PHY_MODE); @@ -720,6 +735,8 @@ void udc_disconnect(void) { u32 plug_st;
+ writel(DEV_CNTL_SOFTDISCONNECT, &udc_regs_p->dev_cntl); + plug_st = readl(&plug_regs_p->plug_state); plug_st |= (PLUG_STATUS_PHY_RESET | PLUG_STATUS_PHY_MODE); writel(plug_st, &plug_regs_p->plug_state); @@ -789,11 +806,6 @@ void dw_udc_plug_irq(void) UDCDBG("device attached and powered"); udc_state_transition(udc_device->device_state, STATE_POWERED); } else { - /* - * USB cable detached - * Reset the PHY and switch the mode. - */ - udc_disconnect(); writel(~0x0, &udc_regs_p->dev_int_mask);
UDCDBG("device detached or unpowered"); @@ -809,13 +821,18 @@ void dw_udc_dev_irq(void) if (readl(&udc_regs_p->dev_int) & DEV_INT_USBRESET) { writel(~0x0, &udc_regs_p->endp_int_mask);
- udc_connect(); - writel(readl(&inep_regs_p[0].endp_cntl) | ENDP_CNTL_FLUSH, &inep_regs_p[0].endp_cntl);
writel(DEV_INT_USBRESET, &udc_regs_p->dev_int);
+ /* + * This endpoint0 specific register can be programmed only + * after the phy clock is initialized + */ + writel((EP0_MAX_PACKET_SIZE << 19) | ENDP_EPTYPE_CNTL, + &udc_regs_p->udc_endp_reg[0]); + UDCDBG("device reset in progess"); udc_state_transition(udc_device->device_state, STATE_DEFAULT); } @@ -902,7 +919,7 @@ void dw_udc_endpoint_irq(void) writel(ENDP0_INT_CTRLIN, &udc_regs_p->endp_int); }
- while (readl(&udc_regs_p->endp_int) & ENDP_INT_NONISOOUT_MSK) { + if (readl(&udc_regs_p->endp_int) & ENDP_INT_NONISOOUT_MSK) { u32 epnum = 0; u32 ep_int = readl(&udc_regs_p->endp_int) & ENDP_INT_NONISOOUT_MSK;
Dear Amit Virdi,
- Adding error condition checks eg. NULL return
- Endpoint other than endpoint 0 (control endpoint) are initialized
Ok, I take it you know what you're doing here:
Dear Marek,
On 3/5/2012 11:43 PM, Marek Vasut wrote:
Dear Amit Virdi,
Thanks.
Best Regards Amit Virdi
This patch adds the support for usb device high speed for designware peripheral.
Signed-off-by: Vipin Kumar vipin.kumar@st.com Signed-off-by: Amit Virdi amit.virdi@st.com --- drivers/usb/gadget/designware_udc.c | 13 +++++++++---- include/usb/designware_udc.h | 3 +++ 2 files changed, 12 insertions(+), 4 deletions(-)
diff --git a/drivers/usb/gadget/designware_udc.c b/drivers/usb/gadget/designware_udc.c index 3c20f3d..d4b53a2 100644 --- a/drivers/usb/gadget/designware_udc.c +++ b/drivers/usb/gadget/designware_udc.c @@ -566,7 +566,7 @@ int udc_init(void) writel(~0x0, &udc_regs_p->dev_int_mask); writel(~0x0, &udc_regs_p->endp_int_mask);
- writel(DEV_CONF_FS_SPEED | DEV_CONF_REMWAKEUP | DEV_CONF_SELFPOW | + writel(DEV_CONF_HS_SPEED | DEV_CONF_REMWAKEUP | DEV_CONF_SELFPOW | DEV_CONF_PHYINT_16, &udc_regs_p->dev_conf);
writel(DEV_CNTL_SOFTDISCONNECT, &udc_regs_p->dev_cntl); @@ -577,6 +577,11 @@ int udc_init(void) return 0; }
