[PATCH v1 1/3] rockchip: serial: restyle the serial_rockchip.c driver
The ns16550.c driver has the following conditions for .of_match:
CONFIG_IS_ENABLED(OF_REAL)
For Rockchip SoCs with TPL/SPL and platform data that need serial support the serial_rockchip.c driver was made. It copies this data and then calls ns16550_serial_probe(). With the addition of yet an other SoC type this driver is in need for a little restyle. Simplify struct rockchip_uart_plat and add extra SoCs with DM_DRIVER_ALIAS(). Return -ENODEV when the ns16550.c driver probe function is available.
Signed-off-by: Johan Jonker jbx6244@gmail.com --- drivers/serial/serial_rockchip.c | 36 +++++++++++++------------------- 1 file changed, 14 insertions(+), 22 deletions(-)
diff --git a/drivers/serial/serial_rockchip.c b/drivers/serial/serial_rockchip.c index 97d40869..0d1d9fff 100644 --- a/drivers/serial/serial_rockchip.c +++ b/drivers/serial/serial_rockchip.c @@ -12,22 +12,19 @@ #include <asm/arch-rockchip/clock.h> #include <dm/device-internal.h>
-#if defined(CONFIG_ROCKCHIP_RK3188) -struct rockchip_uart_plat { - struct dtd_rockchip_rk3188_uart dtplat; - struct ns16550_plat plat; -}; -struct dtd_rockchip_rk3188_uart *dtplat, s_dtplat; -#elif defined(CONFIG_ROCKCHIP_RK3288) struct rockchip_uart_plat { +#if CONFIG_IS_ENABLED(OF_PLATDATA) struct dtd_rockchip_rk3288_uart dtplat; +#endif struct ns16550_plat plat; }; +#if CONFIG_IS_ENABLED(OF_PLATDATA) struct dtd_rockchip_rk3288_uart *dtplat, s_dtplat; #endif
static int rockchip_serial_probe(struct udevice *dev) { +#if CONFIG_IS_ENABLED(OF_PLATDATA) struct rockchip_uart_plat *plat = dev_get_plat(dev);
/* Create some new platform data for the standard driver */ @@ -38,24 +35,19 @@ static int rockchip_serial_probe(struct udevice *dev) dev_set_plat(dev, &plat->plat);
return ns16550_serial_probe(dev); +#else + return -ENODEV; +#endif }
-U_BOOT_DRIVER(rockchip_rk3188_uart) = { - .name = "rockchip_rk3188_uart", - .id = UCLASS_SERIAL, - .priv_auto = sizeof(struct ns16550), - .plat_auto = sizeof(struct rockchip_uart_plat), - .probe = rockchip_serial_probe, - .ops = &ns16550_serial_ops, - .flags = DM_FLAG_PRE_RELOC, -}; - U_BOOT_DRIVER(rockchip_rk3288_uart) = { - .name = "rockchip_rk3288_uart", - .id = UCLASS_SERIAL, + .name = "rockchip_rk3288_uart", + .id = UCLASS_SERIAL, .priv_auto = sizeof(struct ns16550), .plat_auto = sizeof(struct rockchip_uart_plat), - .probe = rockchip_serial_probe, - .ops = &ns16550_serial_ops, - .flags = DM_FLAG_PRE_RELOC, + .probe = rockchip_serial_probe, + .ops = &ns16550_serial_ops, + .flags = DM_FLAG_PRE_RELOC, }; +DM_DRIVER_ALIAS(rockchip_rk3288_uart, rockchip_rk3066_uart) +DM_DRIVER_ALIAS(rockchip_rk3288_uart, rockchip_rk3188_uart)
The Rockchip uart DT nodes have "snps,dw-apb-uart" as fall back string. The driver ns16550.c has CONFIG_IS_ENABLED(OF_REAL) as condition to of_match and does not copy dtplat data. For TPL/SPL the driver serial_rockchip.c is used. Move driver alias to correct driver.
Signed-off-by: Johan Jonker jbx6244@gmail.com --- drivers/serial/ns16550.c | 2 -- drivers/serial/serial_rockchip.c | 2 ++ 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/serial/ns16550.c b/drivers/serial/ns16550.c index 796ff165..a4220fd0 100644 --- a/drivers/serial/ns16550.c +++ b/drivers/serial/ns16550.c @@ -624,8 +624,6 @@ U_BOOT_DRIVER(ns16550_serial) = { #endif };
-DM_DRIVER_ALIAS(ns16550_serial, rockchip_rk3328_uart) -DM_DRIVER_ALIAS(ns16550_serial, rockchip_rk3368_uart) DM_DRIVER_ALIAS(ns16550_serial, ti_da830_uart) #endif #endif /* SERIAL_PRESENT */ diff --git a/drivers/serial/serial_rockchip.c b/drivers/serial/serial_rockchip.c index 0d1d9fff..22c7ac90 100644 --- a/drivers/serial/serial_rockchip.c +++ b/drivers/serial/serial_rockchip.c @@ -51,3 +51,5 @@ U_BOOT_DRIVER(rockchip_rk3288_uart) = { }; DM_DRIVER_ALIAS(rockchip_rk3288_uart, rockchip_rk3066_uart) DM_DRIVER_ALIAS(rockchip_rk3288_uart, rockchip_rk3188_uart) +DM_DRIVER_ALIAS(rockchip_rk3288_uart, rockchip_rk3328_uart) +DM_DRIVER_ALIAS(rockchip_rk3288_uart, rockchip_rk3368_uart)
The Rockchip serial driver depends on an enabled NS16550 driver, so add select SYS_NS16550 to config ROCKCHIP_SERIAL.
Signed-off-by: Johan Jonker jbx6244@gmail.com --- drivers/serial/Kconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/serial/Kconfig b/drivers/serial/Kconfig index 6c8fdda9..054bd21e 100644 --- a/drivers/serial/Kconfig +++ b/drivers/serial/Kconfig @@ -737,6 +737,7 @@ config PL01X_SERIAL config ROCKCHIP_SERIAL bool "Rockchip on-chip UART support" depends on DM_SERIAL && SPL_OF_PLATDATA + select SYS_NS16550 help Select this to enable a debug UART for Rockchip devices when using CONFIG_SPL_OF_PLATDATA (i.e. a compiled-in device tree replacemenmt).
select SYS_NS16550
Other places of rockchip code are implying and selecting the SYS_NS16550, so removing those would be part of this global select.
Jagan.
Hi Johan,
Jagan Teki
Johan Jonker
