[U-Boot] [PATCH v3] riscv: Add Microchip MPFS Icicle board support
This patch adds Microchip MPFS Icicle board support. For now, NS16550 serial driver is only enabled. The Microchip MPFS Icicle defconfig by default builds U-Boot for M-Mode with SMP support.
Signed-off-by: Padmarao Begari padmarao.begari@microchip.com --- Changes in v3 - Fix some typos - Remove CONFIG_DM, CONFIG_DM_SERIAL, CONFIG_BAUDRATE, CONFIG_SYS_NS16550, CONFIG_SYS_TEXT_BASE and CONFIG_NR_DRAM_BANKS from microchip_mpfs_icicle_defconfig - Add config SYS_TEXT_BASE in board kconfig - Imply SYS_NS16550 in BOARD_SPECIFIC_OPTIONS - select BOARD_EARLY_INIT_F in BOARD_SPECIFIC_OPTIONS
Changes in v2 - Fix some typos - Rename target board to TARGET_MICROCHIP_ICICLE - select CONFIG_BOARD_EARLY_INIT_F in BOARD_SPECIFIC_OPTIONS - Remove #ifdef CONFIG_BOARD_EARLY_INIT_F --- arch/riscv/Kconfig | 4 ++ board/microchip/mpfs_icicle/Kconfig | 26 +++++++++++++ board/microchip/mpfs_icicle/MAINTAINERS | 7 ++++ board/microchip/mpfs_icicle/Makefile | 7 ++++ board/microchip/mpfs_icicle/mpfs_icicle.c | 30 +++++++++++++++ configs/microchip_mpfs_icicle_defconfig | 9 +++++ include/configs/microchip_mpfs_icicle.h | 63 +++++++++++++++++++++++++++++++ 7 files changed, 146 insertions(+) create mode 100644 board/microchip/mpfs_icicle/Kconfig create mode 100644 board/microchip/mpfs_icicle/MAINTAINERS create mode 100644 board/microchip/mpfs_icicle/Makefile create mode 100644 board/microchip/mpfs_icicle/mpfs_icicle.c create mode 100644 configs/microchip_mpfs_icicle_defconfig create mode 100644 include/configs/microchip_mpfs_icicle.h
diff --git a/arch/riscv/Kconfig b/arch/riscv/Kconfig index 362f3cd..573d6d6 100644 --- a/arch/riscv/Kconfig +++ b/arch/riscv/Kconfig @@ -11,6 +11,9 @@ choice config TARGET_AX25_AE350 bool "Support ax25-ae350"
+config TARGET_MICROCHIP_ICICLE + bool "Support Microchip PolarFire-SoC Icicle Board" + config TARGET_QEMU_VIRT bool "Support QEMU Virt Board"
@@ -22,6 +25,7 @@ endchoice # board-specific options below source "board/AndesTech/ax25-ae350/Kconfig" source "board/emulation/qemu-riscv/Kconfig" +source "board/microchip/mpfs_icicle/Kconfig" source "board/sifive/fu540/Kconfig"
# platform-specific options below diff --git a/board/microchip/mpfs_icicle/Kconfig b/board/microchip/mpfs_icicle/Kconfig new file mode 100644 index 0000000..bf8e1a1 --- /dev/null +++ b/board/microchip/mpfs_icicle/Kconfig @@ -0,0 +1,26 @@ +if TARGET_MICROCHIP_ICICLE + +config SYS_BOARD + default "mpfs_icicle" + +config SYS_VENDOR + default "microchip" + +config SYS_CPU + default "generic" + +config SYS_CONFIG_NAME + default "microchip_mpfs_icicle" + +config SYS_TEXT_BASE + default 0x80000000 if !RISCV_SMODE + default 0x80200000 if RISCV_SMODE + +config BOARD_SPECIFIC_OPTIONS # dummy + def_bool y + select GENERIC_RISCV + select BOARD_EARLY_INIT_F + imply SMP + imply SYS_NS16550 + +endif diff --git a/board/microchip/mpfs_icicle/MAINTAINERS b/board/microchip/mpfs_icicle/MAINTAINERS new file mode 100644 index 0000000..22f3b97 --- /dev/null +++ b/board/microchip/mpfs_icicle/MAINTAINERS @@ -0,0 +1,7 @@ +Microchip MPFS icicle +M: Padmarao Begari padmarao.begari@microchip.com +M: Cyril Jean cyril.jean@microchip.com +S: Maintained +F: board/microchip/mpfs_icicle/ +F: include/configs/microchip_mpfs_icicle.h +F: configs/microchip_mpfs_icicle_defconfig diff --git a/board/microchip/mpfs_icicle/Makefile b/board/microchip/mpfs_icicle/Makefile new file mode 100644 index 0000000..72b0410 --- /dev/null +++ b/board/microchip/mpfs_icicle/Makefile @@ -0,0 +1,7 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright (C) 2019 Microchip Technology Inc. +# Padmarao Begari padmarao.begari@microchip.com +# + +obj-y += mpfs_icicle.o diff --git a/board/microchip/mpfs_icicle/mpfs_icicle.c b/board/microchip/mpfs_icicle/mpfs_icicle.c new file mode 100644 index 0000000..0ef2431 --- /dev/null +++ b/board/microchip/mpfs_icicle/mpfs_icicle.c @@ -0,0 +1,30 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 Microchip Technology Inc. + * Padmarao Begari padmarao.begari@microchip.com + */ + +#include <common.h> +#include <dm.h> +#include <asm/io.h> + +#define MPFS_SYSREG_SOFT_RESET ((unsigned int *)0x20002088) + +int board_init(void) +{ + /* For now nothing to do here. */ + + return 0; +} + +int board_early_init_f(void) +{ + unsigned int val; + + /* Reset uart peripheral */ + val = readl(MPFS_SYSREG_SOFT_RESET); + val = (val & ~(1u << 5u)); + writel(val, MPFS_SYSREG_SOFT_RESET); + + return 0; +} diff --git a/configs/microchip_mpfs_icicle_defconfig b/configs/microchip_mpfs_icicle_defconfig new file mode 100644 index 0000000..3fa900a --- /dev/null +++ b/configs/microchip_mpfs_icicle_defconfig @@ -0,0 +1,9 @@ +CONFIG_RISCV=y +CONFIG_ARCH_RV64I=y +CONFIG_NR_CPUS=5 +CONFIG_TARGET_MICROCHIP_ICICLE=y +CONFIG_BOOTDELAY=3 +CONFIG_DISTRO_DEFAULTS=y +CONFIG_SYS_PROMPT="RISC-V # " +CONFIG_FIT=y +CONFIG_OF_PRIOR_STAGE=y diff --git a/include/configs/microchip_mpfs_icicle.h b/include/configs/microchip_mpfs_icicle.h new file mode 100644 index 0000000..82c7fbb --- /dev/null +++ b/include/configs/microchip_mpfs_icicle.h @@ -0,0 +1,63 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2019 Microchip Technology Inc. + * Padmarao Begari padmarao.begari@microchip.com + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* + * CPU and Board Configuration Options + */ +#define CONFIG_BOOTP_SEND_HOSTNAME + +/* + * Miscellaneous configurable options + */ +#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ + +/* + * Print Buffer Size + */ +#define CONFIG_SYS_PBSIZE \ + (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) + +/* + * max number of command args + */ +#define CONFIG_SYS_MAXARGS 16 + +/* + * Boot Argument Buffer Size + */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE + +/* + * Size of malloc() pool + * 512kB is suggested, (CONFIG_ENV_SIZE + 128 * 1024) was not enough + */ +#define CONFIG_SYS_MALLOC_LEN (512 << 10) + +/* + * Physical Memory Map + */ +#define PHYS_SDRAM_0 0x80000000 /* SDRAM Bank #1 */ +#define PHYS_SDRAM_0_SIZE 0x40000000 /* 1 GB */ +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_0 + +/* Init Stack Pointer */ +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_SDRAM_BASE + 0x200000) + +#define CONFIG_SYS_LOAD_ADDR 0x80000000 /* SDRAM */ + +/* + * memtest works on DRAM + */ +#define CONFIG_SYS_MEMTEST_START PHYS_SDRAM_0 +#define CONFIG_SYS_MEMTEST_END (PHYS_SDRAM_0 + PHYS_SDRAM_0_SIZE) + +/* When we use RAM as ENV */ +#define CONFIG_ENV_SIZE 0x2000 + +#endif /* __CONFIG_H */
On Mon, May 13, 2019 at 6:52 PM Padmarao Begari padmarao.begari@microchip.com wrote:
Changes in v3
- Fix some typos
Changes in v2
- Fix some typos
Hi Padmarao,
Changes in v3
- Fix some typos
Changes in v2
- Fix some typos
- bool "Support Microchip PolarFire-SoC Icicle Board"
+config SYS_BOARD
- default "mpfs_icicle"
+config SYS_VENDOR
- default "microchip"
+config SYS_CPU
- default "generic"
- default "microchip_mpfs_icicle"
- default 0x80000000 if !RISCV_SMODE
- default 0x80200000 if RISCV_SMODE
- def_bool y
- select GENERIC_RISCV
- imply SMP
- imply SYS_NS16550
- Copyright (C) 2019 Microchip Technology Inc.
- Padmarao Begari padmarao.begari@microchip.com
- /* For now nothing to do here. */
- unsigned int val;
- /* Reset uart peripheral */
- val = readl(MPFS_SYSREG_SOFT_RESET);
- val = (val & ~(1u << 5u));
- writel(val, MPFS_SYSREG_SOFT_RESET);
Your distro boot configuration in microchip_mpfs_icicle.h is incomplete. You will have to include the boot command (config_distro_bootcmd.h), add the mandatory environment variables, and define the boot target devices. See doc/README.distro for details. You may also take a look at include/configs/sifive-fu540.h or include/configs/qemu-riscv.h for examples.
Thanks, Lukas
- CPU and Board Configuration Options
- Miscellaneous configurable options
- Print Buffer Size
- (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16)
- max number of command args
- Boot Argument Buffer Size
- Size of malloc() pool
- 512kB is suggested, (CONFIG_ENV_SIZE + 128 * 1024) was not enough
- Physical Memory Map
- memtest works on DRAM
Hi Lukas,
On Mon, May 20, 2019 at 5:33 PM Auer, Lukas lukas.auer@aisec.fraunhofer.de wrote:
Hi Padmarao,
Changes in v3
- Fix some typos
Changes in v2
- Fix some typos
+config SYS_BOARD
+config SYS_VENDOR
default "microchip"
+config SYS_CPU
default "generic"
def_bool y
imply SMP
imply SYS_NS16550
unsigned int val;
This patch for Microchip MPFS Icicle board only NS16550 serial driver enabled at present, so for that reason i didn't add distro boot configuration. I go through the doc/README.distro and include/configs/sifive-fu540.h or include/configs/qemu-riscv.h. The Sifive and qemu-riscv boot target devices are DHCP, QEMU and VIRTIO.
Thanks and Regards Padmarao
For now, NS16550 serial driverThe microchip mpfs icicle board
Thanks, Lukas
- Print Buffer Size
PHYS_SDRAM_0_SIZE)
Hi Padmarao,
On Mon, 2019-05-27 at 11:13 +0530, Padmarao Begari wrote:
Hi Lukas,
Hi Padmarao,
Changes in v3
- Fix some typos
Changes in v2
- Fix some typos
+config SYS_BOARD
+config SYS_VENDOR
default "microchip"
+config SYS_CPU
default "generic"
def_bool y
imply SMP
imply SYS_NS16550
unsigned int val;
Ok, that makes sense. You may consider removing CONFIG_DISTRO_DEFAULTS from the defconfig.
Thanks, Lukas
For now, NS16550 serial driverThe microchip mpfs icicle board Thanks, Lukas
- Print Buffer Size
Auer, Lukas
Bin Meng
Padmarao Begari
Padmarao Begari
