Re: [U-Boot-Users] IXP425 ethernet & NPE microcode
Hi Martijn,
On Monday 14 May 2007, Martijn de Gouw wrote:
Doesn't apply on current version:
Could you please create a new patch against the current U-Boot version and
here is a new patch
Sorry it took me so long. Still doesn't apply though:
stefan@ubuntu:~/git/u-boot/u-boot-ixp$ cg-patch < u-boot-npe-nor.diff patching file include/configs/pdnb3.h Hunk #2 succeeded at 93 (offset 6 lines). Hunk #3 succeeded at 132 (offset 6 lines). Hunk #4 FAILED at 184. 1 out of 4 hunks FAILED -- saving rejects to file include/configs/pdnb3.h.rej patching file tools/env/fw_env.h patching file cpu/ixp/npe/IxNpeDl.c patching file cpu/ixp/npe/IxNpeDlImageMgr.c patching file cpu/ixp/npe/Makefile patching file cpu/ixp/npe/include/IxNpeDlImageMgr_p.h patching file cpu/ixp/npe/include/IxNpeMicrocode.h patching file cpu/ixp/npe/npe.c patching file include/configs/pdnb3.h Hunk #2 FAILED at 76. Hunk #3 FAILED at 182. Hunk #4 succeeded at 223 (offset 20 lines). 2 out of 4 hunks FAILED -- saving rejects to file include/configs/pdnb3.h.rej
This is quite confusing since you seem to have combined two patches in this single patch file. For example pdnb3.h is patched twice! If it's easier for you, then please send me two patches, one for the IXP-NPE stuff and one for your pdnb3 config file. Thanks.
Could you please resend a patch against the current repository? I'll promise to check and submit this time quickly.
resend. And please add a more descriptive commit log than:
Patch includes trimming of unused functionality in NPE driver.
The following defines define the address to load firmware from:
CONFIG_NPE_B_ADDR1 CONFIG_NPE_C_ADDR1
There are also a second set addresses, in case first fails to contain a valid microcode image:
CONFIG_NPE_B_ADDR2 CONFIG_NPE_C_ADDR2
Thanks. But it's still missing the requested README. As I wrote earlier:
" And please also add a little description (perhap in doc/README.ixp-npe) on how to configure the newly added configuration defines "CONFIG_NPE_x_ADDRx". I assume they point to a location in FLASH where the NPE binary should be stored, right? Please describe this so that other people (and me after a few months) understand this too. "
Best would be to add a small example here, what file needs to get downloaded from Intel (NPE binary), and how to program this to the correct location in FLASH.
Thanks.
Best regards, Stefan
Stefan Roese
