[RESEND PATCH] rockchip: add description for TPL_ROCKCHIP_COMMON_BOARD
SPL_ROCKCHIP_COMMON_BOARD, an almost identical option, has a title but this one doesn't for some reason. Add a description to make the menu easier to read.
Signed-off-by: Thomas Hebb tommyhebb@gmail.com ---
arch/arm/mach-rockchip/Kconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/mach-rockchip/Kconfig b/arch/arm/mach-rockchip/Kconfig index d8d68ba447..b689a420bd 100644 --- a/arch/arm/mach-rockchip/Kconfig +++ b/arch/arm/mach-rockchip/Kconfig @@ -306,7 +306,7 @@ config SPL_ROCKCHIP_COMMON_BOARD no TPL for the board.
config TPL_ROCKCHIP_COMMON_BOARD - bool "" + bool "Rockchip TPL common board file" depends on TPL help Rockchip SoCs have similar boot process, prefer to use TPL for DRAM
Hi Thomas,
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
- bool ""
- bool "Rockchip TPL common board file" depends on TPL help Rockchip SoCs have similar boot process, prefer to use TPL for DRAM
Kever Yang
Thomas Hebb
