[U-Boot] [uboot] [PATCH v2 1/2] net: phy: dp83867: Add device tree bindings and documentation
Add the device tree bindings and the accompanying documentation for the TI DP83867 Giga bit ethernet phy driver.
The original document was from: [commit 2a10154abcb75ad0d7b6bfea6210ac743ec60897 from the Linux kernel]
Signed-off-by: Dan Murphy dmurphy@ti.com ---
v2 - Align the documentation with the actual bindings - https://patchwork.ozlabs.org/patch/606502/
doc/device-tree-bindings/net/ti,dp83867.txt | 28 +++++++++++++++++++++++ include/dt-bindings/net/ti-dp83867.h | 35 +++++++++++++++++++++++++++++ 2 files changed, 63 insertions(+) create mode 100644 doc/device-tree-bindings/net/ti,dp83867.txt create mode 100644 include/dt-bindings/net/ti-dp83867.h
diff --git a/doc/device-tree-bindings/net/ti,dp83867.txt b/doc/device-tree-bindings/net/ti,dp83867.txt new file mode 100644 index 0000000..34b1c35 --- /dev/null +++ b/doc/device-tree-bindings/net/ti,dp83867.txt @@ -0,0 +1,28 @@ +* Texas Instruments - dp83867 Giga bit ethernet phy + +Required properties: + - ti,rx_int_delay - RGMII Recieve Clock Delay - see dt-bindings/net/ti-dp83867.h + for applicable values + - ti,tx_int_delay - RGMII Transmit Clock Delay - see dt-bindings/net/ti-dp83867.h + for applicable values + - ti,fifo-depth - Transmitt FIFO depth- see dt-bindings/net/ti-dp83867.h + for applicable values + +Default child nodes are standard Ethernet PHY device +nodes as described in doc/devicetree/bindings/net/ethernet.txt + +Example: + +&mac { + pinctrl-0 = <&davinci_mdio_default>; + pinctrl-1 = <&davinci_mdio_sleep>; + status = "okay"; + + ti,rx_int_delay = <DP83867_RGMIIDCTL_1_50_NS>; + ti,tx_int_delay = <DP83867_RGMIIDCTL_2_50_NS>; + ti,fifo_depth = <DP83867_PHYCR_FIFO_DEPTH_8_B_NIB>; + +}; + +Datasheet can be found: +http://www.ti.com/product/DP83867IR/datasheet diff --git a/include/dt-bindings/net/ti-dp83867.h b/include/dt-bindings/net/ti-dp83867.h new file mode 100644 index 0000000..5c592fb --- /dev/null +++ b/include/dt-bindings/net/ti-dp83867.h @@ -0,0 +1,35 @@ +/* + * TI DP83867 PHY drivers + * + * SPDX-License-Identifier: GPL-2.0 + * + */ + +#ifndef _DT_BINDINGS_TI_DP83867_H +#define _DT_BINDINGS_TI_DP83867_H + +/* PHY CTRL bits */ +#define DP83867_PHYCR_FIFO_DEPTH_3_B_NIB 0x00 +#define DP83867_PHYCR_FIFO_DEPTH_4_B_NIB 0x01 +#define DP83867_PHYCR_FIFO_DEPTH_6_B_NIB 0x02 +#define DP83867_PHYCR_FIFO_DEPTH_8_B_NIB 0x03 + +/* RGMIIDCTL internal delay for rx and tx */ +#define DP83867_RGMIIDCTL_250_PS 0x0 +#define DP83867_RGMIIDCTL_500_PS 0x1 +#define DP83867_RGMIIDCTL_750_PS 0x2 +#define DP83867_RGMIIDCTL_1_NS 0x3 +#define DP83867_RGMIIDCTL_1_25_NS 0x4 +#define DP83867_RGMIIDCTL_1_50_NS 0x5 +#define DP83867_RGMIIDCTL_1_75_NS 0x6 +#define DP83867_RGMIIDCTL_2_00_NS 0x7 +#define DP83867_RGMIIDCTL_2_25_NS 0x8 +#define DP83867_RGMIIDCTL_2_50_NS 0x9 +#define DP83867_RGMIIDCTL_2_75_NS 0xa +#define DP83867_RGMIIDCTL_3_00_NS 0xb +#define DP83867_RGMIIDCTL_3_25_NS 0xc +#define DP83867_RGMIIDCTL_3_50_NS 0xd +#define DP83867_RGMIIDCTL_3_75_NS 0xe +#define DP83867_RGMIIDCTL_4_00_NS 0xf + +#endif
Not all devices use the same internal delay or fifo depth. Add the ability to set the internal delay for rx or tx and the fifo depth via the devicetree. If the value is not set in the devicetree then set the delay to the default.
