[PATCH] arm: mach-k3: Refactor QoS settings
Refactor common QoS code into a new common header file, and the soc specific setup_qos functions into a common API.
Rename $(soc)_qos_count and $(soc)_qos_data variables to qos_count and qos_data. When QoS settings of more SoCs are added, only one pair will be defined at a time, based on the config SOC_K3_$(soc).
This refactoring has been done for 2 major purposes.
- The auto-generated $(soc)_qos_data.c and $(soc)_qos.h files cannot have any code that is specific to any bootloader. Those files have to remain agnostic of different bootloader implementations and their header files.
- The existing implementation was less than ideal and would have enabled multiple $(soc)_qos_count and $(soc)_qos_data variables for all SoC variants.
Signed-off-by: Aradhya Bhatia a-bhatia1@ti.com --- arch/arm/mach-k3/Kconfig | 8 +++++++ arch/arm/mach-k3/am62a7_init.c | 14 ------------ arch/arm/mach-k3/common.c | 12 ++++++++++ arch/arm/mach-k3/common.h | 8 +++++++ arch/arm/mach-k3/include/mach/hardware.h | 9 -------- arch/arm/mach-k3/include/mach/k3-qos.h | 22 +++++++++++++++++++ arch/arm/mach-k3/r5/am62ax/Makefile | 2 +- .../{include/mach => r5/am62ax}/am62a_qos.h | 0 .../{am62a_qos_data.c => am62a_qos_uboot.c} | 9 ++++---- 9 files changed, 56 insertions(+), 28 deletions(-) create mode 100644 arch/arm/mach-k3/include/mach/k3-qos.h rename arch/arm/mach-k3/{include/mach => r5/am62ax}/am62a_qos.h (100%) rename arch/arm/mach-k3/r5/am62ax/{am62a_qos_data.c => am62a_qos_uboot.c} (85%)
diff --git a/arch/arm/mach-k3/Kconfig b/arch/arm/mach-k3/Kconfig index 03898424c954..ffc4a9c29029 100644 --- a/arch/arm/mach-k3/Kconfig +++ b/arch/arm/mach-k3/Kconfig @@ -139,6 +139,14 @@ config K3_DM_FW bootloader, it makes RM and PM services not being available during R5 SPL execution time.
+config K3_QOS + bool "Enable Quality of Service (QoS) Settings for TI K3 SoCs" + default y if CPU_V7R && SOC_K3_AM62A7 + help + This option enables the R5 SPL to apply QoS settings for various + HW controllers inside the TI K3 SoCs. The files for QoS settings are + generated from Sysconfig and k3-resource-partitioning tools. + config K3_X509_SWRV int "SWRV for X509 certificate used for boot images" default 1 diff --git a/arch/arm/mach-k3/am62a7_init.c b/arch/arm/mach-k3/am62a7_init.c index d72e19936b9b..080274e3af58 100644 --- a/arch/arm/mach-k3/am62a7_init.c +++ b/arch/arm/mach-k3/am62a7_init.c @@ -69,20 +69,6 @@ static void ctrl_mmr_unlock(void) mmr_unlock(PADCFG_MMR1_BASE, 1); }
-#if (IS_ENABLED(CONFIG_CPU_V7R)) -static void setup_qos(void) -{ - u32 i; - - for (i = 0; i < am62a_qos_count; i++) - writel(am62a_qos_data[i].val, (uintptr_t)am62a_qos_data[i].reg); -} -#else -static void setup_qos(void) -{ -} -#endif - void board_init_f(ulong dummy) { struct udevice *dev; diff --git a/arch/arm/mach-k3/common.c b/arch/arm/mach-k3/common.c index f411366778f0..b54f2ddc4729 100644 --- a/arch/arm/mach-k3/common.c +++ b/arch/arm/mach-k3/common.c @@ -28,6 +28,8 @@ #include <elf.h> #include <soc.h>
