[scan-admin@coverity.com: New Defects reported by Coverity Scan for Das U-Boot]
Here's the new issues from the last time I ran Coverity.
----- Forwarded message from scan-admin@coverity.com -----
Date: Tue, 02 Mar 2021 13:31:05 +0000 (UTC) From: scan-admin@coverity.com To: tom.rini@gmail.com Subject: New Defects reported by Coverity Scan for Das U-Boot
Please find the latest report on new defect(s) introduced to Das U-Boot found with Coverity Scan.
2 new defect(s) introduced to Das U-Boot found with Coverity Scan. 3 defect(s), reported by Coverity Scan earlier, were marked fixed in the recent build analyzed by Coverity Scan.
New defect(s) Reported-by: Coverity Scan Showing 2 of 2 defect(s)
** CID 325866: Error handling issues (CHECKED_RETURN) /drivers/core/ofnode.c: 77 in ofnode_read_s32_default()
________________________________________________________________________________________________________ *** CID 325866: Error handling issues (CHECKED_RETURN) /drivers/core/ofnode.c: 77 in ofnode_read_s32_default() 71 return def; 72 } 73 74 int ofnode_read_s32_default(ofnode node, const char *propname, s32 def) 75 { 76 assert(ofnode_valid(node));
CID 325866: Error handling issues (CHECKED_RETURN) Calling "ofnode_read_u32" without checking return value (as is done elsewhere 14 out of 17 times).
77 ofnode_read_u32(node, propname, (u32 *)&def); 78 79 return def; 80 } 81 82 int ofnode_read_u64(ofnode node, const char *propname, u64 *outp)
** CID 325865: Memory - illegal accesses (BUFFER_SIZE_WARNING) /drivers/fastboot/fb_mmc.c: 64 in raw_part_get_info_by_name()
________________________________________________________________________________________________________ *** CID 325865: Memory - illegal accesses (BUFFER_SIZE_WARNING) /drivers/fastboot/fb_mmc.c: 64 in raw_part_get_info_by_name() 58 } 59 } 60 61 info->start = simple_strtoul(argv[0], NULL, 0); 62 info->size = simple_strtoul(argv[1], NULL, 0); 63 info->blksz = dev_desc->blksz;
CID 325865: Memory - illegal accesses (BUFFER_SIZE_WARNING) Calling "strncpy" with a maximum size argument of 32 bytes on destination array "info->name" of size 32 bytes might leave the destination string unterminated.
64 strncpy((char *)info->name, name, PART_NAME_LEN); 65 66 if (raw_part_desc) { 67 if (strcmp(strsep(&raw_part_desc, " "), "mmcpart") == 0) { 68 ulong mmcpart = simple_strtoul(raw_part_desc, NULL, 0); 69 int ret = blk_dselect_hwpart(dev_desc, mmcpart);
________________________________________________________________________________________________________ To view the defects in Coverity Scan visit, https://u15810271.ct.sendgrid.net/ls/click?upn=HRESupC-2F2Czv4BOaCWWCy7my0P0...
To manage Coverity Scan email notifications for "tom.rini@gmail.com", click https://u15810271.ct.sendgrid.net/ls/click?upn=HRESupC-2F2Czv4BOaCWWCy7my0P0...
----- End forwarded message -----
