[U-Boot] [PATCH v2 0/6] ARM: socfpga: refactoring, move files to arch/arm/mach-socfpga
Changes in v2: - Rebase on the top of u-boot-socfpga/master (commit b284d268a)
Masahiro Yamada (6): ARM: socfpga: do not add board directory to header search path ARM: socfpga: remove redundant config.mk ARM: socfpga: move board select into mach-socfpga/Kconfig ARM: socfpga: move SoC sources to mach-socfpga ARM: socfpga: move SoC headers to mach-socfpga/include/mach ARM: socfpga: abolish CONFIG_SOCFPGA
arch/arm/Kconfig | 15 +++-------- arch/arm/Makefile | 1 + arch/arm/cpu/armv7/Makefile | 3 +-- arch/arm/cpu/armv7/socfpga/config.mk | 11 -------- arch/arm/dts/Makefile | 2 +- arch/arm/mach-socfpga/Kconfig | 27 +++++++++++++++++++ .../{cpu/armv7/socfpga => mach-socfpga}/Makefile | 0 .../armv7/socfpga => mach-socfpga}/clock_manager.c | 0 .../armv7/socfpga => mach-socfpga}/fpga_manager.c | 0 .../socfpga => mach-socfpga}/freeze_controller.c | 0 .../include/mach}/clock_manager.h | 0 .../include/mach}/dwmmc.h | 0 .../include/mach}/fpga_manager.h | 0 .../include/mach}/freeze_controller.h | 0 .../include/mach}/gpio.h | 0 .../include/mach}/nic301.h | 0 .../include/mach}/reset_manager.h | 0 .../include/mach}/scan_manager.h | 0 .../include/mach}/scu.h | 0 .../include/mach}/sdram.h | 0 .../include/mach}/socfpga_base_addrs.h | 0 .../include/mach}/system_manager.h | 0 .../include/mach}/timer.h | 0 .../arm/{cpu/armv7/socfpga => mach-socfpga}/misc.c | 0 .../armv7/socfpga => mach-socfpga}/reset_manager.c | 0 .../armv7/socfpga => mach-socfpga}/scan_manager.c | 0 arch/arm/{cpu/armv7/socfpga => mach-socfpga}/spl.c | 0 .../socfpga => mach-socfpga}/system_manager.c | 0 .../{cpu/armv7/socfpga => mach-socfpga}/timer.c | 0 .../armv7/socfpga => mach-socfpga}/u-boot-spl.lds | 0 board/altera/socfpga/Kconfig | 31 ---------------------- board/altera/socfpga/iocsr_config.c | 2 +- configs/socfpga_arria5_defconfig | 1 + configs/socfpga_cyclone5_defconfig | 1 + configs/socfpga_socrates_defconfig | 1 + include/configs/socfpga_common.h | 4 +-- 36 files changed, 39 insertions(+), 60 deletions(-) delete mode 100644 arch/arm/cpu/armv7/socfpga/config.mk create mode 100644 arch/arm/mach-socfpga/Kconfig rename arch/arm/{cpu/armv7/socfpga => mach-socfpga}/Makefile (100%) rename arch/arm/{cpu/armv7/socfpga => mach-socfpga}/clock_manager.c (100%) rename arch/arm/{cpu/armv7/socfpga => mach-socfpga}/fpga_manager.c (100%) rename arch/arm/{cpu/armv7/socfpga => mach-socfpga}/freeze_controller.c (100%) rename arch/arm/{include/asm/arch-socfpga => mach-socfpga/include/mach}/clock_manager.h (100%) rename arch/arm/{include/asm/arch-socfpga => mach-socfpga/include/mach}/dwmmc.h (100%) rename arch/arm/{include/asm/arch-socfpga => mach-socfpga/include/mach}/fpga_manager.h (100%) rename arch/arm/{include/asm/arch-socfpga => mach-socfpga/include/mach}/freeze_controller.h (100%) rename arch/arm/{include/asm/arch-socfpga => mach-socfpga/include/mach}/gpio.h (100%) rename arch/arm/{include/asm/arch-socfpga => mach-socfpga/include/mach}/nic301.h (100%) rename arch/arm/{include/asm/arch-socfpga => mach-socfpga/include/mach}/reset_manager.h (100%) rename arch/arm/{include/asm/arch-socfpga => mach-socfpga/include/mach}/scan_manager.h (100%) rename arch/arm/{include/asm/arch-socfpga => mach-socfpga/include/mach}/scu.h (100%) rename arch/arm/{include/asm/arch-socfpga => mach-socfpga/include/mach}/sdram.h (100%) rename arch/arm/{include/asm/arch-socfpga => mach-socfpga/include/mach}/socfpga_base_addrs.h (100%) rename arch/arm/{include/asm/arch-socfpga => mach-socfpga/include/mach}/system_manager.h (100%) rename arch/arm/{include/asm/arch-socfpga => mach-socfpga/include/mach}/timer.h (100%) rename arch/arm/{cpu/armv7/socfpga => mach-socfpga}/misc.c (100%) rename arch/arm/{cpu/armv7/socfpga => mach-socfpga}/reset_manager.c (100%) rename arch/arm/{cpu/armv7/socfpga => mach-socfpga}/scan_manager.c (100%) rename arch/arm/{cpu/armv7/socfpga => mach-socfpga}/spl.c (100%) rename arch/arm/{cpu/armv7/socfpga => mach-socfpga}/system_manager.c (100%) rename arch/arm/{cpu/armv7/socfpga => mach-socfpga}/timer.c (100%) rename arch/arm/{cpu/armv7/socfpga => mach-socfpga}/u-boot-spl.lds (100%) delete mode 100644 board/altera/socfpga/Kconfig
The compiler option "-Iboard/$(VENDOR)/$(BOARD)" just exists here for iocsr_config.c to be able to include iocsr_config.h.
Use "..." instead of <...> to include a header in the same directory.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
Changes in v2: None
arch/arm/cpu/armv7/socfpga/config.mk | 3 --- board/altera/socfpga/iocsr_config.c | 2 +- 2 files changed, 1 insertion(+), 4 deletions(-)
diff --git a/arch/arm/cpu/armv7/socfpga/config.mk b/arch/arm/cpu/armv7/socfpga/config.mk index 2a99c72..3d18491 100644 --- a/arch/arm/cpu/armv7/socfpga/config.mk +++ b/arch/arm/cpu/armv7/socfpga/config.mk @@ -6,6 +6,3 @@ ifndef CONFIG_SPL_BUILD ALL-y += u-boot.img endif - -# Added for handoff support -PLATFORM_RELFLAGS += -Iboard/$(VENDOR)/$(BOARD) diff --git a/board/altera/socfpga/iocsr_config.c b/board/altera/socfpga/iocsr_config.c index c79aa6d..3b202b5 100644 --- a/board/altera/socfpga/iocsr_config.c +++ b/board/altera/socfpga/iocsr_config.c @@ -6,7 +6,7 @@
/* This file is generated by Preloader Generator */
-#include <iocsr_config.h> +#include "iocsr_config.h"
#ifdef CONFIG_TARGET_SOCFPGA_CYCLONE5 const unsigned long iocsr_scan_chain0_table[((
Because all the SOCFPGA boards define CONFIG_SPL_FRAMEWORK (see include/configs/socfpga_common.h), u-boot.img is automatically added to the target image list by the top Makefile.
Changes in v2: None
arch/arm/cpu/armv7/socfpga/config.mk | 8 -------- 1 file changed, 8 deletions(-) delete mode 100644 arch/arm/cpu/armv7/socfpga/config.mk
diff --git a/arch/arm/cpu/armv7/socfpga/config.mk b/arch/arm/cpu/armv7/socfpga/config.mk deleted file mode 100644 index 3d18491..0000000 --- a/arch/arm/cpu/armv7/socfpga/config.mk +++ /dev/null @@ -1,8 +0,0 @@ -# -# Copyright (C) 2011, Texas Instruments, Incorporated - http://www.ti.com/ -# -# SPDX-License-Identifier: GPL-2.0+ -# -ifndef CONFIG_SPL_BUILD -ALL-y += u-boot.img -endif
Switch to a more standard way of board select; put the SoC select into arch/arm/Kconfig and move the board select menu under arch/arm/mach-socfpga/Kconfig.
Also, consolidate SYS_BOARD, SYS_VENDOR, SYS_SOC, SYS_CONFIG_NAME.
