[U-Boot] [PATCH] imx: imx8: fix loading container image from eMMC boot partitions
Booting with images in eMMC hardware boot partition doesn't work because the container header is loaded from user partition, thus the loaded data doesn't have a valid header. Add partition switching to support booting from eMMC boot partitions.
Signed-off-by: Anatolij Gustschin agust@denx.de --- arch/arm/mach-imx/imx8/image.c | 15 ++++++++++++++- 1 file changed, 14 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-imx/imx8/image.c b/arch/arm/mach-imx/imx8/image.c index 58a29e8..b0e9494 100644 --- a/arch/arm/mach-imx/imx8/image.c +++ b/arch/arm/mach-imx/imx8/image.c @@ -72,7 +72,20 @@ static int get_container_size(void *dev, int dev_type, unsigned long offset) if (dev_type == MMC_DEV) { unsigned long count = 0; struct mmc *mmc = (struct mmc *)dev; - + u8 part; + + part = EXT_CSD_EXTRACT_BOOT_PART(mmc->part_config); + if (part == 7) + part = 0; + if (part == 1 || part == 2) { + if (CONFIG_IS_ENABLED(MMC_TINY)) + ret = mmc_switch_part(mmc, part); + else + ret = blk_dselect_hwpart(mmc_get_blk_desc(mmc), + part); + if (ret) + return ret; + } count = blk_dread(mmc_get_blk_desc(mmc), offset / mmc->read_bl_len, CONTAINER_HDR_ALIGNMENT / mmc->read_bl_len,
Hi Anatolij,
-----Original Message----- From: Anatolij Gustschin agust@denx.de Sent: 2019年10月21日 23:22 To: u-boot@lists.denx.de Cc: sbabic@denx.de; festevam@gmail.com; dl-uboot-imx uboot-imx@nxp.com; Ye Li ye.li@nxp.com Subject: [PATCH] imx: imx8: fix loading container image from eMMC boot partitions
get_boot_device_offset already switched partition, there is no need to add partition switch logic in get_container_size.
Regards, Peng.
u8 part;
if (part == 7)
part = 0;
else
part);
if (ret)
return ret;
count = blk_dread(mmc_get_blk_desc(mmc), offset / mmc->read_bl_len, CONTAINER_HDR_ALIGNMENT / mmc->read_bl_len,}
-- 2.7.4
Hi Peng,
On Tue, 22 Oct 2019 02:43:31 +0000 Peng Fan peng.fan@nxp.com wrote: ...
I'd be very happy if it did, but it didn't, at least not in current mainline tree. I can't find eMMC hw partition switching code in u-boot-imx tree either. I've checked in current master and in next branches:
https://github.com/sbabic/u-boot-imx/blob/master/arch/arm/mach-imx/imx8/imag... https://github.com/sbabic/u-boot-imx/blob/next/arch/arm/mach-imx/imx8/image....
I'll re-spin the patch to add it in spl_mmc_get_uboot_raw_sector(), this seems to be a better place for it.
-- Anatolij
Hi Anatolij,
Subject: Re: [PATCH] imx: imx8: fix loading container image from eMMC boot partitions
Hi Peng,
My bad. I looked wrong. There is no such code.
But I do not understand well. When burn flash.bin into boot partition, SPL will be loaded from boot partition, SPL will load container images from boot partition, but in your case, I think SPL will load container images from user partition, so you switch back to boot partition.
From common/spl/spl_mmc.c, there is boot partition switch there,
Why need to add such logic in imx8/image.c?
Thanks, Peng.
https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fgithub. com%2Fsbabic%2Fu-boot-imx%2Fblob%2Fmaster%2Farch%2Farm%2Fmach-i mx%2Fimx8%2Fimage.c%23L123&data=02%7C01%7Cpeng.fan%40nxp.c om%7Cf5d635a085054823ffe008d756c24582%7C686ea1d3bc2b4c6fa92cd9 9c5c301635%7C0%7C0%7C637073264694636512&sdata=Td3sdxz67eX EFuEMXzM2A3Dtm1OXRsR8m9cKKxo52UE%3D&reserved=0
https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fgithub. com%2Fsbabic%2Fu-boot-imx%2Fblob%2Fnext%2Farch%2Farm%2Fmach-im x%2Fimx8%2Fimage.c%23L123&data=02%7C01%7Cpeng.fan%40nxp.co m%7Cf5d635a085054823ffe008d756c24582%7C686ea1d3bc2b4c6fa92cd99c 5c301635%7C0%7C0%7C637073264694636512&sdata=TjcYIyo%2BO6J B4IHv5%2F5p89BOWh2EPnSu%2Fe%2BKEGg0brY%3D&reserved=0
-- Anatolij
Hi Peng,
On Tue, 22 Oct 2019 08:13:31 +0000 Peng Fan peng.fan@nxp.com wrote: ...
yes, correct. On my test board flash.bin is in the first boot partition and SPL is loaded as expected.
SPL switches to user partition during the inif of mmc driver: spl_mmc_load() -> mmc_init()
Then it tries to load the container image in spl_mmc_get_uboot_raw_sector(), but here it reads the data from user partition and the header is not recognized as a valid header.
yes, because the mmc init switches to user partition.
From common/spl/spl_mmc.c, there is boot partition switch there, Why need to add such logic in imx8/image.c?
spl_mmc_load() reads the container header before partition switching.
-- Anatolij
Hi Peng,
Oh. Indeeded. Not took care of emmc when adding spl_mmc_get_uboot_raw_sector (: Thanks.
Thanks, Peng.
-- Anatolij
On Tue, 22 Oct 2019 10:08:42 +0000 Peng Fan peng.fan@nxp.com wrote: ...
I think we should avoid adding partition switching in get_container_size(), it looks like container header is read several times which is suboptimal. I'll have to rethink this patch, don't have time for this now.
-- Anatolij
ok. I'll give a look, if you not mind.
Thanks, Peng.
-- Anatolij
Anatolij Gustschin
Peng Fan
