[U-Boot] [PATCH v4 1/1] ARM: kirkwood: add mvsdio driver
Signed-off-by: Gerald Kerma drEagle@doukki.net --- Changes in v4: - rename drivers files to MVSDIO - fix MMC clock init which now use dev ID - clean debug strings - remove MVSDIO_TWEAK_NOSDHS quirk - remove dead code
Changes in v3: - Add MVSDIO_TWEAK_NOSDHS quirk - Minor clean
Changes in v2: - Fix some typo and missing lines from patch import
arch/arm/cpu/arm926ejs/kirkwood/cpu.c | 58 ++++ arch/arm/include/asm/arch-kirkwood/config.h | 2 + arch/arm/include/asm/arch-kirkwood/cpu.h | 2 + arch/arm/include/asm/arch-kirkwood/kirkwood.h | 24 ++ arch/arm/include/asm/arch-kirkwood/kw88f6282.h | 33 +++ board/Marvell/openrd/openrd.c | 11 + board/Marvell/sheevaplug/sheevaplug.c | 11 + drivers/mmc/Makefile | 1 + drivers/mmc/mvsdio.c | 384 +++++++++++++++++++++++++ include/configs/openrd.h | 8 + include/configs/sheevaplug.h | 19 +- include/mvsdio.h | 279 ++++++++++++++++++ 12 files changed, 830 insertions(+), 2 deletions(-) create mode 100644 arch/arm/include/asm/arch-kirkwood/kw88f6282.h create mode 100644 drivers/mmc/mvsdio.c create mode 100644 include/mvsdio.h
diff --git a/arch/arm/cpu/arm926ejs/kirkwood/cpu.c b/arch/arm/cpu/arm926ejs/kirkwood/cpu.c index da80240..472aa8a 100644 --- a/arch/arm/cpu/arm926ejs/kirkwood/cpu.c +++ b/arch/arm/cpu/arm926ejs/kirkwood/cpu.c @@ -333,6 +333,64 @@ int arch_cpu_init(void) } #endif /* CONFIG_ARCH_CPU_INIT */
+/***************************************************************************** + * General + ****************************************************************************/ +#if defined(CONFIG_ARCH_DEV_ID) + +void kirkwood_pcie_id(u32 *dev, u32 *rev) +{ + *dev = (readl(KW_REG_PCIE_DEVID) >> 16) & 0xffff; + *rev = readl(KW_REG_PCIE_REVID) & 0xff; +} + +/* + * Identify device ID and revision. + */ +char *kirkwood_id(void) +{ + u32 dev, rev; + + kirkwood_pcie_id(&dev, &rev); + + if (dev == MV88F6281_DEV_ID) { + if (rev == MV88F6281_REV_Z0) + return "MV88F6281-Z0"; + else if (rev == MV88F6281_REV_A0) + return "MV88F6281-A0"; + else if (rev == MV88F6281_REV_A1) + return "MV88F6281-A1"; + else + return "MV88F6281-Rev-Unsupported"; + } else if (dev == MV88F6192_DEV_ID) { + if (rev == MV88F6192_REV_Z0) + return "MV88F6192-Z0"; + else if (rev == MV88F6192_REV_A0) + return "MV88F6192-A0"; + else if (rev == MV88F6192_REV_A1) + return "MV88F6192-A1"; + else + return "MV88F6192-Rev-Unsupported"; + } else if (dev == MV88F6180_DEV_ID) { + if (rev == MV88F6180_REV_A0) + return "MV88F6180-Rev-A0"; + else if (rev == MV88F6180_REV_A1) + return "MV88F6180-Rev-A1"; + else + return "MV88F6180-Rev-Unsupported"; + } else if (dev == MV88F6282_DEV_ID) { + if (rev == MV88F6282_REV_A0) + return "MV88F6282-Rev-A0"; + else if (rev == MV88F6282_REV_A1) + return "MV88F6282-Rev-A1"; + else + return "MV88F6282-Rev-Unsupported"; + } else { + return "Device-Unknown"; + } +} +#endif /* CONFIG_ARCH_DEV_ID */ + /* * SOC specific misc init */ diff --git a/arch/arm/include/asm/arch-kirkwood/config.h b/arch/arm/include/asm/arch-kirkwood/config.h index 7a688e4..a0563a3 100644 --- a/arch/arm/include/asm/arch-kirkwood/config.h +++ b/arch/arm/include/asm/arch-kirkwood/config.h @@ -19,6 +19,8 @@ #include <asm/arch/kw88f6281.h> #elif defined (CONFIG_KW88F6192) #include <asm/arch/kw88f6192.h> +#elif defined(CONFIG_KW88F6182) +#include <asm/arch/kw88f6182.h> #else #error "SOC Name not defined" #endif /* CONFIG_KW88F6281 */ diff --git a/arch/arm/include/asm/arch-kirkwood/cpu.h b/arch/arm/include/asm/arch-kirkwood/cpu.h index 97daa40..e7b6448 100644 --- a/arch/arm/include/asm/arch-kirkwood/cpu.h +++ b/arch/arm/include/asm/arch-kirkwood/cpu.h @@ -151,5 +151,7 @@ int kw_config_mpp(unsigned int mpp0_7, unsigned