Changes in v2: None
arch/arm/Kconfig | 15 ++++----------- arch/arm/mach-socfpga/Kconfig | 27 +++++++++++++++++++++++++++ board/altera/socfpga/Kconfig | 31 ------------------------------- configs/socfpga_arria5_defconfig | 1 + configs/socfpga_cyclone5_defconfig | 1 + configs/socfpga_socrates_defconfig | 1 + 6 files changed, 34 insertions(+), 42 deletions(-) create mode 100644 arch/arm/mach-socfpga/Kconfig delete mode 100644 board/altera/socfpga/Kconfig
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 3702bb0..ac7a11b 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -634,16 +634,8 @@ config TARGET_CM_FX6 select DM_SERIAL select DM_GPIO
-config TARGET_SOCFPGA_ARRIA5 - bool "Support socfpga_arria5" - select CPU_V7 - select SUPPORT_SPL - select DM - select DM_SPI_FLASH - select DM_SPI - -config TARGET_SOCFPGA_CYCLONE5 - bool "Support socfpga_cyclone5" +config ARCH_SOCFPGA + bool "Altera SOCFPGA family" select CPU_V7 select SUPPORT_SPL select DM @@ -819,6 +811,8 @@ source "arch/arm/cpu/armv7/rmobile/Kconfig"
source "arch/arm/cpu/armv7/s5pc1xx/Kconfig"
+source "arch/arm/mach-socfpga/Kconfig" + source "arch/arm/mach-tegra/Kconfig"
source "arch/arm/mach-uniphier/Kconfig" @@ -840,7 +834,6 @@ source "board/CarMediaLab/flea3/Kconfig" source "board/Marvell/aspenite/Kconfig" source "board/Marvell/db-mv784mp-gp/Kconfig" source "board/Marvell/gplugd/Kconfig" -source "board/altera/socfpga/Kconfig" source "board/armadeus/apf27/Kconfig" source "board/armltd/integrator/Kconfig" source "board/armltd/vexpress/Kconfig" diff --git a/arch/arm/mach-socfpga/Kconfig b/arch/arm/mach-socfpga/Kconfig new file mode 100644 index 0000000..204efca --- /dev/null +++ b/arch/arm/mach-socfpga/Kconfig @@ -0,0 +1,27 @@ +if ARCH_SOCFPGA + +choice + prompt "Altera SOCFPGA board select" + +config TARGET_SOCFPGA_ARRIA5 + bool "Altera SOCFPGA Arria V" + +config TARGET_SOCFPGA_CYCLONE5 + bool "Altera SOCFPGA Cyclone V" + +endchoice + +config SYS_BOARD + default "socfpga" + +config SYS_VENDOR + default "altera" + +config SYS_SOC + default "socfpga" + +config SYS_CONFIG_NAME + default "socfpga_arria5" if TARGET_SOCFPGA_ARRIA5 + default "socfpga_cyclone5" if TARGET_SOCFPGA_CYCLONE5 + +endif diff --git a/board/altera/socfpga/Kconfig b/board/altera/socfpga/Kconfig deleted file mode 100644 index cbed8d6..0000000 --- a/board/altera/socfpga/Kconfig +++ /dev/null @@ -1,31 +0,0 @@ -if TARGET_SOCFPGA_CYCLONE5 - -config SYS_BOARD - default "socfpga" - -config SYS_VENDOR - default "altera" - -config SYS_SOC - default "socfpga" - -config SYS_CONFIG_NAME - default "socfpga_cyclone5" - -endif - -if TARGET_SOCFPGA_ARRIA5 - -config SYS_BOARD - default "socfpga" - -config SYS_VENDOR - default "altera" - -config SYS_SOC - default "socfpga" - -config SYS_CONFIG_NAME - default "socfpga_arria5" - -endif diff --git a/configs/socfpga_arria5_defconfig b/configs/socfpga_arria5_defconfig index 52032e5..d658a50 100644 --- a/configs/socfpga_arria5_defconfig +++ b/configs/socfpga_arria5_defconfig @@ -1,5 +1,6 @@ CONFIG_SPL=y CONFIG_ARM=y +CONFIG_ARCH_SOCFPGA=y CONFIG_TARGET_SOCFPGA_ARRIA5=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="socfpga_arria5_socdk" diff --git a/configs/socfpga_cyclone5_defconfig b/configs/socfpga_cyclone5_defconfig index 6c982ab..a67b0c1 100644 --- a/configs/socfpga_cyclone5_defconfig +++ b/configs/socfpga_cyclone5_defconfig @@ -1,5 +1,6 @@ CONFIG_SPL=y CONFIG_ARM=y +CONFIG_ARCH_SOCFPGA=y CONFIG_TARGET_SOCFPGA_CYCLONE5=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_socdk" diff --git a/configs/socfpga_socrates_defconfig b/configs/socfpga_socrates_defconfig index c81ab0f..1aa3ee5 100644 --- a/configs/socfpga_socrates_defconfig +++ b/configs/socfpga_socrates_defconfig @@ -1,5 +1,6 @@ CONFIG_SPL=y CONFIG_ARM=y +CONFIG_ARCH_SOCFPGA=y CONFIG_TARGET_SOCFPGA_CYCLONE5=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_socrates"
Our recent trend is to collect SoC files into arch/arm/mach-(SOC).
