[U-Boot] [PATCH v2 1/2] env: sf: Add support for env init for QSPI-NOR
ENV variables can now be used before relocation.
Signed-off-by: Ashish Kumar Ashish.Kumar@nxp.com --- v2: replace & with && in #if
Tested on ls1088ardb. Tested on ls1012hexa after defining CONFIG_ENV_ADDR
env/sf.c | 21 +++++++++++++++++++++ 1 file changed, 21 insertions(+)
diff --git a/env/sf.c b/env/sf.c index e51b1ae..a2e4c93 100644 --- a/env/sf.c +++ b/env/sf.c @@ -34,6 +34,7 @@
#ifndef CONFIG_SPL_BUILD #define CMD_SAVEENV +#define INITENV #endif
#ifdef CONFIG_ENV_OFFSET_REDUND @@ -348,6 +349,23 @@ out: } #endif
+#if defined(INITENV) && defined(CONFIG_ENV_ADDR) +static int env_sf_init(void) +{ + env_t *env_ptr = (env_t *)(CONFIG_ENV_ADDR); + + if (crc32(0, env_ptr->data, ENV_SIZE) == env_ptr->crc) { + gd->env_addr = (ulong)&(env_ptr->data); + gd->env_valid = 1; + } else { + gd->env_addr = (ulong)&default_environment[0]; + gd->env_valid = 1; + } + + return 0; +} +#endif + U_BOOT_ENV_LOCATION(sf) = { .location = ENVL_SPI_FLASH, ENV_NAME("SPI Flash") @@ -355,4 +373,7 @@ U_BOOT_ENV_LOCATION(sf) = { #ifdef CMD_SAVEENV .save = env_save_ptr(env_sf_save), #endif +#if defined(INITENV) && defined(CONFIG_ENV_ADDR) + .init = env_sf_init, +#endif };
Signed-off-by: Ashish Kumar Ashish.Kumar@nxp.com --- include/configs/ls1088a_common.h | 6 ++++++ include/configs/ls1088aqds.h | 1 - include/configs/ls1088ardb.h | 2 +- 3 files changed, 7 insertions(+), 2 deletions(-)
diff --git a/include/configs/ls1088a_common.h b/include/configs/ls1088a_common.h index b99257e..c96d48d 100644 --- a/include/configs/ls1088a_common.h +++ b/include/configs/ls1088a_common.h @@ -32,6 +32,12 @@
#define CONFIG_SUPPORT_RAW_INITRD
+#ifdef CONFIG_QSPI_BOOT +#define CONFIG_SYS_FSL_QSPI_BASE 0x20000000 +#define CONFIG_ENV_OFFSET 0x300000 /* 3MB */ +#define CONFIG_ENV_ADDR (CONFIG_SYS_FSL_QSPI_BASE + \ + CONFIG_ENV_OFFSET) +#endif
#define CONFIG_SKIP_LOWLEVEL_INIT
diff --git a/include/configs/ls1088aqds.h b/include/configs/ls1088aqds.h index e97091d..6b94667 100644 --- a/include/configs/ls1088aqds.h +++ b/include/configs/ls1088aqds.h @@ -21,7 +21,6 @@ unsigned long get_board_ddr_clk(void);
#if defined(CONFIG_QSPI_BOOT) #define CONFIG_ENV_SIZE 0x2000 /* 8KB */ -#define CONFIG_ENV_OFFSET 0x300000 /* 3MB */ #define CONFIG_ENV_SECT_SIZE 0x40000 #elif defined(CONFIG_SD_BOOT) #define CONFIG_ENV_OFFSET (3 * 1024 * 1024) diff --git a/include/configs/ls1088ardb.h b/include/configs/ls1088ardb.h index 1da8153..bffaa76 100644 --- a/include/configs/ls1088ardb.h +++ b/include/configs/ls1088ardb.h @@ -12,8 +12,8 @@ #define CONFIG_DISPLAY_BOARDINFO_LATE
#if defined(CONFIG_QSPI_BOOT) +#define CONFIG_SYS_FSL_QSPI_BASE 0x20000000 #define CONFIG_ENV_SIZE 0x2000 /* 8KB */ -#define CONFIG_ENV_OFFSET 0x300000 /* 3MB */ #define CONFIG_ENV_SECT_SIZE 0x40000 #elif defined(CONFIG_SD_BOOT) #define CONFIG_ENV_OFFSET (3 * 1024 * 1024)
CONFIG_ENV_OFFSET)
Looks like you are redefining this macro. Will remove when I merge it.
York
-----Original Message----- From: York Sun Sent: Monday, January 15, 2018 11:36 PM To: Ashish Kumar ashish.kumar@nxp.com; u-boot@lists.denx.de Subject: Re: [PATCH v2 2/2] armv8: ls1088ardb: Add environment variable address location for QSPI-NOR
CONFIG_ENV_OFFSET)
Yes. Thanks York.
York
Applied to fsl-qoriq master. Thanks.
York
- env_t *env_ptr = (env_t *)(CONFIG_ENV_ADDR);
- if (crc32(0, env_ptr->data, ENV_SIZE) == env_ptr->crc) {
gd->env_valid = 1;
- } else {
gd->env_valid = 1;
+} +#endif
- .init = env_sf_init,
+#endif };
Please run get_maintainer.pl to get the CC list if you don't use patman.
I wonder how SPI worked before. Did it work, Simon and Jagan?
York
-----Original Message----- From: York Sun Sent: Monday, January 08, 2018 11:53 PM To: Ashish Kumar ashish.kumar@nxp.com; u-boot@lists.denx.de; Simon Glass sjg@chromium.org; Jagan Teki jagan@openedev.com Subject: Re: [PATCH v2 1/2] env: sf: Add support for env init for QSPI-NOR
+#if defined(INITENV) && defined(CONFIG_ENV_ADDR) static int +env_sf_init(void) {
gd->env_valid = 1;
- } else {
gd->env_valid = 1;
+} +#endif
CMD_SAVEENV
+#endif };
SPI is working, this patch adds support to init environment such that it can be used before u-boot relocation similar to that of IFC-NOR.
Regards Ashish
York
York
Ashish Kumar
Ashish Kumar
York Sun