+#include <asm/arch/k3-qos.h> + #if IS_ENABLED(CONFIG_SYS_K3_SPL_ATF) enum { IMAGE_ID_ATF, @@ -595,3 +597,13 @@ int misc_init_r(void) void __weak do_board_detect(void) { } + +#if (IS_ENABLED(CONFIG_K3_QOS)) +void setup_qos(void) +{ + u32 i; + + for (i = 0; i < qos_count; i++) + writel(qos_data[i].val, (uintptr_t)qos_data[i].reg); +} +#endif diff --git a/arch/arm/mach-k3/common.h b/arch/arm/mach-k3/common.h index e9db9fbfb63d..53aa186b31a4 100644 --- a/arch/arm/mach-k3/common.h +++ b/arch/arm/mach-k3/common.h @@ -45,3 +45,11 @@ void ti_secure_image_post_process(void **p_image, size_t *p_size); struct ti_sci_handle *get_ti_sci_handle(void); void do_board_detect(void); void ti_secure_image_check_binary(void **p_image, size_t *p_size); + +#if (IS_ENABLED(CONFIG_K3_QOS)) +void setup_qos(void); +#else +static inline void setup_qos(void) +{ +} +#endif diff --git a/arch/arm/mach-k3/include/mach/hardware.h b/arch/arm/mach-k3/include/mach/hardware.h index a1a9dfbde66c..52ef82e70b07 100644 --- a/arch/arm/mach-k3/include/mach/hardware.h +++ b/arch/arm/mach-k3/include/mach/hardware.h @@ -30,7 +30,6 @@
#ifdef CONFIG_SOC_K3_AM62A7 #include "am62a_hardware.h" -#include "am62a_qos.h" #endif
/* Assuming these addresses and definitions stay common across K3 devices */ @@ -97,12 +96,4 @@ struct rom_extended_boot_data { u32 num_components; };
-struct k3_qos_data { - u32 reg; - u32 val; -}; - -extern struct k3_qos_data am62a_qos_data[]; -extern u32 am62a_qos_count; - #endif /* _ASM_ARCH_HARDWARE_H_ */ diff --git a/arch/arm/mach-k3/include/mach/k3-qos.h b/arch/arm/mach-k3/include/mach/k3-qos.h new file mode 100644 index 000000000000..e00e1de5b9cb --- /dev/null +++ b/arch/arm/mach-k3/include/mach/k3-qos.h @@ -0,0 +1,22 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Quality of Service (QoS) Configuration Header File + * + * Copyright (C) 2024 Texas Instruments Incorporated - https://www.ti.com/ + */ +#ifndef _K3_QOS_H_ +#define _K3_QOS_H_ + +#include <linux/kernel.h> + +struct k3_qos_data { + u32 reg; + u32 val; +}; + +#if (IS_ENABLED(CONFIG_K3_QOS)) +extern struct k3_qos_data qos_data[]; +extern u32 qos_count; +#endif + +#endif /* _K3_QOS_H_ */ diff --git a/arch/arm/mach-k3/r5/am62ax/Makefile b/arch/arm/mach-k3/r5/am62ax/Makefile index 02a941805e9a..e4e55ce5c7dd 100644 --- a/arch/arm/mach-k3/r5/am62ax/Makefile +++ b/arch/arm/mach-k3/r5/am62ax/Makefile @@ -4,4 +4,4 @@
obj-y += clk-data.o obj-y += dev-data.o -obj-y += am62a_qos_data.o +obj-y += am62a_qos_uboot.o diff --git a/arch/arm/mach-k3/include/mach/am62a_qos.h b/arch/arm/mach-k3/r5/am62ax/am62a_qos.h similarity index 100% rename from arch/arm/mach-k3/include/mach/am62a_qos.h rename to arch/arm/mach-k3/r5/am62ax/am62a_qos.h diff --git a/arch/arm/mach-k3/r5/am62ax/am62a_qos_data.c b/arch/arm/mach-k3/r5/am62ax/am62a_qos_uboot.c similarity index 85% rename from arch/arm/mach-k3/r5/am62ax/am62a_qos_data.c rename to arch/arm/mach-k3/r5/am62ax/am62a_qos_uboot.c index 38db4f2f5c8e..9a82944d5fe9 100644 --- a/arch/arm/mach-k3/r5/am62ax/am62a_qos_data.c +++ b/arch/arm/mach-k3/r5/am62ax/am62a_qos_uboot.c @@ -5,10 +5,11 @@ * * Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ */ -#include <asm/arch/hardware.h> -#include "common.h"
-struct k3_qos_data am62a_qos_data[] = { +#include <asm/arch/k3-qos.h> +#include "am62a_qos.h" + +struct k3_qos_data qos_data[] = { /* modules_qosConfig0 - 1 endpoints, 4 channels */ { .reg = K3_DSS_UL_MAIN_0_VBUSM_DMA + 0x100 + 0x4 * 0, @@ -43,4 +44,4 @@ struct k3_qos_data am62a_qos_data[] = { }, };
-uint32_t am62a_qos_count = sizeof(am62a_qos_data) / sizeof(am62a_qos_data[0]); +u32 qos_count = ARRAY_SIZE(qos_data);
base-commit: daa3100250839dd30626f7f4b7daf041f1114f1c
+config K3_QOS
- bool "Enable Quality of Service (QoS) Settings for TI K3 SoCs"
- default y if CPU_V7R && SOC_K3_AM62A7
If this is R5 only, then put it in the arch/arm/mach-k3/r5 Kconfig and you can drop the CPU_V7R check.
