[U-Boot] [PATCH] mx31pdk: Clean up mx31pdk.h file
No need to use '#define SYMBOL 1' to make it active.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- include/configs/mx31pdk.h | 32 ++++++++++++++++---------------- 1 files changed, 16 insertions(+), 16 deletions(-)
diff --git a/include/configs/mx31pdk.h b/include/configs/mx31pdk.h index d4c6d16..50e751a 100644 --- a/include/configs/mx31pdk.h +++ b/include/configs/mx31pdk.h @@ -33,17 +33,17 @@ #include <asm/arch/imx-regs.h>
/* High Level Configuration Options */ -#define CONFIG_ARM1136 1 /* This is an arm1136 CPU core */ -#define CONFIG_MX31 1 /* in a mx31 */ +#define CONFIG_ARM1136 /* This is an arm1136 CPU core */ +#define CONFIG_MX31 /* in a mx31 */ #define CONFIG_MX31_HCLK_FREQ 26000000 #define CONFIG_MX31_CLK32 32768
#define CONFIG_DISPLAY_CPUINFO #define CONFIG_DISPLAY_BOARDINFO
-#define CONFIG_CMDLINE_TAG 1 /* enable passing of ATAGs */ -#define CONFIG_SETUP_MEMORY_TAGS 1 -#define CONFIG_INITRD_TAG 1 +#define CONFIG_CMDLINE_TAG /* enable passing of ATAGs */ +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_INITRD_TAG
#if defined(CONFIG_NAND_U_BOOT) && !defined(CONFIG_NAND_SPL) #define CONFIG_SKIP_LOWLEVEL_INIT @@ -59,11 +59,11 @@ * Hardware drivers */
-#define CONFIG_MXC_UART 1 -#define CONFIG_SYS_MX31_UART1 1 +#define CONFIG_MXC_UART +#define CONFIG_SYS_MX31_UART1
-#define CONFIG_HARD_SPI 1 -#define CONFIG_MXC_SPI 1 +#define CONFIG_HARD_SPI +#define CONFIG_MXC_SPI #define CONFIG_DEFAULT_SPI_BUS 1 #define CONFIG_DEFAULT_SPI_MODE (SPI_MODE_0 | SPI_CS_HIGH)
@@ -72,7 +72,7 @@ #define CONFIG_FSL_PMIC_CS 2 #define CONFIG_FSL_PMIC_CLK 1000000 #define CONFIG_FSL_PMIC_MODE (SPI_MODE_0 | SPI_CS_HIGH) -#define CONFIG_RTC_MC13783 1 +#define CONFIG_RTC_MC13783
/* allow to overwrite serial and ethaddr */ #define CONFIG_ENV_OVERWRITE @@ -112,9 +112,9 @@ "nand write 0x81000000 0x0 0x40000\0"
#define CONFIG_NET_MULTI -#define CONFIG_SMC911X 1 +#define CONFIG_SMC911X #define CONFIG_SMC911X_BASE 0xB6000000 -#define CONFIG_SMC911X_32_BIT 1 +#define CONFIG_SMC911X_32_BIT
/* * Miscellaneous configurable options @@ -139,7 +139,7 @@
#define CONFIG_SYS_HZ 1000
-#define CONFIG_CMDLINE_EDITING 1 +#define CONFIG_CMDLINE_EDITING
/*----------------------------------------------------------------------- * Stack sizes @@ -154,7 +154,7 @@ #define CONFIG_NR_DRAM_BANKS 1 #define PHYS_SDRAM_1 CSD0_BASE #define PHYS_SDRAM_1_SIZE (128 * 1024 * 1024) -#define CONFIG_BOARD_EARLY_INIT_F 1 +#define CONFIG_BOARD_EARLY_INIT_F
#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 #define CONFIG_SYS_INIT_RAM_ADDR IRAM_BASE_ADDR @@ -166,9 +166,9 @@ * FLASH and environment organization */ /* No NOR flash present */ -#define CONFIG_SYS_NO_FLASH 1 +#define CONFIG_SYS_NO_FLASH
-#define CONFIG_ENV_IS_IN_NAND 1 +#define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_OFFSET 0x40000 #define CONFIG_ENV_OFFSET_REDUND 0x60000 #define CONFIG_ENV_SIZE (128 * 1024)
Hi Stefano,
Ping?
Regards,
Fabio Estevam
- Hardware drivers
- Miscellaneous configurable options
@@ -139,7 +139,7 @@
- Stack sizes
- FLASH and environment organization
Applied on u-boot-imx, thanks.
Best regards, Stefano Babic
Fabio Estevam
Fabio Estevam
Stefano Babic
