[U-Boot] [PATCH 1/4] blackfin: the sclk MHz in i2c driver should be divided by 1000 other than 1024
Signed-off-by: Sonic Zhang sonic.zhang@analog.com --- drivers/i2c/bfin-twi_i2c.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/i2c/bfin-twi_i2c.c b/drivers/i2c/bfin-twi_i2c.c index b3a04d3..5c37280 100644 --- a/drivers/i2c/bfin-twi_i2c.c +++ b/drivers/i2c/bfin-twi_i2c.c @@ -274,7 +274,7 @@ unsigned int i2c_get_bus_speed(void) */ void i2c_init(int speed, int slaveaddr) { - uint8_t prescale = ((get_sclk() / 1024 / 1024 + 5) / 10) & 0x7F; + uint8_t prescale = ((get_sclk() / 1000 / 1000 + 5) / 10) & 0x7F;
/* Set TWI internal clock as 10MHz */ twi->control = prescale;
Signed-off-by: Sonic Zhang sonic.zhang@analog.com --- arch/blackfin/include/asm/blackfin_local.h | 7 ------- arch/blackfin/include/asm/clock.h | 11 +++++++++++ drivers/i2c/bfin-twi_i2c.c | 3 ++- drivers/spi/bfin_spi.c | 7 ++++--- drivers/spi/bfin_spi6xx.c | 7 ++++--- 5 files changed, 21 insertions(+), 14 deletions(-)
diff --git a/arch/blackfin/include/asm/blackfin_local.h b/arch/blackfin/include/asm/blackfin_local.h index 4d6eeab..868c82e 100644 --- a/arch/blackfin/include/asm/blackfin_local.h +++ b/arch/blackfin/include/asm/blackfin_local.h @@ -42,13 +42,6 @@
# include <linux/types.h>
-extern u_long get_vco(void); -extern u_long get_cclk(void); -extern u_long get_sclk(void); -extern u_long get_sclk0(void); -extern u_long get_sclk1(void); -extern u_long get_dclk(void); - # define bfin_revid() (bfin_read_CHIPID() >> 28)
extern int bfin_os_log_check(void); diff --git a/arch/blackfin/include/asm/clock.h b/arch/blackfin/include/asm/clock.h index fc84fe4..59d3faa 100644 --- a/arch/blackfin/include/asm/clock.h +++ b/arch/blackfin/include/asm/clock.h @@ -68,10 +68,21 @@ static inline uint32_t early_get_uart_clk(void) return uclk; }
+extern u_long get_vco(void); +extern u_long get_cclk(void); +extern u_long get_sclk(void); + #ifdef CGU_DIV +extern u_long get_sclk0(void); +extern u_long get_sclk1(void); +extern u_long get_dclk(void); # define get_uart_clk get_sclk0 +# define get_i2c_clk get_sclk0 +# define get_spi_clk get_sclk0 #else # define get_uart_clk get_sclk +# define get_i2c_clk get_sclk +# define get_spi_clk get_sclk #endif
#endif diff --git a/drivers/i2c/bfin-twi_i2c.c b/drivers/i2c/bfin-twi_i2c.c index 5c37280..cfab064 100644 --- a/drivers/i2c/bfin-twi_i2c.c +++ b/drivers/i2c/bfin-twi_i2c.c @@ -10,6 +10,7 @@ #include <i2c.h>
#include <asm/blackfin.h> +#include <asm/clock.h> #include <asm/mach-common/bits/twi.h>
/* Every register is 32bit aligned, but only 16bits in size */ @@ -274,7 +275,7 @@ unsigned int i2c_get_bus_speed(void) */ void i2c_init(int speed, int slaveaddr) { - uint8_t prescale = ((get_sclk() / 1000 / 1000 + 5) / 10) & 0x7F; + uint8_t prescale = ((get_i2c_clk() / 1000 / 1000 + 5) / 10) & 0x7F;
