[U-Boot] [PATCH v2 1/2] ls1088ardb: Enable USB command RDB qspi-boot
Signed-off-by: Ashish Kumar Ashish.Kumar@nxp.com Signed-off-by: Amrita Kumari amrita.kumari@nxp.com Signed-off-by: Ran Wang ran.wang_1@nxp.com --- Change in v2: 1.Adjust USB nodes position in dts to keep them sorted in unit-address. 2.Move macro CONFIG_HAS_FSL_XHCI_USB and CONFIG_USB_XHCI_FSL to Kconfig option. 3.Remove CONFIG_USB_MAX_CONTROLLER_COUNT.
Change in v1: Rebased to ba39608 ARM: DRA72x: Add support for detection of DRA71x SR 2.1
arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 8 ++++++++ arch/arm/dts/fsl-ls1088a.dtsi | 14 ++++++++++++++ board/freescale/ls1088a/ls1088a.c | 1 - configs/ls1088ardb_qspi_defconfig | 8 ++++++++ include/linux/usb/xhci-fsl.h | 2 +- 5 files changed, 31 insertions(+), 2 deletions(-)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig index 3518d8601d..3337ff3a00 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig +++ b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig @@ -83,6 +83,8 @@ config ARCH_LS1088A select FSL_TZASC_1 select ARCH_EARLY_INIT_R select BOARD_EARLY_INIT_F + select HAS_FSL_XHCI_USB + select USB_XHCI_FSL
config ARCH_LS2080A bool @@ -346,6 +348,12 @@ config FSL_TZASC_1 config FSL_TZASC_2 bool
+config HAS_FSL_XHCI_USB + bool + +config USB_XHCI_FSL + bool + endmenu
menu "Layerscape clock tree configuration" diff --git a/arch/arm/dts/fsl-ls1088a.dtsi b/arch/arm/dts/fsl-ls1088a.dtsi index d943a9efa3..64b4fcf12b 100644 --- a/arch/arm/dts/fsl-ls1088a.dtsi +++ b/arch/arm/dts/fsl-ls1088a.dtsi @@ -76,6 +76,20 @@ num-cs = <4>; };
+ usb0: usb3@3100000 { + compatible = "fsl,layerscape-dwc3"; + reg = <0x0 0x3100000 0x0 0x10000>; + interrupts = <0 80 0x4>; /* Level high type */ + dr_mode = "host"; + }; + + usb1: usb3@3110000 { + compatible = "fsl,layerscape-dwc3"; + reg = <0x0 0x3110000 0x0 0x10000>; + interrupts = <0 81 0x4>; /* Level high type */ + dr_mode = "host"; + }; + pcie@3400000 { compatible = "fsl,ls-pcie", "snps,dw-pcie"; reg = <0x00 0x03400000 0x0 0x80000 /* dbi registers */ diff --git a/board/freescale/ls1088a/ls1088a.c b/board/freescale/ls1088a/ls1088a.c index 96d9ae7f1d..2156537a27 100644 --- a/board/freescale/ls1088a/ls1088a.c +++ b/board/freescale/ls1088a/ls1088a.c @@ -49,7 +49,6 @@ int checkboard(void) static const char *const freq[] = {"100", "125", "156.25", "100 separate SSCG"}; int clock; - #ifdef CONFIG_TARGET_LS1088AQDS printf("Board: LS1088A-QDS, "); #else diff --git a/configs/ls1088ardb_qspi_defconfig b/configs/ls1088ardb_qspi_defconfig index 2d5a134261..3034f506e2 100644 --- a/configs/ls1088ardb_qspi_defconfig +++ b/configs/ls1088ardb_qspi_defconfig @@ -31,3 +31,11 @@ CONFIG_FSL_DSPI=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_FSL_LS_PPA=y +CONFIG_USB=y +CONFIG_USB_GADGET=y +CONFIG_CMD_USB=y +CONFIG_DM_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_DWC3=y +CONFIG_USB_STORAGE=y diff --git a/include/linux/usb/xhci-fsl.h b/include/linux/usb/xhci-fsl.h index bd54089722..a916afb885 100644 --- a/include/linux/usb/xhci-fsl.h +++ b/include/linux/usb/xhci-fsl.h @@ -58,7 +58,7 @@ struct fsl_xhci { #define CONFIG_SYS_FSL_XHCI_USB1_ADDR CONFIG_SYS_XHCI_USB1_ADDR #define CONFIG_SYS_FSL_XHCI_USB2_ADDR 0 #define CONFIG_SYS_FSL_XHCI_USB3_ADDR 0 -#elif defined(CONFIG_ARCH_LS2080A) +#elif defined(CONFIG_ARCH_LS2080A) || defined(CONFIG_ARCH_LS1088A) #define CONFIG_SYS_FSL_XHCI_USB1_ADDR CONFIG_SYS_XHCI_USB1_ADDR #define CONFIG_SYS_FSL_XHCI_USB2_ADDR CONFIG_SYS_XHCI_USB2_ADDR #define CONFIG_SYS_FSL_XHCI_USB3_ADDR 0
Signed-off-by: Amrita Kumari amrita.kumari@nxp.com Signed-off-by: Ashish Kumar Ashish.Kumar@nxp.com Signed-off-by: Ran Wang ran.wang_1@nxp.com --- Change in v2: Remove macro CONFIG_HAS_FSL_XHCI_USB and CONFIG_USB_XHCI_FSL and CONFIG_USB_MAX_CONTROLLER_COUNT from ls1088aqds.h since Kconfig option has covered. Change in v1: Rebased to ba39608 ARM: DRA72x: Add support for detection of DRA71x SR 2.1
configs/ls1088aqds_qspi_defconfig | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/configs/ls1088aqds_qspi_defconfig b/configs/ls1088aqds_qspi_defconfig index 4b0d604fa0..a24a6011c9 100644 --- a/configs/ls1088aqds_qspi_defconfig +++ b/configs/ls1088aqds_qspi_defconfig @@ -31,3 +31,11 @@ CONFIG_FSL_DSPI=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_FSL_LS_PPA=y +CONFIG_USB=y +CONFIG_USB_GADGET=y +CONFIG_CMD_USB=y +CONFIG_DM_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_DWC3=y +CONFIG_USB_STORAGE=y
Hi Ran,
select USB_XHCI_FSL
bool
This should be in a separate patch to convert HAS_FSL_XHCI_USB to Kconfig and update all FSL boards in the same patch. Don't forget to remove it from scripts/config_whitelist.txt. And please write a help paragraph to explain what this Kconfig is for.
