Re: [U-Boot] ahci: Fix cache align error messages
Hi Eli,
On 04/01/2014 04:09 PM, Eli Nidam wrote:
Hi Roger,
In u-boot I tried to run twice the command “scsi init” and on the second time it’s hung,, after debug I found the patch ahci: Fix cache align error messages replace the malloc with ALLOC_CACHE_ALIGN_BUFFER. And remove the line free(tmpid);
- One more free should be remove in line 653 “free(ataid[port]);” This is why the second scsi init is hung.
- Actually I revert this patch because the ALLOC_CACHE_ALIGN_BUFFER is use the buffer from stack and the ataid[] is used from other routine.
You are right. My patch is all messed up and better to revert it, sorry.
Do you still get the below messages after the revert?
ERROR: v7_dcache_inval_range - start address is not aligned - 0xfee46648 ERROR: v7_dcache_inval_range - stop address is not aligned - 0xfee46848
cheers, -roger
Please let me if I wrong.
Thanks
Eli Nidam Marvell Israel – SW Engineer 6 Hamada Street Mordot HaCarmel Industrial Park Yokneam, 20692, Israel Email: elini@marvell.com Office: +972.4.9091167 - OnNet: 704.1xxx Fax: +972.4.9091501 Mobile: +972.54.2490706 Web site: http://www.marvell.com
This message may contain confidential, proprietary or legally privileged information. The information is intended only for the use of the individual or entity named above. If the reader of this message is not the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us immediately by telephone or by e-mail and delete the message from your computer.
Hi Roger,
I used the definition CONFIG_SYS_DCACHE_OFF (in our u-boot the cache is off)
For this reason I didn't get this message.
Thanks
Eli
-----Original Message----- From: Roger Quadros [mailto:rogerq@ti.com] Sent: Tuesday, April 01, 2014 4:41 PM To: Eli Nidam; Rini, Tom Cc: aneesh@ti.com; morpheus.ibis@gmail.com; Omri Itach; U-Boot-Denx Subject: Re: ahci: Fix cache align error messages
Hi Eli,
Hi Roger,
In u-boot I tried to run twice the command "scsi init" and on the second time it's hung,, after debug I found the patch ahci: Fix cache align error messages replace the malloc with ALLOC_CACHE_ALIGN_BUFFER. And remove the line free(tmpid);
- One more free should be remove in line 653 "free(ataid[port]);" This is why the second scsi init is hung.
cheers, -roger
Thanks
Eli Nidam Marvell Israel - SW Engineer 6 Hamada Street Mordot HaCarmel Industrial Park Yokneam, 20692, Israel Email: elini@marvell.com Office: +972.4.9091167 - OnNet: 704.1xxx Fax: +972.4.9091501 Mobile: +972.54.2490706 Web site: http://www.marvell.com
Eli Nidam
Roger Quadros