/* Set TWI internal clock as 10MHz */ twi->control = prescale; diff --git a/drivers/spi/bfin_spi.c b/drivers/spi/bfin_spi.c index aa89d89..71a31d0 100644 --- a/drivers/spi/bfin_spi.c +++ b/drivers/spi/bfin_spi.c @@ -13,6 +13,7 @@ #include <spi.h>
#include <asm/blackfin.h> +#include <asm/clock.h> #include <asm/gpio.h> #include <asm/portmux.h> #include <asm/mach-common/bits/spi.h> @@ -140,12 +141,12 @@ static const unsigned short cs_pins[][7] = { void spi_set_speed(struct spi_slave *slave, uint hz) { struct bfin_spi_slave *bss = to_bfin_spi_slave(slave); - ulong sclk; + ulong clk; u32 baud;
- sclk = get_sclk(); + clk = get_spi_clk(); /* baud should be rounded up */ - baud = DIV_ROUND_UP(sclk, 2 * hz); + baud = DIV_ROUND_UP(clk, 2 * hz); if (baud < 2) baud = 2; else if (baud > (u16)-1) diff --git a/drivers/spi/bfin_spi6xx.c b/drivers/spi/bfin_spi6xx.c index 07b833d..eba01d1 100644 --- a/drivers/spi/bfin_spi6xx.c +++ b/drivers/spi/bfin_spi6xx.c @@ -22,6 +22,7 @@ #include <spi.h>
#include <asm/blackfin.h> +#include <asm/clock.h> #include <asm/gpio.h> #include <asm/portmux.h> #include <asm/mach-common/bits/spi6xx.h> @@ -135,11 +136,11 @@ static const unsigned short cs_pins[][7] = { void spi_set_speed(struct spi_slave *slave, uint hz) { struct bfin_spi_slave *bss = to_bfin_spi_slave(slave); - ulong sclk; + ulong clk; u32 clock;
- sclk = get_sclk1(); - clock = sclk / hz; + clk = get_spi_clk(); + clock = clk / hz; if (clock) clock--; bss->clock = clock;
Hello Sonic,
Am 28.01.2014 06:53, schrieb Sonic Zhang:
Signed-off-by: Sonic Zhangsonic.zhang@analog.com
Applied to u-boot-i2c.git, thanks!
bye, Heiko
The ADI twi peripheral is not binding to Blackfin processor only. Change to a generic name.
Signed-off-by: Sonic Zhang sonic.zhang@analog.com --- arch/blackfin/include/asm/twi.h | 15 +++++++++++++++ drivers/i2c/Makefile | 2 +- drivers/i2c/{bfin-twi_i2c.c => adi_i2c.c} | 3 +-- include/configs/bct-brettl2.h | 2 +- include/configs/bf518f-ezbrd.h | 2 +- include/configs/bf526-ezbrd.h | 2 +- include/configs/bf527-ad7160-eval.h | 2 +- include/configs/bf527-ezkit.h | 2 +- include/configs/bf527-sdp.h | 2 +- include/configs/bf537-minotaur.h | 2 +- include/configs/bf537-pnav.h | 2 +- include/configs/bf537-srv1.h | 2 +- include/configs/bf537-stamp.h | 2 +- include/configs/bf538f-ezkit.h | 2 +- include/configs/bf548-ezkit.h | 2 +- include/configs/bf609-ezkit.h | 2 +- include/configs/br4.h | 2 +- include/configs/cm-bf527.h | 2 +- include/configs/cm-bf537e.h | 2 +- include/configs/cm-bf537u.h | 2 +- include/configs/cm-bf548.h | 2 +- include/configs/pr1.h | 2 +- include/configs/tcm-bf518.h | 2 +- include/configs/tcm-bf537.h | 2 +- 24 files changed, 38 insertions(+), 24 deletions(-) create mode 100644 arch/blackfin/include/asm/twi.h rename drivers/i2c/{bfin-twi_i2c.c => adi_i2c.c} (99%)