+int is_usbd_high_speed(void) +{ + return (readl(&udc_regs_p->dev_stat) & DEV_STAT_ENUM) ? 0 : 1; +} + /* * udc_setup_ep - setup endpoint * Associate a physical endpoint with endpoint_instance @@ -792,7 +797,7 @@ void udc_startup_events(struct usb_device_instance *device) /* * Plug detection interrupt handling */ -void dw_udc_plug_irq(void) +static void dw_udc_plug_irq(void) { if (readl(&plug_regs_p->plug_state) & PLUG_STATUS_ATTACHED) { /* @@ -816,7 +821,7 @@ void dw_udc_plug_irq(void) /* * Device interrupt handling */ -void dw_udc_dev_irq(void) +static void dw_udc_dev_irq(void) { if (readl(&udc_regs_p->dev_int) & DEV_INT_USBRESET) { writel(~0x0, &udc_regs_p->endp_int_mask); @@ -886,7 +891,7 @@ void dw_udc_dev_irq(void) /* * Endpoint interrupt handling */ -void dw_udc_endpoint_irq(void) +static void dw_udc_endpoint_irq(void) { while (readl(&udc_regs_p->endp_int) & ENDP0_INT_CTRLOUT) {
diff --git a/include/usb/designware_udc.h b/include/usb/designware_udc.h index ae98e8c..8d48ae9 100644 --- a/include/usb/designware_udc.h +++ b/include/usb/designware_udc.h @@ -197,6 +197,9 @@ struct udcfifo_regs { #define UDC_INT_PACKET_SIZE 64 #define UDC_OUT_ENDPOINT 2 #define UDC_BULK_PACKET_SIZE 64 +#if defined(CONFIG_USBD_HS) +#define UDC_BULK_HS_PACKET_SIZE 512 +#endif #define UDC_IN_ENDPOINT 3 #define UDC_OUT_PACKET_SIZE 64 #define UDC_IN_PACKET_SIZE 64
Dear Amit Virdi,
- writel(DEV_CONF_HS_SPEED | DEV_CONF_REMWAKEUP | DEV_CONF_SELFPOW | DEV_CONF_PHYINT_16, &udc_regs_p->dev_conf);
Won't this break anything?
- return (readl(&udc_regs_p->dev_stat) & DEV_STAT_ENUM) ? 0 : 1;
- udc_setup_ep - setup endpoint
- Associate a physical endpoint with endpoint_instance
- Plug detection interrupt handling
This staticisation stuff should go in a separate patch please.
- Device interrupt handling
- Endpoint interrupt handling
You can define this without the ifdef
Dear Marek,
On 3/5/2012 11:45 PM, Marek Vasut wrote:
Dear Amit Virdi,
diff --git a/drivers/usb/gadget/designware_udc.c b/drivers/usb/gadget/designware_udc.c index 3c20f3d..d4b53a2 100644 --- a/drivers/usb/gadget/designware_udc.c +++ b/drivers/usb/gadget/designware_udc.c @@ -566,7 +566,7 @@ int udc_init(void) writel(~0x0,&udc_regs_p->dev_int_mask); writel(~0x0,&udc_regs_p->endp_int_mask);
- writel(DEV_CONF_HS_SPEED | DEV_CONF_REMWAKEUP | DEV_CONF_SELFPOW | DEV_CONF_PHYINT_16,&udc_regs_p->dev_conf);
You're right. Perhaps, it's better to configure FS only if the FS is configured. I'll amend this part.
writel(DEV_CNTL_SOFTDISCONNECT,&udc_regs_p->dev_cntl); @@ -577,6 +577,11 @@ int udc_init(void) return 0; }
- return (readl(&udc_regs_p->dev_stat)& DEV_STAT_ENUM) ? 0 : 1;
Ok.
{ if (readl(&plug_regs_p->plug_state)& PLUG_STATUS_ATTACHED) { /* @@ -816,7 +821,7 @@ void dw_udc_plug_irq(void) /*
*/ -void dw_udc_dev_irq(void) +static void dw_udc_dev_irq(void) { if (readl(&udc_regs_p->dev_int)& DEV_INT_USBRESET) { writel(~0x0,&udc_regs_p->endp_int_mask); @@ -886,7 +891,7 @@ void dw_udc_dev_irq(void) /*
*/ -void dw_udc_endpoint_irq(void) +static void dw_udc_endpoint_irq(void) { while (readl(&udc_regs_p->endp_int)& ENDP0_INT_CTRLOUT) {
Ok.
Thanks for reviewing.
While receiving packets from FIFO sometimes the buffer provided was nonaligned. Fix this by taking a temporary aligned buffer and then copying the content to nonaligned buffer.
