[U-Boot-Users] [PATCH] Declare load_serial_ymodem() when using CFG_CMD_LOADB
Signed-off-by: Jon Loeliger jdl@freescale.com
* Declare load_serial_ymodem() when using CFG_CMD_LOADB. Patch by Jon Loeliger, 01-May-2006
diff --git a/common/cmd_load.c b/common/cmd_load.c index 2432ee2..f63b8e8 100644 --- a/common/cmd_load.c +++ b/common/cmd_load.c @@ -33,9 +33,12 @@ #include <xyzModem.h>
DECLARE_GLOBAL_DATA_PTR;
+#if (CONFIG_COMMANDS & CFG_CMD_LOADB) +static ulong load_serial_ymodem (ulong offset); +#endif + #if (CONFIG_COMMANDS & CFG_CMD_LOADS) static ulong load_serial (ulong offset); -static ulong load_serial_ymodem (ulong offset); static int read_record (char *buf, ulong len); # if (CONFIG_COMMANDS & CFG_CMD_SAVES) static int save_serial (ulong offset, ulong size);
In message 1146513449.24239.45.camel@cashmere.sps.mot.com you wrote:
- Declare load_serial_ymodem() when using CFG_CMD_LOADB. Patch by Jon Loeliger, 01-May-2006
Applied, thanks.
Jon Loeliger