diff --git a/arch/blackfin/include/asm/twi.h b/arch/blackfin/include/asm/twi.h new file mode 100644 index 0000000..922cdbd --- /dev/null +++ b/arch/blackfin/include/asm/twi.h @@ -0,0 +1,15 @@ +/* + * i2c.c - driver for Blackfin on-chip TWI/I2C + * + * Copyright (c) 2006-2010 Analog Devices Inc. + * + * Licensed under the GPL-2 or later. + */ + +#ifndef __ARCH_TWI_H +#define __ARCH_TWI_H + +#include <asm/blackfin.h> +#include <asm/mach-common/bits/twi.h> + +#endif diff --git a/drivers/i2c/Makefile b/drivers/i2c/Makefile index fa3a875..4bf4d2e 100644 --- a/drivers/i2c/Makefile +++ b/drivers/i2c/Makefile @@ -5,7 +5,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-obj-$(CONFIG_BFIN_TWI_I2C) += bfin-twi_i2c.o +obj-$(CONFIG_ADI_I2C) += adi_i2c.o obj-$(CONFIG_DRIVER_DAVINCI_I2C) += davinci_i2c.o obj-$(CONFIG_DW_I2C) += designware_i2c.o obj-$(CONFIG_I2C_MVTWSI) += mvtwsi.o diff --git a/drivers/i2c/bfin-twi_i2c.c b/drivers/i2c/adi_i2c.c similarity index 99% rename from drivers/i2c/bfin-twi_i2c.c rename to drivers/i2c/adi_i2c.c index cfab064..743aa25 100644 --- a/drivers/i2c/bfin-twi_i2c.c +++ b/drivers/i2c/adi_i2c.c @@ -9,9 +9,8 @@ #include <common.h> #include <i2c.h>
-#include <asm/blackfin.h> #include <asm/clock.h> -#include <asm/mach-common/bits/twi.h> +#include <asm/twi.h>
/* Every register is 32bit aligned, but only 16bits in size */ #define ureg(name) u16 name; u16 __pad_##name; diff --git a/include/configs/bct-brettl2.h b/include/configs/bct-brettl2.h index 5b09b45..93a713b 100644 --- a/include/configs/bct-brettl2.h +++ b/include/configs/bct-brettl2.h @@ -121,7 +121,7 @@ /* * I2C Settings */ -#define CONFIG_BFIN_TWI_I2C 1 +#define CONFIG_ADI_I2C 1 #define CONFIG_HARD_I2C 1
diff --git a/include/configs/bf518f-ezbrd.h b/include/configs/bf518f-ezbrd.h index a97972b..4b94ba5 100644 --- a/include/configs/bf518f-ezbrd.h +++ b/include/configs/bf518f-ezbrd.h @@ -134,7 +134,7 @@ /* * I2C Settings */ -#define CONFIG_BFIN_TWI_I2C 1 +#define CONFIG_ADI_I2C 1 #define CONFIG_HARD_I2C 1
diff --git a/include/configs/bf526-ezbrd.h b/include/configs/bf526-ezbrd.h index 0031093..54f26f4 100644 --- a/include/configs/bf526-ezbrd.h +++ b/include/configs/bf526-ezbrd.h @@ -131,7 +131,7 @@ /* * I2C Settings */ -#define CONFIG_BFIN_TWI_I2C 1 +#define CONFIG_ADI_I2C 1 #define CONFIG_HARD_I2C 1
diff --git a/include/configs/bf527-ad7160-eval.h b/include/configs/bf527-ad7160-eval.h index fa05103..ca6b0d5 100644 --- a/include/configs/bf527-ad7160-eval.h +++ b/include/configs/bf527-ad7160-eval.h @@ -119,7 +119,7 @@ /* * I2C Settings */ -#define CONFIG_BFIN_TWI_I2C 1 +#define CONFIG_ADI_I2C 1 #define CONFIG_HARD_I2C 1