int mpp8_15, unsigned int mpp32_39, unsigned int mpp40_47, unsigned int mpp48_55); unsigned int kw_winctrl_calcsize(unsigned int sizeval); +void kirkwood_pcie_id(u32 *dev, u32 *rev); +char *kirkwood_id(void); #endif /* __ASSEMBLY__ */ #endif /* _KWCPU_H */ diff --git a/arch/arm/include/asm/arch-kirkwood/kirkwood.h b/arch/arm/include/asm/arch-kirkwood/kirkwood.h index bc207f5..489517f 100644 --- a/arch/arm/include/asm/arch-kirkwood/kirkwood.h +++ b/arch/arm/include/asm/arch-kirkwood/kirkwood.h @@ -39,6 +39,7 @@ #define KW_EGIGA0_BASE (KW_REGISTER(0x72000)) #define KW_EGIGA1_BASE (KW_REGISTER(0x76000)) #define KW_SATA_BASE (KW_REGISTER(0x80000)) +#define KW_SDIO_BASE (KW_REGISTER(0x90000))
/* Kirkwood Sata controller has two ports */ #define KW_SATA_PORT0_OFFSET 0x2000 @@ -61,10 +62,33 @@ #define MVCPU_WIN_ENABLE KWCPU_WIN_ENABLE #define MVCPU_WIN_DISABLE KWCPU_WIN_DISABLE
+/* + * Supported devices and revisions. + */ +#define MV88F6281_DEV_ID 0x6281 +#define MV88F6281_REV_Z0 0 +#define MV88F6281_REV_A0 2 +#define MV88F6281_REV_A1 3 + +#define MV88F6192_DEV_ID 0x6192 +#define MV88F6192_REV_Z0 0 +#define MV88F6192_REV_A0 2 +#define MV88F6192_REV_A1 3 + +#define MV88F6180_DEV_ID 0x6180 +#define MV88F6180_REV_A0 2 +#define MV88F6180_REV_A1 3 + +#define MV88F6282_DEV_ID 0x6282 +#define MV88F6282_REV_A0 0 +#define MV88F6282_REV_A1 1 + #if defined (CONFIG_KW88F6281) #include <asm/arch/kw88f6281.h> #elif defined (CONFIG_KW88F6192) #include <asm/arch/kw88f6192.h> +#elif defined(CONFIG_KW88F6182) +#include <asm/arch/kw88f6182.h> #else #error "SOC Name not defined" #endif /* CONFIG_KW88F6281 */ diff --git a/arch/arm/include/asm/arch-kirkwood/kw88f6282.h b/arch/arm/include/asm/arch-kirkwood/kw88f6282.h new file mode 100644 index 0000000..5310da2 --- /dev/null +++ b/arch/arm/include/asm/arch-kirkwood/kw88f6282.h @@ -0,0 +1,33 @@ +/* + * (C) Copyright 2009 + * Marvell Semiconductor <www.marvell.com> + * Written-by: Prafulla Wadaskar prafulla@marvell.com + * + * Header file for Feroceon CPU core 88FR131 Based KW88F6281 SOC. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#ifndef _ASM_ARCH_KW88F6281_H +#define _ASM_ARCH_KW88F6281_H + +/* SOC specific definitions */ +#define KW88F6281_REGS_PHYS_BASE 0xf1000000 +#define KW_REGS_PHY_BASE KW88F6281_REGS_PHYS_BASE + +/* TCLK Core Clock definition */ +#ifndef CONFIG_SYS_TCLK +#define CONFIG_SYS_TCLK 200000000 /* 200MHz */ +#endif + diff --git a/board/Marvell/openrd/openrd.c b/board/Marvell/openrd/openrd.c index a005a2f..6e9dca6 100644 --- a/board/Marvell/openrd/openrd.c +++ b/board/Marvell/openrd/openrd.c @@ -17,6 +17,9 @@ #include <asm/arch/kirkwood.h> #include <asm/arch/mpp.h> #include "openrd.h" +#ifdef CONFIG_MVSDIO_MMC +# include <mvsdio.h> +#endif /* CONFIG_MVSDIO_MMC */
DECLARE_GLOBAL_DATA_PTR;
@@ -159,3 +162,11 @@ void reset_phy(void) #endif } #endif /* CONFIG_RESET_PHY_R */ + +#ifdef CONFIG_MRVL_MMC +int board_mmc_init(bd_t *bis) +{ + mrvl_mmc_init(bis); + return 0; +} +#endif /* CONFIG_MRVL_MMC */ diff --git a/board/Marvell/sheevaplug/sheevaplug.c b/board/Marvell/sheevaplug/sheevaplug.c index 87e49f4..c33f55c 100644 --- a/board/Marvell/sheevaplug/sheevaplug.c +++ b/board/Marvell/sheevaplug/sheevaplug.c @@ -12,6 +12,9 @@ #include <asm/arch/kirkwood.h> #include <asm/arch/mpp.h> #include "sheevaplug.h" +#ifdef CONFIG_MVSDIO_MMC +# include <mvsdio.h> +#endif /* CONFIG_MVSDIO_MMC */
