[U-Boot] [PATCH] armv8: ls1046afrwy: Add support for LS1046AFRWY platform
LS1046AFRWY board supports LS1046A family SoCs. This patch add base support for this board. Board support's 4GB ddr memory, i2c, micro-click module,microSD card, serial console,qspi nor flash,ifc nand flash,qsgmii network interface, usb 3.0 and serdes interface to support two x1gen3 pcie interface.
Signed-off-by: Camelia Groza camelia.groza@nxp.com Signed-off-by: Madalin Bucur madalin.bucur@nxp.com Signed-off-by: Pankit Garg pankit.garg@nxp.com Signed-off-by: Pramod Kumar pramod.kumar_1@nxp.com Signed-off-by: Rajesh Bhagat rajesh.bhagat@nxp.com Signed-off-by: Vabhav Sharma vabhav.sharma@nxp.com --- arch/arm/Kconfig | 17 ++ arch/arm/cpu/armv8/Kconfig | 1 + arch/arm/cpu/armv8/fsl-layerscape/ls1046a_serdes.c | 2 + arch/arm/dts/Makefile | 1 + arch/arm/dts/fsl-ls1046a-frwy.dts | 34 +++ board/freescale/ls1046afrwy/Kconfig | 17 ++ board/freescale/ls1046afrwy/MAINTAINERS | 17 ++ board/freescale/ls1046afrwy/Makefile | 9 + board/freescale/ls1046afrwy/README | 76 +++++++ board/freescale/ls1046afrwy/ddr.c | 24 ++ board/freescale/ls1046afrwy/eth.c | 114 ++++++++++ board/freescale/ls1046afrwy/ls1046afrwy.c | 249 +++++++++++++++++++++ board/freescale/ls1046afrwy/ls1046afrwy_pbi.cfg | 22 ++ .../freescale/ls1046afrwy/ls1046afrwy_qspi_pbi.cfg | 26 +++ .../freescale/ls1046afrwy/ls1046afrwy_rcw_qspi.cfg | 7 + board/freescale/ls1046afrwy/ls1046afrwy_rcw_sd.cfg | 7 + configs/ls1046afrwy_tfa_defconfig | 58 +++++ include/configs/ls1046a_common.h | 13 +- include/configs/ls1046afrwy.h | 204 +++++++++++++++++ include/fm_eth.h | 12 + 20 files changed, 908 insertions(+), 2 deletions(-) create mode 100644 arch/arm/dts/fsl-ls1046a-frwy.dts create mode 100644 board/freescale/ls1046afrwy/Kconfig create mode 100644 board/freescale/ls1046afrwy/MAINTAINERS create mode 100644 board/freescale/ls1046afrwy/Makefile create mode 100644 board/freescale/ls1046afrwy/README create mode 100644 board/freescale/ls1046afrwy/ddr.c create mode 100644 board/freescale/ls1046afrwy/eth.c create mode 100644 board/freescale/ls1046afrwy/ls1046afrwy.c create mode 100644 board/freescale/ls1046afrwy/ls1046afrwy_pbi.cfg create mode 100644 board/freescale/ls1046afrwy/ls1046afrwy_qspi_pbi.cfg create mode 100644 board/freescale/ls1046afrwy/ls1046afrwy_rcw_qspi.cfg create mode 100644 board/freescale/ls1046afrwy/ls1046afrwy_rcw_sd.cfg create mode 100644 configs/ls1046afrwy_tfa_defconfig create mode 100644 include/configs/ls1046afrwy.h
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index f91c590..15699a2 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -1329,6 +1329,22 @@ config TARGET_LS1046ARDB development platform that supports the QorIQ LS1046A Layerscape Architecture processor.
+config TARGET_LS1046AFRWY + bool "Support ls1046afrwy" + select ARCH_LS1046A + select ARM64 + select ARMV8_MULTIENTRY + select BOARD_EARLY_INIT_F + select BOARD_LATE_INIT + select DM_SPI_FLASH if DM_SPI + select POWER_MC34VR500 + select SUPPORT_SPL + imply SCSI + help + Support for Freescale LS1046AFRWY platform. + The LS1046A Freeway Board (FRWY) is a high-performance + development platform that supports the QorIQ LS1046A + Layerscape Architecture processor. config TARGET_H2200 bool "Support h2200" select CPU_PXA @@ -1617,6 +1633,7 @@ source "board/freescale/ls1021aiot/Kconfig" source "board/freescale/ls1046aqds/Kconfig" source "board/freescale/ls1043ardb/Kconfig" source "board/freescale/ls1046ardb/Kconfig" +source "board/freescale/ls1046afrwy/Kconfig" source "board/freescale/ls1012aqds/Kconfig" source "board/freescale/ls1012ardb/Kconfig" source "board/freescale/ls1012afrdm/Kconfig" diff --git a/arch/arm/cpu/armv8/Kconfig b/arch/arm/cpu/armv8/Kconfig index 7405c3a..ed31df1 100644 --- a/arch/arm/cpu/armv8/Kconfig +++ b/arch/arm/cpu/armv8/Kconfig @@ -106,6 +106,7 @@ config PSCI_RESET !TARGET_LS1012AFRWY && \ !TARGET_LS1043ARDB && !TARGET_LS1043AQDS && \ !TARGET_LS1046ARDB && !TARGET_LS1046AQDS && \ + !TARGET_LS1046AFRWY && \ !TARGET_LS2081ARDB && !TARGET_LX2160ARDB && \ !TARGET_LX2160AQDS && \ !ARCH_UNIPHIER && !TARGET_S32V234EVB diff --git a/arch/arm/cpu/armv8/fsl-layerscape/ls1046a_serdes.c b/arch/arm/cpu/armv8/fsl-layerscape/ls1046a_serdes.c index f8310f2..caa4862 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/ls1046a_serdes.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/ls1046a_serdes.c @@ -1,6 +1,7 @@ // SPDX-License-Identifier: GPL-2.0+ /* * Copyright 2016 Freescale Semiconductor, Inc. + * Copyright 2019 NXP */
#include <common.h> @@ -33,6 +34,7 @@ static struct serdes_config serdes1_cfg_tbl[] = { SGMII_FM1_DTSEC6} }, {0x2223, {SGMII_2500_FM1_DTSEC9, SGMII_2500_FM1_DTSEC10, SGMII_2500_FM1_DTSEC5, SGMII_FM1_DTSEC6} }, + {0x3040, {NONE, NONE, QSGMII_FM1_A, NONE} }, {} };
