[U-Boot] [PATCH 1/4] mmc: meson: add MMC nodes to Meson GXBB DT
Copied from amlogic/meson-gx.dtsi on Linux with the interrupt definition removed.
Signed-off-by: Heiner Kallweit hkallweit1@gmail.com --- arch/arm/dts/meson-gxbb.dtsi | 18 ++++++++++++++++++ 1 file changed, 18 insertions(+)
diff --git a/arch/arm/dts/meson-gxbb.dtsi b/arch/arm/dts/meson-gxbb.dtsi index e502c24..3f357b4 100644 --- a/arch/arm/dts/meson-gxbb.dtsi +++ b/arch/arm/dts/meson-gxbb.dtsi @@ -329,6 +329,24 @@ #address-cells = <2>; #size-cells = <2>; ranges = <0x0 0x0 0x0 0xd0000000 0x0 0x200000>; + + sd_emmc_a: mmc@70000 { + compatible = "amlogic,meson-gx-mmc", "amlogic,meson-gxbb-mmc"; + reg = <0x0 0x70000 0x0 0x2000>; + status = "disabled"; + }; + + sd_emmc_b: mmc@72000 { + compatible = "amlogic,meson-gx-mmc", "amlogic,meson-gxbb-mmc"; + reg = <0x0 0x72000 0x0 0x2000>; + status = "disabled"; + }; + + sd_emmc_c: mmc@74000 { + compatible = "amlogic,meson-gx-mmc", "amlogic,meson-gxbb-mmc"; + reg = <0x0 0x74000 0x0 0x2000>; + status = "disabled"; + }; };
ethmac: ethernet@c9410000 {
Heiner Kallweit
