[U-Boot] [PATCH RESEND 0/4] Add CONFIG_SPL_NAND_IDENT
RESEND because adding U-Boot NAND maintainer (Scott Wood) on Cc.
When adding SPL support to a custom i.MX6ULL board with Toshiba TC58NVG0S3 NAND chip the MXS NAND SPL loader failed with "Failed to identify". This reason is that the SPL MXS NAND driver only supports ONFi-compliant NAND chips and the mentioned Toshiba NAND chip is non-ONFi.
This patch set makes `nand_get_flash_type()` from `nand_base.c` public, so it can be used by any SPL NAND driver, introduced a new config option `CONFIG_SPL_NAND_IDENT` to enable the lookup for supported NAND chips in the chip ID list. Finally, the MXS NAND SPL driver is refactored so that the original ONFi-only identification routine is enabled by default. For non-ONFi NAND chips the newly introduced config option can be used.
In my setup the binary size of `u-boot-spl.bin` is increased by about 13 kB when `CONFIG_SPL_NAND_IDENT` is enabled. As the i.MX6, as well as the i.MX28, both have an OCRAM of 128 kB the increase in the binary size is reasonable.
Jörg Krause (4): mtd: nand: export nand_get_flash_type function spl, nand: add option CONFIG_SPL_NAND_IDENT to lookup for supported NAND chips mtd: nand: mxs_nand_spl: refactor mxs_flash_ident mtd: nand: mxs_nand_spl: add mxs_flash_full_ident
README | 4 ++++ drivers/mtd/nand/Makefile | 1 + drivers/mtd/nand/mxs_nand_spl.c | 37 ++++++++++++++++++++++++++++++++++++- drivers/mtd/nand/nand_base.c | 3 ++- include/linux/mtd/rawnand.h | 10 +++++++--- scripts/config_whitelist.txt | 1 + 6 files changed, 51 insertions(+), 5 deletions(-)
`nand_get_flash_type()` allows identification of supported NAND flashs. The function is useful in SPL (like mxs_nand_spl.c) to lookup for a NAND flash (which does not support ONFi) instead of using nand_simple.c and hard-coding all required NAND parameters.
Signed-off-by: Jörg Krause joerg.krause@embedded.rocks --- drivers/mtd/nand/nand_base.c | 3 ++- include/linux/mtd/rawnand.h | 10 +++++++--- 2 files changed, 9 insertions(+), 4 deletions(-)
diff --git a/drivers/mtd/nand/nand_base.c b/drivers/mtd/nand/nand_base.c index eb9f121f81..64e4621aaa 100644 --- a/drivers/mtd/nand/nand_base.c +++ b/drivers/mtd/nand/nand_base.c @@ -3755,7 +3755,7 @@ static bool find_full_id_nand(struct mtd_info *mtd, struct nand_chip *chip, /* * Get the flash and manufacturer id and lookup if the type is supported. */ -static struct nand_flash_dev *nand_get_flash_type(struct mtd_info *mtd, +struct nand_flash_dev *nand_get_flash_type(struct mtd_info *mtd, struct nand_chip *chip, int *maf_id, int *dev_id, struct nand_flash_dev *type) @@ -3927,6 +3927,7 @@ ident_done: mtd->erasesize >> 10, mtd->writesize, mtd->oobsize); return type; } +EXPORT_SYMBOL(nand_get_flash_type);
#if CONFIG_IS_ENABLED(OF_CONTROL) DECLARE_GLOBAL_DATA_PTR; diff --git a/include/linux/mtd/rawnand.h b/include/linux/mtd/rawnand.h index 6c3e838d80..3871379fb1 100644 --- a/include/linux/mtd/rawnand.h +++ b/include/linux/mtd/rawnand.h @@ -23,9 +23,16 @@ #include <asm/cache.h>
struct mtd_info; +struct nand_chip; struct nand_flash_dev; struct device_node;
+/* Get the flash and manufacturer id and lookup if the type is supported. */ +struct nand_flash_dev *nand_get_flash_type(struct mtd_info *mtd, + struct nand_chip *chip, + int *maf_id, int *dev_id, + struct nand_flash_dev *type); + /* Scan and identify a NAND device */ int nand_scan(struct mtd_info *mtd, int max_chips); /* @@ -248,9 +255,6 @@ typedef enum { #define NAND_CI_CELLTYPE_MSK 0x0C #define NAND_CI_CELLTYPE_SHIFT 2
-/* Keep gcc happy */ -struct nand_chip; - /* ONFI features */ #define ONFI_FEATURE_16_BIT_BUS (1 << 0) #define ONFI_FEATURE_EXT_PARAM_PAGE (1 << 7)
Add the config option `CONFIG_SPL_NAND_IDENT` for using the NAND chip ID list to identify the NAND flash in SPL.