diff --git a/include/configs/bf527-ezkit.h b/include/configs/bf527-ezkit.h index db1b613..7ec5b02 100644 --- a/include/configs/bf527-ezkit.h +++ b/include/configs/bf527-ezkit.h @@ -134,7 +134,7 @@ /* * I2C Settings */ -#define CONFIG_BFIN_TWI_I2C 1 +#define CONFIG_ADI_I2C 1 #define CONFIG_HARD_I2C 1
diff --git a/include/configs/bf527-sdp.h b/include/configs/bf527-sdp.h index c0e8b5a..96629d4 100644 --- a/include/configs/bf527-sdp.h +++ b/include/configs/bf527-sdp.h @@ -103,7 +103,7 @@ /* * I2C Settings */ -#define CONFIG_BFIN_TWI_I2C 1 +#define CONFIG_ADI_I2C 1 #define CONFIG_HARD_I2C 1
diff --git a/include/configs/bf537-minotaur.h b/include/configs/bf537-minotaur.h index 156eeab..2b2f79c 100644 --- a/include/configs/bf537-minotaur.h +++ b/include/configs/bf537-minotaur.h @@ -120,7 +120,7 @@ /* * I2C settings */ -#define CONFIG_BFIN_TWI_I2C 1 +#define CONFIG_ADI_I2C 1 #define CONFIG_HARD_I2C 1 #define CONFIG_SYS_I2C_SPEED 50000 #define CONFIG_SYS_I2C_SLAVE 0 diff --git a/include/configs/bf537-pnav.h b/include/configs/bf537-pnav.h index 3aa3d50..c81572c 100644 --- a/include/configs/bf537-pnav.h +++ b/include/configs/bf537-pnav.h @@ -142,7 +142,7 @@ /* * I2C settings */ -#define CONFIG_BFIN_TWI_I2C 1 +#define CONFIG_ADI_I2C 1 #define CONFIG_HARD_I2C 1
diff --git a/include/configs/bf537-srv1.h b/include/configs/bf537-srv1.h index e12d761..08bc030 100644 --- a/include/configs/bf537-srv1.h +++ b/include/configs/bf537-srv1.h @@ -120,7 +120,7 @@ /* * I2C settings */ -#define CONFIG_BFIN_TWI_I2C 1 +#define CONFIG_ADI_I2C 1 #define CONFIG_HARD_I2C 1 #define CONFIG_SYS_I2C_SPEED 50000 #define CONFIG_SYS_I2C_SLAVE 0 diff --git a/include/configs/bf537-stamp.h b/include/configs/bf537-stamp.h index 02945be..f32359a 100644 --- a/include/configs/bf537-stamp.h +++ b/include/configs/bf537-stamp.h @@ -128,7 +128,7 @@ /* * I2C Settings */ -#define CONFIG_BFIN_TWI_I2C 1 +#define CONFIG_ADI_I2C 1 #define CONFIG_HARD_I2C 1
diff --git a/include/configs/bf538f-ezkit.h b/include/configs/bf538f-ezkit.h index ffb0caf..e0bcd40 100644 --- a/include/configs/bf538f-ezkit.h +++ b/include/configs/bf538f-ezkit.h @@ -125,7 +125,7 @@ /* * I2C Settings */ -#define CONFIG_BFIN_TWI_I2C 1 +#define CONFIG_ADI_I2C 1 #define CONFIG_HARD_I2C 1
diff --git a/include/configs/bf548-ezkit.h b/include/configs/bf548-ezkit.h index da5f029..c54d2fa 100644 --- a/include/configs/bf548-ezkit.h +++ b/include/configs/bf548-ezkit.h @@ -134,7 +134,7 @@ /* * I2C Settings */ -#define CONFIG_BFIN_TWI_I2C 1 +#define CONFIG_ADI_I2C 1 #define CONFIG_HARD_I2C 1
