Re: [U-Boot] [PATCH] Rpi: Fix compilation error if CONFIG_USB is disabled
Few weeks ago sent patch (as in below mail) to include in U-Boot, And still waiting for response and even not present in U-Boot mailing list.
As per checkpatch.pl, there is following CHECK. However it doesn't have side-effects and similar to include/configs/rockchip-common.h:
CHECK: Macro argument reuse 'func' - possible side-effects? #43: FILE: include/configs/rpi.h:150: + #define BOOT_TARGET_MMC(func) \ + func(MMC, mmc, 0) \ + func(MMC, mmc, 1)
Please suggest if anything wrong I have done to submit the patch or anything wrong in the patch or is it because of above CHECK.
- Ajay
On 13/03/19, 4:42 PM, "akaher" akaher@vmware.com wrote:
This patch is to fix the following compilation error when disabling CONFIG_USB for Rpi3:
include/config_distro_bootcmd.h:242:2: error: expected ‘}’ before ‘BOOT_TARGET_DEVICES_references_USB_without_CONFIG_CMD_USB’ BOOT_TARGET_DEVICES_references_USB_without_CONFIG_CMD_USB
After merging rpi.h changes as per this patch, still getting compilation error if CONFIG_CMD_USB is enabled, so CONFIG_CMD_USB should depends upon CONFIG_USB. Signed-off-by: Ajay Kaher akaher@vmware.com --- cmd/Kconfig | 1 + include/configs/rpi.h | 36 +++++++++++++++++++++++++++++++----- 2 files changed, 32 insertions(+), 5 deletions(-)
diff --git a/cmd/Kconfig b/cmd/Kconfig index 4bcc5c4557..96e665a1c9 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -1059,6 +1059,7 @@ config CMD_UNIVERSE config CMD_USB bool "usb" select HAVE_BLOCK_DEVICE + depends on USB help USB support.
diff --git a/include/configs/rpi.h b/include/configs/rpi.h index 9ce41767a9..f76c7d18ef 100644 --- a/include/configs/rpi.h +++ b/include/configs/rpi.h @@ -146,12 +146,38 @@ "fdt_addr_r=0x02600000\0" \ "ramdisk_addr_r=0x02700000\0"
+#if CONFIG_IS_ENABLED(CMD_MMC) + #define BOOT_TARGET_MMC(func) \ + func(MMC, mmc, 0) \ + func(MMC, mmc, 1) +#else + #define BOOT_TARGET_MMC(func) +#endif + +#if CONFIG_IS_ENABLED(CMD_USB) + #define BOOT_TARGET_USB(func) func(USB, usb, 0) +#else + #define BOOT_TARGET_USB(func) +#endif + +#if CONFIG_IS_ENABLED(CMD_PXE) + #define BOOT_TARGET_PXE(func) func(PXE, pxe, na) +#else + #define BOOT_TARGET_PXE(func) +#endif + +#if CONFIG_IS_ENABLED(CMD_DHCP) + #define BOOT_TARGET_DHCP(func) func(DHCP, dhcp, na) +#else + #define BOOT_TARGET_DHCP(func) +#endif + #define BOOT_TARGET_DEVICES(func) \ - func(MMC, mmc, 0) \ - func(MMC, mmc, 1) \ - func(USB, usb, 0) \ - func(PXE, pxe, na) \ - func(DHCP, dhcp, na) + BOOT_TARGET_MMC(func) \ + BOOT_TARGET_USB(func) \ + BOOT_TARGET_PXE(func) \ + BOOT_TARGET_DHCP(func) + #include <config_distro_bootcmd.h>
#define CONFIG_EXTRA_ENV_SETTINGS \ -- 2.14.2
Can you please re-send the patch and ensure to Cc the maintainer? Thanks!
- #define BOOT_TARGET_MMC(func) \
func(MMC, mmc, 0) \
func(MMC, mmc, 1)
- Ajay
This patch is to fix the following compilation error when disabling CONFIG_USB for Rpi3: include/config_distro_bootcmd.h:242:2: error: expected ‘}’ before ‘BOOT_TARGET_DEVICES_references_USB_without_CONFIG_CMD_USB’ BOOT_TARGET_DEVICES_references_USB_without_CONFIG_CMD_USB After merging rpi.h changes as per this patch, still getting compilation error if CONFIG_CMD_USB is enabled, so CONFIG_CMD_USB should depends upon CONFIG_USB. Signed-off-by: Ajay Kaher <akaher@vmware.com> --- cmd/Kconfig | 1 + include/configs/rpi.h | 36 +++++++++++++++++++++++++++++++----- 2 files changed, 32 insertions(+), 5 deletions(-) diff --git a/cmd/Kconfig b/cmd/Kconfig index 4bcc5c4557..96e665a1c9 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -1059,6 +1059,7 @@ config CMD_UNIVERSE config CMD_USB bool "usb" select HAVE_BLOCK_DEVICE + depends on USB help USB support. diff --git a/include/configs/rpi.h b/include/configs/rpi.h index 9ce41767a9..f76c7d18ef 100644 --- a/include/configs/rpi.h +++ b/include/configs/rpi.h @@ -146,12 +146,38 @@ "fdt_addr_r=0x02600000\0" \ "ramdisk_addr_r=0x02700000\0" +#if CONFIG_IS_ENABLED(CMD_MMC) + #define BOOT_TARGET_MMC(func) \ + func(MMC, mmc, 0) \ + func(MMC, mmc, 1) +#else + #define BOOT_TARGET_MMC(func) +#endif + +#if CONFIG_IS_ENABLED(CMD_USB) + #define BOOT_TARGET_USB(func) func(USB, usb, 0) +#else + #define BOOT_TARGET_USB(func) +#endif + +#if CONFIG_IS_ENABLED(CMD_PXE) + #define BOOT_TARGET_PXE(func) func(PXE, pxe, na) +#else + #define BOOT_TARGET_PXE(func) +#endif + +#if CONFIG_IS_ENABLED(CMD_DHCP) + #define BOOT_TARGET_DHCP(func) func(DHCP, dhcp, na) +#else + #define BOOT_TARGET_DHCP(func) +#endif + #define BOOT_TARGET_DEVICES(func) \ - func(MMC, mmc, 0) \ - func(MMC, mmc, 1) \ - func(USB, usb, 0) \ - func(PXE, pxe, na) \ - func(DHCP, dhcp, na) + BOOT_TARGET_MMC(func) \ + BOOT_TARGET_USB(func) \ + BOOT_TARGET_PXE(func) \ + BOOT_TARGET_DHCP(func) + #include <config_distro_bootcmd.h> #define CONFIG_EXTRA_ENV_SETTINGS \ -- 2.14.2
- Ajay
That indicates to me that this is an independent patch. You want to be able to enable CMD_USB only when USB is enabled. But that is independent from RPi.
Regards, Matthias
_______________________________________________ U-Boot mailing list U-Boot@lists.denx.de https://lists.denx.de/listinfo/u-boot
Ajay Kaher
Matthias Brugger