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 8b97143..4c53662 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -316,6 +316,7 @@ dtb-$(CONFIG_FSL_LSCH2) += fsl-ls1043a-qds-duart.dtb \ fsl-ls1046a-qds-duart.dtb \ fsl-ls1046a-qds-lpuart.dtb \ fsl-ls1046a-rdb.dtb \ + fsl-ls1046a-frwy.dtb \ fsl-ls1012a-qds.dtb \ fsl-ls1012a-rdb.dtb \ fsl-ls1012a-2g5rdb.dtb \ diff --git a/arch/arm/dts/fsl-ls1046a-frwy.dts b/arch/arm/dts/fsl-ls1046a-frwy.dts new file mode 100644 index 0000000..3d41e3b --- /dev/null +++ b/arch/arm/dts/fsl-ls1046a-frwy.dts @@ -0,0 +1,34 @@ +// SPDX-License-Identifier: GPL-2.0+ OR X11 +/* + * Device Tree Include file for NXP Layerscape-1046A family SoC. + * + * Copyright 2019 NXP + * + */ + +/dts-v1/; +/include/ "fsl-ls1046a.dtsi" + +/ { + model = "LS1046A FRWY Board"; + + aliases { + spi0 = &qspi; + }; + +}; + +&qspi { + bus-num = <0>; + status = "okay"; + + qflash0: mt25qu512abb8esf@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "spi-flash"; + spi-max-frequency = <50000000>; + reg = <0>; + }; + +}; + diff --git a/board/freescale/ls1046afrwy/Kconfig b/board/freescale/ls1046afrwy/Kconfig new file mode 100644 index 0000000..6a4c3e9 --- /dev/null +++ b/board/freescale/ls1046afrwy/Kconfig @@ -0,0 +1,17 @@ + +if TARGET_LS1046AFRWY + +config SYS_BOARD + default "ls1046afrwy" + +config SYS_VENDOR + default "freescale" + +config SYS_SOC + default "fsl-layerscape" + +config SYS_CONFIG_NAME + default "ls1046afrwy" + +source "board/freescale/common/Kconfig" +endif diff --git a/board/freescale/ls1046afrwy/MAINTAINERS b/board/freescale/ls1046afrwy/MAINTAINERS new file mode 100644 index 0000000..9ee9de3 --- /dev/null +++ b/board/freescale/ls1046afrwy/MAINTAINERS @@ -0,0 +1,17 @@ +LS1046AFRWY BOARD +M: Pramod Kumar pramod.kumar_1@nxp.com +S: Maintained +F: board/freescale/ls1046afrwy/ +F: board/freescale/ls1046afrwy/ls1046afrwy.c +F: include/configs/ls1046afrwy.h +F: configs/ls1046afrwy_qspi_defconfig +F: configs/ls1046afrwy_qspi_spl_defconfig +F: configs/ls1046afrwy_sdcard_defconfig +F: configs/ls1046afrwy_tfa_defconfig + +LS1046A_SECURE_BOOT BOARD +M: Ruchika Gupta ruchika.gupta@nxp.com +S: Maintained +F: configs/ls1046afrwy_SECURE_BOOT_defconfig +F: configs/ls1046afrwy_sdcard_SECURE_BOOT_defconfig +F: configs/ls1046afrwy_qspi_SECURE_BOOT_defconfig diff --git a/board/freescale/ls1046afrwy/Makefile b/board/freescale/ls1046afrwy/Makefile new file mode 100644 index 0000000..88089e6 --- /dev/null +++ b/board/freescale/ls1046afrwy/Makefile @@ -0,0 +1,9 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright 2019 NXP + +obj-y += ddr.o +obj-y += ls1046afrwy.o +ifndef CONFIG_SPL_BUILD +obj-$(CONFIG_NET) += eth.o +endif diff --git a/board/freescale/ls1046afrwy/README b/board/freescale/ls1046afrwy/README new file mode 100644 index 0000000..d7b5a77 --- /dev/null +++ b/board/freescale/ls1046afrwy/README @@ -0,0 +1,76 @@ +Overview +-------- +The LS1046A Freeway Board (iFRWY) is a high-performance computing, +evaluation, and development platform that supports the QorIQ LS1046A +LayerScape Architecture processor. The FRWY-LS1046A provides SW development +platform for the Freescale LS1046A processor series, with a complete +debugging environment. The FRWY-LS1046A is lead-free and RoHS-compliant. + +LS1046A SoC Overview +-------------------- +Please refer arch/arm/cpu/armv8/fsl-layerscape/doc/README.soc for LS1046A +SoC overview. + + FRWY-LS1046A board Overview + ----------------------- + - SERDES1 Connections, 4 lanes supporting: + - Lane0: Unused + - Lane1: Unused + - Lane2: QSGMII + - Lane3: Unused + - SERDES2 Connections, 4 lanes supporting: + - Lane0: Unused + - Lane1: PCIe3 with PCIe x1 slot + - Lane2: Unused + - Lane3: PCIe3 with PCIe x1 slot + - DDR Controller + - 8GB 64bits DDR4 SDRAM. Support rates of up to 2133MT/s + -IFC/Local Bus + - One 512 MB NAND flash with ECC support + - USB 3.0 + - Two Type A port + - SDHC: connects directly to a full microSD slot + - QSPI: 64 MB high-speed flash Memory for boot code and storage + - 4 I2C controllers + - UART + - Two 4-pin serial ports at up to 115.2 Kbit/s + - Two DB9 D-Type connectors supporting one Serial port each + - ARM JTAG support + +Memory map from core's view +---------------------------- +Start Address End Address Description Size +0x00_0000_0000 - 0x00_000F_FFFF Secure Boot ROM 1MB +0x00_0100_0000 - 0x00_0FFF_FFFF CCSRBAR 240MB +0x00_1000_0000 - 0x00_1000_FFFF OCRAM0 64KB +0x00_1001_0000 - 0x00_1001_FFFF OCRAM1 64KB +0x00_2000_0000 - 0x00_20FF_FFFF DCSR 16MB +0x00_7E80_0000 - 0x00_7E80_FFFF IFC - NAND Flash 64KB +0x00_7FB0_0000 - 0x00_7FB0_0FFF IFC - CPLD 4KB +0x00_8000_0000 - 0x00_FFFF_FFFF DRAM1 2GB +0x05_0000_0000 - 0x05_07FF_FFFF QMAN S/W Portal 128M +0x05_0800_0000 - 0x05_0FFF_FFFF BMAN S/W Portal 128M +0x08_8000_0000 - 0x09_FFFF_FFFF DRAM2 6GB +0x40_0000_0000 - 0x47_FFFF_FFFF PCI Express1 32G +0x48_0000_0000 - 0x4F_FFFF_FFFF PCI Express2 32G +0x50_0000_0000 - 0x57_FFFF_FFFF PCI Express3 32G + +QSPI flash map: +Start Address End Address Description Size +0x00_4000_0000 - 0x00_400F_FFFF RCW + PBI + BL2 1MB +0x00_4010_0000 - 0x00_404F_FFFF FIP Image + (Bl31 + BL32(optee. + bin) + Bl33(uboot) + + headers for secure + boot) 4MB +0x00_4050_0000 - 0x00_405F_FFFF Boot Firmware Env 1MB +0x00_4060_0000 - 0x00_408F_FFFF Secure boot headers 3MB +0x00_4090_0000 - 0x00_4093_FFFF FMan ucode 256KB +0x00_4094_0000 - 0x00_4097_FFFF QE/uQE firmware 256KB +0x00_409C_0000 - 0x00_409F_FFFF Reserved 256KB +0x00_4100_0000 - 0x00_43FF_FFFF FIT Image 48MB + +Booting Options +--------------- +a) QSPI boot +b) microSD boot diff --git a/board/freescale/ls1046afrwy/ddr.c b/board/freescale/ls1046afrwy/ddr.c new file mode 100644 index 0000000..9f4e1a8 --- /dev/null +++ b/board/freescale/ls1046afrwy/ddr.c @@ -0,0 +1,24 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2019 NXP + */ + +#include <common.h> +#include <fsl_ddr_sdram.h> +#include <fsl_ddr_dimm_params.h> +#ifdef CONFIG_FSL_DEEP_SLEEP +#include <fsl_sleep.h> +#endif +#include <asm/arch/clock.h> + +DECLARE_GLOBAL_DATA_PTR; + +int fsl_initdram(void) +{ + gd->ram_size = tfa_get_dram_size(); + + if (!gd->ram_size) + gd->ram_size = fsl_ddr_sdram_size(); + + return 0; +} diff --git a/board/freescale/ls1046afrwy/eth.c b/board/freescale/ls1046afrwy/eth.c new file mode 100644 index 0000000..9f8bd92 --- /dev/null +++ b/board/freescale/ls1046afrwy/eth.c @@ -0,0 +1,114 