[U-Boot-Users] [PATCH] Fix an underflow bug in __lmb_alloc_base
__lmb_alloc_base can underflow if it fails to find free space. This was fixed in linux with commit d9024df02ffe74d723d97d552f86de3b34beb8cc. This patch merely updates __lmb_alloc_base to resemble the current version in Linux.
Signed-off-by: Andy Fleming afleming@freescale.com --- lib_generic/lmb.c | 34 +++++++++++++++++++--------------- 1 files changed, 19 insertions(+), 15 deletions(-)
diff --git a/lib_generic/lmb.c b/lib_generic/lmb.c index a34e2d3..c27a540 100644 --- a/lib_generic/lmb.c +++ b/lib_generic/lmb.c @@ -284,11 +284,14 @@ ulong __lmb_alloc_base(struct lmb *lmb, ulong size, ulong align, ulong max_addr) { long i, j; ulong base = 0; + ulong res_base;
for (i = lmb->memory.cnt-1; i >= 0; i--) { ulong lmbbase = lmb->memory.region[i].base; ulong lmbsize = lmb->memory.region[i].size;
+ if (lmbsize < size) + continue; if (max_addr == LMB_ALLOC_ANYWHERE) base = lmb_align_down(lmbbase + lmbsize - size, align); else if (lmbbase < max_addr) { @@ -297,22 +300,23 @@ ulong __lmb_alloc_base(struct lmb *lmb, ulong size, ulong align, ulong max_addr) } else continue;
- while ((lmbbase <= base) && - ((j = lmb_overlaps_region(&(lmb->reserved), base, size)) >= 0) ) - base = lmb_align_down(lmb->reserved.region[j].base - size, - align); - - if ((base != 0) && (lmbbase <= base)) - break; + while (base && lmbbase <= base) { + j = lmb_overlaps_region(&lmb->reserved, base, size); + if (j < 0) { + /* This area isn't reserved, take it */ + if (lmb_add_region(&lmb->reserved, base, + lmb_align_up(size, + align)) < 0) + return 0; + return base; + } + res_base = lmb->reserved.region[j].base; + if (res_base < size) + break; + base = lmb_align_down(res_base - size, align); + } } - - if (i < 0) - return 0; - - if (lmb_add_region(&(lmb->reserved), base, lmb_align_up(size, align)) < 0) - return 0; - - return base; + return 0; }
int lmb_is_reserved(struct lmb *lmb, ulong addr)
Andy Fleming
