[U-Boot] [PATCH v1] common: Fix load and entry addresses in FIT image
FIT image supports more than 32 bits in addresses by using #address-cell field. However the address length is not handled when parsing FIT images. Beside, the variable used to host address has "ulong" type. It is OK for the target, but not always enough for host tools such as mkimage. This patch replaces "ulong" with "phys_addr_t" to make sure the address is correct for both the target and the host.
Signed-off-by: York Sun yorksun@freescale.com
common/bootm.c | 13 +++++++------ common/image-fit.c | 55 +++++++++++++++++++++++++++++++++++++--------------- include/bootm.h | 6 +++--- include/image.h | 12 ++++++++---- 4 files changed, 57 insertions(+), 29 deletions(-)
diff --git a/common/bootm.c b/common/bootm.c index 667c934..0672e73 100644 --- a/common/bootm.c +++ b/common/bootm.c @@ -325,9 +325,9 @@ static int handle_decomp_error(int comp_type, size_t uncomp_size, return BOOTM_ERR_RESET; }
-int bootm_decomp_image(int comp, ulong load, ulong image_start, int type, - void *load_buf, void *image_buf, ulong image_len, - uint unc_len, ulong *load_end) +int bootm_decomp_image(int comp, phys_addr_t load, phys_addr_t image_start, + int type, void *load_buf, void *image_buf, + ulong image_len, uint unc_len, ulong *load_end) { int ret = 0;
@@ -883,7 +883,8 @@ void memmove_wd(void *to, void *from, size_t len, ulong chunksz) static int bootm_host_load_image(const void *fit, int req_image_type) { const char *fit_uname_config = NULL; - ulong data, len; + phys_addr_t *data = NULL; + ulong len; bootm_headers_t images; int noffset; ulong load_end; @@ -897,7 +898,7 @@ static int bootm_host_load_image(const void *fit, int req_image_type) noffset = fit_image_load(&images, (ulong)fit, NULL, &fit_uname_config, IH_ARCH_DEFAULT, req_image_type, -1, - FIT_LOAD_IGNORED, &data, &len); + FIT_LOAD_IGNORED, data, &len); if (noffset < 0) return noffset; if (fit_image_get_type(fit, noffset, &image_type)) { @@ -912,7 +913,7 @@ static int bootm_host_load_image(const void *fit, int req_image_type)
/* Allow the image to expand by a factor of 4, should be safe */ load_buf = malloc((1 << 20) + len * 4); - ret = bootm_decomp_image(imape_comp, 0, data, image_type, load_buf, + ret = bootm_decomp_image(imape_comp, 0, *data, image_type, load_buf, (void *)data, len, CONFIG_SYS_BOOTM_LEN, &load_end); free(load_buf); diff --git a/common/image-fit.c b/common/image-fit.c index 28f7aa8..513cfdc 100644 --- a/common/image-fit.c +++ b/common/image-fit.c @@ -358,7 +358,7 @@ void fit_image_print(const void *fit, int image_noffset, const char *p) char *desc; uint8_t type, arch, os, comp; size_t size; - ulong load, entry; + phys_addr_t load, entry; const void *data; int noffset; int ndepth; @@ -428,17 +428,17 @@ void fit_image_print(const void *fit, int image_noffset, const char *p) if (ret) printf("unavailable\n"); else - printf("0x%08lx\n", load); + printf("0x%08llx\n", (uint64_t)load); }
if ((type == IH_TYPE_KERNEL) || (type == IH_TYPE_STANDALONE) || (type == IH_TYPE_RAMDISK)) { - fit_image_get_entry(fit, image_noffset, &entry); + ret = fit_image_get_entry(fit, image_noffset, &entry); printf("%s Entry Point: ", p); if (ret) printf("unavailable\n"); else - printf("0x%08lx\n", entry); + printf("0x%08llx\n", (uint64_t)entry); }
/* Process all hash subnodes of the component image node */ @@ -679,7 +679,7 @@ int fit_image_get_comp(const void *fit, int noffset, uint8_t *comp) * fit_image_get_load() - get load addr property for given component image node * @fit: pointer to the FIT format image header * @noffset: component image node offset - * @load: pointer to the uint32_t, will hold load address + * @load: pointer to the phys_addr_t, will hold load address * * fit_image_get_load() finds load address property in a given component * image node. If the property is found, its value is returned to the caller. @@ -688,7 +688,7 @@ int fit_image_get_comp(const void *fit, int noffset, uint8_t *comp) * 0, on success * -1, on failure */ -int fit_image_get_load(const void *fit, int noffset, ulong *load) +int fit_image_get_load(const void *fit, int noffset, phys_addr_t *load) { int len; const uint32_t *data; @@ -699,7 +699,18 @@ int fit_image_get_load(const void *fit, int noffset, ulong *load) return -1; }