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2019 NXP + */ +#include <common.h> +#include <asm/io.h> +#include <netdev.h> +#include <fm_eth.h> +#include <fsl_dtsec.h> +#include <fsl_mdio.h> +#include <malloc.h> + +#include "../common/fman.h" + +int board_eth_init(bd_t *bis) +{ +#ifdef CONFIG_FMAN_ENET + struct memac_mdio_info dtsec_mdio_info; + struct mii_dev *dev; + u32 srds_s1; + struct ccsr_gur *gur = (void *)(CONFIG_SYS_FSL_GUTS_ADDR); + + srds_s1 = in_be32(&gur->rcwsr[4]) & + FSL_CHASSIS2_RCWSR4_SRDS1_PRTCL_MASK; + srds_s1 >>= FSL_CHASSIS2_RCWSR4_SRDS1_PRTCL_SHIFT; + + dtsec_mdio_info.regs = + (struct memac_mdio_controller *)CONFIG_SYS_FM1_DTSEC_MDIO_ADDR; + + dtsec_mdio_info.name = DEFAULT_FM_MDIO_NAME; + + /* Register the 1G MDIO bus */ + fm_memac_mdio_init(bis, &dtsec_mdio_info); + + /* QSGMII on lane B, MAC 6/5/10/1 */ + fm_info_set_phy_address(FM1_DTSEC6, QSGMII_PORT1_PHY_ADDR); + fm_info_set_phy_address(FM1_DTSEC5, QSGMII_PORT2_PHY_ADDR); + fm_info_set_phy_address(FM1_DTSEC10, QSGMII_PORT3_PHY_ADDR); + fm_info_set_phy_address(FM1_DTSEC1, QSGMII_PORT4_PHY_ADDR); + + switch (srds_s1) { + case 0x3040: + break; + default: + printf("Invalid SerDes protocol 0x%x for LS1046AFRWY\n", + srds_s1); + break; + } + + dev = miiphy_get_dev_by_name(DEFAULT_FM_MDIO_NAME); + fm_info_set_mdio(FM1_DTSEC6, dev); + fm_info_set_mdio(FM1_DTSEC5, dev); + fm_info_set_mdio(FM1_DTSEC10, dev); + fm_info_set_mdio(FM1_DTSEC1, dev); + + cpu_eth_init(bis); +#endif + + return pci_eth_init(bis); +} + +#ifdef CONFIG_FMAN_ENET +int fdt_update_ethernet_dt(void *blob) +{ + u32 srds_s1; + int i, prop; + int offset, nodeoff; + const char *path; + struct ccsr_gur *gur = (void *)(CONFIG_SYS_FSL_GUTS_ADDR); + + srds_s1 = in_be32(&gur->rcwsr[4]) & + FSL_CHASSIS2_RCWSR4_SRDS1_PRTCL_MASK; + srds_s1 >>= FSL_CHASSIS2_RCWSR4_SRDS1_PRTCL_SHIFT; + + /* Cycle through all aliases */ + for (prop = 0; ; prop++) { + const char *name; + + /* FDT might have been edited, recompute the offset */ + offset = fdt_first_property_offset(blob, + fdt_path_offset(blob, + "/aliases") + ); + /* Select property number 'prop' */ + for (i = 0; i < prop; i++) + offset = fdt_next_property_offset(blob, offset); + + if (offset < 0) + break; + + path = fdt_getprop_by_offset(blob, offset, &name, NULL); + nodeoff = fdt_path_offset(blob, path); + + switch (srds_s1) { + case 0x3040: + if (!strcmp(name, "ethernet1")) + fdt_status_disabled(blob, nodeoff); + if (!strcmp(name, "ethernet2")) + fdt_status_disabled(blob, nodeoff); + if (!strcmp(name, "ethernet3")) + fdt_status_disabled(blob, nodeoff); + if (!strcmp(name, "ethernet6")) + fdt_status_disabled(blob, nodeoff); + break; + default: + printf("%s:Invalid SerDes prtcl 0x%x for LS1046AFRWY\n", + __func__, srds_s1); + break; + } + } + + return 0; +} +#endif diff --git a/board/freescale/ls1046afrwy/ls1046afrwy.c b/board/freescale/ls1046afrwy/ls1046afrwy.c new file mode 100644 index 0000000..8539fa2 --- /dev/null +++ b/board/freescale/ls1046afrwy/ls1046afrwy.c @@ -0,0 +1,249 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2019 NXP + */ + +#include <common.h> +#include <i2c.h> +#include <fdt_support.h> +#include <asm/io.h> +#include <asm/arch/clock.h> +#include <asm/arch/fsl_serdes.h> +#include <asm/arch/soc.h> +#include <asm/arch-fsl-layerscape/fsl_icid.h> +#include <hwconfig.h> +#include <ahci.h> +#include <mmc.h> +#include <scsi.h> +#include <fm_eth.h> +#include <fsl_csu.h> +#include <fsl_esdhc.h> +#include <power/mc34vr500_pmic.h> +#include <fsl_sec.h> +#include <fsl_dspi.h> + +#define LS1046A_PORSR1_REG 0x1EE0000 +#define BOOT_SRC_SD 0x20000000 +#define BOOT_SRC_MASK 0xFF800000 +#define BOARD_REV_GPIO 13 +#define USB2_SEL_MASK 0x00000100 + +#define BYTE_SWAP_32(word) ((((word) & 0xff000000) >> 24) | \ +(((word) & 0x00ff0000) >> 8) | \ +(((word) & 0x0000ff00) << 8) | \ +(((word) & 0x000000ff) << 24)) +#define SPI_MCR_REG 0x2100000 + +DECLARE_GLOBAL_DATA_PTR; + +int select_i2c_ch_pca9547(u8 ch) +{ + int ret; + + ret = i2c_write(I2C_MUX_PCA_ADDR_PRI, 0, 1, &ch, 1); + if (ret) { + puts("PCA: failed to select proper channel\n"); + return ret; + } + + return 0; +} + +static inline void demux_select_usb2(void) +{ + u32 val; + struct ccsr_gpio *pgpio = (void *)(GPIO3_BASE_ADDR); + + val = in_be32(&pgpio->gpdir); + val |= USB2_SEL_MASK; + out_be32(&pgpio->gpdir, val); + + val = in_be32(&pgpio->gpdat); + val |= USB2_SEL_MASK; + out_be32(&pgpio->gpdat, val); +} + +static inline void set_spi_cs_signal_inactive(void) +{ + /* default: all CS signals inactive state is high */ + uint mcr_val; + uint mcr_cfg_val = DSPI_MCR_MSTR | DSPI_MCR_PCSIS_MASK | + DSPI_MCR_CRXF | DSPI_MCR_CTXF; + + mcr_val = in_be32(SPI_MCR_REG); + mcr_val |= DSPI_MCR_HALT; + out_be32(SPI_MCR_REG, mcr_val); + out_be32(SPI_MCR_REG, mcr_cfg_val); + mcr_val = in_be32(SPI_MCR_REG); + mcr_val &= ~DSPI_MCR_HALT; + out_be32(SPI_MCR_REG, mcr_val); +} + +int board_early_init_f(void) +{ + fsl_lsch2_early_init_f(); + + return 0; +} + +#ifndef CONFIG_SPL_BUILD +static inline uint8_t get_board_version(void) +{ + u8 val; + struct ccsr_gpio *pgpio = (void *)(GPIO2_BASE_ADDR); + + val = (in_le32(&pgpio->gpdat) >> BOARD_REV_GPIO) & 0x03; + + return val; +} + +int checkboard(void) +{ + static const char *freq[2] = {"100.00MHZ", "100.00MHZ"}; + u32 boot_src; + u8 rev; + + rev = get_board_version(); + switch (rev) { + case 0x00: + puts("Board: LS1046AFRWY, Rev: A, boot from "); + break; + case 0x01: + puts("Board: LS1046AFRWY, Rev: B, boot from "); + break; + default: + puts("Board: LS1046AFRWY, Rev: Unknown, boot from "); + break; + } + boot_src = BYTE_SWAP_32(readl(LS1046A_PORSR1_REG)); + + if ((boot_src & BOOT_SRC_MASK) == BOOT_SRC_SD) + puts("SD\n"); + else + puts("QSPI\n"); + printf("SD1_CLK1 = %s, SD1_CLK2 = %s\n", freq[0], freq[1]); + + return 0; +} + +int board_init(void) +{ +#ifdef CONFIG_SECURE_BOOT + /* + * In case of Secure Boot, the IBR configures the SMMU + * to allow only Secure transactions. + * SMMU must be reset in bypass mode. + * Set the ClientPD bit and Clear the USFCFG Bit + */ + u32 val; +val = (in_le32(SMMU_SCR0) | SCR0_CLIENTPD_MASK) & ~(SCR0_USFCFG_MASK); + out_le32(SMMU_SCR0, val); + val = (in_le32(SMMU_NSCR0) | SCR0_CLIENTPD_MASK) & ~(SCR0_USFCFG_MASK); + out_le32(SMMU_NSCR0, val); +#endif + +#ifdef CONFIG_FSL_CAAM + sec_init(); +#endif + + select_i2c_ch_pca9547(I2C_MUX_CH_DEFAULT); + return 0; +} + +int board_setup_core_volt(u32 vdd) +{ + return 0; +} + +int get_serdes_volt(void) +{ + return mc34vr500_get_sw_volt(SW4); +} + +int set_serdes_volt(int svdd) +{ + return mc34vr500_set_sw_volt(SW4, svdd); +} + +int power_init_board(void) +{ + int ret; + + ret = power_mc34vr500_init(0); + if (ret) + return ret; + + setup_chip_volt(); + + return 0; +} + +void config_board_mux(void) +{ +#ifdef CONFIG_HAS_FSL_XHCI_USB + struct ccsr_scfg *scfg = (struct ccsr_scfg *)CONFIG_SYS_FSL_SCFG_ADDR; + u32 usb_pwrfault; + /* + * USB2 is used, configure mux to USB2_DRVVBUS/USB2_PWRFAULT + * USB3 is not used, configure mux to IIC4_SCL/IIC4_SDA + */ + out_be32(&scfg->rcwpmuxcr0, 0x3300); +#ifdef CONFIG_HAS_FSL_IIC3 + /* IIC3 is used, configure mux to use IIC3_SCL/IIC3/SDA */ + out_be32(&scfg->rcwpmuxcr0, 0x0000); +#endif + out_be32(&scfg->usbdrvvbus_selcr, SCFG_USBDRVVBUS_SELCR_USB1); + usb_pwrfault = (SCFG_USBPWRFAULT_DEDICATED << + SCFG_USBPWRFAULT_USB3_SHIFT) | + (SCFG_USBPWRFAULT_DEDICATED << + SCFG_USBPWRFAULT_USB2_SHIFT) | + (SCFG_USBPWRFAULT_SHARED << + SCFG_USBPWRFAULT_USB1_SHIFT); + out_be32(&scfg->usbpwrfault_selcr, usb_pwrfault); +#ifndef CONFIG_HAS_FSL_IIC3 + /* + * LS1046A FRWY board has demultiplexer NX3DV42GU with GPIO3_23 as input + * to select I2C3_USB2_SEL_IO + * I2C3_USB2_SEL = 0: I2C3_SCL/SDA signals are routed to + * I2C3 header (default) + * I2C3_USB2_SEL = 1: USB2_DRVVBUS/PWRFAULT signals are routed to + * USB2 port + * programmed to select USB2 by setting GPIO3_23 output to one + */ + demux_select_usb2(); +#endif +#endif + set_spi_cs_signal_inactive(); +} + +#ifdef CONFIG_MISC_INIT_R +int misc_init_r(void) +{ + config_board_mux(); + return 0; +} +#endif + +int ft_board_setup(void *blob, bd_t *bd) +{ + u64 base[CONFIG_NR_DRAM_BANKS]; + u64 size[CONFIG_NR_DRAM_BANKS]; + + /* fixup DT for the two DDR banks */ + base[0] = gd->bd->bi_dram[0].start; + size[0] = gd->bd->bi_dram[0].size; + base[1] = gd->bd->bi_dram[1].start; + size[1] = gd->bd->bi_dram[1].size; + + fdt_fixup_memory_banks(blob, base, size, 2); + ft_cpu_setup(blob, bd); + +#ifdef CONFIG_SYS_DPAA_FMAN + fdt_fixup_fman_ethernet(blob); +#endif + + fdt_fixup_icid(blob); + + return 0; +} +#endif diff --git a/board/freescale/ls1046afrwy/ls1046afrwy_pbi.cfg b/board/freescale/ls1046afrwy/ls1046afrwy_pbi.cfg new file mode 100644 index 0000000..5478217 --- /dev/null +++ b/board/freescale/ls1046afrwy/ls1046afrwy_pbi.cfg @@ -0,0 +1,22 @@ +#Configure Scratch register +09570600 00000000 +09570604 10000000 +#Disable CCI barrier tranaction +09570178 0000e010 +09180000 00000008 +#USB PHY frequency sel +09570418 0000009e +0957041c 0000009e +09570420 0000009e +#Serdes SATA +09eb1300 80104e20 +09eb08dc 00502880 +#PEX gen3 link +09570158 00000300 +89400890 01048000 +89500890 01048000 +89600890 01048000 +#Alt base register +09570158 00001000 +#flush PBI data +096100c0 000fffff diff --git a/board/freescale/ls1046afrwy/ls1046afrwy_qspi_pbi.cfg b/board/freescale/ls1046afrwy/ls1046afrwy_qspi_pbi.cfg new file mode 100644 index 0000000..735d46c --- /dev/null +++ b/board/freescale/ls1046afrwy/ls1046afrwy_qspi_pbi.cfg @@ -0,0 +1,26 @@ +#QSPI clk +0957015c 40100000 +#Configure Scratch register +09570600 00000000 +09570604 10000000 +#Disable CCI barrier tranaction +09570178 0000e010 +09180000 00000008 +#USB PHY frequency sel +09570418 0000009e +0957041c 0000009e +09570420 0000009e +#Serdes SATA +09eb1300 80104e20 +09eb08dc 00502880 +#PEX gen3 link +09570158 00000300 +89400890 01048000 +89500890 01048000 +89600890 01048000 +#Alt base register +09570158 00001000 +#flush PBI data +096100c0 000fffff +#Change endianness +09550000 000f400c diff --git a/board/freescale/ls1046afrwy/ls1046afrwy_rcw_qspi.cfg b/board/freescale/ls1046afrwy/ls1046afrwy_rcw_qspi.cfg new file mode 100644 index 0000000..7b9be0a --- /dev/null +++ b/board/freescale/ls1046afrwy/ls1046afrwy_rcw_qspi.cfg @@ -0,0 +1,7 @@ +#PBL preamble and RCW header +aa55aa55 01ee0100 +# RCW +0c150010 0e000000 00000000 00000000 +11335559 40005012 40025000 c1000000 +00000000 00000000 00000000 00238800 +20124000 00003101 00000096 00000001 diff --git a/board/freescale/ls1046afrwy/ls1046afrwy_rcw_sd.cfg b/board/freescale/ls1046afrwy/ls1046afrwy_rcw_sd.cfg new file mode 100644 index 0000000..d3b1522 --- /dev/null +++ b/board/freescale/ls1046afrwy/ls1046afrwy_rcw_sd.cfg @@ -0,0 +1,7 @@ +#PBL preamble and RCW header +aa55aa55 01ee0100 +# RCW +0c150012 0e000000 00000000 00000000 +11335559 40005012 60040000 c1000000 +00000000 00000000 00000000 00238800 +20124000 00003101 00000096 00000001 diff --git a/configs/ls1046afrwy_tfa_defconfig b/configs/ls1046afrwy_tfa_defconfig new file mode 100644 index 0000000..1e83c5f --- /dev/null +++ b/configs/ls1046afrwy_tfa_defconfig @@ -0,0 +1,58 @@ +CONFIG_ARM=y +CONFIG_TARGET_LS1046AFRWY=y +CONFIG_SYS_TEXT_BASE=0x82000000 +CONFIG_QSPI_AHB_INIT=y +CONFIG_TFABOOT=y +CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y +CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y +CONFIG_DISTRO_DEFAULTS=y +CONFIG_NR_DRAM_BANKS=2 +CONFIG_FIT_VERBOSE=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_BOOTDELAY=10 +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0500 mtdparts=1550000.quadspi:1m(rcw),15m(u-boot),48m(kernel.itb);7e800000.flash:16m(nand_uboot),48m(nand_kernel),448m(nand_free)" +CONFIG_MISC_INIT_R=y +CONFIG_CMD_GPT=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_NAND=y +CONFIG_CMD_PCI=y +CONFIG_CMD_SF=y +CONFIG_CMD_USB=y +CONFIG_CMD_CACHE=y +CONFIG_MP=y +CONFIG_MTDPARTS_DEFAULT="mtdparts=1550000.quadspi:1m(rcw),15m(u-boot),48m(kernel.itb);7e800000.flash:16m(nand_uboot),48m(nand_kernel),448m(nand_free)" +CONFIG_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1046a-frwy" +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_DM=y +CONFIG_FSL_CAAM=y +CONFIG_FSL_ESDHC=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_STMICRO=y +# CONFIG_SPI_FLASH_USE_4K_SECTORS is not set +CONFIG_PHYLIB=y +CONFIG_PHY_GIGE=y +CONFIG_PHY_VITESSE=y +CONFIG_E1000=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_PCIE_LAYERSCAPE=y +CONFIG_SYS_NS16550=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_FSL_QSPI=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_STORAGE=y +CONFIG_DM_MMC=y +CONFIG_DM_SCSI=y +CONFIG_SATA_CEVA=y +CONFIG_SCSI_AHCI=y +CONFIG_SCSI=y +CONFIG_AHCI=y diff --git a/include/configs/ls1046a_common.h b/include/configs/ls1046a_common.h index ea6209a..757ccc4 100644 --- a/include/configs/ls1046a_common.h +++ b/include/configs/ls1046a_common.h @@ -1,6 +1,7 @@ /* SPDX-License-Identifier: GPL-2.0+ */ /* * Copyright 2016 Freescale Semiconductor + * Copyright 2019 NXP */
#ifndef __LS1046A_COMMON_H @@ -206,6 +207,15 @@ #include <config_distro_bootcmd.h> #endif
+#if defined(CONFIG_TARGET_LS1046AFRWY) +#define LS1046A_BOOT_SRC_AND_HDR\ + "boot_scripts=ls1046afrwy_boot.scr\0" \ + "boot_script_hdr=hdr_ls1046afrwy_bs.out\0" +#else +#define LS1046A_BOOT_SRC_AND_HDR\ + "boot_scripts=ls1046ardb_boot.scr\0" \ + "boot_script_hdr=hdr_ls1046ardb_bs.out\0" +#endif #ifndef SPL_NO_MISC /* Initial environment variables */ #define CONFIG_EXTRA_ENV_SETTINGS \ @@ -236,8 +246,7 @@ "console=ttyS0,115200\0" \ CONFIG_MTDPARTS_DEFAULT "\0" \ BOOTENV \ - "boot_scripts=ls1046ardb_boot.scr\0" \ - "boot_script_hdr=hdr_ls1046ardb_bs.out\0" \ + LS1046A_BOOT_SRC_AND_HDR \ "scan_dev_for_boot_part=" \ "part list ${devtype} ${devnum} devplist; " \ "env exists devplist || setenv devplist 1; " \ diff --git a/include/configs/ls1046afrwy.h b/include/configs/ls1046afrwy.h new file mode 100644 index 0000000..c874b95 --- /dev/null +++ b/include/configs/ls1046afrwy.h @@ -0,0 +1,204 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2019 NXP + */ + +#ifndef __LS1046AFRWY_H__ +#define __LS1046AFRWY_H__ + +#include "ls1046a_common.h" + +#define CONFIG_SYS_CLK_FREQ 100000000 +#define CONFIG_DDR_CLK_FREQ 100000000 + +#define CONFIG_LAYERSCAPE_NS_ACCESS + +#define CONFIG_DIMM_SLOTS_PER_CTLR 1 +/* Physical Memory Map */ +#define CONFIG_CHIP_SELECTS_PER_CTRL 4 + +#define CONFIG_DDR_SPD +#define SPD_EEPROM_ADDRESS 0x51 +#define CONFIG_SYS_SPD_BUS_NUM 0 + +#define CONFIG_DDR_ECC +#define CONFIG_ECC_INIT_VIA_DDRCONTROLLER +#define CONFIG_MEM_INIT_VALUE 0xdeadbeef +#define CONFIG_FSL_DDR_BIST /* enable built-in memory test */ +#ifndef CONFIG_SPL +#define CONFIG_FSL_DDR_INTERACTIVE /* Interactive debugging */ +#endif + +#ifdef CONFIG_SD_BOOT +#define CONFIG_SYS_FSL_PBL_PBI board/freescale/ls1046afrwy/ls1046afrwy_pbi.cfg +#ifdef CONFIG_EMMC_BOOT +#define CONFIG_SYS_FSL_PBL_RCW \ + board/freescale/ls1046afrwy/ls1046afrwy_rcw_emmc.cfg +#else +#define CONFIG_SYS_FSL_PBL_RCW \ + board/freescale/ls1046afrwy/ls1046afrwy_rcw_sd.cfg +#endif +#elif defined(CONFIG_QSPI_BOOT) +#define CONFIG_SYS_FSL_PBL_RCW \ + board/freescale/ls1046afrwy/ls1046afrwy_rcw_qspi.cfg +#define CONFIG_SYS_FSL_PBL_PBI \ + board/freescale/ls1046afrwy/ls1046afrwy_qspi_pbi.cfg +#define CONFIG_SYS_UBOOT_BASE 0x40100000 +#define CONFIG_SYS_SPL_ARGS_ADDR 0x90000000 +#endif + +#ifndef SPL_NO_IFC +/* IFC */ +#define CONFIG_FSL_IFC +/* + * NAND Flash Definitions + */ +#define CONFIG_NAND_FSL_IFC +#endif + +#define CONFIG_SYS_NAND_BASE 0x7e800000 +#define CONFIG_SYS_NAND_BASE_PHYS CONFIG_SYS_NAND_BASE + +#define CONFIG_SYS_NAND_CSPR_EXT (0x0) +#define CONFIG_SYS_NAND_CSPR (CSPR_PHYS_ADDR(CONFIG_SYS_NAND_BASE_PHYS) \ + | CSPR_PORT_SIZE_8 \ + | CSPR_MSEL_NAND \ + | CSPR_V) +#define CONFIG_SYS_NAND_AMASK IFC_AMASK(64 * 1024) +#define CONFIG_SYS_NAND_CSOR (CSOR_NAND_ECC_ENC_EN /* ECC on encode */ \ + | CSOR_NAND_ECC_DEC_EN /* ECC on decode */ \ + | CSOR_NAND_ECC_MODE_4 /* 4-bit ECC */ \ + | CSOR_NAND_RAL_3 /* RAL = 3 Bytes */ \ + | CSOR_NAND_PGS_2K /* Page Size = 2K */ \ + | CSOR_NAND_SPRZ_128 /* Spare size = 128 */ \ + | CSOR_NAND_PB(64)) /* 64 Pages Per Block */ + +#define CONFIG_SYS_NAND_ONFI_DETECTION + +#define CONFIG_SYS_NAND_FTIM0 (FTIM0_NAND_TCCST(0x7) | \ + FTIM0_NAND_TWP(0x18) | \ + FTIM0_NAND_TWCHT(0x7) | \ + FTIM0_NAND_TWH(0xa)) +#define CONFIG_SYS_NAND_FTIM1 (FTIM1_NAND_TADLE(0x32) | \ + FTIM1_NAND_TWBE(0x39) | \ + FTIM1_NAND_TRR(0xe) | \ + FTIM1_NAND_TRP(0x18)) +#define CONFIG_SYS_NAND_FTIM2 (FTIM2_NAND_TRAD(0xf) | \ + FTIM2_NAND_TREH(0xa) | \ + FTIM2_NAND_TWHRE(0x1e)) +#define CONFIG_SYS_NAND_FTIM3 0x0 + +#define CONFIG_SYS_NAND_BASE_LIST { CONFIG_SYS_NAND_BASE } +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_MTD_NAND_VERIFY_WRITE + +#define CONFIG_SYS_NAND_BLOCK_SIZE (128 * 1024) + +/* IFC Timing Params */ +#define CONFIG_SYS_CSPR0_EXT CONFIG_SYS_NAND_CSPR_EXT +#define CONFIG_SYS_CSPR0 CONFIG_SYS_NAND_CSPR +#define CONFIG_SYS_AMASK0 CONFIG_SYS_NAND_AMASK +#define CONFIG_SYS_CSOR0 CONFIG_SYS_NAND_CSOR +#define CONFIG_SYS_CS0_FTIM0 CONFIG_SYS_NAND_FTIM0 +#define CONFIG_SYS_CS0_FTIM1 CONFIG_SYS_NAND_FTIM1 +#define CONFIG_SYS_CS0_FTIM2 CONFIG_SYS_NAND_FTIM2 +#define CONFIG_SYS_CS0_FTIM3 CONFIG_SYS_NAND_FTIM3 + +/* EEPROM */ +#define CONFIG_ID_EEPROM +#define CONFIG_SYS_I2C_EEPROM_NXID +#define CONFIG_SYS_EEPROM_BUS_NUM 0 +#define CONFIG_SYS_I2C_EEPROM_ADDR 0x52 +#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 +#define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 3 +#define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 5 +#define I2C_RETIMER_ADDR 0x18 + +/* I2C bus multiplexer */ +#define I2C_MUX_PCA_ADDR_PRI 0x77 /* Primary Mux*/ +#define I2C_MUX_CH_DEFAULT 0x1 /* Channel 0*/ +#define I2C_MUX_CH_RTC 0x1 /* Channel 0*/ + +/* RTC */ +#define RTC +#define CONFIG_SYS_I2C_RTC_ADDR 0x51 /* Channel 0 I2C bus 0*/ +#define CONFIG_SYS_RTC_BUS_NUM 0 + +/* PMIC */ +#define CONFIG_POWER +#ifdef CONFIG_POWER +#define CONFIG_POWER_I2C +#endif + +/* + * Environment + */ +#ifndef SPL_NO_ENV +#define CONFIG_ENV_OVERWRITE +#endif + +#ifdef CONFIG_TFABOOT +#define CONFIG_SYS_MMC_ENV_DEV 0 + +#define CONFIG_ENV_SIZE 0x2000 /* 8KB */ +#define CONFIG_ENV_OFFSET 0x500000 /* 5MB */ +#define CONFIG_ENV_SECT_SIZE 0x40000 /* 256KB */ +#else +#if defined(CONFIG_SD_BOOT) +#define CONFIG_SYS_MMC_ENV_DEV 0 +#define CONFIG_ENV_OFFSET (3 * 1024 * 1024) +#define CONFIG_ENV_SIZE 0x2000 +#else +#define CONFIG_ENV_SIZE 0x2000 /* 8KB */ +#define CONFIG_ENV_OFFSET 0x300000 /* 3MB */ +#define CONFIG_ENV_SECT_SIZE 0x40000 /* 256KB */ +#endif +#endif + +/* FMan */ +#ifndef SPL_NO_FMAN + +#ifdef CONFIG_SYS_DPAA_FMAN +#define CONFIG_FMAN_ENET + +#define QSGMII_PORT1_PHY_ADDR 0x1c +#define QSGMII_PORT2_PHY_ADDR 0x1d +#define QSGMII_PORT3_PHY_ADDR 0x1e +#define QSGMII_PORT4_PHY_ADDR 0x1f + +#define FDT_SEQ_MACADDR_FROM_ENV + +#define CONFIG_ETHPRIME "FM1@DTSEC3" +#endif + +#endif + +/* QSPI device */ +#ifndef SPL_NO_QSPI +#ifdef CONFIG_FSL_QSPI +#define FSL_QSPI_FLASH_SIZE SZ_64M +#define FSL_QSPI_FLASH_NUM 1 +#endif +#endif + +#ifndef SPL_NO_MISC +#undef CONFIG_BOOTCOMMAND +#ifdef CONFIG_TFABOOT +#define QSPI_NOR_BOOTCOMMAND "run distro_bootcmd; run qspi_bootcmd; " \ + "env exists secureboot && esbc_halt;;" +#define SD_BOOTCOMMAND "run distro_bootcmd;run sd_bootcmd; " \ + "env exists secureboot && esbc_halt;" +#else +#if defined(CONFIG_QSPI_BOOT) +#define CONFIG_BOOTCOMMAND "run distro_bootcmd; run qspi_bootcmd; " \ + "env exists secureboot && esbc_halt;;" +#elif defined(CONFIG_SD_BOOT) +#define CONFIG_BOOTCOMMAND "run distro_bootcmd;run sd_bootcmd; " \ + "env exists secureboot && esbc_halt;" +#endif +#endif +#endif + +#include <asm/fsl_secure_boot.h> + +#endif /* __LS1046AFRWY_H__ */ diff --git a/include/fm_eth.h b/include/fm_eth.h index 2e2ba75..729ad63 100644 --- a/include/fm_eth.h +++ b/include/fm_eth.h @@ -1,6 +1,7 @@ /* SPDX-License-Identifier: GPL-2.0+ */ /* * Copyright 2009-2012 Freescale Semiconductor, Inc. + * Copyright 2019 NXP */
#ifndef __FM_ETH_H__ @@ -41,8 +42,19 @@ enum fm_eth_type { FM_ETH_10G_E, };
+/* Historically, on FMan v3 platforms, the first MDIO bus has been used for + * Clause 22 PHYs and the second MDIO bus for 10G Clause 45 PHYs (thus the + * TGEC name). + * + * On LS1046A-FRWY, the QSGMII PHY is connected to the second MDIO bus, + * and no TGEC ports are present on-board. + */ #ifdef CONFIG_SYS_FMAN_V3 +#ifdef CONFIG_TARGET_LS1046AFRWY +#define CONFIG_SYS_FM1_DTSEC_MDIO_ADDR (CONFIG_SYS_FSL_FM1_ADDR + 0xfd000) +#else #define CONFIG_SYS_FM1_DTSEC_MDIO_ADDR (CONFIG_SYS_FSL_FM1_ADDR + 0xfc000) +#endif #define CONFIG_SYS_FM1_TGEC_MDIO_ADDR (CONFIG_SYS_FSL_FM1_ADDR + 0xfd000) #if (CONFIG_SYS_NUM_FMAN == 2) #define CONFIG_SYS_FM2_DTSEC_MDIO_ADDR (CONFIG_SYS_FSL_FM2_ADDR + 0xfc000)
Dear Vabhav,
-----Original Message----- From: U-Boot u-boot-bounces@lists.denx.de On Behalf Of Vabhav Sharma Sent: Thursday, May 9, 2019 7:34 PM To: u-boot@lists.denx.de Cc: Pramod Kumar pramod.kumar_1@nxp.com; Pankit Garg pankit.garg@nxp.com; Varun Sethi V.Sethi@nxp.com; Camelia Alexandra Groza camelia.groza@nxp.com Subject: [U-Boot] [PATCH] armv8: ls1046afrwy: Add support for LS1046AFRWY platform
- bool "Support ls1046afrwy"
- select ARCH_LS1046A
- select ARM64
- select ARMV8_MULTIENTRY
- select BOARD_EARLY_INIT_F
- select BOARD_LATE_INIT
- select DM_SPI_FLASH if DM_SPI
- select POWER_MC34VR500
- select SUPPORT_SPL
- imply SCSI
- help
!TARGET_LS2081ARDB && !TARGET_LX2160ARDB && \ !TARGET_LX2160AQDS && \ !ARCH_UNIPHIER && !TARGET_S32V234EVB diff --git!TARGET_LS1046AFRWY && \
- Copyright 2016 Freescale Semiconductor, Inc.
- Copyright 2019 NXP
- {0x3040, {NONE, NONE, QSGMII_FM1_A, NONE} }, {}
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 8b97143..4c53662 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -316,6 +316,7 @@ dtb-$(CONFIG_FSL_LSCH2) += fsl-ls1043a-qds- duart.dtb \ fsl-ls1046a-qds-duart.dtb \ fsl-ls1046a-qds-lpuart.dtb \ fsl-ls1046a-rdb.dtb \
- fsl-ls1046a-frwy.dtb \ fsl-ls1012a-qds.dtb \ fsl-ls1012a-rdb.dtb \ fsl-ls1012a-2g5rdb.dtb \
diff --git a/arch/arm/dts/fsl-ls1046a-frwy.dts b/arch/arm/dts/fsl-ls1046a- frwy.dts new file mode 100644 index 0000000..3d41e3b --- /dev/null +++ b/arch/arm/dts/fsl-ls1046a-frwy.dts @@ -0,0 +1,34 @@ +// SPDX-License-Identifier: GPL-2.0+ OR X11 +/*
- Device Tree Include file for NXP Layerscape-1046A family SoC.