board/freescale/ls1043ardb/ls1043ardb.c:130:#ifdef CONFIG_HAS_FSL_XHCI_USB board/freescale/ls1043ardb/ls1043ardb.c:186:#ifdef CONFIG_HAS_FSL_XHCI_USB board/freescale/ls1046ardb/ls1046ardb.c:135:#ifdef CONFIG_HAS_FSL_XHCI_USB board/freescale/ls1046aqds/ls1046aqds.c:171:#ifdef CONFIG_HAS_FSL_XHCI_USB board/freescale/ls1046aqds/ls1046aqds.c:184:#ifdef CONFIG_HAS_FSL_XHCI_USB board/freescale/ls1043aqds/ls1043aqds.c:232:#ifdef CONFIG_HAS_FSL_XHCI_USB board/freescale/ls1043aqds/ls1043aqds.c:245:#ifdef CONFIG_HAS_FSL_XHCI_USB include/configs/ls1021aqds.h:408:#define CONFIG_HAS_FSL_XHCI_USB include/configs/ls1021aqds.h:410:#ifdef CONFIG_HAS_FSL_XHCI_USB include/configs/ls1012ardb.h:25:#define CONFIG_HAS_FSL_XHCI_USB include/configs/ls1012ardb.h:27:#ifdef CONFIG_HAS_FSL_XHCI_USB include/configs/ls1043aqds.h:374:#define CONFIG_HAS_FSL_XHCI_USB include/configs/ls1043aqds.h:375:#ifdef CONFIG_HAS_FSL_XHCI_USB include/configs/ls2080aqds.h:442:#define CONFIG_HAS_FSL_XHCI_USB include/configs/ls1021atwr.h:48:#define CONFIG_HAS_FSL_XHCI_USB include/configs/ls1021atwr.h:50:#ifdef CONFIG_HAS_FSL_XHCI_USB include/configs/ls2080ardb.h:344:#define CONFIG_HAS_FSL_XHCI_USB include/configs/ls1043ardb.h:284:#define CONFIG_HAS_FSL_XHCI_USB include/configs/ls1043ardb.h:285:#ifdef CONFIG_HAS_FSL_XHCI_USB include/configs/ls1021aiot.h:23:#define CONFIG_HAS_FSL_XHCI_USB include/configs/ls1021aiot.h:25:#ifdef CONFIG_HAS_FSL_XHCI_USB include/configs/ls1046ardb.h:214:#define CONFIG_HAS_FSL_XHCI_USB include/configs/ls1046ardb.h:215:#ifdef CONFIG_HAS_FSL_XHCI_USB include/configs/ls1012aqds.h:122:#define CONFIG_HAS_FSL_XHCI_USB include/configs/ls1012aqds.h:124:#ifdef CONFIG_HAS_FSL_XHCI_USB include/configs/ls1012afrdm.h:37:#define CONFIG_HAS_FSL_XHCI_USB include/configs/ls1012afrdm.h:39:#ifdef CONFIG_HAS_FSL_XHCI_USB include/configs/ls1046aqds.h:140:#define CONFIG_HAS_FSL_XHCI_USB include/configs/ls1046aqds.h:141:#ifdef CONFIG_HAS_FSL_XHCI_USB
bool
This should be in a separate patch to convert USB_XHCI_FSL to Kconfig and update all FSL boards in the same patch. Don't forget to remove it from scripts/config_whitelist.txt. And please write a help paragraph to explain what this Kconfig is for. And this should be put in drivers/usb/host/Kconfig instead of here.
endmenu
dr_mode = "host";
dr_mode = "host";
Regards, Bin
Hi Bin
-----Original Message----- From: Bin Meng [mailto:bmeng.cn@gmail.com] Sent: Friday, September 22, 2017 9:24 PM To: Ran Wang ran.wang_1@nxp.com Cc: open list u-boot@lists.denx.de; Albert Aribaud albert.u.boot@aribaud.net; Prabhakar Kushwaha prabhakar.kushwaha@nxp.com; Ashish Kumar ashish.kumar@nxp.com; York Sun york.sun@nxp.com; Z.q. Hou zhiqiang.hou@nxp.com Subject: Re: [U-Boot] [PATCH v2 1/2] ls1088ardb: Enable USB command RDB qspi-boot
Hi Ran,
select USB_XHCI_FSL
bool
bool
OK, I will check this, thanks for your suggestion.
endmenu
dr_mode = "host";
dr_mode = "host";
Regards, Bin
Bin Meng
Ran Wang