Signed-off-by: Jörg Krause joerg.krause@embedded.rocks --- README | 4 ++++ drivers/mtd/nand/Makefile | 1 + scripts/config_whitelist.txt | 1 + 3 files changed, 6 insertions(+)
diff --git a/README b/README index 06f3ed057d..9ca5086097 100644 --- a/README +++ b/README @@ -2786,6 +2786,10 @@ FIT uImage format: CONFIG_SPL_NAND_DRIVERS SPL uses normal NAND drivers, not minimal drivers.
+ CONFIG_SPL_NAND_IDENT + SPL uses the chip ID list to identify the NAND flash. + Requires CONFIG_SPL_NAND_BASE. + CONFIG_SPL_NAND_ECC Include standard software ECC in the SPL
diff --git a/drivers/mtd/nand/Makefile b/drivers/mtd/nand/Makefile index 9f7d9d6ff7..4ed4afde10 100644 --- a/drivers/mtd/nand/Makefile +++ b/drivers/mtd/nand/Makefile @@ -17,6 +17,7 @@ obj-$(CONFIG_SPL_NAND_SIMPLE) += nand_spl_simple.o obj-$(CONFIG_SPL_NAND_LOAD) += nand_spl_load.o obj-$(CONFIG_SPL_NAND_ECC) += nand_ecc.o obj-$(CONFIG_SPL_NAND_BASE) += nand_base.o +obj-$(CONFIG_SPL_NAND_IDENT) += nand_ids.o nand_timings.o obj-$(CONFIG_SPL_NAND_INIT) += nand.o ifeq ($(CONFIG_SPL_ENV_SUPPORT),y) obj-$(CONFIG_ENV_IS_IN_NAND) += nand_util.o diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 4e87d66bea..b01d196f5a 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -2092,6 +2092,7 @@ CONFIG_SPL_NAND_BASE CONFIG_SPL_NAND_BOOT CONFIG_SPL_NAND_DRIVERS CONFIG_SPL_NAND_ECC +CONFIG_SPL_NAND_IDENT CONFIG_SPL_NAND_INIT CONFIG_SPL_NAND_LOAD CONFIG_SPL_NAND_MINIMAL
The existing `mxs_flash_ident()` is limited to identify ONFi compliant NAND chips only. In order to support non-ONFi NAND chips refactor the function and rename it to `mxs_flash_onfi_ident()`.
A follow-up patch will add `mxs_flash_full_ident()` which allows to use the chip ID list to lookup for supported NAND flashs.
