[U-Boot] [PULL] : Please pull u-boot-imx
Hi Albert,
this contains the fix for the i.MX6 errata. I do not foresee now to send another PR before release, maybe this is the last one for 2014.04.
The following changes since commit 1a9df13d5bc0b68c9dcae88d244c995c9351db67:
arm: mxs: Add support for generating signed BootStream (2014-04-04 11:44:59 +0200)
git://www.denx.de/git/u-boot-imx.git master
for you to fetch changes up to 68659d649debc9fb3d8ce21ce4dcfe3a66b63e3a:
MX6: Enable ARM errata workaround 794072 and 761320 (2014-04-07 18:11:01 +0200)
---------------------------------------------------------------- Nitin Garg (3): ARM: Add workaround for Cortex-A9 errata 794072 ARM: Add workaround for Cortex-A9 errata 761320 MX6: Enable ARM errata workaround 794072 and 761320
README | 2 ++ arch/arm/cpu/armv7/start.S | 7 ++++++- include/configs/mx6_common.h | 2 ++ 3 files changed, 10 insertions(+), 1 deletion(-)
Best regards, Stefano
Hi Stefano,
On Mon, 07 Apr 2014 18:20:36 +0200, Stefano Babic sbabic@denx.de wrote:
Hi Albert,
Applied to u-boot-arm/master, thanks!
Amicalement,
Albert ARIBAUD
Stefano Babic
