[UBOOT PATCH v2] test/py: net: Add a TFTP put test
Execute tftpput command for uploading files to a server and validate its size & CRC32.
Signed-off-by: Love Kumar love.kumar@amd.com --- Changes in v2: - Add marking for cmd_tftpput config --- test/py/tests/test_net.py | 72 +++++++++++++++++++++++++++++++++++++++ 1 file changed, 72 insertions(+)
diff --git a/test/py/tests/test_net.py b/test/py/tests/test_net.py index b2241ae6a482..fbb11b640ae8 100644 --- a/test/py/tests/test_net.py +++ b/test/py/tests/test_net.py @@ -7,6 +7,7 @@ import pytest import u_boot_utils import uuid +import datetime
""" Note: This test relies on boardenv_* containing configuration values to define @@ -51,6 +52,7 @@ env__net_tftp_readable_file = { 'addr': 0x10000000, 'size': 5058624, 'crc32': 'c2244b26', + 'timeout': 50000, }
# Details regarding a file that may be read from a NFS server. This variable @@ -326,3 +328,73 @@ def test_net_pxe_get(u_boot_console):
assert expected_text_default in output assert "Config file 'default.boot' found" in output + +@pytest.mark.buildconfigspec("cmd_crc32") +@pytest.mark.buildconfigspec("cmd_net") +@pytest.mark.buildconfigspec("cmd_tftpput") +def test_net_tftpput(u_boot_console): + """Test the tftpput command. + + A file is downloaded from the TFTP server and then uploaded to the TFTP + server, its size and its CRC32 are validated. + + The details of the file to download are provided by the boardenv_* file; + see the comment at the beginning of this file. + """ + + if not net_set_up: + pytest.skip("Network not initialized") + + f = u_boot_console.config.env.get("env__net_tftp_readable_file", None) + if not f: + pytest.skip("No TFTP readable file to read") + + addr = f.get("addr", None) + if not addr: + addr = u_boot_utils.find_ram_base(u_boot_console) + + sz = f.get("size", None) + timeout = f.get("timeout", u_boot_console.p.timeout) + fn = f["fn"] + fnu = "_".join([datetime.datetime.now().strftime("%y%m%d%H%M%S"), fn]) + expected_text = "Bytes transferred = " + if sz: + expected_text += "%d" % sz + + with u_boot_console.temporary_timeout(timeout): + output = u_boot_console.run_command("tftpboot %x %s" % (addr, fn)) + + assert "TIMEOUT" not in output + assert expected_text in output + + expected_tftpb_crc = f.get("crc32", None) + + output = u_boot_console.run_command("crc32 $fileaddr $filesize") + assert expected_tftpb_crc in output + + with u_boot_console.temporary_timeout(timeout): + output = u_boot_console.run_command( + "tftpput $fileaddr $filesize $serverip:%s" % (fnu) + ) + + expected_text = "Bytes transferred = " + if sz: + expected_text += "%d" % sz + addr = addr + sz + assert "TIMEOUT" not in output + assert "Access violation" not in output + assert expected_text in output + + with u_boot_console.temporary_timeout(timeout): + output = u_boot_console.run_command("tftpboot %x %s" % (addr, fnu)) + + expected_text = "Bytes transferred = " + if sz: + expected_text += "%d" % sz + assert "TIMEOUT" not in output + assert expected_text in output + + expected_tftpp_crc = expected_tftpb_crc + + output = u_boot_console.run_command("crc32 $fileaddr $filesize") + assert expected_tftpp_crc in output
Changes in v2:
[snip]
- fnu = "_".join([datetime.datetime.now().strftime("%y%m%d%H%M%S"), fn])
[snip]
I think we need to have the filename to upload as be part of the board env as well, otherwise this is going to fill up the tftpserver over time. I use a 1MiB file and that times boards times number of iterations I end up doing means I'll start noticing in a few months that I've got less free space than I expected in that format.
Love Kumar
