[U-Boot] [PATCH v2 1/2] am43xx_evm: Add qspiboot target
The ePOS EVM and EVM SK have QSPI as an option to boot. Add a qspiboot target that utilizes QSPI for env and so forth as an example of best practices. As QSPI is booted from directly we need to chang CONFIG_SYS_TEXT_BASE.
Note that on ePOS EVM the QSPI and NAND are mutually exclusive choices we need to handle that elsewhere, once NAND support is also added.
Signed-off-by: Sourav Poddar sourav.poddar@ti.com Signed-off-by: Tom Rini trini@ti.com --- arch/arm/cpu/armv7/am33xx/board.c | 2 +- board/ti/am43xx/Makefile | 2 +- board/ti/am43xx/board.c | 2 +- boards.cfg | 1 + include/configs/am43xx_evm.h | 31 ++++++++++++++++++++++++++++--- include/configs/ti_armv7_common.h | 2 +- 6 files changed, 33 insertions(+), 7 deletions(-)
diff --git a/arch/arm/cpu/armv7/am33xx/board.c b/arch/arm/cpu/armv7/am33xx/board.c index 453ad72..9a69b6c 100644 --- a/arch/arm/cpu/armv7/am33xx/board.c +++ b/arch/arm/cpu/armv7/am33xx/board.c @@ -224,7 +224,7 @@ void s_init(void) set_uart_mux_conf(); setup_clocks_for_console(); uart_soft_reset(); -#ifdef CONFIG_NOR_BOOT +#if defined(CONFIG_NOR_BOOT) || defined(CONFIG_QSPI_BOOT) gd->baudrate = CONFIG_BAUDRATE; serial_init(); gd->have_console = 1; diff --git a/board/ti/am43xx/Makefile b/board/ti/am43xx/Makefile index cb5fe88..36ecb30 100644 --- a/board/ti/am43xx/Makefile +++ b/board/ti/am43xx/Makefile @@ -6,7 +6,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-ifdef CONFIG_SPL_BUILD +ifeq ($(CONFIG_SKIP_LOWLEVEL_INIT),) obj-y := mux.o endif
diff --git a/board/ti/am43xx/board.c b/board/ti/am43xx/board.c index 3078fc1..5b11eb2 100644 --- a/board/ti/am43xx/board.c +++ b/board/ti/am43xx/board.c @@ -70,7 +70,7 @@ static int read_eeprom(struct am43xx_board_id *header) return 0; }
-#ifdef CONFIG_SPL_BUILD +#ifndef CONFIG_SKIP_LOWLEVEL_INIT
#define NUM_OPPS 6
diff --git a/boards.cfg b/boards.cfg index 0497a91..19c19c5 100644 --- a/boards.cfg +++ b/boards.cfg @@ -276,6 +276,7 @@ Active arm armv7 am33xx ti am335x Active arm armv7 am33xx ti am335x am335x_evm_uart5 am335x_evm:SERIAL6,CONS_INDEX=6,NAND Tom Rini trini@ti.com Active arm armv7 am33xx ti am335x am335x_evm_usbspl am335x_evm:SERIAL1,CONS_INDEX=1,NAND,SPL_USBETH_SUPPORT Tom Rini trini@ti.com Active arm armv7 am33xx ti am43xx am43xx_evm am43xx_evm:SERIAL1,CONS_INDEX=1 Lokesh Vutla lokeshvutla@ti.com +Active arm armv7 am33xx ti am43xx am43xx_evm_qspiboot am43xx_evm:SERIAL1,CONS_INDEX=1,QSPI,QSPI_BOOT Lokesh Vutla lokeshvutla@ti.com Active arm armv7 am33xx ti ti814x ti814x_evm - Matt Porter matt.porter@linaro.org Active arm armv7 am33xx ti ti816x ti816x_evm - - Active arm armv7 at91 atmel sama5d3_xplained sama5d3_xplained_mmc sama5d3_xplained:SAMA5D3,SYS_USE_MMC Bo Shen voice.shen@atmel.com diff --git a/include/configs/am43xx_evm.h b/include/configs/am43xx_evm.h index c574ed4..94126c7 100644 --- a/include/configs/am43xx_evm.h +++ b/include/configs/am43xx_evm.h @@ -48,15 +48,15 @@ * Since SPL did pll and ddr initialization for us, * we don't need to do it twice. */ -#if !defined(CONFIG_SPL_BUILD) && !defined(CONFIG_NOR_BOOT) +#if !defined(CONFIG_SPL_BUILD) && !defined(CONFIG_QSPI_BOOT) #define CONFIG_SKIP_LOWLEVEL_INIT #endif