arch/arm/Makefile | 1 + arch/arm/cpu/armv7/Makefile | 1 - arch/arm/{cpu/armv7/socfpga => mach-socfpga}/Makefile | 0 arch/arm/{cpu/armv7/socfpga => mach-socfpga}/clock_manager.c | 0 arch/arm/{cpu/armv7/socfpga => mach-socfpga}/fpga_manager.c | 0 arch/arm/{cpu/armv7/socfpga => mach-socfpga}/freeze_controller.c | 0 arch/arm/{cpu/armv7/socfpga => mach-socfpga}/misc.c | 0 arch/arm/{cpu/armv7/socfpga => mach-socfpga}/reset_manager.c | 0 arch/arm/{cpu/armv7/socfpga => mach-socfpga}/scan_manager.c | 0 arch/arm/{cpu/armv7/socfpga => mach-socfpga}/spl.c | 0 arch/arm/{cpu/armv7/socfpga => mach-socfpga}/system_manager.c | 0 arch/arm/{cpu/armv7/socfpga => mach-socfpga}/timer.c | 0 arch/arm/{cpu/armv7/socfpga => mach-socfpga}/u-boot-spl.lds | 0 include/configs/socfpga_common.h | 2 +- 14 files changed, 2 insertions(+), 2 deletions(-) rename arch/arm/{cpu/armv7/socfpga => mach-socfpga}/Makefile (100%) rename arch/arm/{cpu/armv7/socfpga => mach-socfpga}/clock_manager.c (100%) rename arch/arm/{cpu/armv7/socfpga => mach-socfpga}/fpga_manager.c (100%) rename arch/arm/{cpu/armv7/socfpga => mach-socfpga}/freeze_controller.c (100%) rename arch/arm/{cpu/armv7/socfpga => mach-socfpga}/misc.c (100%) rename arch/arm/{cpu/armv7/socfpga => mach-socfpga}/reset_manager.c (100%) rename arch/arm/{cpu/armv7/socfpga => mach-socfpga}/scan_manager.c (100%) rename arch/arm/{cpu/armv7/socfpga => mach-socfpga}/spl.c (100%) rename arch/arm/{cpu/armv7/socfpga => mach-socfpga}/system_manager.c (100%) rename arch/arm/{cpu/armv7/socfpga => mach-socfpga}/timer.c (100%) rename arch/arm/{cpu/armv7/socfpga => mach-socfpga}/u-boot-spl.lds (100%)
diff --git a/arch/arm/Makefile b/arch/arm/Makefile index bd4749c..cd71d46 100644 --- a/arch/arm/Makefile +++ b/arch/arm/Makefile @@ -52,6 +52,7 @@ machine-$(CONFIG_KIRKWOOD) += kirkwood machine-$(CONFIG_ARCH_NOMADIK) += nomadik # TODO: rename CONFIG_ORION5X -> CONFIG_ARCH_ORION5X machine-$(CONFIG_ORION5X) += orion5x +machine-$(CONFIG_ARCH_SOCFPGA) += socfpga machine-$(CONFIG_TEGRA) += tegra machine-$(CONFIG_ARCH_UNIPHIER) += uniphier machine-$(CONFIG_ARCH_VERSATILE) += versatile diff --git a/arch/arm/cpu/armv7/Makefile b/arch/arm/cpu/armv7/Makefile index e6249f1..ffb1cdc 100644 --- a/arch/arm/cpu/armv7/Makefile +++ b/arch/arm/cpu/armv7/Makefile @@ -51,7 +51,6 @@ obj-$(CONFIG_OMAP44XX) += omap4/ obj-$(CONFIG_OMAP54XX) += omap5/ obj-$(CONFIG_RMOBILE) += rmobile/ obj-$(CONFIG_ARCH_S5PC1XX) += s5pc1xx/ -obj-$(CONFIG_SOCFPGA) += socfpga/ obj-$(if $(filter stv0991,$(SOC)),y) += stv0991/ obj-$(CONFIG_ARCH_SUNXI) += sunxi/ obj-$(CONFIG_U8500) += u8500/ diff --git a/arch/arm/cpu/armv7/socfpga/Makefile b/arch/arm/mach-socfpga/Makefile similarity index 100% rename from