- model = "LS1046A FRWY Board";
- aliases {
spi0 = &qspi;
+&qspi {
- bus-num = <0>;
- status = "okay";
- qflash0: mt25qu512abb8esf@0 {
#size-cells = <1>;
reg = <0>;
+config SYS_BOARD
- default "ls1046afrwy"
+config SYS_VENDOR
- default "freescale"
+config SYS_SOC
- default "fsl-layerscape"
There is no secure defconfigs in the patch They why above change
+obj-y += ddr.o +obj-y += ls1046afrwy.o +ifndef CONFIG_SPL_BUILD +obj-$(CONFIG_NET) += eth.o +endif diff --git a/board/freescale/ls1046afrwy/README b/board/freescale/ls1046afrwy/README new file mode 100644 index 0000000..d7b5a77 --- /dev/null +++ b/board/freescale/ls1046afrwy/README @@ -0,0 +1,76 @@ +Overview +-------- +The LS1046A Freeway Board (iFRWY) is a high-performance computing, +evaluation, and development platform that supports the QorIQ LS1046A +LayerScape Architecture processor. The FRWY-LS1046A provides SW +development platform for the Freescale LS1046A processor series, with a +complete debugging environment. The FRWY-LS1046A is lead-free and RoHS-compliant.
+LS1046A SoC Overview +-------------------- +Please refer arch/arm/cpu/armv8/fsl-layerscape/doc/README.soc for +LS1046A SoC overview.
- FRWY-LS1046A board Overview
- Lane0: Unused
- Lane1: Unused
- Lane2: QSGMII
- Lane3: Unused
- Lane0: Unused
- Lane2: Unused
- DDR Controller
- -IFC/Local Bus
- USB 3.0
- Two Type A port
- 4 I2C controllers
- UART
- ARM JTAG support
(Bl31 + BL32(optee.
bin) + Bl33(uboot)
boot) 4MB
Deep sleep??
- gd->ram_size = tfa_get_dram_size();
- if (!gd->ram_size)
- struct memac_mdio_info dtsec_mdio_info;
- struct mii_dev *dev;
- u32 srds_s1;
- struct ccsr_gur *gur = (void *)(CONFIG_SYS_FSL_GUTS_ADDR);
- srds_s1 = in_be32(&gur->rcwsr[4]) &
- srds_s1 >>= FSL_CHASSIS2_RCWSR4_SRDS1_PRTCL_SHIFT;
- dtsec_mdio_info.regs =
- dtsec_mdio_info.name = DEFAULT_FM_MDIO_NAME;
- /* Register the 1G MDIO bus */
- fm_memac_mdio_init(bis, &dtsec_mdio_info);
- /* QSGMII on lane B, MAC 6/5/10/1 */
- fm_info_set_phy_address(FM1_DTSEC6,
- fm_info_set_phy_address(FM1_DTSEC5,
- fm_info_set_phy_address(FM1_DTSEC10,
- fm_info_set_phy_address(FM1_DTSEC1,
- switch (srds_s1) {
- case 0x3040:
break;
- default:
srds_s1);
break;
- dev = miiphy_get_dev_by_name(DEFAULT_FM_MDIO_NAME);
- fm_info_set_mdio(FM1_DTSEC6, dev);
- fm_info_set_mdio(FM1_DTSEC5, dev);
- fm_info_set_mdio(FM1_DTSEC10, dev);
- fm_info_set_mdio(FM1_DTSEC1, dev);
- cpu_eth_init(bis);
- return pci_eth_init(bis);
- u32 srds_s1;
- int i, prop;
- int offset, nodeoff;
- const char *path;
- /* Cycle through all aliases */
- for (prop = 0; ; prop++) {
const char *name;
"/aliases")
if (offset < 0)
break;
switch (srds_s1) {
case 0x3040:
break;
default:
LS1046AFRWY\n",
__func__, srds_s1);
break;
- int ret;
- ret = i2c_write(I2C_MUX_PCA_ADDR_PRI, 0, 1, &ch, 1);
- if (ret) {
return ret;
+static inline void demux_select_usb2(void) {
- u32 val;
- struct ccsr_gpio *pgpio = (void *)(GPIO3_BASE_ADDR);
- val = in_be32(&pgpio->gpdir);
- val |= USB2_SEL_MASK;
- out_be32(&pgpio->gpdir, val);
- val = in_be32(&pgpio->gpdat);
- out_be32(&pgpio->gpdat, val);
+static inline void set_spi_cs_signal_inactive(void) {
- /* default: all CS signals inactive state is high */
- uint mcr_val;
- uint mcr_cfg_val = DSPI_MCR_MSTR | DSPI_MCR_PCSIS_MASK |
- mcr_val = in_be32(SPI_MCR_REG);
- mcr_val |= DSPI_MCR_HALT;
- out_be32(SPI_MCR_REG, mcr_val);
- out_be32(SPI_MCR_REG, mcr_cfg_val);
- mcr_val &= ~DSPI_MCR_HALT;
- fsl_lsch2_early_init_f();
+#ifndef CONFIG_SPL_BUILD +static inline uint8_t get_board_version(void) {
- u8 val;
- struct ccsr_gpio *pgpio = (void *)(GPIO2_BASE_ADDR);
- val = (in_le32(&pgpio->gpdat) >> BOARD_REV_GPIO) & 0x03;
- return val;
- static const char *freq[2] = {"100.00MHZ", "100.00MHZ"};
- u32 boot_src;
- u8 rev;
- rev = get_board_version();
- switch (rev) {
- case 0x00:
break;
- case 0x01:
break;
- default:
break;
- boot_src = BYTE_SWAP_32(readl(LS1046A_PORSR1_REG));
- if ((boot_src & BOOT_SRC_MASK) == BOOT_SRC_SD)
puts("SD\n");
- else
puts("QSPI\n");
- printf("SD1_CLK1 = %s, SD1_CLK2 = %s\n", freq[0], freq[1]);
- u32 val;
- out_le32(SMMU_SCR0, val);
- val = (in_le32(SMMU_NSCR0) | SCR0_CLIENTPD_MASK) &
- out_le32(SMMU_NSCR0, val);
- sec_init();
- select_i2c_ch_pca9547(I2C_MUX_CH_DEFAULT);
- return mc34vr500_get_sw_volt(SW4);
- return mc34vr500_set_sw_volt(SW4, svdd); }
- int ret;
- ret = power_mc34vr500_init(0);
- if (ret)
return ret;
- setup_chip_volt();
- struct ccsr_scfg *scfg = (struct ccsr_scfg
- u32 usb_pwrfault;
- out_be32(&scfg->rcwpmuxcr0, 0x3300);
- /* IIC3 is used, configure mux to use IIC3_SCL/IIC3/SDA */
- out_be32(&scfg->rcwpmuxcr0, 0x0000);
- out_be32(&scfg->usbdrvvbus_selcr,
- usb_pwrfault = (SCFG_USBPWRFAULT_DEDICATED <<
- out_be32(&scfg->usbpwrfault_selcr, usb_pwrfault); #ifndef
+CONFIG_HAS_FSL_IIC3
GPIO3_23 as input
to
* USB2 port
- demux_select_usb2();
+#endif +#endif
- set_spi_cs_signal_inactive();
- config_board_mux();
+} +#endif
+int ft_board_setup(void *blob, bd_t *bd) {
- u64 base[CONFIG_NR_DRAM_BANKS];
- u64 size[CONFIG_NR_DRAM_BANKS];
- /* fixup DT for the two DDR banks */
- base[0] = gd->bd->bi_dram[0].start;
- size[0] = gd->bd->bi_dram[0].size;
- base[1] = gd->bd->bi_dram[1].start;
- size[1] = gd->bd->bi_dram[1].size;
- fdt_fixup_memory_banks(blob, base, size, 2);
- ft_cpu_setup(blob, bd);
- fdt_fixup_fman_ethernet(blob);
- fdt_fixup_icid(blob);
Considering TFA boot is supported, does this file really required