/* Now bring in the rest of the common code. */ #include <configs/ti_armv7_common.h>
-/* Always 128 KiB env size */ -#define CONFIG_ENV_SIZE (128 << 10) +/* Always 64 KiB env size */ +#define CONFIG_ENV_SIZE (64 << 10)
#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG
@@ -86,6 +86,30 @@ #define CONFIG_OMAP_USB_PHY #define CONFIG_AM437X_USB2PHY2_HOST
+#ifdef CONFIG_QSPI_BOOT +#define CONFIG_SYS_TEXT_BASE 0x30000000 +#undef CONFIG_ENV_IS_NOWHERE +#define CONFIG_ENV_IS_IN_SPI_FLASH +#define CONFIG_SYS_REDUNDAND_ENVIRONMENT +#define CONFIG_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED +#define CONFIG_ENV_SECT_SIZE (64 << 10) /* 64 KB sectors */ +#define CONFIG_ENV_OFFSET 0x110000 +#define CONFIG_ENV_OFFSET_REDUND 0x120000 +#ifdef MTDIDS_DEFAULT +#undef MTDIDS_DEFAULT +#endif +#ifdef MTDPARTS_DEFAULT +#undef MTDPARTS_DEFAULT +#endif +#define MTDPARTS_DEFAULT "mtdparts=qspi.0:512k(QSPI.u-boot)," \ + "512k(QSPI.u-boot.backup)," \ + "512k(QSPI.u-boot-spl-os)," \ + "64k(QSPI.u-boot-env)," \ + "64k(QSPI.u-boot-env.backup)," \ + "8m(QSPI.kernel)," \ + "-(QSPI.file-system)" +#endif + /* SPI */ #undef CONFIG_OMAP3_SPI #define CONFIG_TI_QSPI @@ -94,6 +118,7 @@ #define CONFIG_CMD_SF #define CONFIG_CMD_SPI #define CONFIG_TI_SPI_MMAP +#define CONFIG_SPI_FLASH_BAR #define CONFIG_QSPI_SEL_GPIO 48 #define CONFIG_SF_DEFAULT_SPEED 48000000 #define CONFIG_DEFAULT_SPI_MODE SPI_MODE_3 diff --git a/include/configs/ti_armv7_common.h b/include/configs/ti_armv7_common.h index 4854272..3bf4413 100644 --- a/include/configs/ti_armv7_common.h +++ b/include/configs/ti_armv7_common.h @@ -196,7 +196,7 @@ * under common/spl/. Given our generally common memory map, we set a * number of related defaults and sizes here. */ -#ifndef CONFIG_NOR_BOOT +#if !defined(CONFIG_NOR_BOOT) && !defined(CONFIG_QSPI_BOOT) #define CONFIG_SPL #define CONFIG_SPL_FRAMEWORK #define CONFIG_SPL_OS_BOOT
The patch populates the slave data which will be used by flash driver to set the flash quad enable bit.
Signed-off-by: Sourav Poddar sourav.poddar@ti.com --- drivers/spi/ti_qspi.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/spi/ti_qspi.c b/drivers/spi/ti_qspi.c index c5d2245..fd7fea8 100644 --- a/drivers/spi/ti_qspi.c +++ b/drivers/spi/ti_qspi.c @@ -106,6 +106,7 @@ static void ti_spi_setup_spi_register(struct ti_qspi_slave *qslave) slave->memory_map = (void *)MMAP_START_ADDR_DRA; #else slave->memory_map = (void *)MMAP_START_ADDR_AM43x; + slave->op_mode_rx = 8; #endif
memval |= QSPI_CMD_READ | QSPI_SETUP0_NUM_A_BYTES |
Applied to u-boot-ti/master, thanks!
