[U-Boot] [PATCH] tools/fw_env: use fsync to ensure that data is physically stored
Closing a file descriptor does not guarantee that the data has been successfully saved to disk, as the kernel might defer the write.
Signed-off-by: Michael Heimpold mhei@heimpold.de --- tools/env/fw_env.c | 12 ++++++++++++ 1 file changed, 12 insertions(+)
diff --git a/tools/env/fw_env.c b/tools/env/fw_env.c index 428e374..0420495 100644 --- a/tools/env/fw_env.c +++ b/tools/env/fw_env.c @@ -1033,7 +1033,19 @@ static int flash_io (int mode)
rc = flash_write (fd_current, fd_target, dev_target);
+ if (fsync (fd_current)) { + fprintf (stderr, + "fsync failed on %s: %s\n", + DEVNAME (dev_current), strerror (errno)); + } + if (HaveRedundEnv) { + if (fsync (fd_target)) { + fprintf (stderr, + "fsync failed on %s: %s\n", + DEVNAME (dev_current), strerror (errno)); + } + if (close (fd_target)) { fprintf (stderr, "I/O error on %s: %s\n",
Dear Michael Heimpold,
What is the exact problem you are trying to fix?
I mean, when exactly does adding the sync play a role?
Hi Wolfgang Denx,
I'm using fw_setenv during system update process. The sequence of such a shell script is something like (much simplified):
... fw_setenv state=2 dd if=... of=/dev/mmcblk0... fw_setenv state=1 ... reboot
The (redundant) environment is stored in a eMMC flash. The env var 'state' gives a hint to U-Boot whether/where the process was interrupted.
So my intension is to be absolutely sure, that when fw_setenv returns, the environment is written out to disk.
Best regards, Michael
On 21/05/13 18:34, Michael Heimpold wrote:
Hi Wolfgang Denx,
Not sure what final "OS" environment you're running, but I would think that "reboot" would sync for you ?
For instance, under BusyBox, we have:-
# reboot --help BusyBox v1.14.0 (2012-02-15 10:28:26 GMT) multi-call binary
Usage: reboot [-d delay] [-n] [-f]
Reboot the system
Options: -d Delay interval for rebooting -n No call to sync() -f Force reboot (don't go through init)
... and under Ubuntu, we have ...
$ reboot --help Usage: reboot [OPTION]... Reboot the system.
Options: -n, --no-sync don't sync before reboot or halt ...
So by default, reboot would (should ?) call sync automatically.
This might point to some other issue ?
Mark J.
I'm using OpenWRT and reboot links to the busybox implementation. This implemenetation calls sync when I traced it correctly.
According to "man 2 sync":
<quote> DESCRIPTION sync() causes all buffered modifications to file metadata and data to be written to the underlying file systems. </quote>
When I use fw_setenv with /dev/mmcblk0, that means with a block device directly, then I have a problem matching the "filesystem layer" of the description above with the "block layer" which I am using.
Futhermore another quote from the very same man page: <quote> BUGS ...sync() schedules the writes, but may return before the actual writing is done. However, since version 1.3.20 Linux does actually wait. (This still does not guarantee data integrity: modern disks have large caches.) </quote>
So it seems to me, that calling "sync" doesn't do the job.
When looking at "man 2 fsync" I read <quote> ... This includes writing through or flushing a disk cache if present. The call blocks until the device reports that the transfer has completed.... </quote>
This looks much better.
However, I did not trace the call chain in linux kernel down to the block layer yet. Maybe I should.
BR, Michael
participants (5)
Mark Jackson
Mats Kärrman
Michael Heimpold
