[U-Boot] [PATCH 1/1] configs:ls1046afrwy: Add tfa secure boot defonfig.
Add TFA secure boot defconfig and Enables secure boot related configs in it.
Signed-off-by: Udit Agarwal udit.agarwal@nxp.com --- configs/ls1046afrwy_tfa_SECURE_BOOT_defconfig | 61 +++++++++++++++++++ 1 file changed, 61 insertions(+) create mode 100644 configs/ls1046afrwy_tfa_SECURE_BOOT_defconfig
diff --git a/configs/ls1046afrwy_tfa_SECURE_BOOT_defconfig b/configs/ls1046afrwy_tfa_SECURE_BOOT_defconfig new file mode 100644 index 0000000000..6cb192b003 --- /dev/null +++ b/configs/ls1046afrwy_tfa_SECURE_BOOT_defconfig @@ -0,0 +1,61 @@ +CONFIG_ARM=y +CONFIG_TARGET_LS1046AFRWY=y +CONFIG_SYS_TEXT_BASE=0x82000000 +CONFIG_SECURE_BOOT=y +CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y +CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y +CONFIG_QSPI_AHB_INIT=y +CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1046a-frwy" +CONFIG_DISTRO_DEFAULTS=y +CONFIG_NR_DRAM_BANKS=2 +CONFIG_FIT_VERBOSE=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_TFABOOT=y +CONFIG_BOOTDELAY=10 +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0500 mtdparts=1550000.quadspi:1m(rcw),15m(u-boot),48m(kernel.itb);7e800000.flash:16m(nand_uboot),48m(nand_kernel),448m(nand_free)" +CONFIG_MISC_INIT_R=y +# CONFIG_SPI_FLASH_USE_4K_SECTORS is not set +CONFIG_CMD_GPT=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_NAND=y +CONFIG_CMD_PCI=y +CONFIG_CMD_SF=y +CONFIG_CMD_USB=y +CONFIG_CMD_CACHE=y +CONFIG_MP=y +CONFIG_MTDPARTS_DEFAULT="mtdparts=1550000.quadspi:1m(rcw),15m(u-boot),48m(kernel.itb);7e800000.flash:16m(nand_uboot),48m(nand_kernel),448m(nand_free)" +CONFIG_OF_CONTROL=y +CONFIG_DM=y +CONFIG_FSL_CAAM=y +CONFIG_FSL_ESDHC=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_PHYLIB=y +CONFIG_NETDEVICES=y +CONFIG_PHY_GIGE=y +CONFIG_PHY_VITESSE=y +CONFIG_E1000=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_LAYERSCAPE=y +CONFIG_SYS_NS16550=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_ENV_IS_NOWHERE=y +CONFIG_USB=y +CONFIG_FSL_QSPI=y +CONFIG_DM_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_STORAGE=y +CONFIG_RSA=y +CONFIG_DM_MMC=y +CONFIG_DM_SCSI=y +CONFIG_SATA_CEVA=y +CONFIG_SCSI_AHCI=y +CONFIG_SCSI=y +CONFIG_AHCI=y +CONFIG_CMD_SETEXPR=y
-----Original Message----- From: U-Boot u-boot-bounces@lists.denx.de On Behalf Of Udit Agarwal Sent: Wednesday, May 15, 2019 2:15 PM To: u-boot@lists.denx.de Cc: Ruchika Gupta ruchika.gupta@nxp.com; Pramod Kumar pramod.kumar_1@nxp.com; Udit Agarwal udit.agarwal@nxp.com Subject: [U-Boot] [PATCH 1/1] configs:ls1046afrwy: Add tfa secure boot defonfig.
Make sure to generate defconfig using make savedefconfig.
Considering ls1046afrway is not accepted in upstream. Can you please send v2 with dependency of ls1046afrwy patch link
Request to send v2.
--pk
Prabhakar Kushwaha
Udit Agarwal