@@ -0,0 +1,7 @@ +#PBL preamble and RCW header +aa55aa55 01ee0100 +# RCW +0c150012 0e000000 00000000 00000000 +11335559 40005012 60040000 c1000000 +00000000 00000000 00000000 00238800 +20124000 00003101 00000096 00000001 diff --git a/configs/ls1046afrwy_tfa_defconfig b/configs/ls1046afrwy_tfa_defconfig new file mode 100644 index 0000000..1e83c5f --- /dev/null +++ b/configs/ls1046afrwy_tfa_defconfig @@ -0,0 +1,58 @@ +CONFIG_ARM=y +CONFIG_TARGET_LS1046AFRWY=y +CONFIG_SYS_TEXT_BASE=0x82000000 +CONFIG_QSPI_AHB_INIT=y +CONFIG_TFABOOT=y +CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y +CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y +CONFIG_DISTRO_DEFAULTS=y +CONFIG_NR_DRAM_BANKS=2 +CONFIG_FIT_VERBOSE=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_BOOTDELAY=10 +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0500 mtdparts=1550000.quadspi:1m(rcw),15m(u- boot),48m(kernel.itb);7e800000.flash:16m(nand_uboot),48m(nand_kernel), 448m(nand_free)" +CONFIG_MISC_INIT_R=y +CONFIG_CMD_GPT=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_NAND=y +CONFIG_CMD_PCI=y +CONFIG_CMD_SF=y +CONFIG_CMD_USB=y +CONFIG_CMD_CACHE=y +CONFIG_MP=y +CONFIG_MTDPARTS_DEFAULT="mtdparts=1550000.quadspi:1m(rcw),15m( u- boot),48m(kernel.itb);7e800000.flash:16m(nand_uboot),48m(nand_kernel), 448m(nand_free)" +CONFIG_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1046a-frwy" +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_DM=y +CONFIG_FSL_CAAM=y +CONFIG_FSL_ESDHC=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_STMICRO=y +# CONFIG_SPI_FLASH_USE_4K_SECTORS is not set CONFIG_PHYLIB=y +CONFIG_PHY_GIGE=y CONFIG_PHY_VITESSE=y CONFIG_E1000=y CONFIG_PCI=y +CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE=y +CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_QSPI=y +CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y CONFIG_DM_MMC=y +CONFIG_DM_SCSI=y CONFIG_SATA_CEVA=y CONFIG_SCSI_AHCI=y CONFIG_SCSI=y +CONFIG_AHCI=y diff --git a/include/configs/ls1046a_common.h b/include/configs/ls1046a_common.h index ea6209a..757ccc4 100644 --- a/include/configs/ls1046a_common.h +++ b/include/configs/ls1046a_common.h @@ -1,6 +1,7 @@ /* SPDX-License-Identifier: GPL-2.0+ */ /*
- "boot_scripts=ls1046afrwy_boot.scr\0" \
- "boot_script_hdr=hdr_ls1046afrwy_bs.out\0"
- LS1046A_BOOT_SRC_AND_HDR \ "scan_dev_for_boot_part=" \ "part list ${devtype} ${devnum} devplist; " \ "env exists devplist || setenv devplist 1; " \ diff --git
Considering TFA boot is supported, remove all SPL reference in the code
+#ifdef CONFIG_SD_BOOT +#define CONFIG_SYS_FSL_PBL_PBI +board/freescale/ls1046afrwy/ls1046afrwy_pbi.cfg +#ifdef CONFIG_EMMC_BOOT +#define CONFIG_SYS_FSL_PBL_RCW \
- board/freescale/ls1046afrwy/ls1046afrwy_rcw_emmc.cfg
- board/freescale/ls1046afrwy/ls1046afrwy_rcw_sd.cfg
- board/freescale/ls1046afrwy/ls1046afrwy_rcw_qspi.cfg
- board/freescale/ls1046afrwy/ls1046afrwy_qspi_pbi.cfg
Remove all above lines as only tfa boot
- NAND Flash Definitions
| CSPR_PORT_SIZE_8 \
| CSPR_MSEL_NAND \
| CSPR_V)
decode */ \
2K */ \
= 128 */ \
Is PMIC required?
--pk
Dear Prabhakar,
-----Original Message----- From: Prabhakar Kushwaha Sent: Tuesday, May 21, 2019 7:45 PM To: Vabhav Sharma vabhav.sharma@nxp.com; u-boot@lists.denx.de Cc: Pramod Kumar pramod.kumar_1@nxp.com; Pankit Garg pankit.garg@nxp.com; Varun Sethi V.Sethi@nxp.com; Camelia Alexandra Groza camelia.groza@nxp.com Subject: RE: [U-Boot] [PATCH] armv8: ls1046afrwy: Add support for LS1046AFRWY platform
Dear Vabhav,
Sharma
- select ARM64
- imply SCSI
- help
- aliases {
spi0 = &qspi;
+&qspi {
- bus-num = <0>;
- status = "okay";
#size-cells = <1>;
reg = <0>;
+config SYS_BOARD
+config SYS_VENDOR
+config SYS_SOC
Secure defconfig is sent upstream with secure boot support later, I will remove changes from here and include in secure boot support v2
+obj-y += ddr.o +obj-y += ls1046afrwy.o +ifndef CONFIG_SPL_BUILD +obj-$(CONFIG_NET) += eth.o +endif diff --git a/board/freescale/ls1046afrwy/README b/board/freescale/ls1046afrwy/README new file mode 100644 index 0000000..d7b5a77 --- /dev/null +++ b/board/freescale/ls1046afrwy/README @@ -0,0 +1,76 @@ +Overview +-------- +The LS1046A Freeway Board (iFRWY) is a high-performance computing, +evaluation, and development platform that supports the QorIQ LS1046A +LayerScape Architecture processor. The FRWY-LS1046A provides SW +development platform for the Freescale LS1046A processor series, with +a complete debugging environment. The FRWY-LS1046A is lead-free and RoHS-compliant.
- Lane0: Unused
- Lane1: Unused
- Lane2: QSGMII
- Lane3: Unused
- Lane0: Unused
- Lane2: Unused
- DDR Controller
- -IFC/Local Bus
- USB 3.0
- Two Type A port
- 4 I2C controllers
- UART
- ARM JTAG support
(Bl31 + BL32(optee.
bin) + Bl33(uboot)
boot) 4MB
Deep sleep??
Not required, updated
- u32 srds_s1;
- case 0x3040:
break;
- default:
srds_s1);
break;
+#ifdef CONFIG_FMAN_ENET +int fdt_update_ethernet_dt(void *blob) {
- u32 srds_s1;
- int i, prop;
- const char *path;
const char *name;
"/aliases")
if (offset < 0)
break;
switch (srds_s1) {
case 0x3040:
break;
default:
LS1046AFRWY\n",
__func__, srds_s1);
break;
- int ret;
- if (ret) {
return ret;
- u32 val;
- uint mcr_val;
- u8 val;
- return val;
- u32 boot_src;
- u8 rev;
- switch (rev) {
- case 0x00:
break;
- case 0x01:
break;
- default:
break;
puts("SD\n");
- else
puts("QSPI\n");
- u32 val;
- sec_init();
- int ret;
- if (ret)
return ret;
- u32 usb_pwrfault;
- out_be32(&scfg->rcwpmuxcr0, 0x3300); #ifdef CONFIG_HAS_FSL_IIC3
- out_be32(&scfg->rcwpmuxcr0, 0x0000); #endif
GPIO3_23 as input
to
* USB2 port
+#endif +#endif
+} +#endif
No
No
No
No.
Ok
Ok
| CSPR_PORT_SIZE_8 \
| CSPR_MSEL_NAND \
| CSPR_V)
decode */ \
2K */ \
= 128 */ \
I2C bus 0*/
Is PMIC required?
No, config updated
--pk
This patch has been applied to fsl-qoriq master, awaiting upstream.
--pk
Prabhakar Kushwaha
Vabhav Sharma