- *load = uimage_to_cpu(*data); + if (len == 4) { + *load = uimage_to_cpu(*data); + } else if (len == 8 && sizeof(*load) >= 8) { + *load = uimage_to_cpu(data[0]); + *load <<= 32; + *load |= uimage_to_cpu(data[1]); + } else { + printf("Unsupported load address length %d (%zd)\n", + len, sizeof(*load)); + return -1; + } + return 0; }
@@ -707,7 +718,7 @@ int fit_image_get_load(const void *fit, int noffset, ulong *load) * fit_image_get_entry() - get entry point address property * @fit: pointer to the FIT format image header * @noffset: component image node offset - * @entry: pointer to the uint32_t, will hold entry point address + * @entry: pointer to the phys_addr_t, will hold entry point address * * This gets the entry point address property for a given component image * node. @@ -720,7 +731,7 @@ int fit_image_get_load(const void *fit, int noffset, ulong *load) * 0, on success * -1, on failure */ -int fit_image_get_entry(const void *fit, int noffset, ulong *entry) +int fit_image_get_entry(const void *fit, int noffset, phys_addr_t *entry) { int len; const uint32_t *data; @@ -731,7 +742,18 @@ int fit_image_get_entry(const void *fit, int noffset, ulong *entry) return -1; }
- *entry = uimage_to_cpu(*data); + if (len == 4) { + *entry = uimage_to_cpu(*data); + } else if (len == 8 && sizeof(*entry) >= 8) { + *entry = uimage_to_cpu(data[0]); + *entry <<= 32; + *entry |= uimage_to_cpu(data[1]); + } else { + printf("Unsupported entry address length %d (%zd)\n", + len, sizeof(*entry)); + return -1; + } + return 0; }
@@ -1554,7 +1576,7 @@ static const char *fit_get_image_type_property(int type) int fit_image_load(bootm_headers_t *images, ulong addr, const char **fit_unamep, const char **fit_uname_configp, int arch, int image_type, int bootstage_id, - enum fit_load_op load_op, ulong *datap, ulong *lenp) + enum fit_load_op load_op, phys_addr_t *datap, ulong *lenp) { int cfg_noffset, noffset; const char *fit_uname; @@ -1563,7 +1585,8 @@ int fit_image_load(bootm_headers_t *images, ulong addr, const void *buf; size_t size; int type_ok, os_ok; - ulong load, data, len; + phys_addr_t load; + ulong data, len; uint8_t os; const char *prop_name; int ret; @@ -1719,7 +1742,7 @@ int fit_image_load(bootm_headers_t *images, ulong addr, } } else if (load_op != FIT_LOAD_OPTIONAL_NON_ZERO || load) { ulong image_start, image_end; - ulong load_end; + phys_addr_t load_end; void *dst;
/* @@ -1736,8 +1759,8 @@ int fit_image_load(bootm_headers_t *images, ulong addr, return -EXDEV; }
- printf(" Loading %s from 0x%08lx to 0x%08lx\n", - prop_name, data, load); + printf(" Loading %s from 0x%08lx to %08llx\n", + prop_name, data, (uint64_t)load);
dst = map_sysmem(load, len); memmove(dst, buf, len); @@ -1756,7 +1779,7 @@ int fit_image_load(bootm_headers_t *images, ulong addr, }
int boot_get_setup_fit(bootm_headers_t *images, uint8_t arch, - ulong *setup_start, ulong *setup_len) + phys_addr_t *setup_start, ulong *setup_len) { int noffset; ulong addr; diff --git a/include/bootm.h b/include/bootm.h index 4981377..f280ace 100644 --- a/include/bootm.h +++ b/include/bootm.h @@ -69,8 +69,8 @@ void arch_preboot_os(void); * @unc_len: Available space for decompression * @return 0 if OK, -ve on error (BOOTM_ERR_...) */ -int bootm_decomp_image(int comp, ulong load, ulong image_start, int type, - void *load_buf, void *image_buf, ulong image_len, - uint unc_len, ulong *load_end); +int bootm_decomp_image(int comp, phys_addr_t load, phys_addr_t image_start, + int type, void *load_buf, void *image_buf, + ulong image_len, uint unc_len, ulong *load_end);