diff --git a/include/configs/bf609-ezkit.h b/include/configs/bf609-ezkit.h index 1a43e1b..6156ddb 100644 --- a/include/configs/bf609-ezkit.h +++ b/include/configs/bf609-ezkit.h @@ -80,7 +80,7 @@ #define CONFIG_MII
/* i2c Settings */ -#define CONFIG_BFIN_TWI_I2C +#define CONFIG_ADI_I2C #define CONFIG_HARD_I2C
/* diff --git a/include/configs/br4.h b/include/configs/br4.h index ef3752d..f220eb5 100644 --- a/include/configs/br4.h +++ b/include/configs/br4.h @@ -102,7 +102,7 @@ /* * I2C Settings */ -#define CONFIG_BFIN_TWI_I2C +#define CONFIG_ADI_I2C #define CONFIG_HARD_I2C
diff --git a/include/configs/cm-bf527.h b/include/configs/cm-bf527.h index b15a1eb..c4f2f1f 100644 --- a/include/configs/cm-bf527.h +++ b/include/configs/cm-bf527.h @@ -113,7 +113,7 @@ /* * I2C Settings */ -#define CONFIG_BFIN_TWI_I2C 1 +#define CONFIG_ADI_I2C 1 #define CONFIG_HARD_I2C 1
diff --git a/include/configs/cm-bf537e.h b/include/configs/cm-bf537e.h index 2838012..de839c4 100644 --- a/include/configs/cm-bf537e.h +++ b/include/configs/cm-bf537e.h @@ -122,7 +122,7 @@ /* * I2C Settings */ -#define CONFIG_BFIN_TWI_I2C 1 +#define CONFIG_ADI_I2C 1 #define CONFIG_HARD_I2C 1
diff --git a/include/configs/cm-bf537u.h b/include/configs/cm-bf537u.h index da4cc67..9d65e7b 100644 --- a/include/configs/cm-bf537u.h +++ b/include/configs/cm-bf537u.h @@ -120,7 +120,7 @@ /* * I2C Settings */ -#define CONFIG_BFIN_TWI_I2C 1 +#define CONFIG_ADI_I2C 1 #define CONFIG_HARD_I2C 1
diff --git a/include/configs/cm-bf548.h b/include/configs/cm-bf548.h index 7f27eda..7c9d1cd 100644 --- a/include/configs/cm-bf548.h +++ b/include/configs/cm-bf548.h @@ -104,7 +104,7 @@ /* * I2C Settings */ -#define CONFIG_BFIN_TWI_I2C 1 +#define CONFIG_ADI_I2C 1 #define CONFIG_HARD_I2C 1
diff --git a/include/configs/pr1.h b/include/configs/pr1.h index 03d4269..37f3fab 100644 --- a/include/configs/pr1.h +++ b/include/configs/pr1.h @@ -102,7 +102,7 @@ /* * I2C Settings */ -#define CONFIG_BFIN_TWI_I2C +#define CONFIG_ADI_I2C #define CONFIG_HARD_I2C
diff --git a/include/configs/tcm-bf518.h b/include/configs/tcm-bf518.h index 241f210..8d835b4 100644 --- a/include/configs/tcm-bf518.h +++ b/include/configs/tcm-bf518.h @@ -103,7 +103,7 @@ /* * I2C Settings */ -#define CONFIG_BFIN_TWI_I2C 1 +#define CONFIG_ADI_I2C 1 #define CONFIG_HARD_I2C 1
diff --git a/include/configs/tcm-bf537.h b/include/configs/tcm-bf537.h index 58bcdc8..7d1ee77 100644 --- a/include/configs/tcm-bf537.h +++ b/include/configs/tcm-bf537.h @@ -122,7 +122,7 @@ /* * I2C Settings */ -#define CONFIG_BFIN_TWI_I2C 1 +#define CONFIG_ADI_I2C 1 #define CONFIG_HARD_I2C 1
Hello Sonic,
bye, Heiko
The ADI twi peripheral is not binding to Blackfin processor only. Access i2c registers by standard io functions. Fix coding style.