@@ -131,3 +134,11 @@ void reset_phy(void) printf("88E1116 Initialized on %s\n", name); } #endif /* CONFIG_RESET_PHY_R */ + +#ifdef CONFIG_MRVL_MMC +int board_mmc_init(bd_t *bis) +{ + mrvl_mmc_init(bis); + return 0; +} +#endif /* CONFIG_MRVL_MMC */ diff --git a/drivers/mmc/Makefile b/drivers/mmc/Makefile index 34febf5..1c8f275 100644 --- a/drivers/mmc/Makefile +++ b/drivers/mmc/Makefile @@ -37,3 +37,4 @@ obj-$(CONFIG_SPL_MMC_BOOT) += fsl_esdhc_spl.o else obj-$(CONFIG_GENERIC_MMC) += mmc_write.o endif +obj-$(CONFIG_MVSDIO_MMC) += mvsdio.o diff --git a/drivers/mmc/mvsdio.c b/drivers/mmc/mvsdio.c new file mode 100644 index 0000000..64e747d --- /dev/null +++ b/drivers/mmc/mvsdio.c @@ -0,0 +1,384 @@ +/* + * Marvell MMC/SD/SDIO driver + * + * (C) Copyright 2012 + * Marvell Semiconductor <www.marvell.com> + * Written-by: Maen Suleiman, Gérald Kerma + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <malloc.h> +#include <part.h> +#include <mmc.h> +#include <asm/io.h> +#include <asm/arch/cpu.h> +#include <asm/arch/kirkwood.h> + +#include <mvsdio.h> + +#define DRIVER_NAME "MVSDIO" + +#define mvsd_write(offs, val) writel(val, CONFIG_SYS_MMC_BASE + (offs)) +#define mvsd_read(offs) readl(CONFIG_SYS_MMC_BASE + (offs)) + +#define MRVL_MMC_MAKE_CMD(c, f) (((c & 0xff) << 8) | (f & 0xff)) + +static int mrvl_mmc_setup_data(struct mmc_data *data) +{ + u32 ctrl_reg; + + debug("%s, data %s : blocks=%d blksz=%d\n", DRIVER_NAME, + (data->flags & MMC_DATA_READ) ? "read" : "write", + data->blocks, data->blocksize); + + /* default to maximum timeout */ + ctrl_reg = mvsd_read(SDIO_HOST_CTRL); + ctrl_reg |= SDIO_HOST_CTRL_TMOUT(SDIO_HOST_CTRL_TMOUT_MAX); + mvsd_write(SDIO_HOST_CTRL, ctrl_reg); + + if (data->flags & MMC_DATA_READ) { + mvsd_write(SDIO_SYS_ADDR_LOW, (u32)data->dest & 0xffff); + mvsd_write(SDIO_SYS_ADDR_HI, (u32)data->dest >> 16); + } else { + mvsd_write(SDIO_SYS_ADDR_LOW, (u32)data->src & 0xffff); + mvsd_write(SDIO_SYS_ADDR_HI, (u32)data->src >> 16); + } + + mvsd_write(SDIO_BLK_COUNT, data->blocks); + mvsd_write(SDIO_BLK_SIZE, data->blocksize); + + return 0; +} + +static int mrvl_mmc_send_cmd(struct mmc *mmc, struct mmc_cmd *cmd, + struct mmc_data *data) +{ + int timeout = 10; + ushort waittype = 0; + ushort resptype = 0; + ushort xfertype = 0; + ushort resp_indx = 0; + + debug("cmdidx [0x%x] resp_type[0x%x] cmdarg[0x%x]\n", + cmd->cmdidx, cmd->resp_type, cmd->cmdarg); + + udelay(10*1000); + + debug("%s: cmd %d (hw state 0x%04x)\n", DRIVER_NAME, + cmd->cmdidx, mvsd_read(SDIO_HW_STATE)); + + /* Checking if card is busy */ + while ((mvsd_read(SDIO_HW_STATE) & CARD_BUSY)) { + if (timeout == 0) { + printf("%s: card busy!\n", DRIVER_NAME); + return -1; + } + timeout--; + udelay(1000); + } + + /* Set up for a data transfer if we have one */ + if (data) { + int err = mrvl_mmc_setup_data(data); + + if (err) + return err; + } + + resptype = SDIO_CMD_INDEX(cmd->cmdidx); + + /* Analyzing resptype/xfertype/waittype for the command */ + if (cmd->resp_type & MMC_RSP_BUSY) + resptype |= SDIO_CMD_RSP_48BUSY; + else if (cmd->resp_type & MMC_RSP_136) + resptype |= SDIO_CMD_RSP_136; + else if (cmd->resp_type & MMC_RSP_PRESENT) + resptype |= SDIO_CMD_RSP_48; + else + resptype |= SDIO_CMD_RSP_NONE; + + if (cmd->resp_type & MMC_RSP_CRC) + resptype |= SDIO_CMD_CHECK_CMDCRC; + + if (cmd->resp_type & MMC_RSP_OPCODE) + resptype |= SDIO_CMD_INDX_CHECK; + + if (cmd->resp_type & MMC_RSP_PRESENT) { + resptype |= SDIO_UNEXPECTED_RESP; + waittype |= SDIO_NOR_UNEXP_RSP; + } + + if (data) { + resptype |= SDIO_CMD_DATA_PRESENT | SDIO_CMD_CHECK_DATACRC16; + xfertype |= SDIO_XFER_MODE_HW_WR_DATA_EN; + if (data->flags & MMC_DATA_READ) { + xfertype |= SDIO_XFER_MODE_TO_HOST; + waittype = SDIO_NOR_DMA_INI; + } else { + waittype |= SDIO_NOR_XFER_DONE; + } + } else { + waittype |= SDIO_NOR_CMD_DONE; + } + + /* Setting cmd arguments */ + mvsd_write(SDIO_ARG_LOW, cmd->cmdarg & 0xffff); + mvsd_write(SDIO_ARG_HI, cmd->cmdarg >> 16); + + /* Setting Xfer mode */ + mvsd_write(SDIO_XFER_MODE, xfertype); + + mvsd_write(SDIO_NOR_INTR_STATUS, ~SDIO_NOR_CARD_INT); + mvsd_write(SDIO_ERR_INTR_STATUS, SDIO_POLL_MASK); + + /* Sending command */ + mvsd_write(SDIO_CMD, resptype); + + mvsd_write(SDIO_NOR_INTR_EN, SDIO_POLL_MASK); + mvsd_write(SDIO_ERR_INTR_EN, SDIO_POLL_MASK); + + /* Waiting for completion */ + timeout = 1000000; + + while (!