#endif diff --git a/include/image.h b/include/image.h index 63c3d37..bc41ecb 100644 --- a/include/image.h +++ b/include/image.h @@ -33,11 +33,15 @@ struct lmb; #define IMAGE_ENABLE_IGNORE 0 #define IMAGE_INDENT_STRING ""
+/* Be able to hold physical address */ +typedef unsigned long long phys_addr_t; + #else
#include <lmb.h> #include <asm/u-boot.h> #include <command.h> +#include <linux/types.h>
/* Take notice of the 'ignore' property for hashes */ #define IMAGE_ENABLE_IGNORE 1 @@ -494,7 +498,7 @@ int boot_get_loadable(int argc, char * const argv[], bootm_headers_t *images, #endif /* !USE_HOSTCC */
int boot_get_setup_fit(bootm_headers_t *images, uint8_t arch, - ulong *setup_start, ulong *setup_len); + phys_addr_t *setup_start, ulong *setup_len);
/** * fit_image_load() - load an image from a FIT @@ -529,7 +533,7 @@ int boot_get_setup_fit(bootm_headers_t *images, uint8_t arch, int fit_image_load(bootm_headers_t *images, ulong addr, const char **fit_unamep, const char **fit_uname_configp, int arch, int image_type, int bootstage_id, - enum fit_load_op load_op, ulong *datap, ulong *lenp); + enum fit_load_op load_op, phys_addr_t *datap, ulong *lenp);
#ifndef USE_HOSTCC /** @@ -840,8 +844,8 @@ int fit_image_get_os(const void *fit, int noffset, uint8_t *os); int fit_image_get_arch(const void *fit, int noffset, uint8_t *arch); int fit_image_get_type(const void *fit, int noffset, uint8_t *type); int fit_image_get_comp(const void *fit, int noffset, uint8_t *comp); -int fit_image_get_load(const void *fit, int noffset, ulong *load); -int fit_image_get_entry(const void *fit, int noffset, ulong *entry); +int fit_image_get_load(const void *fit, int noffset, phys_addr_t *load); +int fit_image_get_entry(const void *fit, int noffset, phys_addr_t *entry); int fit_image_get_data(const void *fit, int noffset, const void **data, size_t *size);
Hi York,
This looks right to me but I have a few comments.
{ int ret = 0;
ulong data, len;
ulong load, entry;
printf("0x%08llx\n", (uint64_t)load); } if ((type == IH_TYPE_KERNEL) || (type == IH_TYPE_STANDALONE) || (type == IH_TYPE_RAMDISK)) {
If the address is 32-bit we cast it to 64-bit and print 8 digits. If it is 64-bit we print as many digits as we can find.
I think this behaviour is reasonable - and avoids hopelessly confusing 16-character hex strings with lots of leading zeros.
But the code looks a bit odd. Do you think we should add a % formatter to print a phys_addr_t?
} /* Process all hash subnodes of the component image node */
- fit_image_get_load() - get load addr property for given component image node
- @fit: pointer to the FIT format image header
- @noffset: component image node offset
- @load: pointer to the uint32_t, will hold load address
- @load: pointer to the phys_addr_t, will hold load address
- fit_image_get_load() finds load address property in a given component
- image node. If the property is found, its value is returned to the caller.
0, on success
-1, on failure
if (len == 4) {
*load <<= 32;
} else {
return -1;
Can this use fdtdec_get_number()? I'm not sure we need this error message.
- fit_image_get_entry() - get entry point address property
- @entry: pointer to the uint32_t, will hold entry point address
- @entry: pointer to the phys_addr_t, will hold entry point address
- This gets the entry point address property for a given component image
- node.
0, on success
-1, on failure
if (len == 4) {
*entry <<= 32;
} else {
return -1;
Ditto - in fact this code seems duplicated.
phys_addr_t load;
ulong load_end;
phys_addr_t load_end; void *dst; /*
prop_name, data, (uint64_t)load); dst = map_sysmem(load, len); memmove(dst, buf, len);
- @unc_len: Available space for decompression
- @return 0 if OK, -ve on error (BOOTM_ERR_...)
#else
- fit_image_load() - load an image from a FIT
-- 1.7.9.5
On 09/02/2015 09:05 AM, Simon Glass wrote:
Hi York,
{ int ret = 0;
ulong data, len;
ulong load, entry;
Do you mean %pa? I tried and the result looks weird on mkimage. I didn't spend time on it, thinking it could be host CC issue.
I will work on your other comments.
York
York Sun