arch/arm/cpu/armv7/socfpga/Makefile rename to arch/arm/mach-socfpga/Makefile diff --git a/arch/arm/cpu/armv7/socfpga/clock_manager.c b/arch/arm/mach-socfpga/clock_manager.c similarity index 100% rename from arch/arm/cpu/armv7/socfpga/clock_manager.c rename to arch/arm/mach-socfpga/clock_manager.c diff --git a/arch/arm/cpu/armv7/socfpga/fpga_manager.c b/arch/arm/mach-socfpga/fpga_manager.c similarity index 100% rename from arch/arm/cpu/armv7/socfpga/fpga_manager.c rename to arch/arm/mach-socfpga/fpga_manager.c diff --git a/arch/arm/cpu/armv7/socfpga/freeze_controller.c b/arch/arm/mach-socfpga/freeze_controller.c similarity index 100% rename from arch/arm/cpu/armv7/socfpga/freeze_controller.c rename to arch/arm/mach-socfpga/freeze_controller.c diff --git a/arch/arm/cpu/armv7/socfpga/misc.c b/arch/arm/mach-socfpga/misc.c similarity index 100% rename from arch/arm/cpu/armv7/socfpga/misc.c rename to arch/arm/mach-socfpga/misc.c diff --git a/arch/arm/cpu/armv7/socfpga/reset_manager.c b/arch/arm/mach-socfpga/reset_manager.c similarity index 100% rename from arch/arm/cpu/armv7/socfpga/reset_manager.c rename to arch/arm/mach-socfpga/reset_manager.c diff --git a/arch/arm/cpu/armv7/socfpga/scan_manager.c b/arch/arm/mach-socfpga/scan_manager.c similarity index 100% rename from arch/arm/cpu/armv7/socfpga/scan_manager.c rename to arch/arm/mach-socfpga/scan_manager.c diff --git a/arch/arm/cpu/armv7/socfpga/spl.c b/arch/arm/mach-socfpga/spl.c similarity index 100% rename from arch/arm/cpu/armv7/socfpga/spl.c rename to arch/arm/mach-socfpga/spl.c diff --git a/arch/arm/cpu/armv7/socfpga/system_manager.c b/arch/arm/mach-socfpga/system_manager.c similarity index 100% rename from arch/arm/cpu/armv7/socfpga/system_manager.c rename to arch/arm/mach-socfpga/system_manager.c diff --git a/arch/arm/cpu/armv7/socfpga/timer.c b/arch/arm/mach-socfpga/timer.c similarity index 100% rename from arch/arm/cpu/armv7/socfpga/timer.c rename to arch/arm/mach-socfpga/timer.c diff --git a/arch/arm/cpu/armv7/socfpga/u-boot-spl.lds b/arch/arm/mach-socfpga/u-boot-spl.lds similarity index 100% rename from arch/arm/cpu/armv7/socfpga/u-boot-spl.lds rename to arch/arm/mach-socfpga/u-boot-spl.lds diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h index 41bb52b..61ce376 100644 --- a/include/configs/socfpga_common.h +++ b/include/configs/socfpga_common.h @@ -298,7 +298,7 @@ unsigned int cm_get_qspi_controller_clk_hz(void); #define CONFIG_CRC32_VERIFY
/* Linker script for SPL */ -#define CONFIG_SPL_LDSCRIPT "arch/arm/cpu/armv7/socfpga/u-boot-spl.lds" +#define CONFIG_SPL_LDSCRIPT "arch/arm/mach-socfpga/u-boot-spl.lds"
#define CONFIG_SPL_LIBCOMMON_SUPPORT #define CONFIG_SPL_LIBGENERIC_SUPPORT
Move headers to mach-socfpga as well.