((mvsd_read(SDIO_NOR_INTR_STATUS)) & waittype)) { + if (mvsd_read(SDIO_NOR_INTR_STATUS) & SDIO_NOR_ERROR) { + debug("%s: error! cmdidx : %d, err reg: %04x\n", + DRIVER_NAME, cmd->cmdidx, + mvsd_read(SDIO_ERR_INTR_STATUS)); + if (mvsd_read(SDIO_ERR_INTR_STATUS) & + (SDIO_ERR_CMD_TIMEOUT | SDIO_ERR_DATA_TIMEOUT)) + return TIMEOUT; + return COMM_ERR; + } + + timeout--; + udelay(1); + if (timeout <= 0) { + printf("%s: command timed out\n", DRIVER_NAME); + return TIMEOUT; + } + } + + /* Handling response */ + if (cmd->resp_type & MMC_RSP_136) { + uint response[8]; + + for (resp_indx = 0; resp_indx < 8; resp_indx++) + response[resp_indx] = mvsd_read(SDIO_RSP(resp_indx)); + + cmd->response[0] = ((response[0] & 0x03ff) << 22) | + ((response[1] & 0xffff) << 6) | + ((response[2] & 0xfc00) >> 10); + cmd->response[1] = ((response[2] & 0x03ff) << 22) | + ((response[3] & 0xffff) << 6) | + ((response[4] & 0xfc00) >> 10); + cmd->response[2] = ((response[4] & 0x03ff) << 22) | + ((response[5] & 0xffff) << 6) | + ((response[6] & 0xfc00) >> 10); + cmd->response[3] = ((response[6] & 0x03ff) << 22) | + ((response[7] & 0x3fff) << 8); + } else if (cmd->resp_type & MMC_RSP_PRESENT) { + uint response[3]; + + for (resp_indx = 0; resp_indx < 3; resp_indx++) + response[resp_indx] = mvsd_read(SDIO_RSP(resp_indx)); + + cmd->response[0] = ((response[2] & 0x003f) << (8 - 8)) | + ((response[1] & 0xffff) << (14 - 8)) | + ((response[0] & 0x03ff) << (30 - 8)); + cmd->response[1] = ((response[0] & 0xfc00) >> 10); + cmd->response[2] = 0; + cmd->response[3] = 0; + } + + debug("%s: resp[0x%x] ", DRIVER_NAME, cmd->resp_type); + debug("[0x%x] ", cmd->response[0]); + debug("[0x%x] ", cmd->response[1]); + debug("[0x%x] ", cmd->response[2]); + debug("[0x%x] ", cmd->response[3]); + debug("\n"); + + return 0; +} + +static void mvsd_power_up(void) +{ + debug("%s: power up\n", DRIVER_NAME); + + /* disable interrupts */ + mvsd_write(SDIO_NOR_INTR_EN, 0); + mvsd_write(SDIO_ERR_INTR_EN, 0); + + /* SW reset */ + mvsd_write(SDIO_SW_RESET, SDIO_SW_RESET_NOW); + + mvsd_write(SDIO_XFER_MODE, 0); + + /* enable status */ + mvsd_write(SDIO_NOR_STATUS_EN, SDIO_POLL_MASK); + mvsd_write(SDIO_ERR_STATUS_EN, SDIO_POLL_MASK); + + /* enable interrupts status */ + mvsd_write(SDIO_NOR_INTR_STATUS, SDIO_POLL_MASK); + mvsd_write(SDIO_ERR_INTR_STATUS, SDIO_POLL_MASK); +} + +static u32 mrvl_mmc_get_base_clock(void) +{ + u32 devid; + u32 revid; + + kirkwood_pcie_id(&devid, &revid); + + debug("%s: board devid[0x%x] devid[0x%x]\n", + DRIVER_NAME, devid, revid); + + if (revid == 0 && devid != MV88F6282_DEV_ID) { + /* catch all Kirkwood Z0's */ + debug("%s: Kirkwood Z0's base clock = %d\n", + DRIVER_NAME, MRVL_MMC_BASE_FAST_CLK_100); + return MRVL_MMC_BASE_FAST_CLK_100; + } else { + debug("%s: base clock = %d\n", + DRIVER_NAME, MRVL_MMC_BASE_FAST_CLK_200); + return MRVL_MMC_BASE_FAST_CLK_200; + } + return MRVL_MMC_BASE_FAST_CLOCK; +} + +static void mrvl_mmc_set_clk(unsigned int clock) +{ + unsigned int m; + + if (clock == 0) { + debug("%s: clock off\n", DRIVER_NAME); + mvsd_write(SDIO_XFER_MODE, SDIO_XFER_MODE_STOP_CLK); + mvsd_write(SDIO_CLK_DIV, MRVL_MMC_BASE_DIV_MAX); + } else { + m = MRVL_MMC_BASE_FAST_CLOCK/(2*clock) - 1; + if (m > MRVL_MMC_BASE_DIV_MAX) + m = MRVL_MMC_BASE_DIV_MAX; + debug("%s: base = %d dividor = 0x%x clock=%d\n", + DRIVER_NAME, mrvl_mmc_get_base_clock(), + m, clock); + mvsd_write(SDIO_CLK_DIV, m & MRVL_MMC_BASE_DIV_MAX); + } + udelay(10*1000); +} + +static void mrvl_mmc_set_bus(unsigned int bus) +{ + u32 ctrl_reg = 0; + + ctrl_reg = mvsd_read(SDIO_HOST_CTRL); + ctrl_reg &= ~SDIO_HOST_CTRL_DATA_WIDTH_4_BITS; + + switch (bus) { + case 4: + ctrl_reg |= SDIO_HOST_CTRL_DATA_WIDTH_4_BITS; + break; + case 1: + default: + ctrl_reg |= SDIO_HOST_CTRL_DATA_WIDTH_1_BIT; + } + /* default transfer mode */ + ctrl_reg |= SDIO_HOST_CTRL_BIG_ENDIAN; + ctrl_reg &= ~SDIO_HOST_CTRL_LSB_FIRST; + + /* default to maximum timeout */ + ctrl_reg |= SDIO_HOST_CTRL_TMOUT(SDIO_HOST_CTRL_TMOUT_MAX); + + ctrl_reg |= SDIO_HOST_CTRL_PUSH_PULL_EN; + + ctrl_reg |= SDIO_HOST_CTRL_CARD_TYPE_MEM_ONLY; + + debug("%s: ctrl 0x%04x: %s %s %s\n", DRIVER_NAME, ctrl_reg, + (ctrl_reg & SDIO_HOST_CTRL_PUSH_PULL_EN) ? + "push-pull" : "open-drain", + (ctrl_reg & SDIO_HOST_CTRL_DATA_WIDTH_4_BITS) ? + "4bit-width" : "1bit-width", + (ctrl_reg & SDIO_HOST_CTRL_HI_SPEED_EN) ? + "high-speed" : ""); + + mvsd_write(SDIO_HOST_CTRL, ctrl_reg); + udelay(10*1000); +} + +static void mrvl_mmc_set_ios(struct mmc *mmc) +{ + debug("%s: bus[%d] clock[%d]\n", DRIVER_NAME, + mmc->bus_width, mmc->clock); + mrvl_mmc_set_bus(mmc->bus_width); + mrvl_mmc_set_clk(mmc->clock); +} + +static int mrvl_mmc_initialize(struct mmc *mmc) +{ + debug("%s: mrvl_mmc_initialize", DRIVER_NAME); + +/* + * Setting host parameters + * Initial Host Ctrl : Timeout : max , Normal Speed mode, 4-bit data mode + * Big Endian, SD memory Card, Push_pull CMD Line + */ + mvsd_write(SDIO_HOST_CTRL, + SDIO_HOST_CTRL_TMOUT(SDIO_HOST_CTRL_TMOUT_MAX) | + SDIO_HOST_CTRL_DATA_WIDTH_4_BITS | + SDIO_HOST_CTRL_BIG_ENDIAN | + SDIO_HOST_CTRL_PUSH_PULL_EN | + SDIO_HOST_CTRL_CARD_TYPE_MEM_ONLY); + + mvsd_write(SDIO_CLK_CTRL, 0); + + /* enable status */ + mvsd_write(SDIO_NOR_STATUS_EN, SDIO_POLL_MASK); + mvsd_write(SDIO_ERR_STATUS_EN, SDIO_POLL_MASK); + + /* disable interrupts */ + mvsd_write(SDIO_NOR_INTR_EN, 0); + mvsd_write(SDIO_ERR_INTR_EN, 0); + + /* SW reset */ + mvsd_write(SDIO_SW_RESET, SDIO_SW_RESET_NOW); + + udelay(10*1000); + + return 0; +} + +static const struct mmc_ops mrvl_ops = { + .send_cmd = mrvl_mmc_send_cmd, + .set_ios = mrvl_mmc_set_ios, + .init = mrvl_mmc_initialize, +}; + +static struct mmc_config mrvl_cfg = { + .name = DRIVER_NAME, + .ops = &mrvl_ops, + .f_min = MRVL_MMC_BASE_FAST_CLOCK / MRVL_MMC_BASE_DIV_MAX, + .f_max = MRVL_MMC_CLOCKRATE_MAX, + .voltages = MMC_VDD_32_33 | MMC_VDD_33_34, + .host_caps = MMC_MODE_4BIT | MMC_MODE_HS, + .part_type = PART_TYPE_DOS, + .b_max = CONFIG_SYS_MMC_MAX_BLK_COUNT, +}; + +int mrvl_mmc_init(bd_t *bis) +{ + struct mmc *mmc; + + mrvl_cfg.f_min = mrvl_mmc_get_base_clock() / MRVL_MMC_BASE_DIV_MAX; + + debug("%s: %s base_clock = %d", DRIVER_NAME, + kirkwood_id(), mrvl_mmc_get_base_clock()); + + mvsd_power_up(); + + mmc = mmc_create(&mrvl_cfg, bis); + if (mmc == NULL) + return -1; + + return 0; +} diff --git a/include/configs/openrd.h b/include/configs/openrd.h index 8fab6e6..03370b7 100644 --- a/include/configs/openrd.h +++ b/include/configs/openrd.h @@ -49,6 +49,7 @@ #define CONFIG_CMD_DHCP #define CONFIG_CMD_ENV #define CONFIG_CMD_MII +#define CONFIG_CMD_MMC #define CONFIG_CMD_NAND #define CONFIG_CMD_PING #define CONFIG_CMD_USB @@ -123,4 +124,11 @@ #define CONFIG_SYS_ATA_IDE1_OFFSET MV_SATA_PORT1_OFFSET #endif /*CONFIG_MVSATA_IDE*/
+#ifdef CONFIG_CMD_MMC +#define CONFIG_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_MVSDIO_MMC +#define CONFIG_SYS_MMC_BASE KW_SDIO_BASE +#endif /* CONFIG_CMD_MMC */ + #endif /* _CONFIG_OPENRD_BASE_H */ diff --git a/include/configs/sheevaplug.h b/include/configs/sheevaplug.h index ecc93bc..b6ecac9 100644 --- a/include/configs/sheevaplug.h +++ b/include/configs/sheevaplug.h @@ -23,6 +23,8 @@ #define CONFIG_MACH_SHEEVAPLUG /* Machine type */ #define CONFIG_SKIP_LOWLEVEL_INIT /* disable board lowlevel_init */