Andrew
- help
- config K3_X509_SWRV int "SWRV for X509 certificate used for boot images" default 1
- u32 i;
- #if IS_ENABLED(CONFIG_SYS_K3_SPL_ATF) enum { IMAGE_ID_ATF,
- u32 i;
- for (i = 0; i < qos_count; i++)
- u32 reg;
- u32 val;
- Quality of Service (QoS) Configuration Header File
- Copyright (C) 2024 Texas Instruments Incorporated - https://www.ti.com/
- u32 reg;
- u32 val;
- Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/
diff --git a/arch/arm/mach-k3/Kconfig b/arch/arm/mach-k3/Kconfig index 03898424c954..ffc4a9c29029 100644 --- a/arch/arm/mach-k3/Kconfig +++ b/arch/arm/mach-k3/Kconfig @@ -139,6 +139,14 @@ config K3_DM_FW bootloader, it makes RM and PM services not being available during R5 SPL execution time. +config K3_QOS + bool "Enable Quality of Service (QoS) Settings for TI K3 SoCs" + default y if CPU_V7R && SOC_K3_AM62A7
Andrew
That would indeed be better. Thanks!
Regards Aradhya
config K3_X509_SWRV int "SWRV for X509 certificate used for boot images" default 1 diff --git a/arch/arm/mach-k3/am62a7_init.c b/arch/arm/mach-k3/am62a7_init.c index d72e19936b9b..080274e3af58 100644 --- a/arch/arm/mach-k3/am62a7_init.c +++ b/arch/arm/mach-k3/am62a7_init.c @@ -69,20 +69,6 @@ static void ctrl_mmr_unlock(void) mmr_unlock(PADCFG_MMR1_BASE, 1); } -#if (IS_ENABLED(CONFIG_CPU_V7R)) -static void setup_qos(void) -{ - u32 i;
void board_init_f(ulong dummy) { struct udevice *dev; diff --git a/arch/arm/mach-k3/common.c b/arch/arm/mach-k3/common.c index f411366778f0..b54f2ddc4729 100644 --- a/arch/arm/mach-k3/common.c +++ b/arch/arm/mach-k3/common.c @@ -28,6 +28,8 @@ #include <elf.h> #include <soc.h> +#include <asm/arch/k3-qos.h>
+#if (IS_ENABLED(CONFIG_K3_QOS)) +void setup_qos(void); +#else +static inline void setup_qos(void) +{ +} +#endif diff --git a/arch/arm/mach-k3/include/mach/hardware.h b/arch/arm/mach-k3/include/mach/hardware.h index a1a9dfbde66c..52ef82e70b07 100644 --- a/arch/arm/mach-k3/include/mach/hardware.h +++ b/arch/arm/mach-k3/include/mach/hardware.h @@ -30,7 +30,6 @@ #ifdef CONFIG_SOC_K3_AM62A7 #include "am62a_hardware.h" -#include "am62a_qos.h" #endif /* Assuming these addresses and definitions stay common across K3 devices */ @@ -97,12 +96,4 @@ struct rom_extended_boot_data { u32 num_components; }; -struct k3_qos_data { - u32 reg; - u32 val; -};
+#endif /* _K3_QOS_H_ */ diff --git a/arch/arm/mach-k3/r5/am62ax/Makefile b/arch/arm/mach-k3/r5/am62ax/Makefile index 02a941805e9a..e4e55ce5c7dd 100644 --- a/arch/arm/mach-k3/r5/am62ax/Makefile +++ b/arch/arm/mach-k3/r5/am62ax/Makefile @@ -4,4 +4,4 @@ obj-y += clk-data.o obj-y += dev-data.o -obj-y += am62a_qos_data.o +obj-y += am62a_qos_uboot.o diff --git a/arch/arm/mach-k3/include/mach/am62a_qos.h b/arch/arm/mach-k3/r5/am62ax/am62a_qos.h similarity index 100% rename from arch/arm/mach-k3/include/mach/am62a_qos.h rename to arch/arm/mach-k3/r5/am62ax/am62a_qos.h diff --git a/arch/arm/mach-k3/r5/am62ax/am62a_qos_data.c b/arch/arm/mach-k3/r5/am62ax/am62a_qos_uboot.c similarity index 85% rename from arch/arm/mach-k3/r5/am62ax/am62a_qos_data.c rename to arch/arm/mach-k3/r5/am62ax/am62a_qos_uboot.c index 38db4f2f5c8e..9a82944d5fe9 100644 --- a/arch/arm/mach-k3/r5/am62ax/am62a_qos_data.c +++ b/arch/arm/mach-k3/r5/am62ax/am62a_qos_uboot.c @@ -5,10 +5,11 @@ * * Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ */ -#include <asm/arch/hardware.h> -#include "common.h" -struct k3_qos_data am62a_qos_data[] = { +#include <asm/arch/k3-qos.h> +#include "am62a_qos.h"
+struct k3_qos_data qos_data[] = { /* modules_qosConfig0 - 1 endpoints, 4 channels */ { .reg = K3_DSS_UL_MAIN_0_VBUSM_DMA + 0x100 + 0x4 * 0, @@ -43,4 +44,4 @@ struct k3_qos_data am62a_qos_data[] = { }, }; -uint32_t am62a_qos_count = sizeof(am62a_qos_data) / sizeof(am62a_qos_data[0]); +u32 qos_count = ARRAY_SIZE(qos_data);
Andrew Davis
Aradhya Bhatia
