[U-Boot] [PATCH v2] zynq: Use system timer implementation instead of our
Don't use error-prone arch timer code and instead use system timer implementation to simplify our code.
Changes in v2: - Fix commit message - Reported-by: Tom Rini trini@konsulko.com
arch/arm/mach-zynq/include/mach/hardware.h | 1 - arch/arm/mach-zynq/timer.c | 83 +----------------------------- include/configs/zynq-common.h | 5 ++ 3 files changed, 6 insertions(+), 83 deletions(-)
diff --git a/arch/arm/mach-zynq/include/mach/hardware.h b/arch/arm/mach-zynq/include/mach/hardware.h index e2e0b7321ad4..9a51d6ba3b5e 100644 --- a/arch/arm/mach-zynq/include/mach/hardware.h +++ b/arch/arm/mach-zynq/include/mach/hardware.h @@ -12,7 +12,6 @@ #define ZYNQ_SYS_CTRL_BASEADDR 0xF8000000 #define ZYNQ_DEV_CFG_APB_BASEADDR 0xF8007000 #define ZYNQ_SCU_BASEADDR 0xF8F00000 -#define ZYNQ_SCUTIMER_BASEADDR 0xF8F00600 #define ZYNQ_GEM_BASEADDR0 0xE000B000 #define ZYNQ_GEM_BASEADDR1 0xE000C000 #define ZYNQ_SDHCI_BASEADDR0 0xE0100000 diff --git a/arch/arm/mach-zynq/timer.c b/arch/arm/mach-zynq/timer.c index 5ed9642df9b3..8ff82dc9306e 100644 --- a/arch/arm/mach-zynq/timer.c +++ b/arch/arm/mach-zynq/timer.c @@ -78,91 +78,10 @@ int timer_init(void) }
/* - * This function is derived from PowerPC code (read timebase as long long). - * On ARM it just returns the timer value. - */ -ulong get_timer_masked(void) -{ - ulong now; - - now = readl(&timer_base->counter) / - (gd->arch.timer_rate_hz / CONFIG_SYS_HZ); - - if (gd->arch.lastinc >= now) { - /* Normal mode */ - gd->arch.tbl += gd->arch.lastinc - now; - } else { - /* We have an overflow ... */ - gd->arch.tbl += gd->arch.lastinc + (TIMER_LOAD_VAL / - (gd->arch.timer_rate_hz / CONFIG_SYS_HZ)) - - now + 1; - } - gd->arch.lastinc = now; - - return gd->arch.tbl; -} - -void __udelay(unsigned long usec) -{ - u32 countticks; - u32 timeend; - u32 timediff; - u32 timenow; - - if (usec == 0) - return; - - countticks = lldiv(((unsigned long long)gd->arch.timer_rate_hz * usec), - 1000000); - - /* decrementing timer */ - timeend = readl(&timer_base->counter) - countticks; - -#if TIMER_LOAD_VAL != 0xFFFFFFFF - /* do not manage multiple overflow */ - if (countticks >= TIMER_LOAD_VAL) - countticks = TIMER_LOAD_VAL - 1; -#endif - - do { - timenow = readl(&timer_base->counter); - - if (timenow >= timeend) { - /* normal case */ - timediff = timenow - timeend; - } else { - if ((TIMER_LOAD_VAL - timeend + timenow) <= - countticks) { - /* overflow */ - timediff = TIMER_LOAD_VAL - timeend + timenow; - } else { - /* missed the exact match */ - break; - } - } - } while (timediff > 0); -} - -/* Timer without interrupts */ -ulong get_timer(ulong base) -{ - return get_timer_masked() - base; -} - -/* - * This function is derived from PowerPC code (read timebase as long long). - * On ARM it just returns the timer value. - */ -unsigned long long get_ticks(void) -{ - return get_timer(0); -} - -/* * This function is derived from PowerPC code (timebase clock frequency). * On ARM it returns the number of timer ticks per second. */ ulong get_tbclk(void) { - return CONFIG_SYS_HZ; + return gd->arch.timer_rate_hz; } diff --git a/include/configs/zynq-common.h b/include/configs/zynq-common.h index b83e037f6f59..5297e6bcc8ff 100644 --- a/include/configs/zynq-common.h +++ b/include/configs/zynq-common.h @@ -25,6 +25,11 @@ # define CONFIG_SYS_PL310_BASE 0xf8f02000 #endif
+#define ZYNQ_SCUTIMER_BASEADDR 0xF8F00600 +#define CONFIG_SYS_TIMERBASE ZYNQ_SCUTIMER_BASEADDR +#define CONFIG_SYS_TIMER_COUNTS_DOWN +#define CONFIG_SYS_TIMER_COUNTER (CONFIG_SYS_TIMERBASE + 0x4) + /* Serial drivers */ #define CONFIG_BAUDRATE 115200 /* The following table includes the supported baudrates */
Michal Simek
