[U-Boot] [PATCH] arm/km: remove unused code
For some reasons we had an own implementaion of dram_init and dram_init_banksize. This is not needed anymore, use the standard kirkwood functions instead.
Signed-off-by: Holger Brunck holger.brunck@keymile.com cc: Prafulla Wadaskar prafulla@marvell.com cc: Valentin Longchamp valentin.longchamp@keymile.com cc: Gerlando Falauto gerlando.falauto@keymile.com --- board/keymile/km_arm/km_arm.c | 20 -------------------- include/configs/km/keymile-common.h | 1 - 2 files changed, 0 insertions(+), 21 deletions(-)
diff --git a/board/keymile/km_arm/km_arm.c b/board/keymile/km_arm/km_arm.c index ac14a2f..2068b00 100644 --- a/board/keymile/km_arm/km_arm.c +++ b/board/keymile/km_arm/km_arm.c @@ -332,26 +332,6 @@ void board_spi_release_bus(struct spi_slave *slave) kw_gpio_set_value(KM_FLASH_GPIO_PIN, 1); }
-int dram_init(void) -{ - /* dram_init must store complete ramsize in gd->ram_size */ - /* Fix this */ - gd->ram_size = get_ram_size((void *)kw_sdram_bar(0), - kw_sdram_bs(0)); - return 0; -} - -void dram_init_banksize(void) -{ - int i; - - for (i = 0; i < CONFIG_NR_DRAM_BANKS; i++) { - gd->bd->bi_dram[i].start = kw_sdram_bar(i); - gd->bd->bi_dram[i].size = get_ram_size((long *)kw_sdram_bar(i), - kw_sdram_bs(i)); - } -} - #if (defined(CONFIG_KM_PIGGY4_88E6061))
#define PHY_LED_SEL_REG 0x18 diff --git a/include/configs/km/keymile-common.h b/include/configs/km/keymile-common.h index 7ed9958..9983104 100644 --- a/include/configs/km/keymile-common.h +++ b/include/configs/km/keymile-common.h @@ -81,7 +81,6 @@
#define CONFIG_LOADS_ECHO #define CONFIG_SYS_LOADS_BAUD_CHANGE -#define CONFIG_SYS_BOARD_DRAM_INIT /* Used board specific dram_init */
#define CONFIG_I2C_MULTI_BUS #define CONFIG_SYS_MAX_I2C_BUS 1
-----Original Message----- From: Holger Brunck [mailto:holger.brunck@keymile.com] Sent: 09 August 2012 17:08 To: u-boot@lists.denx.de Cc: Holger Brunck; Prafulla Wadaskar; Valentin Longchamp; Gerlando Falauto Subject: [PATCH] arm/km: remove unused code
- /* Fix this */
kw_sdram_bs(0));
- int i;
*)kw_sdram_bar(i),
kw_sdram_bs(i));
Acked-By: Prafulla Wadaskar prafulla@marvell.com
Will pull this patch soon.
Regards... Prafulla . . .
-----Original Message----- From: Prafulla Wadaskar Sent: 13 August 2012 10:20 To: 'Holger Brunck'; u-boot@lists.denx.de Cc: Valentin Longchamp; Gerlando Falauto Subject: RE: [PATCH] arm/km: remove unused code
- /* Fix this */
kw_sdram_bs(0));
- int i;
*)kw_sdram_bar(i),
kw_sdram_bs(i));
Applied to u-boot-marvell.git master branch
Holger Brunck
Prafulla Wadaskar