Signed-off-by: Scott Jiang scott.jiang.linux@gmail.com Signed-off-by: Sonic Zhang sonic.zhang@analog.com --- drivers/i2c/adi_i2c.c | 151 ++++++++++++++++++++++++++------------------------ 1 file changed, 80 insertions(+), 71 deletions(-)
diff --git a/drivers/i2c/adi_i2c.c b/drivers/i2c/adi_i2c.c index 743aa25..675f417 100644 --- a/drivers/i2c/adi_i2c.c +++ b/drivers/i2c/adi_i2c.c @@ -1,7 +1,7 @@ /* - * i2c.c - driver for Blackfin on-chip TWI/I2C + * i2c.c - driver for ADI TWI/I2C * - * Copyright (c) 2006-2010 Analog Devices Inc. + * Copyright (c) 2006-2013 Analog Devices Inc. * * Licensed under the GPL-2 or later. */ @@ -11,6 +11,7 @@
#include <asm/clock.h> #include <asm/twi.h> +#include <asm/io.h>
/* Every register is 32bit aligned, but only 16bits in size */ #define ureg(name) u16 name; u16 __pad_##name; @@ -39,7 +40,7 @@ struct twi_regs { #ifdef TWI_CLKDIV #define TWI0_CLKDIV TWI_CLKDIV #endif -static volatile struct twi_regs *twi = (void *)TWI0_CLKDIV; +static struct twi_regs *twi = (void *)TWI0_CLKDIV;
#ifdef DEBUG # define dmemset(s, c, n) memset(s, c, n) @@ -93,53 +94,54 @@ struct i2c_msg { */ static int wait_for_completion(struct i2c_msg *msg) { - uint16_t int_stat; + u16 int_stat, ctl; ulong timebase = get_timer(0);
do { - int_stat = twi->int_stat; + int_stat = readw(&twi->int_stat);
if (int_stat & XMTSERV) { debugi("processing XMTSERV"); - twi->int_stat = XMTSERV; - SSYNC(); + writew(XMTSERV, &twi->int_stat); if (msg->alen) { - twi->xmt_data8 = *(msg->abuf++); + writew(*(msg->abuf++), &twi->xmt_data8); --msg->alen; } else if (!(msg->flags & I2C_M_COMBO) && msg->len) { - twi->xmt_data8 = *(msg->buf++); + writew(*(msg->buf++), &twi->xmt_data8); --msg->len; } else { - twi->master_ctl |= (msg->flags & I2C_M_COMBO) ? RSTART | MDIR : STOP; - SSYNC(); + ctl = readw(&twi->master_ctl); + if (msg->flags & I2C_M_COMBO) + writew(ctl | RSTART | MDIR, + &twi->master_ctl); + else + writew(ctl | STOP, &twi->master_ctl); } } if (int_stat & RCVSERV) { debugi("processing RCVSERV"); - twi->int_stat = RCVSERV; - SSYNC(); + writew(RCVSERV, &twi->int_stat); if (msg->len) { - *(msg->buf++) = twi->rcv_data8; + *(msg->buf++) = readw(&twi->rcv_data8); --msg->len; } else if (msg->flags & I2C_M_STOP) { - twi->master_ctl |= STOP; - SSYNC(); + ctl = readw(&twi->master_ctl); + writew(ctl | STOP, &twi->master_ctl); } } if (int_stat & MERR) { debugi("processing MERR"); - twi->int_stat = MERR; - SSYNC(); + writew(MERR, &twi->int_stat); return msg->len; } if (int_stat & MCOMP) { debugi("processing MCOMP"); - twi->int_stat = MCOMP; - SSYNC(); + writew(MCOMP, &twi->int_stat); if (msg->flags & I2C_M_COMBO && msg->len) { - twi->master_ctl = (twi->master_ctl & ~RSTART) | + ctl = readw(&twi->master_ctl); + ctl = (ctl & ~RSTART) | (min(msg->len, 0xff) << 6) | MEN | MDIR; - SSYNC(); + writew(ctl, &twi->master_ctl); } else break; } @@ -160,8 +162,11 @@ static int