.../asm/arch-socfpga => mach-socfpga/include/mach}/clock_manager.h | 0 arch/arm/{include/asm/arch-socfpga => mach-socfpga/include/mach}/dwmmc.h | 0 .../asm/arch-socfpga => mach-socfpga/include/mach}/fpga_manager.h | 0 .../asm/arch-socfpga => mach-socfpga/include/mach}/freeze_controller.h | 0 arch/arm/{include/asm/arch-socfpga => mach-socfpga/include/mach}/gpio.h | 0 arch/arm/{include/asm/arch-socfpga => mach-socfpga/include/mach}/nic301.h | 0 .../asm/arch-socfpga => mach-socfpga/include/mach}/reset_manager.h | 0 .../asm/arch-socfpga => mach-socfpga/include/mach}/scan_manager.h | 0 arch/arm/{include/asm/arch-socfpga => mach-socfpga/include/mach}/scu.h | 0 arch/arm/{include/asm/arch-socfpga => mach-socfpga/include/mach}/sdram.h | 0 .../asm/arch-socfpga => mach-socfpga/include/mach}/socfpga_base_addrs.h | 0 .../asm/arch-socfpga => mach-socfpga/include/mach}/system_manager.h | 0 arch/arm/{include/asm/arch-socfpga => mach-socfpga/include/mach}/timer.h | 0 13 files changed, 0 insertions(+), 0 deletions(-) rename arch/arm/{include/asm/arch-socfpga => mach-socfpga/include/mach}/clock_manager.h (100%) rename arch/arm/{include/asm/arch-socfpga => mach-socfpga/include/mach}/dwmmc.h (100%) rename arch/arm/{include/asm/arch-socfpga => mach-socfpga/include/mach}/fpga_manager.h (100%) rename arch/arm/{include/asm/arch-socfpga => mach-socfpga/include/mach}/freeze_controller.h (100%) rename arch/arm/{include/asm/arch-socfpga => mach-socfpga/include/mach}/gpio.h (100%) rename arch/arm/{include/asm/arch-socfpga => mach-socfpga/include/mach}/nic301.h (100%) rename arch/arm/{include/asm/arch-socfpga => mach-socfpga/include/mach}/reset_manager.h (100%) rename arch/arm/{include/asm/arch-socfpga => mach-socfpga/include/mach}/scan_manager.h (100%) rename arch/arm/{include/asm/arch-socfpga => mach-socfpga/include/mach}/scu.h (100%) rename arch/arm/{include/asm/arch-socfpga => mach-socfpga/include/mach}/sdram.h (100%) rename arch/arm/{include/asm/arch-socfpga => mach-socfpga/include/mach}/socfpga_base_addrs.h (100%) rename arch/arm/{include/asm/arch-socfpga => mach-socfpga/include/mach}/system_manager.h (100%) rename arch/arm/{include/asm/arch-socfpga => mach-socfpga/include/mach}/timer.h (100%)
diff --git a/arch/arm/include/asm/arch-socfpga/clock_manager.h b/arch/arm/mach-socfpga/include/mach/clock_manager.h similarity index 100% rename from arch/arm/include/asm/arch-socfpga/clock_manager.h rename to arch/arm/mach-socfpga/include/mach/clock_manager.h diff --git a/arch/arm/include/asm/arch-socfpga/dwmmc.h b/arch/arm/mach-socfpga/include/mach/dwmmc.h similarity index 100% rename from arch/arm/include/asm/arch-socfpga/dwmmc.h rename to arch/arm/mach-socfpga/include/mach/dwmmc.h diff --git a/arch/arm/include/asm/arch-socfpga/fpga_manager.h b/arch/arm/mach-socfpga/include/mach/fpga_manager.h similarity index 100% rename from arch/arm/include/asm/arch-socfpga/fpga_manager.h rename to arch/arm/mach-socfpga/include/mach/fpga_manager.h diff --git a/arch/arm/include/asm/arch-socfpga/freeze_controller.h b/arch/arm/mach-socfpga/include/mach/freeze_controller.h similarity index 100% rename from arch/arm/include/asm/arch-socfpga/freeze_controller.h rename to arch/arm/mach-socfpga/include/mach/freeze_controller.h diff --git a/arch/arm/include/asm/arch-socfpga/gpio.h b/arch/arm/mach-socfpga/include/mach/gpio.h similarity index 100% rename from arch/arm/include/asm/arch-socfpga/gpio.h rename to arch/arm/mach-socfpga/include/mach/gpio.h diff --git a/arch/arm/include/asm/arch-socfpga/nic301.h b/arch/arm/mach-socfpga/include/mach/nic301.h similarity index 100% rename from arch/arm/include/asm/arch-socfpga/nic301.h