Signed-off-by: Jörg Krause joerg.krause@embedded.rocks --- drivers/mtd/nand/mxs_nand_spl.c | 9 ++++++++- 1 file changed, 8 insertions(+), 1 deletion(-)
diff --git a/drivers/mtd/nand/mxs_nand_spl.c b/drivers/mtd/nand/mxs_nand_spl.c index 910f76dd9d..11d8503127 100644 --- a/drivers/mtd/nand/mxs_nand_spl.c +++ b/drivers/mtd/nand/mxs_nand_spl.c @@ -49,7 +49,7 @@ static void mxs_nand_command(struct mtd_info *mtd, unsigned int command, } }
-static int mxs_flash_ident(struct mtd_info *mtd) +static int mxs_flash_onfi_ident(struct mtd_info *mtd) { register struct nand_chip *chip = mtd_to_nand(mtd); int i; @@ -109,6 +109,13 @@ static int mxs_flash_ident(struct mtd_info *mtd) return 0; }
+static int mxs_flash_ident(struct mtd_info *mtd) +{ + int ret; + ret = mxs_flash_onfi_ident(mtd); + return ret; +} + static int mxs_read_page_ecc(struct mtd_info *mtd, void *buf, unsigned int page) { register struct nand_chip *chip = mtd_to_nand(mtd);
For now, the existing SPL MXS NAND driver only supports to identify ONFi-compliant NAND chips. In order to allow identifying non-ONFi-compliant chips add `mxs_flash_full_ident()` which uses the `nand_get_flash_type()` functionality from `nand_base.c` to lookup for supported NAND chips in the chip ID list.
For compatibility reason the full identification support is only available if the config option `CONFIG_SPL_NAND_IDENT` is enabled.
The lookup was tested on a custom i.MX6ULL board with a Toshiba TC58NVG1S3HTAI0 NAND chip.
Signed-off-by: Jörg Krause joerg.krause@embedded.rocks --- drivers/mtd/nand/mxs_nand_spl.c | 28 ++++++++++++++++++++++++++++ 1 file changed, 28 insertions(+)
diff --git a/drivers/mtd/nand/mxs_nand_spl.c b/drivers/mtd/nand/mxs_nand_spl.c index 11d8503127..0c56d9ffc3 100644 --- a/drivers/mtd/nand/mxs_nand_spl.c +++ b/drivers/mtd/nand/mxs_nand_spl.c @@ -49,6 +49,28 @@ static void mxs_nand_command(struct mtd_info *mtd, unsigned int command, } }
+#if defined (CONFIG_SPL_NAND_IDENT) + +/* Trying to detect the NAND flash using ONFi, JEDEC, and (extended) IDs */ +static int mxs_flash_full_ident(struct mtd_info *mtd) +{ + int nand_maf_id, nand_dev_id; + struct nand_chip *chip = mtd_to_nand(mtd); + struct nand_flash_dev *type; + + type = nand_get_flash_type(mtd, chip, &nand_maf_id, &nand_dev_id, NULL); + + if (IS_ERR(type)) { + chip->select_chip(mtd, -1); + return PTR_ERR(type); + } + + return 0; +} + +#else + +/* Trying to detect the NAND flash using ONFi only */ static int mxs_flash_onfi_ident(struct mtd_info *mtd) { register struct nand_chip *chip = mtd_to_nand(mtd); @@ -109,10 +131,16 @@ static int mxs_flash_onfi_ident(struct mtd_info *mtd) return 0; }
+#endif /* CONFIG_SPL_NAND_IDENT */ + static int mxs_flash_ident(struct mtd_info *mtd) { int ret; +#if defined (CONFIG_SPL_NAND_IDENT) + ret = mxs_flash_full_ident(mtd); +#else ret = mxs_flash_onfi_ident(mtd); +#endif return ret; }
this patch series propably felt off the radar?
Best regards, Jörg Krause
Hi Jörg,
I guess yes, but I doubt we can apply the series again. I guess you should at least rebase it.
Regards, Stefano
Hi Stefano,
On Wed, 2018-06-27 at 09:43 +0200, Stefano Babic wrote:
Hi Jörg,
No problem!
I've applied the series without any conflicts on the master branch. Looks like nothing has changed in the mxs nand driver...
Regards, Stefano
Hi Jörg,
On 27/06/2018 11:51, Jörg Krause wrote:
Hi Stefano,
Hi Jörg,
No problem!
There are some changes - I have applied Stefan's patches according to the discussion with Tom:
https://patchwork.ozlabs.org/patch/897270/
But I have applied your patches on top of my u-boot-imx (with Stefan's), no conflict at all. I guess it is ok if I merged yours into u-boot-imx as I did for Stefan's.
Best regards, Stefano Babic
Regards, Stefano
Jörg Krause
Stefano Babic
