[U-Boot] [PATCH v2] Aquantia: Print information about system interface and firmware version
Print information about Aquantia firmware loaded on the phy.
Signed-off-by: Valentin Catalin Neacsu valentin-catalin.neacsu@nxp.com --- V2: - Fix typo in title. (Clement Peron)
drivers/net/phy/aquantia.c | 21 +++++++++++++++++++++ 1 file changed, 21 insertions(+)
diff --git a/drivers/net/phy/aquantia.c b/drivers/net/phy/aquantia.c index 553069f3dc..2609664c69 100644 --- a/drivers/net/phy/aquantia.c +++ b/drivers/net/phy/aquantia.c @@ -22,6 +22,11 @@
#define AQUANTIA_SYSTEM_INTERFACE_SR 0xe812 #define AQUANTIA_VENDOR_PROVISIONING_REG 0xC441 +#define AQUANTIA_FIRMWARE_ID 0x20 +#define AQUANTIA_RESERVED_STATUS 0xc885 +#define AQUANTIA_FIRMWARE_MAJOR_MASK 0xff00 +#define AQUANTIA_FIRMWARE_MINOR_MASK 0xff +#define AQUANTIA_FIRMWARE_BUILD_MASK 0xf0
#define AQUANTIA_USX_AUTONEG_CONTROL_ENA 0x0008 #define AQUANTIA_SI_IN_USE_MASK 0x0078 @@ -30,6 +35,7 @@ int aquantia_config(struct phy_device *phydev) { u32 val = phy_read(phydev, MDIO_MMD_PMAPMD, MII_BMCR); + u32 reg_val1 = 0;
if (phydev->interface == PHY_INTERFACE_MODE_SGMII) { /* 1000BASE-T mode */ @@ -56,6 +62,11 @@ int aquantia_config(struct phy_device *phydev) phy_write(phydev, MDIO_MMD_PHYXS, AQUANTIA_VENDOR_PROVISIONING_REG, AQUANTIA_USX_AUTONEG_CONTROL_ENA); + printf("%s: system interface USXGMII\n", + phydev->dev->name); + } else { + printf("%s: system interface XFI\n", + phydev->dev->name); }
} else if (phydev->interface == PHY_INTERFACE_MODE_SGMII_2500) { @@ -73,6 +84,16 @@ int aquantia_config(struct phy_device *phydev) val = (val & ~AQUNTIA_SPEED_MSB_MASK) | AQUNTIA_SPEED_LSB_MASK; phy_write(phydev, MDIO_MMD_PMAPMD, MII_BMCR, val); } + + val = phy_read(phydev, MDIO_MMD_VEND1, AQUANTIA_RESERVED_STATUS); + reg_val1 = phy_read(phydev, MDIO_MMD_VEND1, AQUANTIA_FIRMWARE_ID); + + printf("%s: %s Firmware Version %x.%x.%x\n", phydev->dev->name, + phydev->drv->name, + (reg_val1 & AQUANTIA_FIRMWARE_MAJOR_MASK) >> 8, + reg_val1 & AQUANTIA_FIRMWARE_MINOR_MASK, + (val & AQUANTIA_FIRMWARE_BUILD_MASK) >> 4); + return 0; }
On Tue, Nov 6, 2018 at 6:17 AM Valentin-catalin Neacsu valentin-catalin.neacsu@nxp.com wrote:
V2:
u32 reg_val1 = 0; if (phydev->interface == PHY_INTERFACE_MODE_SGMII) { /* 1000BASE-T mode */
Is this still needed? This hunk doesn't apply any more.
Thanks, -Joe
phydev->dev->name);
} else {
phydev->dev->name); } } else if (phydev->interface == PHY_INTERFACE_MODE_SGMII_2500) {
phydev->drv->name,
-- 2.17.1
On Tue, Jan 22, 2019 at 5:14 PM Joe Hershberger joe.hershberger@gmail.com wrote:
V2:
I fixed up the conflict and will take it as is.
Thanks, -Joe
phydev->dev->name);
} else {
phydev->drv->name,
-- 2.17.1
Hi Valentin-catalin,
https://patchwork.ozlabs.org/patch/993651/ was applied to http://git.denx.de/?p=u-boot/u-boot-net.git
Thanks! -Joe
Joe Hershberger
Joe Hershberger
