[U-Boot] Pull request for UEFI system for v2019.04-rc5
The following changes since commit a00d15757d7a513e410f15f2f910cb52333361a3:
Merge git://git.denx.de/u-boot-marvell (2019-03-19 19:58:48 -0400)
git://git.denx.de/u-boot-efi.git tags/efi-2019-04-rc5
for you to fetch changes up to d0bd87612f410a723d5ddb3001e805485e3efb4f:
efi_selftest: fix test_hii_string_get_string() (2019-03-20 18:16:53 +0100)
Primary key fingerprint: 6DC4 F9C7 1F29 A6FA 06B7 6D33 C481 DBBC 2C05 1AC4
Travis CI: https://travis-ci.org/xypron2/u-boot/builds/509045246
---------------------------------------------------------------- Pull request for UEFI system for v2019.04-rc5
A bunch of small fixes. The major ones being
- avoid illegal memory access in efi_allocate_pool() on 32 bit systems - avoid endless loop in HII protocol
---------------------------------------------------------------- Heinrich Schuchardt (7): efi_loader: correct parameter size in efi_allocate_pool efi_loader: endless loop in add_strings_package() efi_loader: missing return in efi_get_next_variable_name() efi_loader: memory leak in efi_dump_single_var() efi_loader: remove superfluous check in efi_setup_loaded_image() efi_loader: superfluous conversion in efi_file_open() efi_selftest: fix test_hii_string_get_string()
cmd/nvedit_efi.c | 1 - lib/efi_loader/efi_boottime.c | 6 ++---- lib/efi_loader/efi_file.c | 2 +- lib/efi_loader/efi_hii.c | 5 ++--- lib/efi_loader/efi_memory.c | 5 +++-- lib/efi_loader/efi_variable.c | 2 +- lib/efi_selftest/efi_selftest_hii.c | 17 ++++------------- 7 files changed, 13 insertions(+), 25 deletions(-)