If devicetree is not used then use the default defines within the driver.
v2 - no change from v1
drivers/net/phy/ti.c | 81 ++++++++++++++++++++++++++++++++++++++++++++++------ 1 file changed, 73 insertions(+), 8 deletions(-)
diff --git a/drivers/net/phy/ti.c b/drivers/net/phy/ti.c index c3912d5..e91a6ed 100644 --- a/drivers/net/phy/ti.c +++ b/drivers/net/phy/ti.c @@ -6,6 +6,14 @@ */ #include <common.h> #include <phy.h> +#include <linux/compat.h> +#include <malloc.h> + +#include <fdtdec.h> +#include <dm.h> +#include <dt-bindings/net/ti-dp83867.h> + +DECLARE_GLOBAL_DATA_PTR;
/* TI DP83867 */ #define DP83867_DEVADDR 0x1f @@ -57,6 +65,17 @@ #define MII_MMD_CTRL_INCR_RDWT 0x8000 /* post increment on reads & writes */ #define MII_MMD_CTRL_INCR_ON_WT 0xC000 /* post increment on writes only */
+/* User setting - can be taken from DTS */ +#define DEFAULT_RX_ID_DELAY DP83867_RGMIIDCTL_2_25_NS +#define DEFAULT_TX_ID_DELAY DP83867_RGMIIDCTL_2_75_NS +#define DEFAULT_FIFO_DEPTH DP83867_PHYCR_FIFO_DEPTH_4_B_NIB + +struct dp83867_private { + int rx_id_delay; + int tx_id_delay; + int fifo_depth; +}; + /** * phy_read_mmd_indirect - reads data from the MMD registers * @phydev: The PHY device bus @@ -134,16 +153,58 @@ static inline bool phy_interface_is_rgmii(struct phy_device *phydev) phydev->interface <= PHY_INTERFACE_MODE_RGMII_TXID; }
-/* User setting - can be taken from DTS */ -#define RX_ID_DELAY 8 -#define TX_ID_DELAY 0xa -#define FIFO_DEPTH 1 +#if defined(CONFIG_DM_ETH) +/** + * dp83867_data_init - Convenience function for setting PHY specific data + * + * @phydev: the phy_device struct + */ +static int dp83867_of_init(struct phy_device *phydev) +{ + struct dp83867_private *dp83867 = phydev->priv; + struct udevice *dev = phydev->dev; + + dp83867->rx_id_delay = fdtdec_get_uint(gd->fdt_blob, dev->of_offset, + "ti,rx_int_delay", DEFAULT_RX_ID_DELAY); + + dp83867->tx_id_delay = fdtdec_get_uint(gd->fdt_blob, dev->of_offset, + "ti,tx_int_delay", DEFAULT_TX_ID_DELAY); + + dp83867->fifo_depth = fdtdec_get_uint(gd->fdt_blob, dev->of_offset, + "ti,fifo_depth", DEFAULT_FIFO_DEPTH); + + return 0; +} +#else +static int dp83867_of_init(struct phy_device *phydev) +{ + dp83867->rx_id_delay = DEFAULT_RX_ID_DELAY; + dp83867->tx_id_delay = DEFAULT_TX_ID_DELAY; + dp83867->fifo_depth = DEFAULT_FIFO_DEPTH; + + return 0; +} +#endif
static int dp83867_config(struct phy_device *phydev) { + struct dp83867_private *dp83867; unsigned int val, delay; int ret;