+#define CONFIG_ARCH_DEV_ID 1 + /* * Commands configuration */ @@ -31,9 +33,11 @@ #define CONFIG_CMD_DHCP #define CONFIG_CMD_ENV #define CONFIG_CMD_MII +#define CONFIG_CMD_MMC #define CONFIG_CMD_NAND #define CONFIG_CMD_PING #define CONFIG_CMD_USB + /* * mv-common.h should be defined after CMD configs since it used them * to enable certain macros @@ -49,13 +53,14 @@ #else #define CONFIG_ENV_IS_NOWHERE 1 /* if env in SDRAM */ #endif + /* * max 4k env size is enough, but in case of nand * it has to be rounded to sector size */ #define CONFIG_ENV_SIZE 0x20000 /* 128k */ -#define CONFIG_ENV_ADDR 0x60000 -#define CONFIG_ENV_OFFSET 0x60000 /* env starts here */ +#define CONFIG_ENV_ADDR 0x80000 +#define CONFIG_ENV_OFFSET 0x80000 /* env starts here */
/* * Default environment variables @@ -82,6 +87,16 @@ #endif /* CONFIG_CMD_NET */
/* + * SDIO/MMC Card Configuration + */ +#ifdef CONFIG_CMD_MMC +#define CONFIG_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_MVSDIO_MMC +#define CONFIG_SYS_MMC_BASE KW_SDIO_BASE +#endif /* CONFIG_CMD_MMC */ + +/* * File system */ #define CONFIG_CMD_EXT2 diff --git a/include/mvsdio.h b/include/mvsdio.h new file mode 100644 index 0000000..70d7b1c --- /dev/null +++ b/include/mvsdio.h @@ -0,0 +1,279 @@ +/* + * Marvell MMC/SD/SDIO driver + * + * (C) Copyright 2012 + * Marvell Semiconductor <www.marvell.com> + * Written-by: Maen Suleiman, Gérald Kerma + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __MRVL_MMC_H__ +#define __MRVL_MMC_H__ + +/* needed for the mmc_cfg definition */ +#include <mmc.h> + +#define MMC_BLOCK_SIZE 512 + +/* + * Clock rates + */ + +#define MRVL_MMC_CLOCKRATE_MAX 50000000 +#define MRVL_MMC_BASE_DIV_MAX 0x7ff +#define MRVL_MMC_BASE_FAST_CLOCK CONFIG_SYS_TCLK +#define MRVL_MMC_BASE_FAST_CLK_100 100000000 +#define MRVL_MMC_BASE_FAST_CLK_200 200000000 + +/* SDIO register */ +#define SDIO_SYS_ADDR_LOW 0x000 +#define SDIO_SYS_ADDR_HI 0x004 +#define SDIO_BLK_SIZE 0x008 +#define SDIO_BLK_COUNT 0x00c +#define SDIO_ARG_LOW 0x010 +#define SDIO_ARG_HI 0x014 +#define SDIO_XFER_MODE 0x018 +#define SDIO_CMD 0x01c +#define SDIO_RSP(i) (0x020 + ((i)<<2)) +#define SDIO_RSP0 0x020 +#define SDIO_RSP1 0x024 +#define SDIO_RSP2 0x028 +#define SDIO_RSP3 0x02c +#define SDIO_RSP4 0x030 +#define SDIO_RSP5 0x034 +#define SDIO_RSP6 0x038 +#define SDIO_RSP7 0x03c +#define SDIO_BUF_DATA_PORT 0x040 +#define SDIO_RSVED 0x044 +#define SDIO_HW_STATE 0x048 +#define SDIO_PRESENT_STATE0 0x048 +#define SDIO_PRESENT_STATE1 0x04c +#define SDIO_HOST_CTRL 0x050 +#define SDIO_BLK_GAP_CTRL 0x054 +#define SDIO_CLK_CTRL 0x058 +#define SDIO_SW_RESET 0x05c +#define SDIO_NOR_INTR_STATUS 0x060 +#define SDIO_ERR_INTR_STATUS 0x064 +#define SDIO_NOR_STATUS_EN 0x068 +#define SDIO_ERR_STATUS_EN 0x06c +#define SDIO_NOR_INTR_EN 0x070 +#define SDIO_ERR_INTR_EN 0x074 +#define SDIO_AUTOCMD12_ERR_STATUS 0x078 +#define SDIO_CURR_BYTE_LEFT 0x07c +#define SDIO_CURR_BLK_LEFT 0x080 +#define SDIO_AUTOCMD12_ARG_LOW 0x084 +#define SDIO_AUTOCMD12_ARG_HI 0x088 +#define SDIO_AUTOCMD12_INDEX 0x08c +#define SDIO_AUTO_RSP(i) (0x090 + ((i)<<2)) +#define SDIO_AUTO_RSP0 0x090 +#define SDIO_AUTO_RSP1 0x094 +#define SDIO_AUTO_RSP2 0x098 +#define SDIO_CLK_DIV 0x128 + +#define WINDOW_CTRL(i) (0x108 + ((i) << 3)) +#define WINDOW_BASE(i) (0x10c + ((i) << 3)) + +/* SDIO_PRESENT_STATE */ +#define CARD_BUSY (1 << 1) +#define CMD_INHIBIT (1 << 0) +#define CMD_TXACTIVE (1 << 8) +#define CMD_RXACTIVE (1 << 9) +#define CMD_AUTOCMD12ACTIVE (1 << 14) +#define CMD_BUS_BUSY (CMD_AUTOCMD12ACTIVE | \ + CMD_RXACTIVE | \ + CMD_TXACTIVE | \ + CMD_INHIBIT | \ + CARD_BUSY) + +/* + * SDIO_CMD + */ + +#define SDIO_CMD_RSP_NONE (0 << 0) +#define SDIO_CMD_RSP_136 (1 << 0) +#define SDIO_CMD_RSP_48 (2 << 0) +#define SDIO_CMD_RSP_48BUSY (3 << 0) + +#define SDIO_CMD_CHECK_DATACRC16 (1 << 2) +#define SDIO_CMD_CHECK_CMDCRC (1 << 3) +#define SDIO_CMD_INDX_CHECK (1 << 4) +#define SDIO_CMD_DATA_PRESENT (1 << 5) +#define SDIO_UNEXPECTED_RESP (1 << 7) + +#define SDIO_CMD_INDEX(x) ((x) << 8) + +/* + * SDIO_XFER_MODE + */ + +#define SDIO_XFER_MODE_STOP_CLK (1 << 5) +#define SDIO_XFER_MODE_HW_WR_DATA_EN (1 << 1) +#define SDIO_XFER_MODE_AUTO_CMD12 (1 << 2) +#define SDIO_XFER_MODE_INT_CHK_EN (1 << 3) +#define SDIO_XFER_MODE_TO_HOST (1 << 4) +#define SDIO_XFER_MODE_DMA (0 << 6) + +/* + * SDIO_HOST_CTRL + */ + +#define SDIO_HOST_CTRL_PUSH_PULL_EN (1 << 0) + +#define SDIO_HOST_CTRL_CARD_TYPE_MEM_ONLY (0 << 1) +#define SDIO_HOST_CTRL_CARD_TYPE_IO_ONLY (1 << 1) +#define SDIO_HOST_CTRL_CARD_TYPE_IO_MEM_COMBO (2 << 1) +#define SDIO_HOST_CTRL_CARD_TYPE_IO_MMC (3 << 1) +#define SDIO_HOST_CTRL_CARD_TYPE_MASK (3 << 1) + +#define SDIO_HOST_CTRL_BIG_ENDIAN (1 << 3) +#define SDIO_HOST_CTRL_LSB_FIRST (1 << 4) +#define SDIO_HOST_CTRL_DATA_WIDTH_1_BIT (0 << 9) +#define SDIO_HOST_CTRL_DATA_WIDTH_4_BITS (1 << 9) +#define SDIO_HOST_CTRL_HI_SPEED_EN (1 << 10) + +#define SDIO_HOST_CTRL_TMOUT_MAX 0xf +#define SDIO_HOST_CTRL_TMOUT_MASK (0xf << 11) +#define SDIO_HOST_CTRL_TMOUT(x) ((x) << 11) +#define SDIO_HOST_CTRL_TMOUT_EN (1 << 15) + +/* + * SDIO_SW_RESET + */ + +#define SDIO_SW_RESET_NOW (1 << 8) + +/* + * Normal interrupt status bits + */ + +#define SDIO_NOR_ERROR (1 << 15) +#define SDIO_NOR_UNEXP_RSP (1 << 14) +#define SDIO_NOR_AUTOCMD12_DONE (1 << 13) +#define SDIO_NOR_SUSPEND_ON (1 << 12) +#define SDIO_NOR_LMB_FF_8W_AVAIL (1 << 11) +#define SDIO_NOR_LMB_FF_8W_FILLED (1 << 10) +#define SDIO_NOR_READ_WAIT_ON (1 << 9) +#define SDIO_NOR_CARD_INT (1 << 8) +#define SDIO_NOR_READ_READY (1 << 5) +#define SDIO_NOR_WRITE_READY (1 << 4) +#define SDIO_NOR_DMA_INI (1 << 3) +#define SDIO_NOR_BLK_GAP_EVT (1 << 2) +#define SDIO_NOR_XFER_DONE (1 << 1) +#define SDIO_NOR_CMD_DONE (1 << 0) + +/* + * Error status bits + */ + +#define SDIO_ERR_CRC_STATUS (1 << 14) +#define SDIO_ERR_CRC_STARTBIT (1 << 13) +#define SDIO_ERR_CRC_ENDBIT (1 << 12) +#define SDIO_ERR_RESP_TBIT (1 << 11) +#define SDIO_ERR_XFER_SIZE (1 << 10) +#define SDIO_ERR_CMD_STARTBIT (1 << 9) +#define SDIO_ERR_AUTOCMD12 (1 << 8) +#define SDIO_ERR_DATA_ENDBIT (1 << 6) +#define SDIO_ERR_DATA_CRC (1 << 5) +#define SDIO_ERR_DATA_TIMEOUT (1 << 4) +#define SDIO_ERR_CMD_INDEX (1 << 3) +#define SDIO_ERR_CMD_ENDBIT (1 << 2) +#define SDIO_ERR_CMD_CRC (1 << 1) +#define SDIO_ERR_CMD_TIMEOUT (1 << 0) +/* enable all for polling */ +#define SDIO_POLL_MASK 0xffff + +/* + * CMD12 error status bits + */ + +#define SDIO_AUTOCMD12_ERR_NOTEXE (1 << 0) +#define SDIO_AUTOCMD12_ERR_TIMEOUT (1 << 1) +#define SDIO_AUTOCMD12_ERR_CRC (1 << 2) +#define SDIO_AUTOCMD12_ERR_ENDBIT (1 << 3) +#define SDIO_AUTOCMD12_ERR_INDEX (1 << 4) +#define SDIO_AUTOCMD12_ERR_RESP_T_BIT (1 << 5) +#define SDIO_AUTOCMD12_ERR_RESP_STARTBIT (1 << 6) + +#define MMC_RSP_PRESENT (1 << 0) +/* 136 bit response */ +#define MMC_RSP_136 (1 << 1) +/* expect valid crc */ +#define MMC_RSP_CRC (1 << 2) +/* card may send busy */ +#define MMC_RSP_BUSY (1 << 3) +/* response contains opcode */ +#define MMC_RSP_OPCODE (1 << 4) + +#define MMC_BUSMODE_OPENDRAIN 1 +#define MMC_BUSMODE_PUSHPULL 2 + +#define MMC_BUS_WIDTH_1 0 +#define MMC_BUS_WIDTH_4 2 +#define MMC_BUS_WIDTH_8 3 + +/* Can the host do 4 bit transfers */ +#define MMC_CAP_4_BIT_DATA (1 << 0) +/* Can do MMC high-speed timing */ +#define MMC_CAP_MMC_HIGHSPEED (1 << 1) +/* Can do SD high-speed timing */ +#define MMC_CAP_SD_HIGHSPEED (1 << 2) +/* Can signal pending SDIO IRQs */ +#define MMC_CAP_SDIO_IRQ (1 << 3) +/* Talks only SPI protocols */ +#define MMC_CAP_SPI (1 << 4) +/* Needs polling for card-detection */ +#define MMC_CAP_NEEDS_POLL (1 << 5) +/* Can the host do 8 bit transfers */ +#define MMC_CAP_8_BIT_DATA (1 << 6) + +/* Nonremovable e.g. eMMC */ +#define MMC_CAP_NONREMOVABLE (1 << 8) +/* Waits while card is busy */ +#define MMC_CAP_WAIT_WHILE_BUSY (1 << 9) +/* Allow erase/trim commands */ +#define MMC_CAP_ERASE (1 << 10) +/* can support DDR mode at 1.8V */ +#define MMC_CAP_1_8V_DDR (1 << 11) +/* can support DDR mode at 1.2V */ +#define MMC_CAP_1_2V_DDR (1 << 12) +/* Can power off after boot */ +#define MMC_CAP_POWER_OFF_CARD (1 << 13) +/* CMD14/CMD19 bus width ok */ +#define MMC_CAP_BUS_WIDTH_TEST (1 << 14) +/* Host supports UHS SDR12 mode */ +#define MMC_CAP_UHS_SDR12 (1 << 15) +/* Host supports UHS SDR25 mode */ +#define MMC_CAP_UHS_SDR25 (1 << 16) +/* Host supports UHS SDR50 mode */ +#define MMC_CAP_UHS_SDR50 (1 << 17) +/* Host supports UHS SDR104 mode */ +#define MMC_CAP_UHS_SDR104 (1 << 18) +/* Host supports UHS DDR50 mode */ +#define MMC_CAP_UHS_DDR50 (1 << 19) +/* Host supports Driver Type A */ +#define MMC_CAP_DRIVER_TYPE_A (1 << 23) +/* Host supports Driver Type C */ +#define MMC_CAP_DRIVER_TYPE_C (1 << 24) +/* Host supports Driver Type D */ +#define MMC_CAP_DRIVER_TYPE_D (1 << 25) +/* CMD23 supported. */ +#define MMC_CAP_CMD23 (1 << 30) +/* Hardware reset */ +#define MMC_CAP_HW_RESET (1 << 31) + + +struct mrvl_cfg { + u32 mvsdio_base; + u32 mvsdio_clk; + u8 max_bus_width; + struct mmc_config cfg; +}; + +/* + * Functions prototypes + */ + +int mrvl_mmc_init(bd_t *bis); + +#endif /* __MRVL_MMC_H__ */
Hi Gerald,
Changes in v4:
- remove dead code
Thanks. But still some more comments below.
Changes in v3:
- Minor clean
Changes in v2:
- General
- *dev = (readl(KW_REG_PCIE_DEVID) >> 16) & 0xffff;
- *rev = readl(KW_REG_PCIE_REVID) & 0xff;
- Identify device ID and revision.
- u32 dev, rev;
- kirkwood_pcie_id(&dev, &rev);
- if (dev == MV88F6281_DEV_ID) {
else
- } else if (dev == MV88F6192_DEV_ID) {
else
- } else if (dev == MV88F6180_DEV_ID) {
else
- } else if (dev == MV88F6282_DEV_ID) {
else
- } else {
I still don't see why this function is needed for the MMC driver. It seems to only be used from a debug() output. I suggest to remove it from this patch to not touch the general kirkwood stuff.
Also this MMC driver should be able to support multiple Marvells SoC's, right? So calling some "kirkwood" functions doesn't seem to be generic.
- SOC specific misc init
- Supported devices and revisions.
- #if defined (CONFIG_KW88F6281) #include <asm/arch/kw88f6281.h> #elif defined (CONFIG_KW88F6192) #include <asm/arch/kw88f6192.h>
- (C) Copyright 2009
- Marvell Semiconductor <www.marvell.com>
- Written-by: Prafulla Wadaskar prafulla@marvell.com
- Header file for Feroceon CPU core 88FR131 Based KW88F6281 SOC.
- project.
Again, please use the SPDX license identifier as done in all U-Boot sources now. This is mandatory!
BTW: You seem to be adding a new Kirkwood SoC version with this MMC patch. This really is not MMC related and should be split into a separate patch.
Thanks, Stefan
Hi Stefan,
On 25/07/2014 09:15, Stefan Roese wrote:
Hi Gerald,
Thanks for the review.
Just sent a new version of the patch.
Agree, cleaned as requested.
Oops...
Will do this.
Enjoy,
Hi Gerald,
On 25.07.2014 15:34, drEagle wrote:
Hi Stefan,
Hi Gerald,
Great. I still have a few comments though. Sorry for not pointing out earlier. I'll send a separate mail for this.
Thanks, Stefan
drEagle
Gerald Kerma
Stefan Roese
Stefan Roese
