[U-Boot] [PATCH] smdk6400: Move smdk6400 board from Makefile to boards.cfg
Signed-off-by: Zhong Hongbo bocui107@gmail.com --- Makefile | 20 -------------------- board/samsung/smdk6400/config.mk | 4 +--- boards.cfg | 2 ++ include/configs/smdk6400.h | 2 +- 4 files changed, 4 insertions(+), 24 deletions(-)
diff --git a/Makefile b/Makefile index 0197239..e3af33f 100644 --- a/Makefile +++ b/Makefile @@ -695,26 +695,6 @@ SX1_config: unconfig fi; @$(MKCONFIG) -n $@ SX1 arm arm925t sx1
-######################################################################### -## ARM1176 Systems -######################################################################### -smdk6400_noUSB_config \ -smdk6400_config : unconfig - @mkdir -p $(obj)include $(obj)board/samsung/smdk6400 - @mkdir -p $(obj)nand_spl/board/samsung/smdk6400 - @echo "#define CONFIG_NAND_U_BOOT" > $(obj)include/config.h - @echo "CONFIG_NAND_U_BOOT = y" >> $(obj)include/config.mk - @if [ -z "$(findstring smdk6400_noUSB_config,$@)" ]; then \ - echo "RAM_TEXT = 0x57e00000" >> $(obj)board/samsung/smdk6400/config.tmp;\ - else \ - echo "RAM_TEXT = 0xc7e00000" >> $(obj)board/samsung/smdk6400/config.tmp;\ - fi - @$(MKCONFIG) smdk6400 arm arm1176 smdk6400 samsung s3c64xx - @echo "CONFIG_NAND_U_BOOT = y" >> $(obj)include/config.mk - -######################################################################### -######################################################################### - clean: @rm -f $(obj)examples/standalone/82559_eeprom \ $(obj)examples/standalone/atmel_df_pow2 \ diff --git a/board/samsung/smdk6400/config.mk b/board/samsung/smdk6400/config.mk index 6f04c2f..93a1a0d 100644 --- a/board/samsung/smdk6400/config.mk +++ b/board/samsung/smdk6400/config.mk @@ -21,10 +21,8 @@ # # download area is 0x5000c000
-sinclude $(OBJTREE)/board/$(BOARDDIR)/config.tmp - ifndef CONFIG_NAND_SPL -CONFIG_SYS_TEXT_BASE = $(RAM_TEXT) +CONFIG_SYS_TEXT_BASE = $(CONFIG_RAM_TEXT) else CONFIG_SYS_TEXT_BASE = 0 endif diff --git a/boards.cfg b/boards.cfg index 53f6dc3..42b0883 100644 --- a/boards.cfg +++ b/boards.cfg @@ -47,6 +47,8 @@ flea3 arm arm1136 - CarMedi mx35pdk arm arm1136 - freescale mx35 apollon arm arm1136 apollon - omap24xx omap2420h4 arm arm1136 - ti omap24xx +smdk6400 arm arm1176 smdk6400 samsung s3c64xx smdk6400:NAND_U_BOOT,RAM_TEXT=0xc7e00000 +smdk6400_nousb arm arm1176 smdk6400 samsung s3c64xx smdk6400:NAND_U_BOOT,RAM_TEXT=0x57e00000 tnetv107x_evm arm arm1176 tnetv107xevm ti tnetv107x integratorap_cm720t arm arm720t integrator armltd - integratorap:CM720T integratorap_cm920t arm arm920t integrator armltd - integratorap:CM920T diff --git a/include/configs/smdk6400.h b/include/configs/smdk6400.h index 04caeef..47326d6 100644 --- a/include/configs/smdk6400.h +++ b/include/configs/smdk6400.h @@ -54,7 +54,7 @@ /* input clock of PLL: SMDK6400 has 12MHz input clock */ #define CONFIG_SYS_CLK_FREQ 12000000
-#if !defined(CONFIG_NAND_SPL) && (CONFIG_SYS_TEXT_BASE >= 0xc0000000) +#if !defined(CONFIG_NAND_U_BOOT) && (CONFIG_SYS_TEXT_BASE >= 0xc0000000) #define CONFIG_ENABLE_MMU #endif
Hi Minkyu,
Could you help me to review the patch.
Thanks
- else \
- fi
Zhong Hongbo