rename to arch/arm/mach-socfpga/include/mach/nic301.h diff --git a/arch/arm/include/asm/arch-socfpga/reset_manager.h b/arch/arm/mach-socfpga/include/mach/reset_manager.h similarity index 100% rename from arch/arm/include/asm/arch-socfpga/reset_manager.h rename to arch/arm/mach-socfpga/include/mach/reset_manager.h diff --git a/arch/arm/include/asm/arch-socfpga/scan_manager.h b/arch/arm/mach-socfpga/include/mach/scan_manager.h similarity index 100% rename from arch/arm/include/asm/arch-socfpga/scan_manager.h rename to arch/arm/mach-socfpga/include/mach/scan_manager.h diff --git a/arch/arm/include/asm/arch-socfpga/scu.h b/arch/arm/mach-socfpga/include/mach/scu.h similarity index 100% rename from arch/arm/include/asm/arch-socfpga/scu.h rename to arch/arm/mach-socfpga/include/mach/scu.h diff --git a/arch/arm/include/asm/arch-socfpga/sdram.h b/arch/arm/mach-socfpga/include/mach/sdram.h similarity index 100% rename from arch/arm/include/asm/arch-socfpga/sdram.h rename to arch/arm/mach-socfpga/include/mach/sdram.h diff --git a/arch/arm/include/asm/arch-socfpga/socfpga_base_addrs.h b/arch/arm/mach-socfpga/include/mach/socfpga_base_addrs.h similarity index 100% rename from arch/arm/include/asm/arch-socfpga/socfpga_base_addrs.h rename to arch/arm/mach-socfpga/include/mach/socfpga_base_addrs.h diff --git a/arch/arm/include/asm/arch-socfpga/system_manager.h b/arch/arm/mach-socfpga/include/mach/system_manager.h similarity index 100% rename from arch/arm/include/asm/arch-socfpga/system_manager.h rename to arch/arm/mach-socfpga/include/mach/system_manager.h diff --git a/arch/arm/include/asm/arch-socfpga/timer.h b/arch/arm/mach-socfpga/include/mach/timer.h similarity index 100% rename from arch/arm/include/asm/arch-socfpga/timer.h rename to arch/arm/mach-socfpga/include/mach/timer.h
Replace CONFIG_SOCFPGA with CONFIG_ARCH_SOCFPGA.
arch/arm/cpu/armv7/Makefile | 2 +- arch/arm/dts/Makefile | 2 +- include/configs/socfpga_common.h | 2 -- 3 files changed, 2 insertions(+), 4 deletions(-)
diff --git a/arch/arm/cpu/armv7/Makefile b/arch/arm/cpu/armv7/Makefile index ffb1cdc..a2e17c0 100644 --- a/arch/arm/cpu/armv7/Makefile +++ b/arch/arm/cpu/armv7/Makefile @@ -12,7 +12,7 @@ obj-y += cache_v7.o obj-y += cpu.o cp15.o obj-y += syslib.o
-ifneq ($(CONFIG_AM43XX)$(CONFIG_AM33XX)$(CONFIG_OMAP44XX)$(CONFIG_OMAP54XX)$(CONFIG_TEGRA)$(CONFIG_MX6)$(CONFIG_TI81XX)$(CONFIG_AT91FAMILY)$(CONFIG_SUNXI)$(CONFIG_SOCFPGA),) +ifneq ($(CONFIG_AM43XX)$(CONFIG_AM33XX)$(CONFIG_OMAP44XX)$(CONFIG_OMAP54XX)$(CONFIG_TEGRA)$(CONFIG_MX6)$(CONFIG_TI81XX)$(CONFIG_AT91FAMILY)$(CONFIG_SUNXI)$(CONFIG_ARCH_SOCFPGA),) ifneq ($(CONFIG_SKIP_LOWLEVEL_INIT),y) obj-y += lowlevel_init.o endif diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 09708d9..8c421b1 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -49,7 +49,7 @@ dtb-$(CONFIG_ZYNQ) += zynq-zc702.dtb \ zynq-zc770-xm013.dtb dtb-$(CONFIG_AM33XX) += am335x-boneblack.dtb
-dtb-$(CONFIG_SOCFPGA) += \ +dtb-$(CONFIG_ARCH_SOCFPGA) += \ socfpga_arria5_socdk.dtb \ socfpga_cyclone5_socdk.dtb \ socfpga_cyclone5_socrates.dtb diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h index 61ce376..e742acf 100644 --- a/include/configs/socfpga_common.h +++ b/include/configs/socfpga_common.h @@ -13,8 +13,6 @@
#define CONFIG_SYS_THUMB_BUILD
-#define CONFIG_SOCFPGA - /* * High level configuration */
On Tuesday, April 21, 2015 at 01:38:17 PM, Masahiro Yamada wrote:
Changes in v2:
All applied, thank you very much!
Best regards, Marek Vasut
Hi Marek,
2015-04-22 2:50 GMT+09:00 Marek Vasut marex@denx.de:
Changes in v2:
Applied to where?
I cannot see this series yet.