+ if (!phydev->priv) { + dp83867 = kzalloc(sizeof(*dp83867), GFP_KERNEL); + if (!dp83867) + return -ENOMEM; + + phydev->priv = dp83867; + ret = dp83867_of_init(phydev); + if (ret) + goto err_out; + } else { + dp83867 = (struct dp83867_private *)phydev->priv; + } + /* Restart the PHY. */ val = phy_read(phydev, MDIO_DEVAD_NONE, DP83867_CTRL); phy_write(phydev, MDIO_DEVAD_NONE, DP83867_CTRL, @@ -152,9 +213,9 @@ static int dp83867_config(struct phy_device *phydev) if (phy_interface_is_rgmii(phydev)) { ret = phy_write(phydev, MDIO_DEVAD_NONE, MII_DP83867_PHYCTRL, (DP83867_MDI_CROSSOVER_AUTO << DP83867_MDI_CROSSOVER) | - (FIFO_DEPTH << DP83867_PHYCR_FIFO_DEPTH_SHIFT)); + (dp83867->fifo_depth << DP83867_PHYCR_FIFO_DEPTH_SHIFT)); if (ret) - return ret; + goto err_out; }
if ((phydev->interface >= PHY_INTERFACE_MODE_RGMII_ID) && @@ -175,8 +236,8 @@ static int dp83867_config(struct phy_device *phydev) phy_write_mmd_indirect(phydev, DP83867_RGMIICTL, DP83867_DEVADDR, phydev->addr, val);
- delay = (RX_ID_DELAY | - (TX_ID_DELAY << DP83867_RGMII_TX_CLK_DELAY_SHIFT)); + delay = (dp83867->rx_id_delay | + (dp83867->tx_id_delay << DP83867_RGMII_TX_CLK_DELAY_SHIFT));
phy_write_mmd_indirect(phydev, DP83867_RGMIIDCTL, DP83867_DEVADDR, phydev->addr, delay); @@ -184,6 +245,10 @@ static int dp83867_config(struct phy_device *phydev)
genphy_config_aneg(phydev); return 0; + +err_out: + kfree(dp83867); + return ret; }
static struct phy_driver DP83867_driver = {
+Example:
+&mac {
- pinctrl-0 = <&davinci_mdio_default>;
- pinctrl-1 = <&davinci_mdio_sleep>;
- status = "okay";
- ti,rx_int_delay = <DP83867_RGMIIDCTL_1_50_NS>;
- ti,tx_int_delay = <DP83867_RGMIIDCTL_2_50_NS>;
- ti,fifo_depth = <DP83867_PHYCR_FIFO_DEPTH_8_B_NIB>;
- TI DP83867 PHY drivers
- SPDX-License-Identifier: GPL-2.0
Nack from me. Just follow Linux binding instead of create new one.
Thanks, Michal
+Example:
+&mac {
- status = "okay";
Why a nack?
This comes from the Linux kernel mainline code I submited. I am not creating anything new. This technically should have come in with the original port of the driver I pushed to the Linux kernel.
But I defer to the Tom for the resolution.
Dan
Thanks, Michal
+Example:
+&mac {
- status = "okay";
Why a nack?
Well boo. I know what you are referring to now.
I did not use ti,tx-internal-delay and ti,rx-internal-delay. I used ti,tx-int-delay and ti,rx-int-delay
which is wrong. Here come v3 with the update
Dan
Dan
Thanks, Michal
Dan Murphy
Michal Simek
