[U-Boot] [PATCH] pci: move pciauto_config_init() to pci.h
Fixing build regressions for the Integrator I get find that a few boards try to work around the missing declaration of pciauto_config_init() by declaring it in the local scope. This does not make sense when the sibling functions are in <pci.h> so move the function to the header, ridding the build error in the Integrator and getting rid of the local declarations here and there.
Reported-by: Wolfgang Denk wd@denx.de Signed-off-by: Linus Walleij linus.walleij@linaro.org --- board/esd/cpci750/pci.c | 1 - board/prodrive/p3mx/pci.c | 1 - drivers/pci/fsl_pci_init.c | 1 - drivers/pci/pci.c | 1 - include/pci.h | 1 + 5 files changed, 1 insertions(+), 4 deletions(-)
diff --git a/board/esd/cpci750/pci.c b/board/esd/cpci750/pci.c index a2c1c50..24ab13f 100644 --- a/board/esd/cpci750/pci.c +++ b/board/esd/cpci750/pci.c @@ -29,7 +29,6 @@ #include <pci.h>
#ifdef CONFIG_PCI_PNP -void pciauto_config_init(struct pci_controller *hose); int pciauto_region_allocate(struct pci_region* res, unsigned int size, unsigned int *bar); #endif
diff --git a/board/prodrive/p3mx/pci.c b/board/prodrive/p3mx/pci.c index e36b676..712c21c 100644 --- a/board/prodrive/p3mx/pci.c +++ b/board/prodrive/p3mx/pci.c @@ -29,7 +29,6 @@ #include <pci.h>
diff --git a/drivers/pci/fsl_pci_init.c b/drivers/pci/fsl_pci_init.c index bff1314..d04a08c 100644 --- a/drivers/pci/fsl_pci_init.c +++ b/drivers/pci/fsl_pci_init.c @@ -51,7 +51,6 @@ void pciauto_prescan_setup_bridge(struct pci_controller *hose, pci_dev_t dev, int sub_bus); void pciauto_postscan_setup_bridge(struct pci_controller *hose, pci_dev_t dev, int sub_bus); -void pciauto_config_init(struct pci_controller *hose);
#ifndef CONFIG_SYS_PCI_MEMORY_BUS #define CONFIG_SYS_PCI_MEMORY_BUS 0 diff --git a/drivers/pci/pci.c b/drivers/pci/pci.c index bee2b52..007b850 100644 --- a/drivers/pci/pci.c +++ b/drivers/pci/pci.c @@ -518,7 +518,6 @@ void pci_cfgfunc_do_nothing(struct pci_controller *hose, * to get the correct result when scanning bridges */ extern int pciauto_config_device(struct pci_controller *hose, pci_dev_t dev); -extern void pciauto_config_init(struct pci_controller *hose);
#if defined(CONFIG_CMD_PCI) || defined(CONFIG_PCI_SCAN_SHOW) const char * pci_class_str(u8 class) diff --git a/include/pci.h b/include/pci.h index 1284c42..7d98ad4 100644 --- a/include/pci.h +++ b/include/pci.h @@ -527,6 +527,7 @@ extern void pciauto_setup_device(struct pci_controller *hose, struct pci_region *mem, struct pci_region *prefetch, struct pci_region *io); +extern void pciauto_config_init(struct pci_controller *hose); int pciauto_config_device(struct pci_controller *hose, pci_dev_t dev);
extern pci_dev_t pci_find_device (unsigned int vendor, unsigned int device, int index);
Dear "Linus Walleij",
In message 1330805108-24007-1-git-send-email-linus.walleij@linaro.org you wrote:
Applied, thanks.
Linus Walleij