On Thursday, May 07, 2015 at 04:34:27 AM, Masahiro Yamada wrote:
Hi Marek,
Changes in v2:
Applied to where?
Uh, I am really an idiot, I don't know what happened here. For some obscure reason, I even have the application in my bash history, but they are not in the repository. I apologize. I just applied them.
Thank you for pointing this out !
Apologies for the inconvenience :-(
Hi Marek,
2015-05-07 12:25 GMT+09:00 Marek Vasut marex@denx.de:
Hi Marek,
Changes in v2:
Applied to where?
OK, thanks.
Please apply this too if you agree. http://patchwork.ozlabs.org/patch/462966/
On Thursday, May 07, 2015 at 06:15:51 AM, Masahiro Yamada wrote:
Hi Marek,
Hi!
Hi Marek,
Changes in v2:
Applied to where?
OK, thanks.
Yessir, applied, thanks!
Hi Marek,
Hi!
Hi Marek,
Changes in v2:
Applied to where?
OK, thanks.
Actually, Dinh asked to be copied on socfpga patches, and he knows a lot about the hardware, so would it make sense to make it?
Thanks, Pavel
index 5f8438e..218349b 100644 --- a/doc/git-mailrc +++ b/doc/git-mailrc @@ -64,6 +64,7 @@ alias rmobile uboot, iwamatsu alias s3c samsung alias s5pc samsung alias samsung uboot, prom +alias socfpga uboot, marex, Dinh Nguyen dinguyen@opensource.altera.com alias sunxi uboot, ijc, jwrdegoede alias tegra uboot, sjg, Tom Warren twarren@nvidia.com, Stephen Warren swarren@nvidia.com alias tegra2 tegra
Hi Marek,
Hi!
Hi Marek,
On Tuesday, April 21, 2015 at 01:38:17 PM, Masahiro Yamada wrote: > Changes in v2: > - Rebase on the top of u-boot-socfpga/master (commit b284d268a) > > Masahiro Yamada (6): > ARM: socfpga: do not add board directory to header search path > ARM: socfpga: remove redundant config.mk > ARM: socfpga: move board select into mach-socfpga/Kconfig > ARM: socfpga: move SoC sources to mach-socfpga > ARM: socfpga: move SoC headers to mach-socfpga/include/mach > ARM: socfpga: abolish CONFIG_SOCFPGA
Applied to where?
OK, thanks.
Yes.
There are three Altera gurus involved with U-Boot though, so do we CC all three of them or just Dinh ? Ideas ?
Hi Marek,
Hi!
Hi Marek,
2015-04-22 2:50 GMT+09:00 Marek Vasut marex@denx.de: > On Tuesday, April 21, 2015 at 01:38:17 PM, Masahiro Yamada wrote: >> Changes in v2: >> - Rebase on the top of u-boot-socfpga/master (commit b284d268a) >> >> Masahiro Yamada (6): >> ARM: socfpga: do not add board directory to header search path >> ARM: socfpga: remove redundant config.mk >> ARM: socfpga: move board select into mach-socfpga/Kconfig >> ARM: socfpga: move SoC sources to mach-socfpga >> ARM: socfpga: move SoC headers to mach-socfpga/include/mach >> ARM: socfpga: abolish CONFIG_SOCFPGA > > All applied, thank you very much!
Applied to where?
OK, thanks.
Yes.
You can just use me and I will parse out the information internally.
Dinh
Hi Marek,
Hi!
On Thursday, May 07, 2015 at 04:34:27 AM, Masahiro Yamada wrote: > Hi Marek,
> 2015-04-22 2:50 GMT+09:00 Marek Vasut marex@denx.de: >> On Tuesday, April 21, 2015 at 01:38:17 PM, Masahiro Yamada wrote: >>> Changes in v2: >>> - Rebase on the top of u-boot-socfpga/master (commit b284d268a) >>> >>> Masahiro Yamada (6): >>> ARM: socfpga: do not add board directory to header search path >>> ARM: socfpga: remove redundant config.mk >>> ARM: socfpga: move board select into mach-socfpga/Kconfig >>> ARM: socfpga: move SoC sources to mach-socfpga >>> ARM: socfpga: move SoC headers to mach-socfpga/include/mach >>> ARM: socfpga: abolish CONFIG_SOCFPGA >> >> All applied, thank you very much! > > Applied to where?
OK, thanks.
Yes.
Yes sir, can you please send a quick patch on top of u-boot-socfpga please? I will send PR after that.
Thanks!
Dinh Nguyen
Masahiro Yamada
Pavel Machek
