[PATCH v3] ARM: imx: verdin-imx8mm: Set CAN oscillator frequency based on model
The older i.MX8M Mini Verdin SoMs may came with 20 MHz SPI CAN controller oscillator, the newer SoMs always use 40 MHz oscillator. Handle both by overriding the oscillator frequency just before booting the kernel.
These are the known variants with 20 MHz oscillator: - 0055, V1.1A, V1.1B, V1.1C and V1.1D, use a 20MHz oscillator - 0059, V1.1A and V1.1B, use a 20MHz oscillator
Signed-off-by: Marek Vasut marex@denx.de --- Cc: "NXP i.MX U-Boot Team" uboot-imx@nxp.com Cc: Fabio Estevam festevam@gmail.com Cc: Francesco Dolcini francesco.dolcini@toradex.com Cc: Marcel Ziswiler marcel.ziswiler@toradex.com Cc: Martyn Welch martyn.welch@collabora.com Cc: Stefano Babic sbabic@denx.de Cc: u-boot@lists.denx.de --- V2: - Update the comment in conditional statement - Update ver_assembly check for 0055 rev.A/B/C/D V3: - Update code comment per upstream feedback --- board/toradex/verdin-imx8mm/verdin-imx8mm.c | 29 +++++++++++++++++++++ 1 file changed, 29 insertions(+)
diff --git a/board/toradex/verdin-imx8mm/verdin-imx8mm.c b/board/toradex/verdin-imx8mm/verdin-imx8mm.c index 55c02653da6..59cc28f652f 100644 --- a/board/toradex/verdin-imx8mm/verdin-imx8mm.c +++ b/board/toradex/verdin-imx8mm/verdin-imx8mm.c @@ -125,6 +125,35 @@ int board_phys_sdram_size(phys_size_t *size) #if defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP) int ft_board_setup(void *blob, struct bd_info *bd) { + const char *canoscpath = "/oscillator"; + int freq = 40000000; /* 40 MHz is used on most variants */ + int canoscoff, ret; + + canoscoff = fdt_path_offset(blob, canoscpath); + if (canoscoff < 0) /* No CAN oscillator found. */ + goto exit; + + /* + * The following "prodid" (PID4 in Toradex naming) use + * a 20MHz CAN oscillator: + * - 0055, V1.1A, V1.1B, V1.1C and V1.1D + * - 0059, V1.1A and V1.1B + */ + if ((tdx_hw_tag.ver_major == 1 && tdx_hw_tag.ver_minor == 1) && + ((tdx_hw_tag.prodid == VERDIN_IMX8MMQ_IT && + tdx_hw_tag.ver_assembly <= 1) || /* 0059 rev. A or B */ + (tdx_hw_tag.prodid == VERDIN_IMX8MMQ_WIFI_BT_IT && + tdx_hw_tag.ver_assembly <= 3))) { /* 0055 rev. A/B/C/D */ + freq = 20000000; + } + + ret = fdt_setprop_u32(blob, canoscoff, "clock-frequency", freq); + if (ret < 0) { + printf("Failed to set CAN oscillator clock-frequency, ret=%d\n", + ret); + } + +exit: return ft_common_board_setup(blob, bd); } #endif
Hello Marek, thank for taking care of this.
Reviewed-by: Francesco Dolcini francesco.dolcini@toradex.com
Francesco
Applied, thanks.
Fabio Estevam
Francesco Dolcini
