[PATCH] bugfix: tpm2_tis_spi: redeclaration compile error
tpm2_tis_spi driver fails to compile with errors like this:
drivers/tpm/tpm_tis.h:117:2: error: redeclaration of enumerator 'TPM_ACCESS_VALID' drivers/tpm/tpm_tis.h:118:2: error: redeclaration of enumerator 'TPM_ACCESS_ACTIVE_LOCALITY' drivers/tpm/tpm_tis.h:119:2: error: redeclaration of enumerator 'TPM_ACCESS_REQUEST_PENDING' drivers/tpm/tpm_tis.h:120:2: error: redeclaration of enumerator 'TPM_ACCESS_REQUEST_USE' drivers/tpm/tpm_tis.h:124:2: error: redeclaration of enumerator 'TPM_STS_VALID' drivers/tpm/tpm_tis.h:125:2: error: redeclaration of enumerator 'TPM_STS_COMMAND_READY' drivers/tpm/tpm_tis.h:126:2: error: redeclaration of enumerator 'TPM_STS_GO' drivers/tpm/tpm_tis.h:127:2: error: redeclaration of enumerator 'TPM_STS_DATA_AVAIL' drivers/tpm/tpm_tis.h:128:2: error: redeclaration of enumerator 'TPM_STS_DATA_EXPECT'
This is due to redeclaration of 9 values in tis_access and tis_status enums from tpm_tis.h. Defines are now declared in include/tpm-v2.h, so removing duplicates from tpm_tis.h.
Signed-off-by: Bruno Thomsen bruno.thomsen@gmail.com --- drivers/tpm/tpm_tis.h | 15 --------------- 1 file changed, 15 deletions(-)
diff --git a/drivers/tpm/tpm_tis.h b/drivers/tpm/tpm_tis.h index 947585f8e3..4043f1aeaf 100644 --- a/drivers/tpm/tpm_tis.h +++ b/drivers/tpm/tpm_tis.h @@ -113,19 +113,4 @@ struct tpm_cmd_t { */ #define MAX_COUNT_LONG 50
-enum tis_access { - TPM_ACCESS_VALID = 0x80, - TPM_ACCESS_ACTIVE_LOCALITY = 0x20, - TPM_ACCESS_REQUEST_PENDING = 0x04, - TPM_ACCESS_REQUEST_USE = 0x02, -}; - -enum tis_status { - TPM_STS_VALID = 0x80, - TPM_STS_COMMAND_READY = 0x40, - TPM_STS_GO = 0x20, - TPM_STS_DATA_AVAIL = 0x10, - TPM_STS_DATA_EXPECT = 0x08, -}; - #endif
base-commit: 04da1cd8076b44ff49a79b7fe048a9e8e56b5f60
Doing it this way however breaks tpm1 support. I've taken a different patch for this issue, thanks!
Bruno Thomsen