wait_for_completion(struct i2c_msg *msg) * Here we just get the i2c stuff all prepped and ready, and then tail off * into wait_for_completion() for all the bits to go. */ -static int i2c_transfer(uchar chip, uint addr, int alen, uchar *buffer, int len, u8 flags) +static int i2c_transfer(uchar chip, uint addr, int alen, uchar *buffer, + int len, u8 flags) { + int ret; + u16 ctl; uchar addr_buffer[] = { (addr >> 0), (addr >> 8), @@ -174,62 +179,59 @@ static int i2c_transfer(uchar chip, uint addr, int alen, uchar *buffer, int len, .abuf = addr_buffer, .alen = alen, }; - int ret;
dmemset(buffer, 0xff, len); - debugi("chip=0x%x addr=0x%02x alen=%i buf[0]=0x%02x len=%i flags=0x%02x[%s] ", - chip, addr, alen, buffer[0], len, flags, (flags & I2C_M_READ ? "rd" : "wr")); + debugi("chip=0x%x addr=0x%02x alen=%i buf[0]=0x%02x len=%i ", + chip, addr, alen, buffer[0], len); + debugi("flags=0x%02x[%s] ", flags, + (flags & I2C_M_READ ? "rd" : "wr"));
/* wait for things to settle */ - while (twi->master_stat & BUSBUSY) + while (readw(&twi->master_stat) & BUSBUSY) if (ctrlc()) return 1;
/* Set Transmit device address */ - twi->master_addr = chip; + writew(chip, &twi->master_addr);
/* Clear the FIFO before starting things */ - twi->fifo_ctl = XMTFLUSH | RCVFLUSH; - SSYNC(); - twi->fifo_ctl = 0; - SSYNC(); + writew(XMTFLUSH | RCVFLUSH, &twi->fifo_ctl); + writew(0, &twi->fifo_ctl);
/* prime the pump */ if (msg.alen) { len = (msg.flags & I2C_M_COMBO) ? msg.alen : msg.alen + len; debugi("first byte=0x%02x", *msg.abuf); - twi->xmt_data8 = *(msg.abuf++); + writew(*(msg.abuf++), &twi->xmt_data8); --msg.alen; } else if (!(msg.flags & I2C_M_READ) && msg.len) { debugi("first byte=0x%02x", *msg.buf); - twi->xmt_data8 = *(msg.buf++); + writew(*(msg.buf++), &twi->xmt_data8); --msg.len; }
/* clear int stat */ - twi->master_stat = -1; - twi->int_stat = -1; - twi->int_mask = 0; - SSYNC(); + writew(-1, &twi->master_stat); + writew(-1, &twi->int_stat); + writew(0, &twi->int_mask);
/* Master enable */ - twi->master_ctl = - (twi->master_ctl & FAST) | - (min(len, 0xff) << 6) | MEN | - ((msg.flags & I2C_M_READ) ? MDIR : 0); - SSYNC(); - debugi("CTL=0x%04x", twi->master_ctl); + ctl = readw(&twi->master_ctl); + ctl = (ctl & FAST) | (min(len, 0xff) << 6) | MEN | + ((msg.flags & I2C_M_READ) ? MDIR : 0); + writew(ctl, &twi->master_ctl);
/* process the rest */ ret = wait_for_completion(&msg); debugi("ret=%d", ret);
if (ret) { - twi->master_ctl &= ~MEN; - twi->control &= ~TWI_ENA; - SSYNC(); - twi->control |= TWI_ENA; - SSYNC(); + ctl = readw(&twi->master_ctl) & ~MEN; + writew(ctl, &twi->master_ctl); + ctl = readw(&twi->control) & ~TWI_ENA; + writew(ctl, &twi->control); + ctl = readw(&twi->control) | TWI_ENA; + writew(ctl, &twi->control); }
