[PATCH] arm: davinci: remove unused defines
The last usage of the DV_TIMER_ and DV_WDT_ definitions were removed in commits 8d7757637138 ("ARM: davinci: remove support for cam_enc_4xx") and cef443c1666c ("arm: davinci: remove leftover code for dm* SoCs"), respectively.
Signed-off-by: Emil Kronborg emil.kronborg@protonmail.com --- arch/arm/mach-davinci/include/mach/timer_defs.h | 16 ---------------- 1 file changed, 16 deletions(-)
diff --git a/arch/arm/mach-davinci/include/mach/timer_defs.h b/arch/arm/mach-davinci/include/mach/timer_defs.h index 110e67e454ce..38188dc699cf 100644 --- a/arch/arm/mach-davinci/include/mach/timer_defs.h +++ b/arch/arm/mach-davinci/include/mach/timer_defs.h @@ -20,22 +20,6 @@ struct davinci_timer { u_int32_t wdtcr; };
-#define DV_TIMER_TCR_ENAMODE_MASK 3 - -#define DV_TIMER_TCR_ENAMODE12_SHIFT 6 -#define DV_TIMER_TCR_CLKSRC12_SHIFT 8 -#define DV_TIMER_TCR_READRSTMODE12_SHIFT 10 -#define DV_TIMER_TCR_CAPMODE12_SHIFT 11 -#define DV_TIMER_TCR_CAPVTMODE12_SHIFT 12 -#define DV_TIMER_TCR_ENAMODE34_SHIFT 22 -#define DV_TIMER_TCR_CLKSRC34_SHIFT 24 -#define DV_TIMER_TCR_READRSTMODE34_SHIFT 26 -#define DV_TIMER_TCR_CAPMODE34_SHIFT 27 -#define DV_TIMER_TCR_CAPEVTMODE12_SHIFT 28 - -#define DV_WDT_ENABLE_SYS_RESET 0x00020000 -#define DV_WDT_TRIGGER_SYS_RESET 0x00020002 - #ifdef CONFIG_HW_WATCHDOG void davinci_hw_watchdog_enable(void); void davinci_hw_watchdog_reset(void);
base-commit: 01a5d7547ed3a51a8ac5837c31a150f85bc475f8
Thanks, Stefan
Viele Grüße, Stefan Roese
Emil Kronborg
Stefan Roese
