[U-Boot] [PATCH v2] usb: eth: asix88179: add ability to modify MAC address
This patch enables U-Boot to modify the MAC address of the AX88179. Tested on RECS5250 (similar to Arndale5250)
Signed-off-by: Rene Griessl rgriessl@cit-ec.uni-bielefeld.de ---
Changes for v2: - removed memcpy
drivers/usb/eth/asix88179.c | 14 ++++++++++++++ 1 file changed, 14 insertions(+)
diff --git a/drivers/usb/eth/asix88179.c b/drivers/usb/eth/asix88179.c index b8ca720..0ef85db 100644 --- a/drivers/usb/eth/asix88179.c +++ b/drivers/usb/eth/asix88179.c @@ -271,6 +271,19 @@ static int asix_read_mac(struct eth_device *eth) return 0; }
+static int asix_write_mac(struct eth_device *eth) +{ + struct ueth_data *dev = (struct ueth_data *)eth->priv; + int ret; + + ret = asix_write_cmd(dev, AX_ACCESS_MAC, AX_NODE_ID, ETH_ALEN, + ETH_ALEN, eth->enetaddr); + if (ret < 0) + debug("Failed to set MAC address: %02x\n", ret); + + return ret; +} + static int asix_basic_reset(struct ueth_data *dev) { struct asix_private *dev_priv = (struct asix_private *)dev->dev_priv; @@ -686,6 +699,7 @@ int ax88179_eth_get_info(struct usb_device *dev, struct ueth_data *ss, eth->send = asix_send; eth->recv = asix_recv; eth->halt = asix_halt; + eth->write_hwaddr = asix_write_mac; eth->priv = ss;
if (asix_basic_reset(ss))
Changes for v2:
- removed memcpy
Hi!
what was the reason for the memcpy() in the first place please ?
Otherwise,
Best regards, Marek Vasut
Am 12.01.2015 um 17:54 schrieb Marek Vasut:
Changes for v2:
- removed memcpy
Hi!
I copied the function from the asix.c driver. There it is needed for the cache aligned buffer. But in this case the alignment is already implemented in the write function. So you were right, it is not needed here!
Otherwise,
Changes for v2:
- removed memcpy
Hi!
OK, thanks!
Applied to u-boot-usb/next , thanks!
Changes for v2:
- removed memcpy
Hi!
OK, thanks!
Looks good... Thanks, guys!
-Joe
Joe Hershberger
Rene Griessl
René Griessl