return ret; @@ -246,10 +248,11 @@ int i2c_set_bus_speed(unsigned int speed) /* Set TWI interface clock */ if (clkdiv < I2C_DUTY_MAX || clkdiv > I2C_DUTY_MIN) return -1; - twi->clkdiv = (clkdiv << 8) | (clkdiv & 0xff); + clkdiv = (clkdiv << 8) | (clkdiv & 0xff); + writew(clkdiv, &twi->clkdiv);
/* Don't turn it on */ - twi->master_ctl = (speed > 100000 ? FAST : 0); + writew(speed > 100000 ? FAST : 0, &twi->master_ctl);
return 0; } @@ -260,8 +263,9 @@ int i2c_set_bus_speed(unsigned int speed) */ unsigned int i2c_get_bus_speed(void) { + u16 clkdiv = readw(&twi->clkdiv) & 0xff; /* 10 MHz / (2 * CLKDIV) -> 5 MHz / CLKDIV */ - return 5000000 / (twi->clkdiv & 0xff); + return 5000000 / clkdiv; }
/** @@ -274,27 +278,22 @@ unsigned int i2c_get_bus_speed(void) */ void i2c_init(int speed, int slaveaddr) { - uint8_t prescale = ((get_i2c_clk() / 1000 / 1000 + 5) / 10) & 0x7F; + u16 prescale = ((get_i2c_clk() / 1000 / 1000 + 5) / 10) & 0x7F;
/* Set TWI internal clock as 10MHz */ - twi->control = prescale; + writew(prescale, &twi->control);
/* Set TWI interface clock as specified */ i2c_set_bus_speed(speed);
/* Enable it */ - twi->control = TWI_ENA | prescale; - SSYNC(); + writew(TWI_ENA | prescale, &twi->control);
- debugi("CONTROL:0x%04x CLKDIV:0x%04x", twi->control, twi->clkdiv); + debugi("CONTROL:0x%04x CLKDIV:0x%04x", readw(&twi->control), + readw(&twi->clkdiv));
#if CONFIG_SYS_I2C_SLAVE # error I2C slave support not tested/supported - /* If they want us as a slave, do it */ - if (slaveaddr) { - twi->slave_addr = slaveaddr; - twi->slave_ctl = SEN; - } #endif }
@@ -320,7 +319,8 @@ int i2c_probe(uchar chip) */ int i2c_read(uchar chip, uint addr, int alen, uchar *buffer, int len) { - return i2c_transfer(chip, addr, alen, buffer, len, (alen ? I2C_M_COMBO : I2C_M_READ)); + return i2c_transfer(chip, addr, alen, buffer, + len, (alen ? I2C_M_COMBO : I2C_M_READ)); }
/** @@ -346,15 +346,21 @@ int i2c_set_bus_num(unsigned int bus) { switch (bus) { #if CONFIG_SYS_MAX_I2C_BUS > 0 - case 0: twi = (void *)TWI0_CLKDIV; return 0; + case 0: + twi = (void *)TWI0_CLKDIV; + return 0; #endif #if CONFIG_SYS_MAX_I2C_BUS > 1 - case 1: twi = (void *)TWI1_CLKDIV; return 0; + case 1: + twi = (void *)TWI1_CLKDIV; + return 0; #endif #if CONFIG_SYS_MAX_I2C_BUS > 2 - case 2: twi = (void *)TWI2_CLKDIV; return 0; + case 2: + twi = (void *)TWI2_CLKDIV; + return 0; #endif - default: return -1; + default: return -1; } }
@@ -365,14 +371,17 @@ unsigned int i2c_get_bus_num(void) { switch ((unsigned long)twi) { #if CONFIG_SYS_MAX_I2C_BUS > 0 - case TWI0_CLKDIV: return 0; + case TWI0_CLKDIV: + return 0; #endif #if CONFIG_SYS_MAX_I2C_BUS > 1 - case TWI1_CLKDIV: return 1; + case TWI1_CLKDIV: + return 1; #endif #if CONFIG_SYS_MAX_I2C_BUS > 2 - case TWI2_CLKDIV: return 2; + case TWI2_CLKDIV: + return 2; #endif - default: return -1; + default: return -1; } }
Hello Sonic,
Signed-off-by: Scott Jiangscott.jiang.linux@gmail.com Signed-off-by: Sonic Zhangsonic.zhang@analog.com
bye, Heiko
Hello Sonic,
bye, Heiko
Heiko Schocher
Sonic Zhang