Signed-off-by: Shiraz Hashim shiraz.hashim@st.com Signed-off-by: Amit Virdi amit.virdi@st.com --- drivers/usb/gadget/designware_udc.c | 15 ++++++++++++++- 1 files changed, 14 insertions(+), 1 deletions(-)
diff --git a/drivers/usb/gadget/designware_udc.c b/drivers/usb/gadget/designware_udc.c index d4b53a2..878123c 100644 --- a/drivers/usb/gadget/designware_udc.c +++ b/drivers/usb/gadget/designware_udc.c @@ -202,6 +202,7 @@ static int usbgetpckfromfifo(int epNum, u8 *bufp, u32 len) u32 i, nw, nb; u32 *wrdp; u8 *bytp; + u32 tmp[128];
if (readl(&udc_regs_p->dev_stat) & DEV_STAT_RXFIFO_EMPTY) return -1; @@ -209,7 +210,12 @@ static int usbgetpckfromfifo(int epNum, u8 *bufp, u32 len) nw = len / sizeof(u32); nb = len % sizeof(u32);
- wrdp = (u32 *)bufp; + /* use tmp buf if bufp is not word aligned */ + if ((int)bufp & 0x3) + wrdp = (u32 *)&tmp[0]; + else + wrdp = (u32 *)bufp; + for (i = 0; i < nw; i++) { writel(readl(fifo_ptr), wrdp); wrdp++; @@ -223,6 +229,13 @@ static int usbgetpckfromfifo(int epNum, u8 *bufp, u32 len) } readl(&outep_regs_p[epNum].write_done);
+ /* copy back tmp buffer to bufp if bufp is not word aligned */ + if ((int)bufp & 0x3) { + bytp = (u8 *)&tmp[0]; + for (i = 0; i < len; i++) + bufp[i] = bytp[i]; + } + return 0; }
Dear Amit Virdi,
u32 tmp[128];
- /* use tmp buf if bufp is not word aligned */
- if ((int)bufp & 0x3)
- else
wrdp = (u32 *)bufp;
- for (i = 0; i < nw; i++) { writel(readl(fifo_ptr), wrdp); wrdp++;
- /* copy back tmp buffer to bufp if bufp is not word aligned */
- if ((int)bufp & 0x3) {
bufp[i] = bytp[i];
This addresses EHCI cache problem, that's why you need bounce buffer, right?
This is the patch from Puneet, can you give it a go and tell me if EHCI works for you without 4/4 patch from your series or do you still see issues?
http://permalink.gmane.org/gmane.comp.boot-loaders.u-boot/126447
Thanks in advance!
Dear Marek,
On 3/5/2012 11:51 PM, Marek Vasut wrote:
Dear Amit Virdi,
Signed-off-by: Shiraz Hashimshiraz.hashim@st.com Signed-off-by: Amit Virdiamit.virdi@st.com
u32 tmp[128];
if (readl(&udc_regs_p->dev_stat)& DEV_STAT_RXFIFO_EMPTY) return -1;
- if ((int)bufp& 0x3)
- else
wrdp = (u32 *)bufp;
- for (i = 0; i< nw; i++) { writel(readl(fifo_ptr), wrdp); wrdp++;
- if ((int)bufp& 0x3) {
for (i = 0; i< len; i++)
bufp[i] = bytp[i];
- return 0; }
No. The problem was we were copying data word-by-word to a non-word aligned memory in the USB gadget. So, this is different from the USB host controller issue.
Thanks in advance!
Best regards, Marek Vasut .
Dear Amit Virdi,
Dear Marek,
Dear Amit Virdi,
u32 tmp[128];
return -1;
if ((int)bufp& 0x3)
else
wrdp = (u32 *)bufp;
bufp[i] = bytp[i];
I see ... why isn't buffer aligned by the usb stack then?
Thanks!
Thanks in advance!
u32 tmp[128];
return -1;
if ((int)bufp& 0x3)
else
wrdp = (u32 *)bufp;
bufp[i] = bytp[i];
because it might not be a requirement higher up. i.e. it's dealing with a data byte stream. forcing all higher layers to use 32bit alignment because this host controller requires 32bit alignment in its FIFOs is incorrect. -mike
Dear Marek,
The usb gadget is used by the usbtty so we can receive any number of bytes and, as Mike explains, we cannot force 32-bit alignment.
Thanks Amit Virdi
bufp[i] = bytp[i];
memcpy(bufp, tmp, len) ? -mike
Hey Mike,
bufp[i] = bytp[i];
Yes, memcpy can be used. I'll amend the code.
Thanks Amit Virdi
Hello Remy,
-- 1.7.2.2
Any comment on this patchset?
Thanks Amit Virdi
Dear Amit Virdi,
Hello Remy,
-- 1.7.2.2
Thanks Amit Virdi
I took over after Remy, let's sort this out.
Amit Virdi
Amit Virdi
Mike Frysinger
