[PATCH] mpc85xx: relocate code in non-SPL build
When building a non-SPL image, relocation is needed. This patch restores the old behaviour before commit b35316fb67: CONFIG_SPL_SKIP_RELOCATE was only defined if CONFIG_SPL_BUILD was defined.
Fixes: b35316fb67cb ("Convert CONFIG_SPL_INIT_MINIMAL et al to Kconfig") Signed-off-by: Martin Fäcknitz faecknitz@hotsplots.de --- arch/powerpc/cpu/mpc85xx/start.S | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/powerpc/cpu/mpc85xx/start.S b/arch/powerpc/cpu/mpc85xx/start.S index 562b6993b9..318872f82b 100644 --- a/arch/powerpc/cpu/mpc85xx/start.S +++ b/arch/powerpc/cpu/mpc85xx/start.S @@ -1617,7 +1617,7 @@ relocate_code: mr r10,r5 /* Save copy of Destination Address */
GET_GOT -#ifndef CONFIG_SPL_SKIP_RELOCATE +#if !defined(CONFIG_SPL_SKIP_RELOCATE) || !defined(CONFIG_SPL_BUILD) mr r3,r5 /* Destination Address */ lis r4,CONFIG_VAL(SYS_MONITOR_BASE)@h /* Source Address */ ori r4,r4,CONFIG_VAL(SYS_MONITOR_BASE)@l
This is now applied to u-boot/master, thanks! But also, can you please confirm that top of tree now works for you, and which defconfig that is? As part of my testing I check for size changes before/after and this doesn't change any platform, which would lead to how I had missed the problem during the conversion.
Works now. I used T1042D4RDB_SDCARD_defconfig.
relocate_code in arch/powerpc/cpu/mpc85xx/start.o before patch (non-SPL build):
00000dc0 <relocate_code>: dc0: 7c 61 1b 78 mr r1,r3 dc4: 7c 89 23 78 mr r9,r4 dc8: 7c aa 2b 78 mr r10,r5 dcc: 48 00 00 05 bl dd0 <relocate_code+0x10> dd0: 7d 88 02 a6 mflr r12 dd4: 80 0c 01 fc lwz r0,508(r12) dd8: 7d 80 62 14 add r12,r0,r12
00000ddc <in_ram>: ...
After Patch: 00000dc0 <relocate_code>: dc0: 7c 61 1b 78 mr r1,r3 dc4: 7c 89 23 78 mr r9,r4 dc8: 7c aa 2b 78 mr r10,r5 dcc: 48 00 00 05 bl dd0 <relocate_code+0x10> dd0: 7d 88 02 a6 mflr r12 dd4: 80 0c 02 c8 lwz r0,712(r12) dd8: 7d 80 62 14 add r12,r0,r12 ... ea0: 7c 08 03 a6 mtlr r0 ea4: 4e 80 00 20 blr
00000ea8 <in_ram>: ...
In SPL build, relocate_code is same in both builds (because of CONFIG_SPL_SKIP_RELOCATE).
Thanks for confirming!
Martin Fäcknitz
